74HC594; 74HCT594
8-bit shift register with output register
Rev. 5 — 12 August 2021
Product data sheet
1. General description
The 74HC594; 74HCT594 is an 8-bit serial-in/serial or parallel-out shift register with a storage
register. Separate clock and reset inputs are provided on both shift and storage registers. The
device features a serial input (DS) and a serial output (Q7S) to enable cascading. Data is shifted
on the LOW-to-HIGH transitions of the SHCP input, and the data in the shift register is transferred
to the storage register on a LOW-to-HIGH transition of the STCP input. If both clocks are
connected together, the shift register will always be one clock pulse ahead of the storage register.
A LOW level on one of the two register reset pins (SHR and STR) will clear the corresponding
register. Inputs include clamp diodes. This enables the use of current limiting resistors to interface
inputs to voltages in excess of VCC.
2. Features and benefits
Synchronous serial input and output
8-bit parallel output
Shift and storage registers have independent direct clear and clocks
Independent clocks for shift and storage registers
100 MHz (typical)
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Complies with JEDEC standards
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Input levels:
• For 74HC594: CMOS level
• For 74HCT594: TTL level
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Applications
Serial-to parallel data conversion
Remote control holding register
74HC594; 74HCT594
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
74HC594D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74HCT594D
74HC594DB
74HCT594DB
74HC594PW
5. Functional diagram
14
DS
11
SHCP
10
SHR
8-STAGE SHIFT REGISTER
9
12
STCP
13
STR
8-BIT STORAGE REGISTER
15 1
2
3
4
5
6
7
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7
Fig. 1.
mbc320
Functional diagram
SHCP STCP
11
STR
12
9
DS
Fig. 2.
Q7S
74HC_HCT594
Product data sheet
Q7S
SHR
R2
12
10
11
C2
R1 SRG8
15
Q0
1
Q1
2
Q2
3
Q3
2
4
Q4
3
5
Q5
4
6
Q6
7
Q7
14
Logic symbol
STCP
13
10
13
SHR
STR
SHCP
DS
14
C1/
1D
15
2D
1
5
6
7
9
mbc319
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
Q7S
mbc322
Fig. 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 21
74HC594; 74HCT594
Nexperia
STAGE 0
DS
D
STAGES 1 TO 6
Q
D
STAGE 7
Q
FFSH0
CP
D
Q7S
Q
FFSH7
CP
R
R
SHCP
SHR
D
D
Q
FFST0
CP
Q
FFST7
CP
R
R
STCP
STR
Q0
Fig. 4.
Q1 Q2 Q3 Q4 Q5 Q6
Q7
mbc321
Logic diagram
SHCP
DS
STCP
SHR
STR
Q0
Q1
Q6
Q7
Q7S
mbc323
Fig. 5.
Timing diagram
74HC_HCT594
Product data sheet
3 / 21
74HC594; 74HCT594
Nexperia
6. Pinning information
6.1. Pinning
74HC594
74HCT594
Q1
1
16 VCC
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
GND
8
74HC594
74HCT594
10 SHR
9
1
16 VCC
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 SHR
GND
8
9
Q7S
Q7S
001aaf613
001aaf611
Fig. 6.
Q1
Fig. 7.
Pin configuration SOT109-1 (SO16)
Pin configuration SOT338-1 (SSOP16) and
SOT403-1 (TSSOP16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
15, 1, 2, 3, 4, 5, 6, 7
parallel data output
GND
8
ground (0 V)
Q7S
9
serial data output
SHR
10
shift register reset (active LOW)
SHCP
11
shift register clock input
STCP
12
storage register clock input
STR
13
storage register reset (active LOW)
DS
14
serial data input
VCC
16
supply voltage
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH transition; X = don’t care.
