F-224 WEB
IJ5C–04–0400–S–D–NUS–1
IJ5C–08–0600–S–D–NUS–1
(4.00 mm) .1575"
IJ5C SERIES
50 Ω HIGH ISOLATION RF CABLE ASSEMBLY
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?IJ5C
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Pin Material:
Copper Alloy
Dielectric Material:
Black LCP
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-40 °C to +90 °C
RoHS Compliant: Yes
Cable (-1):
Conductor Size:
26 AWG,
(0.48 mm) .019" dia.
Conductor Material:
Silver Plated Copper
Insulator Diameter:
(1.27 mm) .050"
Insulator Material:
Foamed FEP
Shield Material:
Jacket Material:
FEP
Jacket Diameter:
(1.80 mm) .071"
Bend Radius:
3.18 mm
Impedance:
50 Ω
Current Rating:
3.0 A
RoHS Compliant: Yes
Cable (-2):
Conductor Size:
26 AWG, (0.51 mm) .020" dia.
Conductor Material:
Silver and Copper
Plated Steel Wire
Insulator Diameter:
(1.52 mm) .060"
Insulator Material:
PTFE
Shield Material:
Silver Plated Copper Wire
Jacket Material:
FEP
Jacket Diameter:
(2.54 mm) .100"
Bend Radius:
12.8 mm
Impedance:
50 Ω
Current Rating:
5 A DC
RoHS Compliant: Yes
Single or
Double Ended
Mates with:
IP5
1 Meter Cable Assembly
Frequency
Insertion Loss = 3 dB
9.5 GHz / 19.0 Gbps
Return Loss = 15 dB
2.2 GHz / 4.4 Gbps
Isolation = 60 dB
3.1 GHz / 6.2 Gbps
Performance and complete test data available at
www.samtec.com?IJ5C or contact sig@samtec.com
NO. OF
POSITIONS
IJ5C
(20.87) .822
–04
(32.87) 1.294
–02
–06
–08
1, 2, 4, 6 or 8
Positions
–“XXXX”
= Assembled
Length
in millimeters
–0100 to –1000
(100 mm) 3.94"
minimum
A
–01
Positive latching
system
ASSEMBLED
LENGTH
–01, –02,
–04, –06, –08
NO. OF
POSITIONS
High-performance
26 AWG
coax cable
PLATING
OPTION
END
OPTION
–S
= 30 µ"
(0.76 µm)
Gold on
contact
–S
= Single
Ended
(24.87) .979
(40.87) 1.609
–NUS
CABLE
TYPE
–1
= Notch up,
straight
= CTB-2650F-01
P1 to P1
cable
–NDS
= Notch
down,
straight
P1 to PN
–2
= RG 316 cable
ASSEMBLED LENGTH
(48.87) 1.924
(4.00)
.1575
–D
= Double
Ended
END 2
OPTION
(25.17)
.991
N
N
01
01
A
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
FILE NO. E111594
Note:
This Series is non-standard,
non-returnable.
–NUS SHOWN
P1 to P1
(8.55)
.336
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“IJ5C-06-0153-S-S-1”相匹配的价格&库存,您可以联系我们找货
