1000 Eaton Boulevard
Cleveland, OH 44122
United States
OmniVS 230V 1000VA 500W Line-Interactive
UPS, Tower, USB port, C13 Outlets
MODEL NUMBER: OMNIVSINT1000
Highlights
1000VA / 1kVA tower 230V line
interactive UPS
Corrects brownouts as low as
159V without using battery
power
USB port, TEL/DSL/ethernet
protection
C14 input and 6 C13 outlets
Package Includes
Description
Tripp Lite's OMNIVSINT1000 line interactive UPS system offers voltage regulation, surge suppression and
long lasting battery support for personal computers, internetworking equipment and other sensitive
electronics. Internal UPS circuits support entry level PC systems for up to 60 minutes during power
failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation
(AVR) circuits regulate brownouts as low as 159 volts back to usable levels without using battery power.
Offers complete desktop power protection in an attractive black tower configuration. Includes 6 outlets
with battery support and AC surge suppression. USB port enables optional unattended system shutdown
without data loss in the case of extended power failure, USB cable included. PowerAlert software
available via free download. Built-in single line RJ phone surge suppression jacks protect modem, fax
machine, cordless phone or other peripheral with a standard dialup/DSL phone connection. Built-in
audible alarm and 4 front panel LEDs indicate line power status, battery power status, battery low/replace
status and load status. 1000VA power handling ability supports entry-level PCs, network workstations,
point-of-sale equipment, small business phone systems, audio/video equipment and home theater
systems. Offers 5 minutes battery runtime with a full load of 1000VA and 12 minutes with a half load of
500VA. Supports battery replacement via built-in access panel.
Features
OMNIVSINT1000 Uninterruptible Power Supply offers voltage regulation, surge suppression and long
Supports entry level PCs up to 60 minutes during blackouts to enable shutdown without data loss
Regulates brownouts as low as 159 volts back to usable levels without using battery power
6 IEC320 C13 outlets with complete AC surge suppression
C14 accepts user-supplied AC power cord with country-specific plug
USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Single line phone surge suppression protects standard dialup/DSL phone connection
1/5
UPS
2 C13 to C14 interconnection
cables
USB and phone line cables
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Audible alarm and 4 front panel LEDs offer complete UPS and line power status information
1000VA power handling ability supports a variety of sensitive electronic equipment
5 minutes full load runtime (1000VA), 12 minutes half load runtime (500VA)
Attractive full color retail packaging
Specifications
OVERVIEW
UPC Code
037332120571
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
2.4A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
Attached 15cm line cord with C14 inlet. The C14 inlet accepts a user-supplied AC power cord with country specific
plug.
UPS Input Cord Length (ft.)
0.5
UPS Input Cord Length (m)
0.2
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
500
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
2/5
Cleveland, OH 44122
United States
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5 min. (500w)
Runtime Half Load (min.)
12 min. (250w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 9 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 159
Undervoltage Correction
Input voltages between 159 and 199 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
508
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
191
Primary UPS Height (mm)
274
3/5
Cleveland, OH 44122
United States
Primary UPS Width (mm)
132
Shipping Dimensions (hwd / in.)
8.10 x 13.80 x 9.60
Shipping Dimensions (hwd / cm)
20.57 x 35.05 x 24.38
Shipping Weight (lbs.)
21.50
Shipping Weight (kg)
9.75
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
27.43 x 13.21 x 19.05
(hwd, in.)
10.8 x 5.2 x 7.5
UPS Power Module Weight (kg)
7.57
UPS Power Module Weight (lbs.)
16.7
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
152
AC Mode Efficiency Rating (100%
Load)
92%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB
LINE / BATTERY TRANSFER
Transfer Time
4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
159
High Voltage Transfer to Battery
Power (Setpoint)
Yes
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
WARRANTY & SUPPORT
4/5
Cleveland, OH 44122
United States
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“OMNIVSINT1000”相匹配的价格&库存,您可以联系我们找货
