MBRB3045CT
Technical Data
Data Sheet N0789, Rev. B
Green Products
MBRB3045CT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
200℃ TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
Pure tin plated, solderable per MIL-STD-750, Method 2026
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions (In mm):
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
OPTION 1(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
4.70
0.10
2.69
0.81
1.27
0.38
1.27
8.70
0.61
1.37
8.85
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
4.85
0.25
2.89
0.96
15.6
2.70
1.40
2.20
8°
MBRB3045CT
Technical Data
Green Products
OPTION 2(MX)
MBRB3045CT
Technical Data
Green Products
OPTION 3(CJ)
D²PAK
MBRB3045CT
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
B
30
45
CT
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (30A)
= Reverse Voltage (45V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
D²PAK
(Pb-Free)
MBRB3045CT
Shipping
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current
Peak One Cycle Non-Repetitive
Surge Current (per leg)
Symbol
VRRM
VRWM
VR
IF (AV)
IFSM
Condition
Max.
45
Units
50% duty cycle @TC =123 °C,
rectangular wave form
8.3 ms, half Sine pulse
15(per leg)
30(per device)
240
A
A
MBRB3045CT
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current (per leg) *
Symbol
VF1
VF2
IR1
IR2
Junction Capacitance
(per leg)
Series Inductance
(per leg)
Voltage Rate of Change
CT
LS
dv/dt
Condition
@ 15 A, Pulse, TJ = 25 °C
@ 15 A, Pulse, TJ = 125 °C
@VR = rated VR
TC = 25 °C
@VR = rated VR
TC = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Typ.
0.60
0.56
Max.
0.65
0.62
Units
V
V
0.06
0.2
mA
mA
300
800
pF
8.0
nH
10,000
V/μs
Units
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR3045CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.70770
- 10+5.02240
- 32+3.45570
- 86+3.26880
