1000 Eaton Boulevard
Cleveland, OH 44122
United States
Full Motion Dual Desk Clamp for 13" to 27"
Monitors and Laptops Up to 15"
MODEL NUMBER: DDR1327NBMSC
Highlights
Fits most flat-panel displays
from 13 to 27 in.
Fits most laptops up to 15 in.
One-touch adjustment for
comfortable viewing
Supports monitors up to 22 lbs
(9.9 kgs) and laptops up to 11
lbs (4.9 kgs)
Package Includes
Desk mount assembly
End cap
(2) Arms
Notebook holder
Notebook mounting assembly
Monitor mounting assembly
(3) Collars
(2) Sleeves
(2) Knobs
(2) Front safety clips
(2) Side safety clips
Description
(4) M4 screws
The VESA-compliant DDR1327NBMSC Full Motion Dual Desk Clamp attaches to your desk, table or
(4) M5 screws
workstation, allowing you to mount a monitor and a laptop above it and free up valuable workspace. Ideal
(4) Washers
for home and office, the DDR1327NBMSC fits most flat-panel displays from 13 to 27 inches and laptops
Hex key, 4 mm
up to 15 inches.
Hex key, 6 mm
Owner’s manual
Mounts a monitor and a laptop off the surface of your desk, table or workstation to free up valuable space.
Ideal for home or office use.
Dual swivel arms can be independently adjusted for angle and height to give you maximum flexibility in
positioning your displays to fit your environment and comfort level. Move a screen closer to you, or push
both screens out of your way when not in use. The monitor mount's 180° swivel and -80° to 90° tilt
capability minimizes glare and provides comfortable viewing from multiple angles. The laptop mount
swivels 180° with a 25° tilt capability. The monitor mount rotates 360° for viewing in portrait or landscape
orientation.
Durable clamp attaches to most flat surfaces up to 2.4 inches thick for a firm grip. The unit supports
monitors up to 22 lbs (9.9 kgs) and laptops up to 11 lbs (4.9 kgs). The durable all-metal frame with
scratch-resistant powder-coated finish tolerates frequent handling and blends with any décor. Mounting
hardware is included. Conforms to VESA-compliant displays with any of the following mounting hole
patterns: 75 x 75 mm and 100 x 100 mm.
Features
Attaches to Most Desks, Tables and Workstations
● Clamps securely to most flat surfaces from 0.4 in. to 2.4 in.
Fits most flat-panel displays from 13 to 27 in.
1/3
Cleveland, OH 44122
United States
Dual swivel arms adjust independently for angle and height
Ideal for home and office use
Convenient One-Touch Adjustment
● Monitor mount swivels 180° with -80° to 90° tilt capability for comfortable viewing from multiple angles
Laptop mount swivels 180° with 25° tilt capability
Monitor mount rotates 360° for viewing in portrait or landscape orientation
Durable Metal Construction
● Monitor arm supports up to 22 lbs (9.9 kgs)
Laptop arm supports up to 11 lbs (4.9 kgs)
Scratch-resistant powder-coated finish blends with any décor
Mounting hardware included
VESA Compliance
● Supports the following VESA mounting hole patterns: 75 x 75 mm and 100 x 100 mm
Specifications
OVERVIEW
UPC Code
037332186225
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black; Silver
Material of Construction
Steel
VESA Pattern (mm)
75x75; 100x100
Motion
Full
Mounting Location
Desk Clamp
Degrees of Motion
-80/+90 Tilt; 180 Swivel; 360 Rotate
Laptop Display Size (cm)
12.7 - 38.1
Laptop Display Size (in.)
5 - 15
Minimum Screen Size (in.)
13
Minimum Screen Size (cm)
33.02
Maximum Screen Size (in.)
27
Maximum Screen Size (cm)
68.58
Maximum Weight Capacity (lbs.)
22
Maximum Weight Capacity (kg)
10
2/3
Cleveland, OH 44122
United States
Number of Displays
2
Shipping Dimensions (hwd / in.)
4.92 x 20.39 x 9.76
Shipping Dimensions (hwd / cm)
12.50 x 51.79 x 24.79
Shipping Weight (lbs.)
9.65
Shipping Weight (kg)
4.38
Unit Dimensions (hwd / in.)
12.520 x 33.860 x 4.450
Unit Dimensions (hwd / cm)
31.80 x 86.0 x 11.30
Unit Weight (lbs.)
7.53
Unit Weight (kg)
3.42
FEATURES & SPECIFICATIONS
Cord Management
Yes
Tools Necessary
Yes
Security Lock
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DDR1327NBMSC”相匹配的价格&库存,您可以联系我们找货
