1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 40kVA Modular 3-Phase UPS
System, On-line Double-Conversion International
UPS
Highlights
40,000 VA (40kVA) 3-phase
tower UPS
N+1 redundant modular
architecture helps assure 100%
availability
1+1 parallel capability allows for
system redundancy or increased
capacity
Low THDi reduces installation
costs by permitting 1:1
generator sizing
3-phase hardwire (220/380V,
230/400V or 240/415V AC, 3phase, 4-wire + ground, wye)
input/output
IGBT technology and zero
transfer time, on-line doubleconversion operation
Runtime is expandable via
external battery cabinet options
MODEL NUMBER: SU40KX
Package Includes
Description
SU40KX UPS System
DB9 Serial cable
Instruction manual
Warranty information
Tripp Lite's SU40KX (40kVA) SmartOnline Modular 3-Phase Intelligent, True On-Line UPS System
provides 100% system availability with N+1 modular architecture and 1+1 parallel capability. In N+1
configuration, the SU40KX provides two self-contained, redundant 20kVA power modules that can be hotswapped (load remaining powered) if maintenance is required. In 1+1 configuration , two SU40KX models
connected in parallel can provide fail-safe redundancy (two 40kVA models supporting a 40kVA load) or
increased capacity (two 40kVA models supporting an 80kVA load). Large capacity 40,000VA/32,000W
UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into
AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time
assures compatibility with all equipment types. High input power factor, advanced IGBT inverter
technology and Digital Signal Processor (DSP) technology produce less than 3% input total harmonic
distortion (THDi). With low THDi, generators run cooler and last longer, allowing managers to save
installation costs by installing a generator with a capacity equal to the equipment load (1:1 ratio).
Extremely efficient operation (up to 97%) saves money by lowering electricity consumption. Hardwire input
and output connections. Frequency is 50 or 60 Hz (auto-selectable). The SU40KX combines internal
power and battery modules in a single small-footprint tower compartment. Typical half-load/full-load
runtimes are 13 min./5.5 min. Battery runtime can be extended with optional stand-alone hardwired
external battery modules (Models BP480V26B and BP480V40C, available separately). A manual bypass
breaker and an automatic bypass function ensure 100% availability of connected equipment by safely
passing through AC power if the UPS requires maintenance.
Features
N+1 configuration: If maintenance is required, two self-contained, redundant 20kVA power modules can
be hot-swapped with the load remaining powered
1+1 configuration: Two SU40KX can be connected in parallel to provide either fail-safe redundancy or
increased capacity
1/5
Cleveland, OH 44122
United States
High input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP)
technology produce low input total harmonic distortion (THDi)
Low THDi (less than 3%) reduces installation costs by allowing 1:1 generator sizing
Extremely efficient operation (up to 97%) saves money by reducing electricity consumption
True on-line, double-conversion UPS with IGBT technology provides pure sine wave AC output at all
times
Maintains continuous operation with zero transfer time through blackouts, voltage fluctuations and
surges
Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power
problems
40,000VA/32,000W power capacity with 3-phase, hardwire input/output connections
Wide input voltage correction range: 173-300V/276-477V AC
Precision +/-1% output voltage regulation
Internal power and battery modules are combined in a single small-footprint tower compartment. Typical
half-load/full-load runtimes are 13 min./5.5 min. Battery runtime can be extended with optional standalone hardwired external battery modules (Models BP480V26B and BP480V40C, available separately)
Front panel combination LCD/LED display includes a real-time event log screen with up to 500 events
listed
Dynamic battery management screen optimizes battery function to lengthen service life and allow cold
restart of the UPS
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Emergency Power Off button turns UPS output OFF and disables Bypass output
Built-in Emergency Power Off (EPO) dry-contact interface supports remote emergency shutdown in
large facilities
Specifications
OVERVIEW
UPC Code
037332141378
UPS Type
On-Line
INPUT
Input Phase
3-Phase
Rated input current (Maximum Load)
48A/50A/53A
Nominal Input Voltage(s) Supported
220/380V 3-PH Wye; 230/400V 3-PH Wye; 240/415V 3-PH Wye
Nominal Input Voltage Description
3-Phase Wye, 4 wire (L1, L2, L3, N, G)
UPS Input Connection Type
Hardwire
OUTPUT
Output Capacity (VA)
40000
Output Capacity (kVA)
40
2/5
Cleveland, OH 44122
United States
Output Capacity (Watts)
32000
Output Capacity (kW)
32
Power Factor
0.8
Crest Factor
3:1
Frequency Compatibility
50 / 60 Hz
Output Voltage Regulation (Line
Mode)
+/- 1%
Output Voltage Regulation (Battery
Mode)
+/- 1%
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
Output Receptacles
Hardwire
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
5.5 min. (32kw)
Runtime Half Load (min.)
13 min. (16kw)
Expandable Runtime
Yes
Expandable Runtime Description
External battery pack wiring is contractor supplied
External Battery Pack Compatibility
BP480V200; BP480V26B; BP480V300; BP480V400; BP480V40C ; BP480V500
DC System Voltage (VDC)
+/- 240VDC
Battery Recharge Rate (Included
Batteries)
4 hours from 10% to 90%
Battery Replacement Description
Hot-swappable, replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
Maintains continuous operation without using battery power during overvoltages to 276-477 (3-phase, 4-wire, wye),
reducing output within 1% of nominal
Undervoltage Correction
Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300 (3phase, 4-wire, wye)
USER INTERFACE, ALERTS & CONTROLS
Switches
ON button turns UPS inverter on. OFF button turns UPS inverter off. LCD Display Control Buttons browse through
and select items displayed on LCD screen. EPO (Emergency Power Off) button turns UPS output off and disables
Bypass output
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
3/5
Cleveland, OH 44122
United States
Audible Alarm
Alarms signal a variety of operational conditions: low-battery, overload, shutdown, bypass and more
LED Indicators
4-LED Display: Displays normal AC input, on battery power, bypass input and fault conditions
SURGE / NOISE SUPPRESSION
EMI / RFI AC Noise Suppression
Yes
AC Suppression Joule Rating
5950
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fans
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
856
Primary UPS Height (mm)
1,163
Primary UPS Width (mm)
521
Shipping Dimensions (hwd / in.)
54.50 x 28.50 x 42.50
Shipping Dimensions (hwd / cm)
138.43 x 72.39 x 107.95
Shipping Weight (lbs.)
1058.00
Shipping Weight (kg)
479.90
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
116.33 x 52.07 x 85.60
(hwd, in.)
45.8 x 20.5 x 33.7
UPS Power Module Weight (kg)
411.86
UPS Power Module Weight (lbs.)
908
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
7006
Battery Mode BTU / Hr. (Full Load)
6975
COMMUNICATIONS
4/5
Cleveland, OH 44122
United States
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cabling included
Communications Interface
DB9 Serial; Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300V
AC (3-phase, 4-wire, wye). Below this point, output is maintained utilizing reserve battery power
High Voltage Transfer to Battery
Power (Setpoint)
Maintains continuous operation without using battery power during overvoltages to 276-477V AC (3-phase, 4-wire,
wye), reducing output within 1% of nominal. Above this point, output is maintained utilizing reserve battery power
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic inverter bypass; Hot swappable batteries
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
1-year limited warranty
Product Warranty Period (Puerto
Rico)
3-Phase Warranty Statement
Tripp Lite 3-Phase UPS Factory Warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
