BM2R
Timers
Syrline
17.5 mm - 2 Relay 8A
›› Multi-function or mono-function
›› Multi-range (12 function)
›› Multi-voltage 12 →240 V AC/DC
›› LED status indicator (relay version)
›› Possibility of external load connection in parallel to the
control input
›› 3-wire PNP sensor compatible
Specifications
Functions
Delay
Output
Nominal rating
Connections
Supply voltage
Code
A - Ac - At - B - C - D - Di H - Ht -N - TL - Tt
0,5 s →10 days
2 changeover
relays
2x8A
Screw terminals
12 →240 V ∿/⎓
BM2R08MV1
Output relay
Contact arrangement
2 CO (SPDT) (ChangeOver -Simple Pole Double Throw-)
R1: Follow timing function
R2: Follow timing function / Instantaneous
Maximum switching voltage
250 VAC/ 8 A resistive / 250 VDC / 0.3 A resistive
Switching current rate (resistive)
NO / NC : 8A 250 V AC / 8 A 30 VDC @ 25°C
NO / NC : 5A 250 V AC / 5 A 30 VDC @ 60°C
Minimum switching contact
10 mA / 5 VDC
Maximum switching power (resistive)
2000 VA / 80 W @ 25°C
Electrical life
105 cycles min at 250 VAC/ 8 A resistive
Maximum rate (at max switching power)
360 cycles /hour
Mechanical life
10 x 106 cycles
Rated impulse voltage
5 kV (1.2/50µs)
Dielectric strength between coil / contacts
IEC 60664-1: 5 kV /1 min / 1 mA / 50 Hz
Dielectric strength between open contacts
2.5 kV /1 min / 1 mA / 50 Hz
Timing
Timing ranges (7 ranges)
0.5→10s, 0.05→1min, 0.5→10min, 0.05→1h, 0.5→10h, 0.05→1day,
0.5→10days
Minimum pulse duration typically (relay version)
IEC 1812-1: 30 ms
100 ms with load
Maximum reset time by de-energisation typically (relay version)
IEC 1812-1: 120 ms
Repeatability
IEC 1812-1: ≤ ± 0,5 %
Repetition accuracy with constant parameters
IEC 1812-1: ≤ ± 10 %
Drift Temperature
≤ ± 0.05 % / °C
Voltage-dependent drift
≤ ± 0.2 % / V
I Timers
I 02 I www.crouzet-control.com
Supply
Multi-voltage power supply
12→240 V∿/⎓
Operating range
15 %, +10 %
Operating frequency (Hz)
50 / 60 Hz ± 5 %
Galvanic isolation
No
Max. absorbed power
Approx. 3 VA (V∿) 1.5 W (V⎓)
Immunity from micro power cuts
10 ms
General characteristics
Insulation voltage, IEC 60664-1
300 V
Installation category (acc. to IEC/EN 60664-1)
Overvoltage category III ; pollution degree 2
Impulse voltage CEI/EN 60664-1
4 kV (1,2 / 50 μs)
Clearance / Creepage distances
IEC 60664-1: 3 mm / 3.2 mm
Breakdown voltage
EN-61812-1: 2,5 kV / 1 min / 1 mA / 50 Hz
Insulation resistance
NFC 93 050: > 500 MΩ / 250 V⎓ / 1min
Status indication
Un: green LED blinks when count, continuous ON when supplied
R: yellow LED continuous ON when the relay is ON
Casing
DIN 43880: 17,5 mm
Fixing: Symmetrical DIN rail
EN 50022: 35 mm
Mounting position
All positions
Housing material
Enclosure plastic type UL94 - V0
Protection (IEC/EN 60529)
Housing: IP40 / Terminal block: IP20
Terminal capacity Single-wire without ferrule
IEC 60947-1
1 x 0.5 →3.3 mm² (AWG 20 →AWG 12)
2 x 0.5 →1.5 mm² (AWG 20 →AWG 16)
Max. tightening torque (Nm)
IEC 60947-1: 0,5 N.m / 4,4 lbf.in
Operating temperature range (°C)
IEC 60068-2: -20 °C →+60 °C
Storage temperature range (°C)
IEC 60068-2: -40 °C →+70 °C
Relative humidity no condensation acc. to IEC/EN 60068-2-30
93 % without condensation
