engineered to light up your design
www.vcclite.com
1.800.522.5546
5684F Series PC Board Quad Array T-1 LEDs
Description and Features
All dimensions in inches.
HOLDE R
MAT 'L: B LAC K T HE R MOP LAS T IC
P OLY E S T E R UL94V -0
.580
.140
LE D (4)
.260
.200
Available options :
• Low current, 5V and 12V built-in resistors .
• Bi-color and blue LEDs also offered.
• Call factory for ordering information.
.070
Refer to “Mounting Hole Pattern 2.pdf”
.090
.350
Features
• 4 T-1 LEDs mounted in single block
• High density - only 0.26" wide
• Black plastic mounting block for high
contrast ratio.
• Meets UL 94V-O and Bellcore
flammability specifications .
• RoHS Compliant
.270
.130
.240
Pos # 2
Pos #1
Pos # 4
Pos # 3
ANODE (+)
Ordering Information: Use chart below to determine model number.
LE D
R ed
1
G reen
5
Amber
3
Model No. is as follows: 5684F
P os. 1
_
Y ellow
7
P os. 2
_
P os. 3
_
P os. 4
E xample: P osition 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. The part number is 5684F 5_1_7_3.
Electro-Optical Characteristics and Ratings
P art Number
5684F 1_1_1_1
5684F 3_3_3_3
5684F 5_5_5_5
5684F 7_7_7_7
E mitted
C olor
R ed
Amber
G reen
Y ellow
R ated
C urrent
(mA)
10
10
10
10
T yp.
Intensity
(mcd)
10
6.5
8.5
10
C ontinuous
F orward
C urrent Max.
(mA)
T yp.
(V )
Max.
(V )
R everse
B reakdown
V oltage Min.(V )
P eak
Wavelength
(nm)
25
25
25
25
2.2
2.2
2.3
2.2
3.0
3.0
3.0
3.0
5.0
5.0
5.0
5.0
635
602
565
583
F orward V oltage
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5684F3_3_3_3”相匹配的价格&库存,您可以联系我们找货
