MH113-MH1RP-MH1RP-0100 数据手册
50 Ω MICRO HIGH FREQUENCY RF CABLES TO 6 GHz
MHF
Cable Assemblies
MH081, MH113
SERIES
MH081
END 1
CONNECTOR
END 2
CONNECTOR
OVERALL LENGTH
–0030
Specify END OPTIONS from chart
= 0.81 mm Cable
MH113
= 1.18" (30 mm)
–0050
= 1.13 mm Cable
= 1.97" (50 mm)
–0100
= 3.94" (100 mm)
–0150
APPLICATION
SPECIFICATIONS
Outer Contact Material:
Au plated Phosphor Bronze
Center Contact Material:
(MHX)
Au plated BeCu (SMA)
Insulator Material:
PBT (MHX)
PTFE (SMA)
Operating Temperature:
-40 °C to +90 °C
Voltage Rating:
170 V max
Dielectric Withstanding
Voltage:
200 Vrms
= 5.91" (150 mm)
–MH1RP
PP0$;
1.13 mm Cable:
Capacitance:
95 pF/meter
Max Attenuation
(cable only):
2 dB @ 1 GHz
Conductor Size:
32 AWG, (1.13 mm) .045" dia.
Conductor Material:
Silver Plated Copper
Conductor Resistance:
0.60 Ω/meter max
Insulator Diameter:
(0.66 mm) .026"
Insulator Material:
FEP
Shield Material:
Tinned Copper
Jacket Material:
FEP
Jacket Diameter:
(1.13 mm) .045" dia
Bend Radius:
6.8 mm
Jacket Temp Rating:
-40 °C to +90 °C
EXTRACTION TOOLS
MH1RP = RSP-122893-01
–MH3RP
MH3RP = RSP-122893-02
MH4RP = RSP-122893-03
PP0$;
MATING SOLUTIONS
–MH4RP
MH1RP end
mates with RSP-122811-01
(Cycles: 30 max.)
0.81 mm Cable:
Capacitance:
100 pF/meter
Max Attenuation
(cable only):
3.1 dB @ 1 GHz
Conductor Size:
36 AWG, (0.81 mm) .032" dia.
Conductor Material:
1.40 Ω/meter max
Insulator Diameter:
(0.4 mm) .016"
Insulator Material: FEP
Shield Material:
Jacket Material: PFA
Jacket Diameter:
Bend Radius: 5.0 mm
Jacket Temp Rating:
-40 °C to +90 °C
–0300
= 11.81" (300 mm)
PP
0$;
MH3RP end
mates with RSP-122811-02
MH4RP end
mates with RSP-122811-03
END OPTIONS
–MH1RP = MHF1 Type Plug
(3.9 µ" (0.1 µm) Gold on Center Contact,
1.9 µ" (0.05 µm) Gold on Shell)
–MH3RP = MHF3 Type Plug
(MH081 only)
–MH4RP = MHF4 Type Plug
(10 µ" (0.25 µm) Gold on Center Contact,
(MH4RP is not available with MH1RP & MH3RP)
(MH081 only)
–01BJ1 = SMA Straight Bulkhead Jack (MH081 only)
–01BJ2 = SMA Straight Bulkhead Jack,
Reversed Polarity
–01SB1 = SMA Straight Jack, Sealed Bulkhead
–01SR1 = SMA Straight Jack, Sealed Bulkhead,
Reversed Polarity
(30 µ" (0.76 µm) Gold on Center Contact,
Gold Flash on Shell)
STRIPPED & TINNED
(Dimensions in mm)
CALLOUT A
–SING =
Single Ended
(End 2 callout)
XXXXXX =
Stripped & Tinned
(End 2 callout)
B
C
A
B
C
–303030
3.0 3.0 3.0
–303040
3.0 3.0 4.0
–403030
4.0 3.0 3.0
–403040
4.0 3.0 4.0
–404040
4.0 4.0 4.0
Both center conductor and
braid shield are stripped, only
the center conductor is tinned.
samtec.com/MHF
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
MH113-MH1RP-MH1RP-0100 价格&库存
很抱歉,暂时无法提供与“MH113-MH1RP-MH1RP-0100”相匹配的价格&库存,您可以联系我们找货
