74AXP1T14
Dual supply Schmitt trigger inverter
Rev. 2 — 9 May 2017
1
Product data sheet
General description
The 74AXP1T14 is a dual supply Schmitt trigger inverter. It features one input (A), an
output (Y) and dual supply pins (VCCI and VCCO). The input is referenced to VCCI and the
output is referenced to VCCO. Input A can be connected directly to VCCI or GND. VCCI can
be supplied at any voltage between 0.7 V and 2.75 V and VCCO can be supplied at any
voltage between 1.2 V and 5.5 V. This feature allows voltage level translation.
This device ensures very low static and dynamic power consumption across the entire
supply range and is fully specified for partial power down applications using IOFF. The
IOFF circuitry disables the output, preventing the potentially damaging backflow current
through the device when it is powered down.
2
Features and benefits
• Wide supply voltage range:
– VCCI: 0.7 V to 2.75 V
– VCCO: 1.2 V to 5.5 V
• Low input capacitance; CI = 0.6 pF (typical)
• Low output capacitance; CO = 1.8 pF (typical)
• Low dynamic power consumption; CPD = 0.5 pF at VCCI = 1.2 V (typical)
• Low dynamic power consumption; CPD = 7.1 pF at VCCO = 3.3 V (typical)
• Low static power consumption; ICCI = 0.5 μA (85 °C maximum)
• Low static power consumption; ICCO = 1.8 μA (85 °C maximum)
• High noise immunity
• Complies with JEDEC standard:
– JESD8-12A.01 (1.1 V to 1.3 V; A input)
– JESD8-11A.01 (1.4 V to 1.6 V)
– JESD8-7A (1.65 V to 1.95 V)
– JESD8-5A.01 (2.3 V to 2.7 V)
– JESD8-C (2.7 V to 3.6 V; Y output)
– JESD12-6 (4.5 V to 5.5 V; Y output)
• ESD protection:
– HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
– CDM JESD22-C101E exceeds 1000 V
• Latch-up performance exceeds 100 mA per JESD78D Class II
• Inputs accept voltages up to 2.75 V
• Low noise overshoot and undershoot < 10% of VCCO
• IOFF circuitry provides partial power-down mode operation
• Specified from -40 °C to +85 °C
74AXP1T14
Nexperia
3
Ordering information
Table 1. Ordering information
Type number Package
Temperature
range
Name
Description
Version
74AXP1T14GW -40 °C to +85 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AXP1T14GX
X2SON5
plastic thermal enhanced extremely thin small outline
SOT1226
package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm
4
-40 °C to +85 °C
Marking
Table 2. Marking
Type number
Marking code
74AXP1T14GW
rL
74AXP1T14GX
rL
[1]
5
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
Functional diagram
A
2
Y
A
4
Y
VCCI
VCCO
aaa-025789
aaa-025790
Figure 1. Logic symbol
6
Figure 2. Logic diagram
Pinning information
6.1 Pinning
74AXP1T14
74AXP1T14
VCCI
1
A
2
GND
3
5
VCCO
4
Y
VCCI
VCCO
2
4
Y
aaa-026568
Transparent top view
aaa-025791
Figure 3. Pin configuration SOT353-1 (TSSOP5)
Product data sheet
5
3
GND
A
74AXP1T14
1
Figure 4. Pin configuration SOT1226 (X2SON5)
All information provided in this document is subject to legal disclaimers.
Rev. 2 — 9 May 2017
© Nexperia B.V. 2017. All rights reserved.
