Additional Resources:
Product Page
date
03/13/2023
page 1 of 4
MODEL: PJ-031H-SMT-TR | DESCRIPTION: DC POWER JACK
FEATURES
• 0.65 mm center pin
• 2.5 A rating
• right angle orientation
• surface mount (SMT)
• internal switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
24
units
Vdc
rated input current
2.5
A
contact resistance
50
mΩ
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
100
insertion/withdrawal force
0.3
operating temperature
-25
life
MΩ
500
Vac
2
kg
85
5,000
flammability rating
UL94V-0
RoHS
yes
°C
cycles
SOLDERABILITY
parameter
reel storage
≤40°C, ≤80% humidity
reflow soldering
see reflow profile
Note:
min
typ
255
260
1. CUI Devices recommends usage of the product within 24 hours after T&R is opened. After 24 hours, CUI Devices recommends drying the parts prior to use.
cuidevices.com
max
units
°C
Product Page
CUI DEVICES | MODEL: PJ-031H-SMT-TR | DESCRIPTION: DC POWER JACK
date 03/13/2023 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.20 mm
X.XX ±0.15 mm
X.XXX ±0.10 mm
PCB: ±0.05 mm
unless otherwise specified
DESCRIPTION
MATERIAL
PLATING/COLOR
center pin
copper alloy
silver
terminal 1
copper alloy t=0.30
silver
terminal 2
copper alloy t=0.25
silver
terminal 3
copper alloy t=0.25
silver
housing
PA10T (UL94V-0)
black
Recommended PCB Layout
Top View
1
3
2
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 8.2 mm
Model
PJ-031H-SMT
Center Pin
Ø0.65 mm
cuidevices.com
Product Page
PACKAGING
units: mm
Reel Size: Ø390 mm
Reel QTY: 1,200 pcs per reel
cuidevices.com
date 03/13/2023 | page 3 of 4
Product Page
date 03/13/2023 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
02/01/2007
1.01
added TR package option and jack insertion depth
11/07/2012
1.02
applied new spec template
08/28/2013
1.03
increased voltage rating
04/14/2016
1.04
added storage and drying conditions, and tape and reel
packaging details
07/25/2017
1.05
brand update
10/21/2019
1.06
logo, datasheet style update
08/05/2022
1.07
product reengineered for improved manufacturability and production yield, see
PCN for details
03/13/2023
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-031H-SMT-TR”相匹配的价格&库存,您可以联系我们找货