Function
Input
SHR
STR
SHCP STCP
DS
Clear shift register
L
X
X
X
X
Clear storage register
X
L
X
X
X
Load DS into shift register stage 0, advance previous stage data to the next stage
H
X
X
H or L
Transfer shift register data to storage register and outputs Qn
X
H
X
X
Shift register one count pulse ahead of storage register
H
H
X
74HC_HCT594
Product data sheet
4 / 21
74HC594; 74HCT594
Nexperia
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7.0
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
VO = -0.5 V to VCC + 0.5 V
Serial data output Q7S
±25
mA
Parallel data output Qn
±35
mA
50
mA
70
mA
-50
mA
-70
mA
-65
+150
°C
500
mW
ICC
supply current
IGND
ground current
Tstg
storage temperature
Ptot
total power dissipation
[1]
[2]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT338-1 (SSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC594
74HCT594
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+125
-40
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC
supply voltage
VI
74HC_HCT594
Product data sheet
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
5 / 21
74HC594; 74HCT594
Nexperia
10. Static characteristics
Table 6. Static characteristics type 74HC594
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
Q7S; IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
V
Q7S; IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
V
Qn; IO = -6.0 mA; VCC = 4.5 V
3.98
4.32
V
Qn; IO = -7.8 mA; VCC = 6.0 V
5.48
5.81
V
Q7S; IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
V
Q7S; IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
V
Qn; IO = 6.0 mA; VCC = 4.5 V
0.15
0.26
V
Qn; IO = 7.8 mA; VCC = 6.0 V
0.16
0.26
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
±0.1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 6.0 V
8.0
μA
Ci
input capacitance
3.5
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
3.84
V
5.34
V
3.84
V
5.34
V
0.33
V
0.33
V
0.33
V
0.33
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
80
μA
74HC_HCT594
Product data sheet
6 / 21
74HC594; 74HCT594
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
3.7
V
5.2
V
3.7
V
5.2
V
0.4
V
0.4
V
0.4
V
0.4
V
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
160
μA
Conditions
Min
Typ
Max
Unit
Table 7. Static characteristics type 74HCT594
Symbol Parameter
Tamb = 25 °C
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
VI = VIH or VIL
3.98
4.32
V
3.98
4.32
V
0.15
0.26
V
VOL
VI = VIH or VIL
0.16
0.26
V
II
VI = VCC or GND; VCC = 5.5 V
±0.1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A; VCC = 5.5 V
8.0
μA
ΔICC
additional supply current
per input pin; VI = VCC - 2.1 V and
other inputs at VCC or GND; IO = 0 A;
pins SHR, SHCP, STCP, STR
150
540
μA
pin DS
25
90
μA
3.5
pF
Ci
input capacitance
74HC_HCT594
Product data sheet
7 / 21
74HC594; 74HCT594
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VIH
2.0
V
VIL
0.8
V
VOH
VI = VIH or VIL
3.84
V
3.84
V
0.33
V
0.33
V
VOL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
80
μA
ΔICC
675
μA
pin DS
112.5
μA
VIH
2.0
V
VIL
0.8
V
VOH
VI = VIH or VIL
3.7
V
3.7
V
0.4
V
0.4
V
VOL
VI = VIH or VIL
II
±1.0
μA
ICC
supply current
160
μA
ΔICC
735
μA
pin DS
122.5
μA
74HC_HCT594
Product data sheet
8 / 21
74HC594; 74HCT594
Nexperia
11. Dynamic characteristics
Table 8. Dynamic characteristics type 74HC594
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; For test circuit see Fig. 14.
