BPW 34
BPW 34
    AMSOSRAM(艾迈斯半导体)
    插件
    Photodiode PIN Chip 850nm 0.62A/W Sensitivity Automotive 2-Pin DIL
BPW 34 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 BPW 34   BPW 34 DIL Silicon PIN Photodiode Applications ——Electronic Equipment ——Industrial Automation (Machine Controls, Light Barriers, Vision Controls) Features: ——Package: Epoxy, diffuse ——Corrosion Robustness Class: 3B ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) ——Especially suitable for applications from 400 nm to 1100 nm ——Short switching time (typ. 20 ns) ——DIL plastic package with high packing density Ordering Information  Type Photocurrent 1)  Ev = 1000 lx; Std. Light A; VR = 5 V IP ≥ 55 µA  BPW 34 1 Version 1.5 | 2020-01-08 Photocurrent  typ. Ev = 1000 lx; Std. Light A; VR = 5 V IP 80 µA Ordering Code Q62702P0073 BPW 34   Maximum Ratings TA = 25 °C Parameter Symbol Operating Temperature Top min. max. -40 °C 100 °C Storage temperature Tstg min. max. -40 °C 100 °C Reverse voltage VR max. 32 V Total power dissipation Ptot max. 150 mW ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV   2 Version 1.5 | 2020-01-08 Values BPW 34   Characteristics TA = 25 °C Parameter Symbol Spectral sensitivity VR = 5 V; Std. Light A; T = 2856 K S typ. 80 nA/lx Wavelength of max sensitivity λS max typ. 920 nm Spectral range of sensitivity λ10% typ. 420 ... 1120 nm Radiant sensitive area A typ. 7.02 mm² Dimensions of active chip area LxW typ. 2.65 x 2.65 mm x mm Half angle φ typ. 60 ° Dark current VR = 10 V IR typ. max. Spectral sensitivity of the chip λ = 850 nm Sλ typ. 0.62 A / W Quantum yield of the chip λ = 850 nm η typ. 0.90 Electrons / Photon Open-circuit voltage Ev = 1000 lx; Std. Light A; VR = 0 V VO min. typ. 300 mV 365 mV Short-circuit current Ev = 1000 lx; Std. Light A; VR = 0 V ISC typ. 80 µA Rise time VR = 5 V; RL = 50 Ω; λ = 850 nm; IP = 800 µA tr typ. 0.02 µs Fall time VR = 5 V; RL = 50 Ω; λ = 850 nm; IP = 800 µA tf typ. 0.02 µs Forward voltage IF = 100 mA; E = 0  VF typ. 1.3 V Capacitance VR = 0 V; f = 1 MHz; E = 0  C0 typ. 72 pF Temperature coefficient of voltage TCV typ. -2.6 mV / K Temperature coefficient of short-circuit current Std. Light A  TCI typ. 0.18 % / K Noise equivalent power VR = 10 V; λ = 850 nm NEP typ. 0.041 pW / Hz1/2 Detection limit VR = 10 V; λ = 850 nm D* typ. 6.5e12 cm x Hz1/2 / W   3 Version 1.5 | 2020-01-08 Values 2 nA 30 nA BPW 34   Relative Spectral Sensitivity 2), 3) Srel = f (λ) [ ] 100 80 60 40 20 0 400 Directional Characteristics 600 800 1000 λ[ ] 2), 3) Srel = f (φ) 40 30 20 10  50 ϕ 0 1.0 0.8 60 0.6 70 0.4 80 0.2 0 90 1.0 0.8  100 OHF01402 4 Version 1.5 | 2020-01-08 0.6 0.4 0 20 40 60 80 100 120 BPW 34   Photocurrent/Open-Circuit Voltage IP (VR = 5 V) / VO = f (Ee) ΙP 2), 3) Dark Current 2), 3) IR = f (VR); E = 0  OHF01066 10 3 µA 10 2 10 4 mV OHF00080 4000 VO ΙR pA 10 3 3000 10 2 2000 10 1 1000 10 0 0 VO 10 1 ΙP 10 0 10 -1 10 0 10 1 10 2 10 3 lx 10 4 EV Capacitance 2), 3) C = f (VR); f = 1MHz; E = 0; TA = 25°C OHF00081 100 C pF  80 70 60 50 40 30 20 10 10 -1 10 0 10 1  0 -2 10 5 Version 1.5 | 2020-01-08 V 10 2 VR 0 5 10 15 V VR 20 BPW 34   Dark Current 2) IR = f (TA); E = 0; VR = 10 V OHF05717 104 IR nA 103 102 101 100 10-1 0 20 40 60 80 ˚C 100 TA Power Consumption Ptot = f (TA) OHF00394 160 mW Ptot 140  120 100 80 60 40 20 0 20 40 60  0 6 Version 1.5 | 2020-01-08 80 ˚C 100 TA BPW 34   Dimensional Drawing 4) 5.4 (0.213) Chip position 0.6 (0.024) 0.4 (0.016) 2.2 (0.087) 1.9 (0.075) 4.3 (0.169) 0.8 (0.031) 0.6 (0.024) 3.7 (0.146) 1.2 (0.047) 0.7 (0.028) 4.9 (0.193) 4.5 (0.177) 0.6 (0.024) 0.4 (0.016) Cathode marking 4.0 (0.157) 1.8 (0.071) 1.4 (0.055) 0.6 (0.024) 0.4 (0.016) 0.4 (0.016) 0.35 (0.014) 0.5 (0.020) 0.2 (0.008) 0.3 (0.012) 0.8 (0.031) 0.6 (0.024) 3.5 (0.138) 3.0 (0.118) 0.6 (0.024) 0 ... 5˚ 5.08 (0.200) spacing Photosensitive area 2.65 (0.104) x 2.65 (0.104) GEOY6643 Further Information: Approximate Weight: 78.0 mg Package marking: Cathode Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43)   7 Version 1.5 | 2020-01-08 BPW 34   TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t   8 Version 1.5 | 2020-01-08 BPW 34   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   9 Version 1.5 | 2020-01-08 BPW 34   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   10 Version 1.5 | 2020-01-08 BPW 34   Glossary 1) Photocurrent: The photocurrent values are measured (by irradiating the devices with a homogenous light source and applying a voltage to the device) with a tolerance of ±11 %. 2) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 3) Testing temperature: TA = 25°C (unless otherwise specified) 4) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm.   11 Version 1.5 | 2020-01-08 BPW 34   Revision History Version Date Change 1.5 2020-01-07 Characteristics Electro - Optical Characteristics (Diagrams)   12 Version 1.5 | 2020-01-08 BPW 34     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 13 Version 1.5 | 2020-01-08
BPW 34 价格&库存
很抱歉,暂时无法提供与“BPW 34”相匹配的价格&库存,您可以联系我们找货
