SS52-SS520
Surface Mount Schottky Barrier Rectifiers
SMC/DO-214AB
Features
Plastic package has Underwriters Laborator
Flammability Classification 94V-0
For surface mounted applications
Low profile package
Built-in strain relief
Metal silicon junction, majority carrier conduction
High surge capability
High current capability,low forward voltage drop
Low power loss,high effciency
For use in low voltage high frequency inverters,free
wheeling and polarity protection applications
Guardring for overvoltage protection
High temperature soldering guaranteed:250oC/10 1
seconds at terminals
Dimensions in inches and (millimeters)
Mechanical Data
Case:JEDEC SMC,molded plastic over
1111passivated chip
Polarity: Color band denotes cathode end
Weight: 0.007 ounces, 0.21 gram
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS52 SS53 SS54 SS55 SS56 SS58 SS59 SS510 SS520 UNITS
50
60
80
28
35
42
56
40
50
60
80
100
200
V
63
70
100
140
200
V
90
VRRM
Maximum RMS voltage
VRWS
14
21
Maximum DC blocking voltage
VDC
Maximum average forw ord rectified current at
c TL(SEE FIG.1) (NOTE 2)
I(AV)
5.0
A
Peak forw ard surge current 8.3ms single halfc sine-w ave superimposed on rated load(JEDEC
c Method)
IFSM
175
A
Maximum instantaneous forw ard voltage at
v 5.0A(NOTE.1)
at rated DC blockjing voltage(NOTE1) @TA=100oC
Typical thermal resitance (NOTE2)
Operating junction temperature range
Storage temperature range
0.70
0.55
VF
Maximum DC reverse current @TA=25oC
40
90
Maximum recurrent peak reverse voltage
RθJA
55
RθJL
17
V
0.85
0.5
IR
V
mA
o
C/W
TJ
-55--- +150
o
TSTG
-55--- +150
o
C
C
NOTE: 1.Pulse test:300μS pulse width,1%duty cy cle
2. P.C.B.mounted with 0.55"X0.55"(14.0X14.0mm 2)copper pad areas
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS52-SS520
Ratings AND Charactieristic Curves
FIG.2-- PEAK FORWARD SURGE CURRENT
175
5.0
Resistive or
inductive Load
PEAK FORWARD SURGE
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
2.5
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
50
60
70 80
90 100 110 120 130 140 150 160 170
140
8.3ms Single Half Sine Wave
TJ=125
105
70
35
AMBIENT TEMPERATURE ℃
NUMBER OF CYCLES AT 60HZ
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
10
SS52-SS54
SS58-SS520
SS55-SS56
1
TJ =25
Pulse width=300 s
1% duty Cycle
.1
.1
.3
.5
.7
.9
1.1
1.3
1.5
1.7
1.9
2.1
INSTANTANEOUS REVERSE
CURRENT,MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
100
10
5.0
.5
.1
.05
TJ = 25
.01
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE,%
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMC
3000/REEL
42000
36X36X36.5
18.50
15.50
ht t p : //
TJ = 125
1.0
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS54 (SMC)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.56999
- 100+0.53199
- 300+0.49399
- 500+0.45600
- 2000+0.43700
- 5000+0.42560