Symbol Parameter
tpd
Conditions
25 °C
propagation SHCP to Q7S; see Fig. 8
delay
VCC = 2.0 V
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
[1]
44
150
185
225
ns
VCC = 4.5 V
16
30
37
45
ns
VCC = 5.0 V; CL = 15 pF
13
ns
VCC = 6.0 V
14
26
31
38
ns
VCC = 2.0 V
44
150
185
225
ns
VCC = 4.5 V
16
30
37
45
ns
13
ns
VCC = 6.0 V
14
26
31
38
ns
39
150
185
225
ns
14
30
37
45
ns
11
ns
12
26
31
38
ns
VCC = 2.0 V
39
125
155
185
ns
VCC = 4.5 V
14
25
31
37
ns
11
ns
VCC = 6.0 V
12
21
26
31
ns
19
75
95
110
ns
7
15
19
22
ns
6
13
16
19
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
19
75
95
110
ns
7
15
19
22
ns
6
13
16
19
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
STCP to Qn; see Fig. 9
tPHL
SHR to Q7S; see Fig. 12
HIGH
to LOW
VCC = 2.0 V
propagation
VCC = 4.5 V
delay
VCC = 6.0 V
STR to Qn; see Fig. 13
tTHL
Q7S; see Fig. 8
HIGH to
LOW output
VCC = 2.0 V
transition
VCC = 4.5 V
time
VCC = 6.0 V
Qn
tTLH
Q7S; see Fig. 8
LOW to
HIGH output
VCC = 2.0 V
transition
VCC = 4.5 V
time
VCC = 6.0 V
Qn
74HC_HCT594
Product data sheet
9 / 21
74HC594; 74HCT594
Nexperia
Symbol Parameter
tW
pulse width
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
80
10
100
120
ns
VCC = 4.5 V
16
4
ns
VCC = 6.0 V
14
3
17
ns
VCC = 2.0 V
80
10
100
120
ns
VCC = 4.5 V
16
4
ns
VCC = 6.0 V
14
3
17
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
5
ns
VCC = 6.0 V
14
4
17
ns
VCC = 2.0 V
100
10
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
3
21
26
ns
VCC = 2.0 V
100
14
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
4
21
26
ns
VCC = 2.0 V
100
17
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
5
21
26
ns
VCC = 2.0 V
25
-8
30
35
ns
VCC = 4.5 V
5
-3
6
7
ns
VCC = 6.0 V
4
-2
5
6
ns
VCC = 2.0 V
50
-14
65
75
ns
VCC = 4.5 V
10
-5
13
15
ns
VCC = 6.0 V
9
-4
11
13
ns
SHCP (HIGH or LOW);
see Fig. 8
STCP (HIGH or LOW);
see Fig. 9
SHR and STR
(HIGH or LOW); see Fig. 12
and Fig. 13
tsu
set-up time
DS to SHCP; see Fig. 10
SHR to STCP; see Fig. 11
SHCP to STCP; see Fig. 9
th
trec
hold time
recovery
time
74HC_HCT594
Product data sheet
SHR to SHCP and
STR to STCP; see Fig. 12
and Fig. 13
10 / 21
74HC594; 74HCT594
Nexperia
Symbol Parameter
fmax
Conditions
25 °C
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
6.0
30
4.8
4.0
MHz
VCC = 4.5 V
30
92
24
MHz
100
MHz
VCC = 6.0 V
35
109
28
24
MHz
power
VI = GND to VCC; VCC = 5 V; [2]
dissipation
fi = 1 MHz
capacitance
84
pF
SHCP or STCP;
see Fig. 8 and Fig. 9
[1]
[2]
Min
maximum
frequency
CPD
-40 °C to +85 °C
tpd is the same as tPHL and tPLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
Table 9. Dynamic characteristics type 74HCT594
GND = 0 V; VCC = 4.5 V; tr = tf = 6 ns; CL = 50 pF; For test circuit see Fig. 14.
Symbol Parameter
Conditions
tpd
propagation
delay
25 °C
Typ
Max
Min
Max
Min
Max
18
32
40
48
ns
15
ns
18
32
40
48
ns
15
ns
17
30
38
45
ns
14
ns
17
30
38
45
ns
14
ns
7
15
19
22
ns
5
12
15
18
ns
7
15
19
22
ns
5
12
15
18
ns
SHCP (HIGH or LOW);
see Fig. 8
16
4
ns
STCP (HIGH or LOW);
see Fig. 9
16
4
ns
SHR and STR
(HIGH or LOW);
see Fig. 12 and Fig. 13
16
6
ns
HIGH
to LOW
propagation
delay
tTHL
tTLH
tW
Q7S; see Fig. 8
HIGH to
LOW output
VCC = 4.5 V
transition
Qn
time
VCC = 4.5 V
Q7S; see Fig. 8
LOW to
HIGH output
VCC = 4.5 V
transition
Qn
time
VCC = 4.5 V
pulse width
74HC_HCT594
Product data sheet
Min
[1]
tPHL
-40 °C to +85 °C
11 / 21
74HC594; 74HCT594
Nexperia
Symbol Parameter
tsu
set-up time
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
25
30
ns
25
30
ns
25
30
ns
th
hold time
5
-3
6
7
ns
trec
recovery
time
SHR to SHCP and
STR to STCP;
10
-5
13
15
ns
fmax
maximum
frequency
SHCP or STCP;
30
92
24
MHz
100
MHz
89
pF
CPD
[1]
[2]
power
VI = GND to VCC - 1.5 V;
dissipation
VCC = 5 V; fi = 1 MHz
capacitance
[2]
2
2
2
11.1. Waveforms and test circuit
1/fmax
SHCP input
VM
tW
tPLH
Q7S output
tPHL
VM
tTLH
tTHL
001aae341
Measurement points are given in Table 10.
