SFH 320-3-Z
SFH 320-3-Z
    AMSOSRAM(艾迈斯半导体)
    LCC-2
    光电晶体管 980nm 顶视图 2-LCC(J 形引线)
SFH 320-3-Z 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 SFH 320   SFH 320 TOPLED ® Silicon NPN Phototransistor in SMT Package Applications —Electronic Equipment —White Goods Features: —Package: clear epoxy —ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) —Spectral range of sensitivity: (typ) 450 ... 1150 nm —High linearity —P-LCC-2 package —Available in groups —Suitable for all soldering methods Ordering Information  Type SFH 320-3/4-Z Photocurrent 1) VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² IPCE  Ordering Code 28 ... 71 µA Q65110A1781 SFH 320-3-Z 28 ... 45 µA Q65110A2469 SFH 320-Z 18 ... 71 µA Q65110A2471 SFH 320-4-Z 45 ... 71 µA Q65110A2510  Only one bin within one packing unit (variation less than 2:1) 1 Version 1.7 | 2021-11-22 SFH 320   Maximum Ratings TA = 25 °C Parameter Symbol Operating temperature Top min. max. -40 °C 100 °C Storage temperature Tstg min. max. -40 °C 100 °C Collector-emitter voltage VCE max. 35 V Collector current IC max. 15 mA Collector surge current τ ≤ 10 µs ICS max. 75 mA Total power dissipation Ptot max. 165 mW ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV   2 Version 1.7 | 2021-11-22 Values SFH 320   Characteristics TA = 25 °C Parameter Symbol Wavelength of max sensitivity λS max typ. 980 nm Spectral range of sensitivity λ10% typ. 450 ... 1150 nm Dimensions of chip area LxW typ. 0.45 x 0.45 mm x mm Radiant sensitive area A typ. 0.038 mm² Half angle φ typ. 60 ° Photocurrent VCE = 5 V; Std. Light A; Ev = 1000 lx IPCE typ. 650 µA Dark current VCE = 20 V; E = 0  ICE0 typ. max. 1 nA 50 nA Rise time IC = 1 mA; λ = 950 nm; VCC = 5 V; RL = 1 kΩ tr typ. 7 µs Fall time IC = 1 mA; λ = 950 nm; VCC = 5 V; RL = 1 kΩ tf typ. 7 µs Collector-emitter saturation voltage 2) IC = IPCE,min X 0.3; λ = 950 nm; Ee = 0.1 mW/cm² VCEsat typ. 150 mV Capacitance VCE = 0 V; f = 1 MHz; E = 0  CCE typ. 5 pF Thermal resistance junction ambient real RthJA max.   3 Version 1.7 | 2021-11-22 Values 450 K / W SFH 320   Photocurrent Groups  TA = 25 °C Group Photocurrent 1) VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² min. IPCE Photocurrent 1) VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² max. IPCE 2 18 µA 28 µA 3 28 µA 45 µA 4 45 µA 71 µA Relative Spectral Sensitivity 3), 4) Srel = f (λ)  Srel 100 % OHF00207 80 70 60 50 40 30 20 10  0 400 500 600 700 800 900 4 Version 1.7 | 2021-11-22 nm 1100 λ SFH 320   Directional Characteristics 3), 4) Srel = f (φ) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 1.0 Photocurrent 0.8 0.6 0.4 IPCE = f (Ee) ; VCE = 5 V 40 60 80 100 120 3), 4) IPCE = f (VCE); Ee = Parameter OHF01924 10 3 µA 4 3 2 10 1 OHF01529 10 0 mA mW 1 2 cm Ι PCE  10 2 20 Photocurrent 3), 4) Ι PCE 0 0.5 mW cm 2 0.25 mW cm 2 0.1 mW cm 2 10 -1 10 0 10 -1 -3 10 10 -2 10 0 mW/cm 2  Ee 5 Version 1.7 | 2021-11-22 10 -2 0 5 10 15 20 25 30 V 35 V CE SFH 320   Dark Current 3), 4) ICE0 = f (VCE) ; E = 0  OHF01527 10 1 nA Ι CEO 