AP8M122G
AP8M122G
    IDEC
    IDEC - AP8M122G - PANEL MOUNT INDICATOR, LED, 8MM, GREEN, 24V
AP8M122G 数据手册
Switches & Pilot Devices Signaling Lights Switches & Pilot Devices Miniature ø8-16mm AP Series AP Series — Miniature Pilot Lights Key features: • Long service life, low maintenance • Space saving miniature style • Dome or flat lens models • Built-in current-limiting resistor • Five illumination colors: red, green, amber, yellow, and white • Transformer (120V AC and 240V AC) and DC-DC Converter (110V DC) options on 12mm and 16mm units Contactors Timers Relays & Sockets UL Recognized File No. E55996 * CSA Certified File No. LR21451 *AP8/AP1 series only. Specifications Lamp Built-in LED with current limiting resistor Operational Voltage 5, 6, 12, 24VDC (full voltage), 110/120, 220/240VAC, (with transformer) 110VDC (with converter) Current Ratings AP8: 5V DC/9mA, 12V DC/9mA, 24V DC/9mA, 12V AC/15mA, 24V AC/15mA AP1: 5V DC/9mA, 12V DC/9mA, 24V DC/9mA, 12V AC/15mA, 24V AC/15mA AP2: 6V DC/33mA, 12V DC/22mA, 24V DC/11mA AP6: 6V DC/33mA, 12V DC/22mA, 24V DC/11mA Operating Temp. -20ºC to +55ºC Operating Humidity 45 to 85% RH Insul. Resistance 100MΩ min. (500V DC megger) Between live and dead parts Rev. Withstand Voltage AP2/AP6: 100V AP1/AP8: 200V Solder Terminal Soldering 260ºC maximum (5 sec.) Degree of Protection AP8: IP40 (dustproof) Other Series: IP65 (oiltight) Optional Adaptors/Converters Transformer Model Terminal Blocks Applicable Units Operating Voltage DC-DC Converter AP2 & AP6 (with 6V LED only) 110/120VAC 50/60 Hz 220/240VAC 50/60 Hz 110V DC (90 to 140V DC) Power Consumption 1.6 VA maximum 1W maximum Insulation Voltage 250 V AC 140V DC Insulation Resistance Dielectric Strength 10MΩ min. (500V DC megger) Between live and dead parts 2,000V AC, 1 minute Between live/dead parts 2,000V AC, 1 minute Between terminals 2,000V AC, 1 minute Between live/dead parts 1,500V AC, 1 minute Between terminals Circuit Breakers Available as one piece only (replacement LEDs are not available). 472 www.IDEC.com Switches & Pilot Devices Miniature ø8-16mm AP Series Switches & Pilot Devices Miniature Pilot Lights AP Miniature Pilot Lights - ø8 & ø10mm Style Lens Style Operating Voltage Part Numbers Dome 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP8M255-k AP8M211-k AP8M222-k AP8 Series - Ø8mm Flat AP1 Series - Ø10mm Flat AP8M155-k AP8M111-k AP8M122-k 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP1M255-k AP1M211-k AP1M222-k 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% AP1M155-k AP1M111-k AP1M122-k Color Code Amber A Green G Red R Blue S* Warm White W Cool White PW Yellow Y Signaling Lights Dome 5V DC +/- 5% 12V AC/DC +/- 10% 24V AC/DC +/- 10% k Color Codes * Available in only the AP8 and AP1 series. 1. In place of k, specify the color code. 2. For dimensions, see page 475. 3. For accessories, see page 474. Relays & Sockets AP Miniature Pilot Lights - ø12 & ø16mm Style Operating Voltage Part Numbers Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M266-k AP2M211-k AP2M222-k Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M166-k AP2M111-k AP2M122-k 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP6M266-k AP6M211-k AP6M222-k 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP6M166-k AP6M111-k AP6M122-k AP2 Series - Ø12mm Dome AP6 Series - Ø16mm Flat k Color Codes Color Code Amber A Green G Red R Warm White W Yellow Y Timers Lens Style Contactors 1. In place of k, specify the color code. 2. For dimensions, see page 475. 