DZ1R08MV1
DZ1R08MV1
    CROUZET(高诺斯)
    CROUZET - DZ1R08MV1 - DIGITAL TIMER, 0.001S - DAYS, 8A, SPDT
DZ1R08MV1 数据手册
| | 11/2019 ››Universal Digital Timer DIN Rail Mount 17.5 mm ››Digital timer (LED Screen) ››Multifunction (23 base functions + options = 138 functions) ››Precise time configuration ››Optional features: password setting and time limit setting ››2 use modes (basic and advanced) ››Programmable without power supply ››Wide time range (from 0.1 seconds up to 100 days) ››Universal power supply (12-240 Va/c) ››Universal connection DZ1R08MV1 Multifunction Product selection Type Function Output Supply Voltage DZ1R Multifunction Z: (A, Ab, Ac, Ad, Ah, At, B, Bw, C, D, Di, H, Ht, L, Li, O, N, P, Pt, T, TL, Tt, W) + options 1 relay 12 → 240 Vz Part Number DZ1R08MV1 PART NUMBERING SYSTEM Function Z: Multifunction Z D Type Z D: 17.5 mm Digital 1 Output Type R: Relay R Output Quantity 1: 1 Output 08 Power Supply MV1: 12-240 Va/c MV1 Output Power 08: 8 A You have a project? Contact us on www.crouzet.com Description: Syr-line, the specialized range at Crouzet, aimed to satisfy the most unique requirements of your applications by innovating in design, engineering and development. The Universal Digital Timer, the new Syr-line timer that fits all your needs. The Universal Digital Timer offers the same ease of use as analog timers but it is powered with visualization, higher-precision and all the functions you need (up to 138). For more information about Crouzet’s Syr-line range, please visit www.crouzet.com. | | CONTROL.CROUZET.COM || 2 | | Universal Digital Timer | | 11/2019 DZ1R08MV1 Input Specifications Rated supply voltage Un 12 → 240 Vz Voltage supply tolerance -15 %, +10 % AC supply voltage frequency 50 / 60 Hz ± 5% Galvanic isolation of supply / inputs No Power consumption @ Un Approx. 2.5 VA (Va) 1 W (Vc) Immunity to power micro cuts 10 ms Timing Specifications Specified time ranges 0.001 → 9.999 s, 1 s → 99 m 59 s, 1 m → 99 h 59 m, 1 h →99 d 23 h Minimum control pulse duration IEC 61812-1 45 ms for PNP mode 150 ms for NPN mode Recovery time (after by de-energisation) IEC 61812-1 120 ms Repeatability IEC 61812-1 ≤ 0.5 % ±150 ms Note: For COMMAND function of SUM and PAUSE, Repeatability is < 0.5 % ± 250ms Setting accuracy IEC 61812-1 ≤ 0.5 % ±150 ms Note: For COMMAND function of SUM and PAUSE, Setting Accuracy is < 0.5 % ± 250ms Temperature drift ≤ 0.5 % ±50 ms Voltage drift ≤ 0.5 % ±50 ms Output Specifications Contact arrangement 1 CO (SPDT) (ChangeOver - Single Pole Double Throw-) Maximum switching voltage 250 Va / 30 Vc Switching current rate (resistive) NO / NC: 8 A 250 Va / 8 A 30 Vc @ 40 °C NO / NC: 5 A 250 Va / 5 A 30 Vc @ 50 °C Minimum switching contact 10 mA / 5 Vc Maximum switching power (resistive) 2 000 VA / 240 W Electrical life 105 cycles min at 250 Va / 8 A resistive (NO only) Maximum rate (at max switching power) 360 cycles / hour Mechanical life 10 x 106 cycles Rated impulse voltage IEC 60664-1 4 kV (1.2 / 50µs) Dielectric strength between coil / contacts IEC 60664-1 2.5 kV /1 min / 1 mA / 50 Hz Dielectric strength between open contacts 1 kV /1 min / 1 mA / 50 Hz Insulation Specifications Rated Insulation voltage IEC 60664-1 250 V Insulation coordination IEC 60664-1 Overvoltage category III; pollution degree 2 Rated impulse voltage IEC 60664-1 4 kV (1.2 / 50µs) Clearance / Creepage distances (IEC 60664-1 3 mm / 3.2 