74HC273PW,118
74HC273PW,118
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    带复位的八进制D型触发器;正边缘触发器
74HC273PW,118 数据手册
74HC273; 74HCT273 Octal D-type flip-flop with reset; positive-edge trigger Rev. 5 — 26 February 2016 Product data sheet 1. General description The 74HC273; 74HCT273 is an octal positive-edge triggered D-type flip-flop. The device features clock (CP) and master reset (MR) inputs. The outputs Qn will assume the state of their corresponding Dn inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. A LOW on MR forces the outputs LOW independently of clock and data inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC273: CMOS level  For 74HCT273: TTL level  Common clock and master reset  Eight positive edge-triggered D-type flip-flops  Complies with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC273D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT273D 74HC273DB 74HCT273DB 74HC273PW 74HCT273PW 74HC273BQ 74HCT273BQ SOT764-1 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 4. Functional diagram &3 05            ' ' ' ' ' ' ' ' )) 72 )) 4 4 4 4 4 4 4 4                05  &3 Functional diagram 74HC_HCT273 Product data sheet ' 4 ' 4 ' 4 ' 4 ' 4 ' 4 ' 4 ' 05 4  DDH Fig 1. &3 Fig 2.         ' ' ' ' ' ' ' '    & 5  '               PQD Logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 4 4 4 4 4 4 4 4 PQD Fig 3. IEC logic symbol © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger ' ' ' 4 ' ' &3 )) 4 ' &3 )) 5' ' 4 ' &3 )) 5' 4 &3 )) 5' 5' &3 05 4 ' 4 ' ' 4 ' ' &3 )) 4 4 4 ' &3 )) 5' 4 ' ' &3 )) 5' 4 5' 4 4 &3 )) 5' 4 4 DDH Fig 4. Logic diagram 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 5. Pinning information 5.1 Pinning  05 WHUPLQDO LQGH[DUHD +& +&7  9&& +& +&7 4   4 '   ' '   ' 05   9&& 4   4 '   ' 4   4  4   ' 4    4 '  4   4 '   ' '   ' 4   4 *1'   &3    '  4 *1'  ' 4  ' *1'  &3  ' 4 DDH 7UDQVSDUHQWWRSYLHZ DDH (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 5. Pin configuration SO20, SSOP20 and TSSOP20 Fig 6. Pin configuration DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description MR 1 master reset input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 2, 5, 6, 9, 12, 15, 16, 19 flip-flop output D0, D1, D2, D3, D4, D5, D6, D7 3, 4, 7, 8, 13, 14, 17, 18 data input GND 10 ground (0 V) CP 11 clock input (LOW-to-HIGH, edge-triggered) VCC 20 supply voltage 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 6. Functional description Table 3. Function table[1] Operating modes Inputs Outputs MR CP Dn Qn reset (clear) L X X L load “1” H  h H load “0” H  l L [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; X = don’t care;  = LOW-to-HIGH clock transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA 50 mA IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current 0.5 V < VO < VCC + 0.5 V ICC supply current - IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW Tamb = 40 C to +125 C SO20, SSOP20, TSSOP20 and DHVQFN20 package [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO20 package: above 70 C the value of Ptot derates linearly with 8 mW/K. For SSOP20 and TSSOP20 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN20 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC273 Min Typ 74HCT273 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 - +125 40 - +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC273 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT273 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA; VCC = 5.5 V - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI MR input - 100 360 - 450 - 490 A CP input - 175 630 - 787.5 - 857.5 A Dn input - 15 54 - 67.5 - 73.5 A - 3.5 - - - - - pF input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 41 150 - 185 - 225 ns VCC = 4.5 V - 15 30 - 37 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns VCC = 6.0 V - 13 26 - 31 - 38 ns 74HC273 tpd propagation delay 74HC_HCT273 Product data sheet CP to Qn; see Figure 7 [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter tPHL HIGH to LOW propagation delay 25 C Conditions tW transition time pulse width Min Typ Max Min Max Min Max MR to Qn; see Figure 8 VCC = 2.0 V - 44 150 - 185 - 225 ns VCC = 4.5 V - 16 30 - 37 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns - 14 26 - 31 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 15 - 19 ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 60 17 - 75 - 90 - ns VCC = 4.5 V 12 6 - 15 - 18 - ns VCC = 6.0 V 10 5 - 13 - 15 - ns VCC = 2.0 V 50 6 - 65 - 75 - ns VCC = 4.5 V 10 2 - 13 - 15 - ns VCC = 6.0 V 9 2 - 11 - 13 - ns VCC = 2.0 V 60 11 - 75 - 90 - ns VCC = 4.5 V 12 4 - 15 - 18 - ns VCC = 6.0 V 10 3 - 13 - 15 - ns VCC = 2.0 V 3 6 - 3 - 3 - ns VCC = 4.5 V 3 2 - 3 - 3 - ns VCC = 6.0 V 3 2 - 3 - 3 - ns VCC = 2.0 V 6 20.6 - 4.8 - 4 - MHz VCC = 4.5 V 30 103 - 24 - 20 - MHz - 66 - - - - - MHz 35 122 - 28 - 24 - MHz - 20 - - - - - pF VCC = 6.0 V tt 40 C to +85 C 40 C to +125 C Unit Qn output; see Figure 7 [2] CP input HIGH or LOW; see Figure 7 MR input LOW; see Figure 8 trec tsu th fmax recovery time set-up time hold time maximum frequency MR to CP; see Figure 8 Dn to CP; see Figure 9 Dn to CP; see Figure 9 CP input; see Figure 7 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT273 Product data sheet per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 4.5 V - 16 30 - 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns 74HCT273 propagation delay tpd tPHL tt CP to Qn; see Figure 7 HIGH to LOW propagation delay MR to Qn; see Figure 8 transition time Qn output; see Figure 7 [1] VCC = 4.5 V - 23 34 - 43 - 51 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 7 15 - 19 - 22 ns 16 9 - 20 - 24 - ns 16 8 - 20 - 24 - ns 10 2 - 13 - 15 - ns 12 5 - 15 - 18 - ns 3 4 - 3 - 3 - ns [2] VCC = 4.5 V pulse width tW CP input; see Figure 7 VCC = 4.5 V MR input LOW; see Figure 8 VCC = 4.5 V recovery time trec MR to CP; see Figure 8 VCC = 4.5 V tsu set-up time Dn to CP; see Figure 9 th hold time Dn to CP; see Figure 9 VCC = 4.5 V VCC = 4.5 V maximum frequency fmax CP input; see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF power dissipation capacitance CPD [1] per package; VI = GND to VCC  1.5 V [3] 30 56 - 24 - 20 - MHz - 36 - - - - - MHz - 23 - - - - - pF tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz;  (CL  VCC2  fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 11. Waveforms IPD[ 9, &3LQSXW  90 90 *1' W: W: W 3+/ W 3/+ 92+  4QRXWSXW 90  92/ W7+/ W7/+ DDH Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay clock input (CP) to output (Qn), clock (CP) pulse width, output transition time and the maximum clock pulse frequency 9, 90 05LQSXW  *1' W: WUHF 9, &3LQSXW  90 *1' W3+/ 92+ 90 4QRXWSXW 92/ PQD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Propagation delay master reset (MR) to output (Qn), pulse width master reset (MR) and recovery time master reset (MR) to clock (CP) 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 9, 90 &3LQSXW *1' W VX W VX WK WK 9, 90 'QLQSXW *1' 92+ 90 4QRXWSXW 92/ PQD Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig 9. Data set-up and hold times data input (Dn) Table 8. Measurement points Type Input VI VM VM 74HC273 VCC 0.5VCC 0.5VCC 74HCT273 3V 1.3 V 1.3 V 74HC_HCT273 Product data sheet Output All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Fig 10. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH 74HC273 VCC 6 ns 15 pF, 50 pF 1 k open 74HCT273 3V 6 ns 15 pF, 50 pF 1 k open 74HC_HCT273 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 S1 position © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' $ ( ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   H ES GHWDLO; Z 0   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ PP                                           LQFKHV         =       ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 11. Package outline SOT163-1 (SO20) 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   Z 0 ES H GHWDLO;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 12. Package outline SOT339-1 (SSOP20) 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 13. Package outline SOT360-1 (TSSOP20) 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV WHUPLQDOVERG\[[PP % ' 627 $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD H & H E   Y Z & $ % & \ & \ /   (K H     ; 'K   PP VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW $  $ E PD[    QRP    PLQ    PP F '  'K (  (K H H / Y                    Z \   \  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627  02  VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 14. Package outline SOT764-1 (DHVQFN20) 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT273 v.5 20160226 Product data sheet - 74HC_HCT273 v.4 Modifications: 74HC_HCT273 v.4 Modifications: • Type numbers 74HC273N and 74HCT273N (SOT146-1) removed. 20130610 Product data sheet - 74HC_HCT273 v.3 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT273 v.3 20060124 Product data sheet - 74HC_HCT273_CNV v.2 74HC_HCT273_CNV v.2 19970827 Product specification - - 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT273 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 18 of 20 74HC273; 74HCT273 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT273 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC273; 74HCT273 Octal D-type flip-flop with reset; positive-edge trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 February 2016
74HC273PW,118 价格&库存
很抱歉,暂时无法提供与“74HC273PW,118”相匹配的价格&库存,您可以联系我们找货
74HC273PW,118
    • 5+1.50552
    • 50+1.20366
    • 150+1.07428
    • 500+0.91293
    • 2500+0.84100
    • 5000+0.79791
    库存:4812
    74HC273PW,118
