1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA SmartPro 120V 1kVA 800W Line-Interactive
Sine Wave UPS, 1U Rack/Vertical, Network Card
Options, USB, 6 Outlets
MODEL NUMBER: SM1000RM1UTAA
Highlights
Corrects under- and
overvoltages from 83V to 147V
6 NEMA 5-15R outlets—2
switchable via network interface
Network power management
and control capability
99% efficiency rating saves
energy and operating cost
14 min. runtime at half load; 4
min. at full load
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Ideal solution for servers, storage devices and telecom
hardware.
Features
Protects Mission-Critical Rack-Mounted EquipmentProvides fully regulated sine wave AC output for
servers, network storage devices and telecom hardwareAudible alarm signals loss of utility power,
overload and low battery6 NEMA 5-15R outlets10-ft. (3.05 m) power cord with 120V NEMA 5-15P
input450-joule surge suppression rating
Reliable Battery BackupSupports half load up to 14 min. and full load up to 4 min.Internal batteries
designed for hot-swap field replacement
Switchable Outlets2 load banks, each with one outlet controllable remotely to reboot equipment or shed
nonessential loads
Automatic Voltage Regulation (AVR)Maintains 120V nominal output over input range of 83V-147V
without using battery power
EMI/RFI Line Noise FilteringRemoves electromagnetic and radio frequency interference that can disrupt
or damage equipment's performance
High Efficiency Operation99% line mode efficiency saves money and energy and protects the
environment
LED IndicatorsFront-panel LEDs signal power, voltage correction, load level and battery charge state
Optional Network Management CardsCompatible with Tripp Lite UPS management cards, such as
WEBCARDLX
Communications PortsUSB and DB9 ports enable data-saving unattended shutdown when used with
Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/poweralertEPO port supports emergency shutdown in large facilities
1/6
SM1000RM1UTAA SmartPro
120V 1kVA 800W LineInteractive Sine Wave UPS
USB cable
DB9 cable
EPO cable
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Versatile Installation OptionsHardware included for mounting in 1U of EIA-standard 19 in. 2- or 4-post
rackOptional 4POSTRAILKIT1U accessory available for extra support in 4-post installationsCompatible
with vertical mount cabinets
TAA CompliantComplies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332184184
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
9.0A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
800
Output Capacity (kW)
0.8
Power Factor
0.8
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-21%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Load Management Receptacles
Two switchable single-outlet 5-15R load banks
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
2/6
Cleveland, OH 44122
United States
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4 min. (800W)
Runtime Half Load (min.)
14 min. (400W)
Expandable Runtime
No
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC69-1U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 83 and 107 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
450
UPS Dataline Suppression
1 line TEL/DSL or Ethernet
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount; Vertical
Rack Height
1U
Cooling Method
Fan
3/6
Cleveland, OH 44122
United States
Included Mounting Accessory
Description
Included mounting brackets provide front-rail installation in 2 or 4 post racks; For additional stability in 4 post racks,
consider optional 4 post mounting accessories 4POSTRAILKIT1U & 4POSTRAILKITWM
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount
with Optional Accessories
Vertical Mount Enclosures ( SRWF5U36 , SRWF5U , SRWF10UMOD )
Minimum Required Rack Depth (cm)
50.80
(inches)
Optional Mounting Accessory Notes
Optional 4POSTRAILKITWM enables installation in 4-port
short-depth racks from 14.5 to 23.5 inches (368 to 597mm); Optional 4POSTRAILKIT1U enables installation in 4-post full-depth racks from 20.5 to 36
inches (521 to 914mm)
Primary UPS Depth (mm)
425
Primary UPS Height (mm)
44
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
6.25 x 23.50 x 22.50
Shipping Dimensions (hwd / cm)
15.88 x 59.69 x 57.15
Shipping Weight (lbs.)
36.00
Shipping Weight (kg)
16.33
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
4.44 x 44.45 x 42.54
(hwd, in.)
1.75 x 17.5 x 16.75
UPS Power Module Weight (kg)
14.51
UPS Power Module Weight (lbs.)
32
Unit Weight (lbs.)
32.0000
Unit Weight (kg)
14.51
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
39
AC Mode Efficiency Rating (100%
Load)
99%
Audible Noise
45 dBA maximum, front side 1m
4/6
Cleveland, OH 44122
United States
COMMUNICATIONS
SNMPWEBCARD; TLNETCARD ; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in USB or DB9 ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB
LINE / BATTERY TRANSFER
Transfer Time
5 milliseconds AC to DC; 1 millisecond DC to AC
Low Voltage Transfer to Battery
Power (Setpoint)
83
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Individually controllable load banks
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
很抱歉,暂时无法提供与“SM1000RM1UTAA”相匹配的价格&库存,您可以联系我们找货