2 / 17
74AXP1T14
Nexperia
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
VCCI
1
input supply voltage
A
2
data input A
GND
3
ground (0 V)
Y
4
data output Y
VCCO
5
output supply voltage
7
Functional description
Table 4. Function table
[1]
Supply voltage
Input
Output
VCCI
VCCO
A
Y
0.7 V to 2.75 V
1.2 V to 5.5 V
L
H
0.7 V to 2.75 V
1.2 V to 5.5 V
H
L
GND
1.2 V to 5.5 V
X
Z
0.7 V to 2.75 V
GND
X
Z
GND
GND
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCCI
-0.5
3.3
V
VCCO
-0.5
6.0
V
IIK
input clamping current
-50
-0.5
3.3
VI
input voltage
IOK
output clamping current
VO
output voltage
VI < 0 V
[1]
VO < 0 V
Active mode
Power-down or 3-state mode
mA
V
-50
[1] [2]
-0.5
VCCO + 0.5
V
[1]
-0.5
6.0
V
±25
mA
IO
output current
ICCI
input supply current
50
mA
ICCO
output supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
74AXP1T14
Product data sheet
VO = 0 V to VCCO
mA
Rev. 2 — 9 May 2017
3 / 17
74AXP1T14
Nexperia
Symbol Parameter
Conditions
Ptot
Tamb = -40 °C to +85 °C
[1]
[2]
total power dissipation
Min
Max
Unit
250
mW
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCCO + 0.5 V should not exceed 6.0 V.
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCCI
Min
Max
Unit
0.7
2.75
V
VCCO
1.2
5.5
V
VI
input voltage
V
VO
output voltage
Active mode
VCCO
V
V
-40
+85
°C
Tamb
Conditions
ambient temperature
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
hysteresis voltage
Conditions
Min
Typ
25 °C
Max
25 °C
Max
85 °C
VCCI = 0.75 V to 0.85 V
0.3VCCI
0.8VCCI
0.8VCCI
V
VCCI = 1.1 V to 1.95 V
0.4VCCI
0.7VCCI
0.7VCCI
V
VCCI = 2.3 V to 2.7 V
0.9
1.7
1.7
V
0.2VCCI
0.7VCCI
0.7VCCI
V
0.3VCCI
0.6VCCI
0.6VCCI
V
0.7
1.5
1.5
V
0.06VCCI
0.5VCCI
0.5VCCI
V
0.1VCCI
0.4VCCI
0.4VCCI
V
0.2
1.0
1.0
V
1.05
V
IO = -3 mA; VCCO = 1.4 V
1.05
V
IO = -4.5 mA; VCCO = 1.65 V
1.2
V
IO = -8 mA; VCCO = 2.3 V
1.7
V
see Figure 5 and Figure 6
VOH
HIGH-level output
voltage
74AXP1T14
Product data sheet
Unit
IO = -2 mA; VCCO = 1.2 V
[1]
Rev. 2 — 9 May 2017
4 / 17
74AXP1T14
Nexperia
Symbol Parameter
Conditions
Min
Typ
25 °C
Max
25 °C
Max
85 °C
2.2
V
3.7
V
0.18
V
IO = 3 mA; VCCO = 1.4 V
0.35
0.35
V
IO = 4.5 mA; VCCO = 1.65 V
0.45
0.45
V
IO = 8 mA; VCCO = 2.3 V
0.7
0.7
V
IO = 10 mA; VCCO = 3.0 V
0.8
0.8
V
0.8
0.8
V
±0.001
±0.1
±0.5
μA
±0.001
±0.1
±0.5
μA
IO = -10 mA; VCCO = 3.0 V
IO = -12 mA; VCCO = 4.5 V
VOL
LOW-level output
voltage
Unit
[1]
IO = 2 mA; VCCO = 1.2 V
IO = 12 mA; VCCO = 4.5 V
[1]
II
input leakage
current
VI = 0 V to 2.75 V;
VCCI = 0 V to 2.75 V
IOZ
OFF-state output
current
VO = 0 V to 5.5 V;
VCCO = 1.2 V to 5.5 V
IOFF
power-off leakage
current
inputs; VI = 0 V to 2.75 V;
VCCI = 0 V;
VCCO = 0 V to 5.5 V
[1]
±0.01
±0.1
±0.5
μA
output; VO = 0 V to 5.5 V;
VCCO = 0 V;
VCCI = 0 V to 2.75 V;
VI = 0 V to 2.75 V
[1]
±0.01
±0.1
±0.5
μA
inputs; VI = 0 V or 2.75 V;
VCCI = 0 V to 0.1 V;
VCCO = 0 V to 5.5 V
[1]
±0.02
±0.1
±0.5
μA
output; VO = 0 V or 5.5 V;
VCCO = 0 V to 0.1 V;
VI = 0 V or 2.75 V
[1]
±0.02
±0.1
±0.5
μA
ΔIOFF
[1]
additional
power-off leakage
current
Typical values are measured at VCCI = VCCO = 1.2 V unless otherwise specified.