3. For accessories, see page 474. Optional Transformers and DC-DC Converters (for AP2 and AP6 only) Style Voltage Part Numbers Used with AP2 Series Used with AP6 Series 110/120V AC 220/240V AC AP2-0126D AP2-0246D AP6-0126D AP6-0246D DC-DC Converter 110V DC (90–140V DC) AP2-016DD AP6-016DD Terminal Blocks Transformer 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. Optional Transformers and DC-DC converters snap onto the back of AP2 or AP6 pilot lights. 2. Transformers and DC-DC Converters step down to 6V. 3. For dimensions, see page 475. 473 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices Miniature ø8-16mm AP Series Accessories — AP Series Item Appearance Description Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Locking Ring Wrench Mounting Hole Plug Made of rubber. Fills unused mounting holes to provide IP65 protection Transformer Removal Tool A Series Blank/Lens Removal Tool Replacement Lenses Lenses (included with all units). 1. In place of k, specify the Lens Color Code. 2. Internal LED is fixed and cannot be removed or replaced. Color Code Amber A Green G Red R Blue S* White W Yellow Y *Blue available in AP8/AP1 series only. Circuit Breakers Terminal Blocks Contactors Timers k Lens Color Codes 474 www.IDEC.com Used With Part Number Ø 16mm units MT-001 Ø 12mm units MT-002 Ø 10mm units MT-003 Ø 8mm units MT-004 Unused 8mm panel cutouts AL-B8 Unused 10mm panel cutouts AL-B1 Unused 12mm panel cutouts AL-B2 Unused 16mm panel cutouts AL-B6 AP2 and AP6 snap on transformer and DC-DC converter MT-100 AP1M Flat AP1M-L1-k AP1M Dome AP1M-L2-k AP2M Flat AP2M-L1-k AP2M Dome AP2M-L2-k AP6M Flat AP6M-L1-k AP6M Dome AP6M-L2-k Switches & Pilot Devices Miniature ø8-16mm AP Series Switches & Pilot Devices Dimensions — AP Series Pilot Lights (AP Series) AP8 Style AP1 Flat Panel Cut-out Dome Flat AP2 Dome Ø 0.319” (+0.0118, –0) 8.1mm (+0.3, –0) Ø 0.398” (+0.0118, –0) 10.1mm (+0.3, –0) Ø 0.386” (9.8mm) Ø 0.472” (12mm) Outside Dimension Flat Dome Flat Ø 0.480” (+0.0118, –0) 12.2mm (+0.3, –0) Ø 0.551” (14mm) w/ Adaptor or Converter Dome Ø 0.638” (+0.0118, –0) 16.2mm (+0.3, –0) Ø 0.709” (18mm)  0.709” (18mm)  0.709” (18mm) Signaling Lights AP6 AP6 w/ Adaptor or Converter AP2 Panel Thickness: 0.8 to 6 mm Dome 7 5 11.5 29.5 Panel Cut-out ø15.6 .2 +0 0 9.5 When using the Transformer unit (When using the DC-DC converter unit) 9.5 Transformer unit (or DC-DC converter unit) M3 terminal screw + Terminal 18 TOP 18 X2 X1 TOP X2 71 58.7 1.3 Timers 71 18 1.3 18 58.7 + Terminal X1 M3 terminal screw Transformer unit (or DC-DC converter unit) .2 0 +0 2 2. ø1 5.5 2 6. ø1 ø12 ø14 Panel Cut-out 5.5 When using the Transformer unit (When using the DC-DC converter unit) 29.5 Flat Relays & Sockets 8 21.5 21.5 5.5 - 13.5 ø18 1.5 2.2 + 5.5 Flat ø14 1.5 ø15.6 ø18 2.2 ø12 Gasket Dome Gasket - + Panel Thickness: 0.8 to 6 mm – Terminal – Terminal AP1 AP8 2.2 1.5 Panel Thickness: 0.8 to 6 mm Panel Thickness: 0.8 to 6 mm 2.8 3 5.5 9.5 21.5 8 29.5 Panel Cut-out ø1 +0 0 .2 5.5 .1 0. 1 +0 . 0 2 ø10 9.5 Terminal Blocks ø9.8 Flat ø8 Panel Cut-out 5.5 ø8 + 8 29.5 Flat ø12 ø9.8 - 21.5 ø8 2.8 4 ø10 ø12 5.5 10 Gasket Dome Contactors Gasket Dome 1.5 2.2 8.5 Circuit Breakers 800-262-IDEC (4332) • USA & Canada 475
AP8M122G 价格&库存
很抱歉,暂时无法提供与“AP8M122G”相匹配的价格&库存,您可以联系我们找货
