HEF4053B
Triple single-pole double-throw analog switch
Rev. 12 — 25 March 2016
Product data sheet
1. General description
The HEF4053B is a triple single-pole double-throw (SPDT) analog switch, suitable for use
as an analog or digital multiplexer/demultiplexer. Each switch has a digital select input
(Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output (nZ). All
three switches share an enable input (E). A HIGH on E causes all switches into the
high-impedance OFF-state, independent of Sn.
VDD and VSS are the supply voltage connections for the digital control inputs (Sn and E).
The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0, nY1 and nZ) can
swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may not
exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +125 C
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4053BT
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4053BTT
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
HEF4053B
Nexperia
5. Functional diagram
9''
很抱歉,暂时无法提供与“HEF4053BT,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.45599
- 30+1.40399
- 100+1.35199
- 500+1.24800
- 1000+1.19600
- 2000+1.16480