Vibration resistance according to IEC/EN 60068-2-6
± 0.15 mm from 10 Hz →60 Hz 2g from 60 Hz →150 Hz
Impact resistance
IEC 60068-2-27
15gn - 11ms ; 3 x 6 axis (output OFF)
5gn - 11ms ; 3 x 6 axis (Output ON)
Drop to concrete floor
IEC 60068-2-32
High: 0.75m
Weight: casing 17,5 mm
70 g
80 g with packaging
Directives
2014/30/EU: EMC
2014/35/EU: low voltage
Certifications
CE - cULus Listed Industrial Control Equipment - CCC
Conformity to standards
CEI 60664-1: Insulation coordination for equipment within low-voltage
systems
CEI 61812-1/ Specified time relays for industrial use
UL 60947-4-1/ Industrial Control Equipment (NRNT- Industrial Control
Switches)
Conformity with environmental directives
2015/863/UE: RoHS
1907/2006: Reach
2012/19/UE: WEEE
Electromagnetic compatibility IEC 61000-6-2, IEC 61000-6-3,
IEC 61000-6-4
Immunity for industrial environment
Emission residential environment
Emission industrial environment
Electromagnetic compatibility - Immunity to electrostatic discharges
acc to IEC/EN 61000-4-2
Level III Air ± 8 KV / Contact ± 6 KV
I Timers
I 03 I www.crouzet-control.com
Immunity to radiated, radio-frequency, electromagnetic field acc.
IEC/EN 61000-4-3
Level III
10 V/m (80 M Hz to 1 G Hz) 80 % AM (1 k Hz)
3 V/m (1,4 →2 G Hz) 80 % AM (1K Hz)
1V/m (2 →2.7 G Hz) 80 % AM (1K Hz)
Immunity to rapid transient bursts acc. to IEC/EN 61000-4-4
Level III direct ± 2 kV (power supply) / capacitive coupling clamp
± 1 KV (command input and outputs)
Immunity to shock waves on power supply acc. to IEC/EN 61000-4-5
Level III
line-to-earth ± 2 kV / line-to-line ± 1kV
Immunity to radio frequency in common mode acc. to
IEC/EN 61000-4-6
Level III
Immunity to voltage dips and breaks acc. to IEC/EN 61000-4-11
Industrial Class II:
10 Vrms (0,15 →80 M Hz) 80 % AM (1 k Hz)
0 % residual voltage during 1cycle a.c. power ports
70 % residual voltage during 25/30 cycles a.c. power ports
0 % residual voltage, 250/300 cycles a.c. power ports
Residential:
0 % residual voltage during 10 cycle a.c.power ports
40 % residual voltage during 10 cycles a.c. power ports
70 % residual voltage during 10 cycles a.c. power ports
Mains-borne and radiated emissions acc. to EN 55022 (CISPR22),
EN55011 (CISPR11)
EN 55022 / CISPR22 Class B (IT equipment)
EN 55011 / CISPR11 Class B, Group 1 (Medical equipment)
Dimensions
Curves
Function A Delay on energisation
Function Ac Timing after closing and opening of control contact
U
R1/R2
R2
T
U
Y1
R1/R2
T
T
R2 inst.
Function At Timing on energisation with memory
Function B Timing on impulse one shot
U
Y1
R1/R2
t1
t2
T = t1+t2
U
Y1
R1/R2
R2
Function C Timing after impulse
T
U
Y1
R1/R2
2R
T
I Timers
I 04 I www.crouzet-control.com
Curves
Function Di Flip-flop Pulse start
U
R1/R2
R2
U
Y1
R1/R2
R2
Function H Timing on energisation
Function Ht Delay on energisation with memory
T T
T T
U
R1/R2
R2
T
U
Y1
R1/R2
R2
Function N Watchdog
Function TL Impulse relay
t1
t2
T = t1+t2
U
Y1
R1/R2
R2
T
T
U
Y1
R1/R2
8
8
8
Function D Flip-flop Pause start
Connections
2 changeover relay output
U
A1
A2
Y1
15
R1
16 18
25
R2
26 28
很抱歉,暂时无法提供与“BM2R08MV1.”相匹配的价格&库存,您可以联系我们找货