10 0 10 -1 10 -2 10 -3 0 5 10 15 20 25 30 V 35 V CE Collector-Emitter Capacitance CCE = f (VCE); f = 1 MHz; E = 0  OHF01528 5.0 C CE pF  4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 10 -1 10 0 10 1 V 10 2 V CE  0 10 -2 6 Version 1.7 | 2021-11-22 3), 4) SFH 320   Dark Current Photocurrent 3) ICE0 = f (TA); VCE = 20 V; Ee = 0 mW/cm² IPCE,rel = f (TA); VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² OHF01530 10 3 nA Ι PCE Ι CEO Ι PCE 25 10 2 3) OHF01524 1.6 1.4 1.2 1.0 10 1 0.8 0.6 0.4 10 0 0.2 10 -1 -25 0 25 50 75 ˚C 100 TA Power Consumption Ptot = f (TA); RthJA = 450 K / W  OHF00871 200 mW P tot  160 120 80 40 0 20 40 60  0 7 Version 1.7 | 2021-11-22 80 ˚C 100 TA 0 -25 0 25 50 75 C 100 TA SFH 320   Dimensional Drawing 5) 2.1 (0.083) 3.0 (0.118) 2.6 (0.102) 2.3 (0.091) 1.7 (0.067) 0.1 (0.004) (typ.) 0.5 (0.020) 1.1 (0.043) Collector marking 3.7 (0.146) 3.3 (0.130) 4˚±1 3.4 (0.134) 3.0 (0.118) (2.4) (0.095) 2.1 (0.083) 0.9 (0.035) 0.7 (0.028) 0.18 (0.007) 0.12 (0.005) 0.6 (0.024) 0.4 (0.016) GPLY6030 Further Information: Approximate Weight: 35.0 mg Package marking: Collector   8 Version 1.7 | 2021-11-22 SFH 320   Recommended Solder Pad   9 Version 1.7 | 2021-11-22 5) SFH 320   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 10 Version 1.7 | 2021-11-22 °C 480 s K/s s SFH 320   5) 2.9 (0.114) 4 (0.157)   11 Version 1.7 | 2021-11-22 Cathode/Collector Marking 8 (0.315) 2 (0.079) 1.75 (0.069) 4 (0.157) 3.5 (0.138) 1.5 (0.059) 3.6 (0.142) Taping OHAY2271 SFH 320   Tape and Reel 6) Reel Dimensions A W Nmin W1 W2 max Pieces per PU 180 mm 8 + 0.3 / - 0.1 mm 60 mm 8.4 + 2 mm 14.4 mm 2000 330 mm 8 + 0.3 / - 0.1 mm 60 mm 8.4 + 2 mm 14.4 mm 8000   12 Version 1.7 | 2021-11-22 SFH 320   Barcode-Product-Label (BPL) Dry Packing Process and Materials 5) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 13 Version 1.7 | 2021-11-22 SFH 320   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   14 Version 1.7 | 2021-11-22 SFH 320   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   15 Version 1.7 | 2021-11-22 SFH 320   Glossary 1) Photocurrent: The photocurrent values are measured (by irradiating the devices with a homogenous light source and applying a voltage to the device) with a tolerance of ±11 %. 2) IPCEmin: IPCEmin is the min. photocurrent of the specified group. 3) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 4) Testing temperature: TA = 25°C (unless otherwise specified) 5) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 6) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   16 Version 1.7 | 2021-11-22 SFH 320   Revision History Version Date Change 1.6 2021-07-13 Schematic Transportation Box Dimensions of Transportation Box 1.7 2021-11-22 Characteristics Electro - Optical Characteristics (Diagrams)   17 Version 1.7 | 2021-11-22 SFH 320     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 18 Version 1.7 | 2021-11-22
SFH 320-3-Z 价格&库存
很抱歉,暂时无法提供与“SFH 320-3-Z”相匹配的价格&库存,您可以联系我们找货
SFH 320-3-Z
  • 2000+1.603812000+0.19339
库存:1348