Fig. 8.
The shift clock (SHCP) to output (Q7S) propagation delays, the shift clock pulse width, the maximum shift
clock frequency, and output transition times
74HC_HCT594
Product data sheet
12 / 21
74HC594; 74HCT594
Nexperia
SHCP input
VM
tsu
1/fmax
VM
STCP input
tW
tPHL
tPLH
Qn outputs
VM
mla512
Fig. 9.
The storage clock (STCP) to output (Qn), propagation delays, the storage clock pulse width, the maximum
storage clock pulse frequency and the shift clock to storage clock set-up time
VM
SHCP input
t su
t su
th
th
VM
DS input
VM
Q7 output
001aae342
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 10. The data set-up time and hold times for DS input to SHCP
VM
SHR input
tsu
VM
STCP input
VM
Qn outputs
mbc326
Fig. 11. The set-up time shift reset (SHR) to storage clock (STCP)
74HC_HCT594
Product data sheet
13 / 21
74HC594; 74HCT594
Nexperia
VM
SHR input
tW
trec
VM
SHCP input
tPHL
VM
Q7S output
mbc324
Fig. 12. The shift reset (SHR) pulse width, the shift reset to output (Q7S) propagation delay and the shift reset to
shift clock (SHCP) recovery time
VM
STR input
tW
trec
VM
STCP input
tPHL
VM
Qn outputs
mbc325
Fig. 13. The storage reset (STR) pulse width, the storage reset to output (Qn) propagation delay and the storage
reset to storage clock (STCP) recovery time
Table 10. Measurement points
Type
Input
Output
VM
VM
74HC594
0.5 × VCC
0.5 × VCC
74HCT594
1.3 V
1.3 V
74HC_HCT594
Product data sheet
14 / 21
74HC594; 74HCT594
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 11.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance
S1 = Test selection switch
Fig. 14. Test circuit for measuring switching times
Table 11. Test data
Type
Input
Load
VI
tr, tf
CL
74HC594
VCC
6 ns
74HCT594
3V
6 ns
74HC_HCT594
Product data sheet
S1 position
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
15 pF, 50 pF 1 kΩ
open
GND
VCC
15 pF, 50 pF 1 kΩ
open
GND
VCC
15 / 21
74HC594; 74HCT594
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 15. Package outline SOT109-1 (SO16)
74HC_HCT594
Product data sheet
16 / 21
74HC594; 74HCT594
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
0o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 16. Package outline SOT338-1 (SSOP16)
74HC_HCT594
Product data sheet
17 / 21
74HC594; 74HCT594
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 17. Package outline SOT403-1 (TSSOP16)
74HC_HCT594
Product data sheet
18 / 21
74HC594; 74HCT594
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT594 v.5
20210812
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC594PW (SOT403-1/TSSOP16) added.
Section 8: Derating values for Ptot total power dissipation updated.
74HC_HCT594 v.4
20160225
Modifications:
74HC_HCT594 v.3
20061220
Modifications:
74HC_HCT594_CNV v.2
74HC_HCT594
Product data sheet
74HC_HCT594 v.4
Product data sheet
74HC_HCT594 v.3
Type numbers 74HC594N and 74HCT594N (SOT38-4) removed.
Product data sheet
74HC_HCT594_CNV v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Table 1: Ordering information updated.
19970908
Product specification
74HC_HCT594_CNV v.1
19 / 21
74HC594; 74HCT594
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT594
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
20 / 21
74HC594; 74HCT594
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................4
6.1. Pinning.........................................................................4
6.2. Pin description............................................................. 4
7. Functional description................................................. 4
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................5
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................9
11.1. Waveforms and test circuit.......................................12
12. Package outline........................................................ 16
13. Abbreviations............................................................ 19
14. Revision history........................................................19
15. Legal information......................................................20
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 August 2021
74HC_HCT594
Product data sheet
21 / 21