mm Dielectric strength EN-61812-1 2.5 kV /1 min / 1 mA / 50 Hz Insulation resistance NFC 93 050 > 500 MOhms / 250 Vc / 1min General specifications Display 1 general control knob 128*32 panel matrix OLED display Casing DIN 43 880 17.5 mm Din rail mounting EN 50022 35 mm symmetrical DIN rail Mounting position All positions Housing material UL94 Enclosure plastic type V0 Degree of protection IEC 60529 Housing: IP40 / Terminal block: IP20 Terminal capacity single-wire IEC 60947-1 without ferrule (copper conductors only) 1 x 0.5 → 3.3 mm² (AWG 20 → AWG 12) Stripping length 6 mm Maximum tightening torques IEC 60947-1 0.5 N.m / 4.4 lbf.in 2 x 0.5 → 1.5 mm² (AWG 20→ AWG 16) | | CONTROL.CROUZET.COM || 3 | | Universal Digital Timer | | 11/2019 DZ1R08MV1 Operating temperature IEC 60068-2 -20 → +50 °C Storage temperature IEC 60068-2 -40 °C → 30 °C Max (for optimal storage time) Humidity IEC 60068-2-30 93 % without condensation Vibration resistance IEC 60068-2-6 ± 0.15mm from 10 Hz → 60 Hz 2 g from 60 Hz → 150 Hz Shock resistance IEC 60068-2-27 15 gn - 11 ms; 3 x 6 axis (Output non-energized) 5 gn - 11 ms; 3 x 6 axis (Output energized) Drop to concrete floor IEC 60068-2-32 High: 0.75 m Weight 81 g 100 g with packaging Standards Specifications CEE Directive: 2014/30/EU EMC 2014/35/EU Low voltage Approvals / Marking CE cULus Listed Industrial Control Equipment Security standard IEC 60664-1 Conformity with environmental directives 2015/863/UE 1907/2006  2012/19/UE Insulation coordination for equipment within low-voltage systems RoHS Reach WEEE 2006/66/CE Battery Directive Product standard IEC 61812-1  Specified time relays for industrial use UL 60947-4-1 Industrial Control Equipment (NRNT- Industrial Control Switches) Electromagnetic compatibility IEC 61000-6-2  Immunity for industrial environment IEC 61000-6-3 Emission residential environment IEC 61000-6-4 Emission industrial environment Immunity to electrostatic discharges IEC 61000-4-2 Level III Air ±8 KV / Contact ±6 KV Immunity to radiated, radio-frequency, electromagnetic field IEC 61000-4-3 Level III 10 V/m (80 MHz → 1 GHz) 80 % AM (1 kHz) 3 V/m (1.4 → 2 GHz) 80 % AM (1 KHz) 1 V/m (2 → 2.7 GHz) 80 % AM (1 KHz) Immunity to rapid transient bursts IEC 61000-4-4 Level III direct ±2 kV (power supply) capacitive coupling clamp ±1 KV (command input and outputs) Immunity to shock waves on power supply IEC 61000-4-5 Level III line-to-earth ±2 kV line-to-line ±1 kV Immunity to radiofrequency in common mode IEC 61000-4-6 Level III 10 Vrms (0.15 → 80 MHz) 80 % AM (1 kHz) Immunity to voltage dips and breaks IEC 61000-4-11 0 % residual voltage / 1 cycle (Crit. B), 40 % residual voltage / 10 cycles 50 Hz / 12 cycles 60 Hz (Crit C) 70 % residual voltage / 25 cycles 50 Hz / 30 cycles 60 Hz (Crit C) Short interruptions: 0 % residual voltage / 250 cycles 50 Hz / 300 cycles 60 Hz (Crit C) | | CONTROL.CROUZET.COM || 4 | | Universal Digital Timer | | 11/2019 DZ1R08MV1 AC/DC main port emissions IEC 61000-6-3  CISPR 16-2-1 (7.4.1), CISPR 16-1-2 (4.3) IEC 61000-6-4 0.15 MHz – 0.5 MHz, 66 dB(μV) – 56 dB(μV) quasi-peak, 56 dB(μV) – 46 dB(μV) average 0.5 MHz – 5 MHz, 56 dB(μV) quasi-peak, 46 dB(μV) average 5 MHz – 30 MHz, 60 dB(μV) quasi-peak, 50 dB(μV) average CISPR 14-1 0.15 MHz – 30 MHz CISPR 16-2-1 (7.4.1), CISPR 16-1-2 (4.3) 0.15 MHz – 0.5 MHz, 79 dB(μV) quasi-peak, 66 dB(μV) average 0.5 MHz – 30 MHz, 73 dB(μV) quasi-peak, 