SS32 - SS315
3.0 AMPS. Surface Mount Schottky Barrier Rectifiers
SMB/DO-214AA
Features
0.180(4.57)
0.160(4.06)
For surface mounted application
Easy pick and place
Metal to silicon rectifier, majority carrier conduction
Low power loss, high efficiency
High current capability, low VF
High surge current capability
Plastic material used carriers Underwriters
Laboratory Classification 94V-0
Epitaxial construction
High temperature soldering:
260oC / 10 seconds at terminals
0.086(2.20)
0.077(1.95)
0.209(5.30)
0.201(5.10)
0.012(0.30)
0.006(0.15)
0.096(2.44)
0.084(2.13)
0.059(1.50)
0.035(0.90)
Mechanical Data
0.155(3.94)
0.130(3.30)
Case: JEDEC SMB/DO-214AA Molded plastic
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Weight: 0.064 gram
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol SS SS SS SS
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current at TL(See Fig. 1)
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
IF= 3.0A @ 25oC
(Note 1)
@ 100oC
o
Maximum DC Reverse Current @ TA =25 C at
o
Rated DC Blocking Voltage
@ TA=125 C
Typical Thermal Resistance ( Note 2 )
VRRM
VRMS
VDC
32
30
21
30
34
40
28
40
IFSM
100
ht t p : //
SS Units
315
150
V
105
V
150
V
VF
0.5
0.4
A
70
0.75
0.65
0.5
10
R ΘJL
R θJA
TJ
Operating Temperature Range
-55 to +125
TSTG
Storage Temperature Range
Notes:
1. Pulse Test with PW=300 usec, 1% Duty Cycle
Revision:20170701-P1
SS SS
39 310
90 100
63
70
90 100
3.0
I(AV)
IR
SS
36
60
42
60
35
50
35
50
5
28
88
0.85
0.95
0.70
0.80
0.1
0.5
-55 to +150
-55 to +150
www.lgesemi .c o m
A
V
mA
mA
o
C/W
o
o
C
C
mail:lge@lgesemi.com
SS32 - SS315
RATINGS AND CHARACTERISTIC CURVES (SS32B THRU SS315B)
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
100
PEAK FORWARD SURGE CURRENT. (A)
3
AVERAGE FORWARD CURRENT. (A)
RESISTIVE OR
INDUCTIVE LOAD
SS35B-SS315B
SS32B-SS34B
2
1
PCB MOUNTED ON 0.6X0.6"
(16X16mm) COPPER PAD AREAS
60
70
80
90
100
110
120
130
140
150
FIG.2- MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
AT RATED TL
8.3ms Single Half Sine Wave
JEDEC Method
80
60
40
160
10
NUMBER OF CYCLES AT 60Hz
o
LEAD TEMPERATURE. ( C)
FIG.4- TYPICAL REVERSE CHARACTERISTICS
FIG.3- TYPICAL FORWARD CHARACTERISTICS
TJ=25 0C
10
TJ=125C
10
INSTANTANEOUS REVERSE CURRENT. (mA)
INSTANTANEOUS FORWARD CURRENT. (A)
SS35B-SS36B
SS32B-SS34B
1
SS39B-SS310B
0.1
1
TJ=75C
0.1
0.01
TJ=25 0C
SS315B
PULSE WIDTH=300 S
1% DUTY CYCLE
0.01
0.6
0.4
0.8
1.0
1.2
1.4
SS32A-SS34A
SS35A-SS315A
0.001
60
80
100
120
140
FIG.6- TYPICAL TRANSIENT THERMAL
CHARACTERISTICS
FIG.5- TYPICAL JUNCTION CAPACITANCE
1000
100
TJ=25C
f=1.0MHz
Vsig=50mVp-p
100
SS32B-SS34B
SS35B-SS36B
SS39B-SS315B
10
0.1
1
10
100
REVERSE VOLTAGE. (V)
TRANSIENT THERMAL IMPEDANCE. (OC/W)
JUNCTION CAPACITANCE.(pF)
40
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
FORWARD VOLTAGE. (V)
10
1
0.1
0.01
1
10
T, PULSE DURATION. (sec)
0.1
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMB
3000/REEL
48000
36X35.8X36.5
12.00
11.00
ht t p : //
100
www.lgesemi .c o m
100
很抱歉,暂时无法提供与“SS34 (SMB)”相匹配的价格&库存,您可以联系我们找货
