HEF4053BT-Q100J
HEF4053BT-Q100J
    NEXPERIA(安世)
    SOIC16_150MIL
    三次单极双掷模拟开关
HEF4053BT-Q100J 数据手册
HEF4053B-Q100 Triple single-pole double-throw analog switch Rev. 2 — 11 September 2014 Product data sheet 1. General description The HEF4053B-Q100 is a triple single-pole double-throw (SPDT) analog switch, suitable for use as an analog or digital multiplexer/demultiplexer. Each switch has a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output (nZ). All three switches share an enable input (E). A HIGH on E causes all switches into the high-impedance OFF-state, independent of Sn. VDD and VSS are the supply voltage connections for the digital control inputs (Sn and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0, nY1 and nZ) can swing between VDD as a positive limit and VEE as a negative limit. VDD  VEE may not exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically ground). VEE and VSS are the supply voltage connections for the switches. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Fully static operation  5 V, 10 V, and 15 V parametric ratings  Standardized symmetrical output characteristics  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Complies with JEDEC standard JESD 13-B 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating HEF4053B-Q100 Nexperia Triple single-pole double-throw analog switch 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package HEF4053BT-Q100 Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 HEF4053BTT-Q100 TSSOP16 5. Functional diagram E 6 VDD 16 13 1Y1 S1 11 LOGIC LEVEL CONVERSION 12 1Y0 DECODER 14 1Z 1 2Y1 S2 10  6
HEF4053BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4053BT-Q100J”相匹配的价格&库存,您可以联系我们找货