60 dB(μV) average Radiated emissions IEC 61000-6-3  CISPR 16-2-3 IEC61000-6-4 30 MHz – 230 MHz, 30 dB(μV/m) Quasi-peak at 10 m 230 MHz – 1 000 MHz, 37 dB(μV/m) Quasi-peak at 10 m Or: 30 MHz – 230 MHz, 40 dB(μV/m) Quasi-peak at 3 m in a semi-anechoic chamber 230 MHz – 1 000 MHz, 47 dB(μV/m) Quasi-peak at 3 m in a semi-anechoic Connections Universal connection DZ1R08MV1 2 connections options with the same product: type 1 or type 2 U U U + Y1 Y1 A1 A2 Y1 15 R 16 18 U: Supply A1 Y1 A2 A1 Y1 A2 15 15 R R 15 16 18 15 16 18 A2 A2 Type 1  Type 2 Y1: Input signal R: Output relay Basic Time Chart Function A - On-Delay (Delay on make) Function Ab - Delayed Interval | | CONTROL.CROUZET.COM || 5 | | Universal Digital Timer Function Ac - On/Off Delay (Delay on make/break) Function Ad - Delay on Start Function Ah - Triggered Flashing Cycle (Single shot flip-flop) Function At - Summation time relay Function B - Single Shot (One Shot) Function Bw - Pulse output Function C - Off-Delay (Delay on break) Function D - Flasher (Symmetrical) – OFF Start Function Di - Flasher (Symmetrical) – ON Start Function H - Interval | | 11/2019 | | CONTROL.CROUZET.COM || 6 | | Universal Digital Timer | | 11/2019 Function Ht - Interval with Memory Function L - Repeat Cycle (Asymmetrical) – OFF Start Function Li - Repeat Cycle (Asymmetrical) – ON Start Function O - Delayed watchdog Function N - Watchdog Function P - Pulse delayed relay Function Pt - Impulse counter (delay on) Function T - On-Delay (Delay on make): sum of times Function TL - Latching (Alternating) – Leading Edge Function Tt - Delayed Latching (Alternating) – Leading Edge | | CONTROL.CROUZET.COM || 7 | | Universal Digital Timer | | 11/2019 Function W - Timing after pulse of control contact Outline dimensions (mm) 70.21±0.5 64.63±0.3 48.22±0.3 27.82±0.3 1 67.39±0.3 45.11±0.3 90±0.4 18 -10 2.79 2 4.23 1 LED Screen 2 Select button Keys Function Enter to Timing Change Mode TIME2 TIME2 03 35 03 35 05:00 A 05:00 A IN OUT IN OUT O MIN MIN SEC SEG SEC SEG 1 2 TIME 03 35 MIN SEC SEG X ✓ 3 1 Run mode 2 Press button less than 3 s 3 Timing change mode 4 Rotate button: change selection / press button: confirm selection TIME 03 35 MIN SEC SEG X ✓ 4 | | CONTROL.CROUZET.COM || 8 | | Universal Digital Timer | | 11/2019 Keys Function Enter to Programming Mode TIME2 TIME2 03 35 PROG 03 35 MIN MIN SEG SEC SEG SEC 05:00 A 05:00 A IN OUT IN OUT OU PROG BASIC BASIC ADVAN ADVAN TEST TEST EXIT EXIT XIT 3s 1 2 3 4 1 Run mode 2 Press button more than 3 s 3 Programming mode 4 Rotate button: change selection / press button: confirm selection Programming Mode Basic Mode - Timer setting in few seconds Programming mode choice FUNCTION ● 23 basic functions RANGE ● Milliseconds ➟ Days ● UP/DOWN MEMORY ● YES/NO Advanced Mode - Optional additional parameters ● PNP ● NPN ● ● ● TIME CHANGE INPUT FUNCTION INPUT TYPE OFF Sum LOWER LIMIT ● ● Trigger Stop ● Reset ● ● Min value ● Low High ● Instantaneous At end UPPER LIMIT ● Max value LOCK SCREEN SAVER BRIGHTNESS ● Test mode choice COUNT Medium ● ● OFF _5S ➟ 60S ● ● OFF ALL ● Programming DEFAULT RESET ● Reset all Test Mode DISPLAY OUTPUT ● ON/OFF ● TEST MEMORY ● TEST Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
DZ1R08MV1 价格&库存
很抱歉,暂时无法提供与“DZ1R08MV1”相匹配的价格&库存,您可以联系我们找货
DZ1R08MV1
  • 1+1091.407971+141.00140
  • 8+1011.900858+130.72970
  • 16+939.6534616+121.39590
库存:2
DZ1R08MV1
库存:54
