Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/04/2021
page
1 of 3
SERIES: RCJ-02 │ DESCRIPTION: RCA JACK
FEATURES
• through hole
• 2 conductors, 2 contacts
PART NUMBER KEY
RCJ-02 X
Base Number
Insulator Color:
1 = Black
2 = Red
3 = White
4 = Yellow
5 = Blue
6 = Green
7 = Orange
SPECIFICATIONS
parameter
conditions/description
min
typ
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
RoHS
yes
30
mΩ
500
Vac
MΩ
5,000
UL94V-0
units
100
life
flammability rating
max
cuidevices.com
cycles
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: RCJ-02 │ DESCRIPTION: RCA JACK
date 11/04/2021│ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
shell
brass
nickel
2
mounting bracket
iron
tin
3
terminal
brass
tin
4
insulator
PBT
see color code
5
insulator
PA9T
black
Recommended PCB Layout
Top View
Model No.
RCJ-02
2
Schematic
cuidevices.com
1
Product Page
3D Model
PCB Footprint
date 11/04/2021│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
01/10/2006
1.01
updated drawing
05/08/2013
1.02
updated drawing, brand update
11/04/2021
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“RCJ-021”相匹配的价格&库存,您可以联系我们找货