VO
VI
VI
VH
VT-
VT+
Figure 5. Transfer characteristic
74AXP1T14
Product data sheet
VT+
VH
VT-
VO
mna207
mna208
Figure 6. Definition of VT+, VT-, and VH
Rev. 2 — 9 May 2017
5 / 17
74AXP1T14
Nexperia
Table 8. Static characteristics supply current
Symbol Parameter
ICCI
ΔICCI
Unit
Typ
25 °C
Max
25 °C
Typ
85 °C
Max
85 °C
VI = 0 V or VCCI;
input supply
current
ICCO
[1]
[2]
[3]
Conditions
VCCI = 0.7 V to 1.3 V
[1]
1
100
10
300
nA
VCCI = 1.3 V to 2.75 V
[2]
1
100
nA
VCCI = 2.75 V; VCCO = 0 V
1
100
nA
VCCI = 0 V; VCCO = 5.5 V
1
100
1
100
nA
VI = 0 V or VCCI; IO = 0 A;
see Table 9
output supply
current
additional input
supply current
VCCO = 1.2 V to 3.6 V
[1]
0.001
1.0
0.01
1.2
μA
VCCO = 3.6 V to 5.5 V
[3]
0.8
1.5
1.0
1.8
μA
0.001
0.1
0.003
0.2
μA
VCCI = 0 V; VCCO = 3.6 V
0.2
0.6
0.3
0.8
μA
0.4
0.8
0.5
1.0
μA
2
100
14
150
μA
VI = VCCI - 0.5 V; VCCI = 2.5 V
Typical values are measured at VCCI = VCCO = 2.5 V.
Typical values are measured at VCCI = 1.2 V and VCCO = 5.0 V.
Table 9. Typical output supply current (ICCO)
VCCI
VCCO
Unit
0V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
0V
5
200
400
nA
0.8 V
1
10
150
200
300
500
800
nA
1.2 V
1
1
5
200
300
500
800
nA
1.5 V
1
1
5
100
300
500
800
nA
1.8 V
1
1
5
100
300
500
800
nA
2.5 V
1
1
5
100
100
500
800
nA
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
6 / 17
74AXP1T14
Nexperia
11 Dynamic characteristics
Table 10. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 11 ; for wave form see Figure 7.
Symbol Parameter Conditions
VCCO
1.2 V
Typ
[1]
Unit
1.5 V ± 0.1 V
Min
Typ
[1]
1.8 V ± 0.15 V
Max
Min
Typ
[1]
Max
Tamb = 25 °C
tpd
[2]
propagation A to Y
delay
23
3
18
73
3
16
69
ns
VCCI = 1.1 V to 1.3 V
16.9
3.1
10.8
20.1
2.8
8.7
16.1 ns
VCCI = 1.4 V to 1.6 V
16.0
2.8
9.9
18.5
2.5
7.8
13.5 ns
VCCI = 1.65 V to 1.95 V
15.6
2.7
9.5
17.7
2.4
7.3
12.2 ns
15.2
2.5
9.0
17.3
2.2
6.9
11.5 ns
23
3
18
148
3
16
145
16.9
3.1
10.8
20.1
2.8
8.7
16.1 ns
16.0
2.8
9.9
18.5
2.5
7.8
13.5 ns
15.6
2.7
9.5
17.7
2.4
7.3
12.2 ns
15.2
2.5
9.0
17.3
2.2
6.9
11.5 ns
1.0
1.0
tpd
[2]
propagation A to Y
delay
tt
[1]
[2]
[3]
transition
time
VCCI = 0.75 V to 2.7 V
[3]
ns
ns
Typical values are measured at nominal supply voltages and Tamb = +25 °C.
tpd is the same as tPLH and tPHL.
tt is the same as tTHL and tTLH.
