PESD1CAN-UX
PESD1CAN-UX
    NEXPERIA(安世)
    SOT323
    ESD VRWM=24V Ipp=3A VBR(Min)=25.4V Ppp=150W Vc=50V SOT323
PESD1CAN-UX 数据手册
PESD1CAN-U CAN bus ESD protection diode Rev. 1 — 27 March 2013 Product data sheet 1. Product profile 1.1 General description ElectroStatic Discharge (ESD) protection diode in a very small SOT323 (SC-70 ) Surface-Mounted Device (SMD) plastic package designed to protect two automotive Controller Area Network (CAN) bus lines from the damage caused by ESD and other transients. 1.2 Features and benefits       One very small SOT323 package to protect two CAN bus lines Low clamping voltage VCL = 35 V at IPP = 1 A Typical diode capacitance matching Cd/Cd = 0.1 % ESD protection up to 23 kV; IEC 61000-4-2, level 4 IEC 61000-4-5 (surge); IPPM = 3 A at tp = 8/20 s AEC-Q101 qualified 1.3 Applications  CAN bus protection  Automotive applications 1.4 Quick reference data Table 1. Quick reference data Tamb = 25 C unless otherwise specified. Symbol Parameter VRWM reverse standoff voltage Cd diode capacitance Conditions f = 1 MHz; VR = 0 V Min Typ Max Unit - - 24 V - 9.3 12 pF 2. Pinning information Table 2. Pinning Pin Description 1 cathode 1 2 cathode 2 3 common cathode Simplified outline Graphic symbol 3 1 3 2 1 2 006aaa155 PESD1CAN-U Nexperia CAN bus ESD protection diode 3. Ordering information Table 3. Ordering information Type number Package PESD1CAN-U Name Description Version SC-70 plastic surface-mounted package; 3 leads SOT323 4. Marking Table 4. Marking codes Type number Marking code[1] PESD1CAN-U NB* [1] * = placeholder for manufacturing site code. 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit PPPM rated peak pulse power Conditions [1][2] - 150 W IPPM rated peak pulse current [1][2] - 3 A Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Device stressed with ten non-repetitive current pulses (8/20 s exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321). [2] Measured from pin 1 or 2 to 3. Table 6. ESD maximum ratings Symbol Parameter VESD Conditions electrostatic discharge voltage Min IEC 61000-4-2 (contact discharge) machine model MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 or 2 to 3. Table 7. PESD1CAN-U Product data sheet Max Unit [1][2] - 23 kV [2] - 400 V - 10 kV ESD standards compliance Standard Conditions IEC 61000-4-2, level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 2 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 1. t tr = 0.7 ns to 1 ns 0 60 ns 8/20 s pulse waveform according to IEC 61000-4-5 and IEC 61643-321 Fig 2. ESD pulse waveform according to IEC 61000-4-2 6. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions VRWM reverse standoff voltage IRM reverse leakage current VRWM = 24 V VBR breakdown voltage IR = 5 mA clamping voltage VCL IPP = 1 A [1][2] IPPM = 3 A diode capacitance Cd Cd/Cd [1] PESD1CAN-U Product data sheet Max Unit - 24 V - 1 50 nA 25.4 27.8 30.3 V - - 35 V - - 50 V - 9.3 12 pF f = 1 MHz; VR = 2.5 V - 7.2 - pF - 0.1 - % - 0.1 - % - 1.5 -  capacitance matching f = 1 MHz; VR = 0 V dynamic resistance Typ - f = 1 MHz; VR = 0 V [3] f = 1 MHz; VR = 2.5 V rdyn Min IR = 10 A [2][4] Device stressed with 8/20 s exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321. [2] Measured from pin 1 or 2 to 3. [3] Cd is the difference of the capacitance measured between pin 1 and pin 3 and the capacitance measured between pin 2 and pin 3. [4] Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANS/IESD STM5.1-2008. All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 3 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode aaa-007015 102 006aab321 1.2 PPPM PPPM(25°C) PPPM (W) 0.8 10 0.4 1 10-1 0 1 tp (ms) 10 0 50 100 150 200 Tj (°C) Tamb = 25 C Fig 3. Rated peak pulse power as a function of square pulse duration; typical values Fig 4. Relative variation of peak pulse power as a function of junction temperature; typical values IPPM IPP aaa-007016 10 Cd (pF) 8 -VCL -VBR -VRWM IR IRM -IRM -IR VRWM VBR VCL 6 - 4 -30 -10 10 VR (V) -IPP 30 -IPPM f = 1 MHz; Tamb = 25 C Fig 5. Product data sheet 006aab325 . Diode capacitance as a function of reverse voltage; typical values PESD1CAN-U + Fig 6. V-I characteristics for a bidirectional ESD protection diode All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 4 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode ESD TESTER Rd 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10x ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 network Cs = 150 pF; Rd = 330 Ω vertical scale = 50 V/div horizontal scale = 10 ns/div vertical scale = 2 kV/div horizontal scale = 10 ns/div GND GND clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) vertical scale = 50 V/div horizontal scale = 10 ns/div vertical scale = 2 kV/div horizontal scale = 10 ns/div GND GND unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 7. clamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-007017 ESD clamping test setup and waveforms PESD1CAN-U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 5 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 7. Application information The device is designed for the protection of two automotive CAN bus lines from surge pulses and ESD damage. The device is suitable on lines where the signal polarities are both, positive and negative with respect to ground. SPLIT CANH RT/2 CAN BUS TRANSCEIVER CAN bus RT/2 CANL Common mode choke (optional) 2 1 CG PESD1CAN-U 3 aaa-007049 Fig 8. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the device as close to the input terminal or connector as possible. 2. Minimize the path length between the device and the protected line. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD1CAN-U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 6 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 9. Package outline 2.2 1.8 1.1 0.8 0.45 0.15 3 2.2 1.35 2.0 1.15 1 2 0.4 0.3 0.25 0.10 1.3 Dimensions in mm Fig 9. PESD1CAN-U Product data sheet 04-11-04 Package outline SOT323 (SC-70) All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 7 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 10. Soldering 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) sot323_fr Fig 10. Reflow soldering footprint SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Fig 11. Wave soldering footprint SOT323 (SC-70) PESD1CAN-U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 8 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PESD1CAN-U v.1 20130327 Product data sheet - - PESD1CAN-U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 9 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PESD1CAN-U Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 10 of 12 PESD1CAN-U Nexperia CAN bus ESD protection diode No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PESD1CAN-U Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 27 March 2013 © Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia PESD1CAN-U CAN bus ESD protection diode 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Quality information . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 March 2013
PESD1CAN-UX 价格&库存
很抱歉,暂时无法提供与“PESD1CAN-UX”相匹配的价格&库存,您可以联系我们找货
PESD1CAN-UX
  • 1+0.66895
  • 30+0.64506
  • 100+0.62117
  • 500+0.57339
  • 1000+0.54949
  • 2000+0.53516
库存:2292
PESD1CAN-UX
  • 9000+0.92001
  • 18000+0.90806
  • 27000+0.89639
  • 45000+0.88508
  • 90000+0.86319
  • 225000+0.84240
  • 450000+0.82261
库存:45000
