260.00
[10.24]
79.20
[3.12]
240.00
[9.45]
5.54
[.22]
(INSIDE HEIGHT)
B
4.80
[.19]
A
147.80
[5.82]
160.00
[6.30]
A
(INSIDE
WIDTH)
140.00
[5.51]
B
TOP VIEW
90.00
[3.54]
SECTION B-B
END VIEW
15.20
[.60]
2.50
[.10]
5.00
[.20]
20.00
[.79]
233.00
[9.17]
70.00
[2.76]
246.49
[9.70]
85.00
[3.35]
SECTION A-A
SIDE VIEW
215.00
[8.46]
7.00
[.28]
38.00
[1.50]
214.07
[8.43]
240.00
[9.45]
141.07
[5.55]
11.11
[.44]
INSIDE LID
SECTION C-C
MOUNTING HOLE
Screw Should Not be Torqued Past 8-9.5 lbf.in (90-110 cN.m)
220.96
[8.70]
C
C
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
Purchased assembly includes Box, Lid, Gasket and 4 cover screws
Enclosure Molded from Glass Reinforced Polyester
248.56
[9.79]
20.00
[.79]
6.80
[.27]
US LISTED
FILE #E65324
NEMA 4, 4X
NOTE
ACCEPTS
M6 X 1 SCREW
83.57
[3.29]
C
(Part number and text placement/orientation on our products are subject to change,
we do not recommend using them as a locating reference for modification purposes)
14.00
[.55]
241.07
[9.49]
UL
O
143.00
[5.63]
STEEL INNER PANEL
SOLD SEPERATLY
29.00
[1.14]
(INSIDE LENGTH)
243.00
[9.57]
PART NUMBERS
1590ZGRP162 Enclosure
Grey Enclosure
110.00
[4.33]
90.96
148.96
[3.58]
[5.86]
ACCESSORIES
Copper Ground Hardware (4 Pack)
[M6 - 1.0 X 6mm / M6 Washer]
1590ZGRP162GY
SCGM6GRP
Steel Inner Panel
1590ZGRP162PL
Hinge Kit (2 Pack)
1427HK
ACCEPTS M6x1 SCREW
INSIDE BOX
Dimensions:
mm
[inches]
1590ZGRP162
www.hammondmfg.com
很抱歉,暂时无法提供与“1590ZGRP162”相匹配的价格&库存,您可以联系我们找货