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
7 / 17
74AXP1T14
Nexperia
Table 11. Dynamic characteristics
VCCO
2.5 V ± 0.2 V
Min
Unit
3.3 V ± 0.3 V
Typ Max Min
[1]
5.0 V ± 0.5 V
Typ Max Min
[1]
Typ Max
[1]
Tamb = 25 °C
tpd
propagation A to Y
delay
[2]
2
14
69
2
14
77
2
15
89
ns
2.4
6.9
11.1
2.2
6.3
9.8
2.1
6.0
9.3
ns
2.1
6.0
9.4
2.0
5.4
8.5
1.9
5.0
8.0
ns
2.0
5.6
9.0
1.8
4.9
8.0
1.8
4.6
7.6
ns
1.9
5.1
8.5
1.7
4.5
7.5
1.6
4.1
7.0
ns
2
14
164
2
14
191
2
15
222 ns
2.4
6.9
11.1
2.2
6.3
9.8
2.1
6.0
9.3
ns
2.1
6.0
9.4
2.0
5.4
8.5
1.9
5.0
8.0
ns
2.0
5.6
9.0
1.8
4.9
8.0
1.8
4.6
7.6
ns
1.9
5.1
8.5
1.7
4.5
7.5
1.6
4.1
7.0
ns
1.0
1.0
1.0
ns
tpd
[2]
propagation A to Y
delay
tt
transition
[3]
time
[1]
[2]
[3]
Typical values are measured at nominal supply voltages and tamb = +25 °C.
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
8 / 17
74AXP1T14
Nexperia
Table 12. Typical dynamic characteristics at Tamb = 25 °C
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 11; for wave form see Figure 7.
CPD
VCCO
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
VCCI = 0.8 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.2 V
0.6
0.6
0.6
0.6
0.6
0.6
pF
VCCI = 1.5 V
0.7
0.7
0.7
0.7
0.7
0.7
pF
VCCI = 1.8 V
0.8
0.8
0.8
0.8
0.8
0.8
pF
VCCI = 2.5 V
1.0
1.0
1.0
1.0
1.0
1.0
pF
VCCI = 0.8 V
6.7
6.8
6.8
6.9
7.5
9.5
pF
VCCI = 1.2 V
6.8
6.9
7.0
7.0
7.1
7.6
pF
VCCI = 1.5 V
6.9
6.9
6.9
7.0
7.1
7.6
pF
VCCI = 1.8 V
6.9
6.9
6.9
7.0
7.2
7.6
pF
VCCI = 2.5 V
6.9
7.0
7.0
7.0
7.2
7.6
pF
VI = 0 V or VCCI;
0.6
0.6
0.6
0.6
0.6
0.6
pF
1.8
1.8
1.8
1.8
1.8
1.8
pF
power
fi = 1 MHz; RL = ∞ Ω;
dissipation
VI = 0 V to VCCI
capacitance input supply
input
[1]
[2]
[3]
output supply
CI
Unit
capacitance VCCI = 0 V to 2.7 V
CO
output
VO = 0 V; VCCO = 0 V
capacitance
[1]
[2]
[3]
CPD is used to determine the dynamic power dissipation (PD in μW).
Power dissipated from input supply (VCCI)
2
PD = CPD × VCCI × fi × N where:
CPD = power dissipation capacitance of the input supply.
VCCI = input supply voltage in V;
fi = input frequency in MHz;
N = number of inputs switching;
Power dissipated from output supply (VCCO)
2
PD = (CL + CPD) × VCCO × fo where:
CL = load capacitance in pF;
CPD = power dissipation capacitance of the output supply.
VCCO = output supply voltage in V;
fo = output frequency in MHz;
11.1 Waveforms and graphs
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
9 / 17
74AXP1T14
Nexperia
VI
A input
VM
VM
GND
tPLH
VOH
Y output
90 %
tPHL
90 %
VM
VOL
VM
10 %
10 %
tTLH
tTHL
aaa-014793
Measurement points are given in Table 13 .
VOL and VOH are typical output voltage drops that occur with the output load.
Figure 7. Input A to output Y propagation delay times and output transition times
Table 13. Measurement points
Supply voltage
Output
Input
VCCI
VCCO
VM
VM
VI
0.75 V to 2.7 V
1.2 V to 5.5 V
0.5VCCO
0.5VCCI
VCCI
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
10 / 17
74AXP1T14
Nexperia
aaa-018538
6
tpd
(ns)
aaa-018539
6
(3)
tpd
(ns)
(3)
(2)
(2)
4
4
(1)
(1)
2
2
60
90
CL (pF)
60
90
CL (pF)
120
Tamb = -40 °C to +85 °C unless otherwise specified.
(1) Minimum: VCCO = 5.5 V
(1) Minimum: VCCO = 3.6 V
(2) Typical: Tamb = 25 °C; VCCO = 5 V
(2) Typical: Tamb = 25 °C; VCCO = 3.3 V
(3) Maximum: VCCO = 4.5 V
(3) Maximum: VCCO = 3 V
Figure 8. Additional propagation delay versus load capacitance
aaa-018540
(3)
8
aaa-018541
12
(3)
tpd
(ns)
tpd
(ns)
6
(2)
4
8
(2)
(1)
(1)
4
2
60
90
CL (pF)
60
90
CL (pF)
120
(1) Minimum: VCCO = 2.7 V
(2) Typical: Tamb = 25 °C; VCCO = 2.5 V
(3) Maximum: VCCO = 2.3 V
(1) Minimum: VCCO = 1.95 V
(2) Typical: Tamb = 25 °C; VCCO = 1.8 V
(3) Maximum: VCCO = 1.65 V
Figure 9. Additional propagation delay versus load capacitance
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
11 / 17
74AXP1T14
Nexperia
aaa-018542
18
aaa-018543
18
(3)
tpd
(ns)
tpd
(ns)
12
12
(2)
6
(1)
60
90
CL (pF)
60
90
CL (pF)
120
Tamb = 25 °C; VCCO = 1.2 V.
(1) Minimum: VCCO = 1.6 V
(2) Typical: Tamb = 25 °C; VCCO = 1.5 V
(3) Maximum: VCCO = 1.4 V
Figure 10. Additional propagation delay versus load capacitance
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
12 / 17
74AXP1T14
Nexperia
VI
negative
pulse
tW
90 %
10 %
0V
tf
tr
tr
tf
VI
positive
pulse
0V
VM
VM
90 %
VM
VM
10 %
tW
VCCI VCCO
PULSE
GENERATOR
VI
DUT
RT
VO
CL
RL
aaa-018544
Test data is given in Table 14.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = Load resistance.
Figure 11. Test circuit for measuring switching times
Table 14. Test data
Supply voltage
Load
Input
VCCI
VCCO
CL
RL
tr, tf
VI
0.75 V to 2.7 V
1.2 V to 5.5 V
5 pF
5 kΩ
≤3.0 ns
VCCI
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
13 / 17
74AXP1T14
Nexperia
12 Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Figure 12. Package outline SOT353-1 (TSSOP5)
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
14 / 17
74AXP1T14
Nexperia
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
D
A
B
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
v
w
b
1
2
terminal 1
index area
C
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.040 0.75 0.20 0.75 0.17
0.20 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Figure 13. Package outline SOT1226 (X2SON5)
74AXP1T14
Product data sheet
Rev. 2 — 9 May 2017
15 / 17
74AXP1T14
Nexperia
13 Abbreviations
Table 15. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14 Revision history
Table 16. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AXP1T14 v.2
20170509
Product data sheet
74AXP1T14 v.1
Modifications:
• Added type number 74AXP1T14GX (SOT1226/X2SON5).
74AXP1T14 v.1
20161121
74AXP1T14
Product data sheet
Product data sheet
Rev. 2 — 9 May 2017
16 / 17
74AXP1T14
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 3
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 4
Static characteristics .......................................... 4
Dynamic characteristics .....................................7
Waveforms and graphs ..................................... 9
Package outline .................................................14
Abbreviations .................................................... 16
Revision history ................................................ 16
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 9 May 2017
Document identifier: 74AXP1T14
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AXP1T14GWH 74AXP1T14GXH
很抱歉,暂时无法提供与“74AXP1T14GWH”相匹配的价格&库存,您可以联系我们找货
