NCR320Z / NCR321Z
250 mA LED driver in SOT223
Rev. 1 — 4 February 2019
Product data sheet
1. Product profile
1.1. General description
LED driver consisting of a resistor-equipped NPN transistor with two diodes on one chip in a
medium power SOT223 (SC-73) Surface-Mounted Device (SMD) plastic package.
Table 1. Product overview
Type number
Package
Nexperia
JEITA
NCR320Z
SOT223
SC-73
NCR321Z
SOT223
SC-73
1.2. Features and benefits
Stabilized output current of 10 mA without external resistor
Stabilized output current adjustable up to 250 mA when an external resistor is used
High current accuracy at supply voltage variation
Low voltage overhead of 1.4 V
Reduces component count and board space
High power dissipation of 1250 mW
Supply voltage up to 16 V
Digital PWM input up to 10 kHz frequency for NCR321Z
AEC-Q101 qualified
1.3. Applications
Constant current LED driver
Generic constant current source
Automotive applications (for example: interior lighting, dash board, instrumentation, number
plate light)
Increase stabilized output current by paralleling drivers
NCR320Z / NCR321Z
Nexperia
1.4. Quick reference data
Table 2. Quick reference data
Symbol
Parameter
Min
Typ
Max
Unit
NCR320Z
25
V
NCR321Z
4.5
V
Vout
output voltage
16
V
Iout
VEN
[1]
Conditions
enable voltage
NCR320Z
Vout= 1.4 V;
VEN= 12 V
[1] 9
10
11
mA
NCR321Z
Vout= 1.4 V;
VEN= 3.3 V
[1] 9
10
11
mA
Pulse test: tp ≤ 300 µs; δ ≤ 0.02
2. Pinning information
Table 3. Pinning
Pin
Symbol
Description
1
VEN
enable voltage
2
REXT
external resistor
3
GND
ground
4
IOUT
output current
Simplified outline
Symbol
IOUT
4
1
2
3
VEN
REXT
GND
aaa-029430
3. Ordering information
Table 4. Ordering information
Type number Package
Name
Description
Version
NCR320Z
SC-73
plastic surface-mounted package with
increased heatsink; 4 leads
SOT223
NCR321Z
SC-73
SOT223
4. Marking
NCR320Z_NCR321Z
Product data sheet
Table 5. Marking codes
Type number
Marking code
NCR320Z
CR320Z
NCR321Z
CR321Z
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 18
NCR320Z / NCR321Z
Nexperia
5. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Iout
stabilized output current if
300
mA
VEN
enable voltage
NCR320Z
25
V
NCR321Z
4.5
V
Vout
output voltage
16
V
VR
reverse voltage
[1] -
0.5
V
Ptot
total power dissipation
[2] -
765
mW
[3] -
1160
mW
[4] -
1250
mW
[5] -
1800
mW
Tamb ≤ 25 °C
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
[3]
[4]
[5]
Between all terminals.
Device mounted on an FR4 Printed-Circuit Board (PCB), single-side copper (70 µm), tin-plated and
standard footprint.
Device mounted on an FR4 Printed-Circuit Board (PCB), single-side copper (70 µm), tin-plated; mounting
2
pad for collector 1 cm .
Device mounted on an FR4 Printed-Circuit Board (PCB), 4-layer copper, tin-plated and standard footprint.
Device mounted on an FR4 Printed-Circuit Board (PCB), 4-layer copper, tin-plated; mounting pad for
2
collector 1 cm .
aaa.029431
2.0
Ptot
(W)
(1)
1.6
1.2
(2)
(3)
0.8 (4)
0.4
-25
25
75
125
175
Tamb (°C)
2
(1) FR4 PCB, 4-layer copper, 1 cm
(2) FR4 PCB, 4-layer copper, standard footprint
2
(3) FR4 PCB, single sided copper (70 µm), 1 cm
(4) FR4 PCB, single-sided copper (70 µm), standard footprint
Fig. 1.
NCR320Z_NCR321Z
Product data sheet
Power derating curve
3 / 18
NCR320Z / NCR321Z
Nexperia
6. Thermal characteristics
Table 7. Thermal characteristics
Symbol Parameter
Conditions
Rth(j-a)
in free air
Rth(j-sp)
[1]
[2]
[3]
[4]
thermal resistance from
junction to ambient
Min
Typ
Max
Unit
[1] -
164
K/W
[2] -
108
K/W
[3] -
100
K/W
[4] -
70
K/W
27
K/W
junction to solder point
Device mounted on an FR4 PCB, single-sided copper (70 µm), tin-plated and standard footprint.
Device mounted on an FR4 PCB, single-sided copper (70 µm), tin-plated; mounting pad
2
Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, 4-layer copper, tin-plated; mounting pad for collector 1 cm .
aaa-029432
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.50
0.33
0.20
0.10
10
0.05
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB; single-sided copper; tin-plated and standard footprint
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-029433
103
Zth(j-a)
(K/W)
102 duty cycle = 1
0.75
0.50
0.33
0.20
0.10
10
0.05
0.02
0.01
-5
10
10-4
10-3
10-2
10-1
1
FR4 PCB; single-sided copper, tin-plated; mounting pad for collector 1 cm
Fig. 3.
10
102
tp (s)
103
2
NCR320Z_NCR321Z
Product data sheet
4 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029434
103
Zth(j-a)
(K/W)
102 duty cycle = 1
0.75
0.50
0.33
0.20
0.10
10
0.05
0.02
0.01
-5
10
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB; 4-layer copper; tin-plated and standard footprint
Fig. 4.
aaa-029435
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.50
0.75
0.33
10
0.20
0.10
0.05
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
FR4 PCB; 4-layer copper, tin-plated; mounting pad for collector 1 cm
Fig. 5.
10
102
tp (s)
103
2
NCR320Z_NCR321Z
Product data sheet
5 / 18
NCR320Z / NCR321Z
Nexperia
7. Characteristics
Table 8. Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)CEO
collector-emitter
breakdown voltage
IC = 1 mA; IB = 0 A
16
V
hFE
DC current gain
VCE =1 V; IC = 50 mA
350
Rint
internal resistor
IRint = 10 mA
95
105
Ω
VRint
voltage drop at internal
resistor Rint
Iout = 10 mA
[1] 0.85
0.95
1.05
V
IEN
enable current
NCR320Z
VEN = 12 V
[1] -
1.2
mA
NCR321Z
VEN =3.3 V
[1] -
1.2
mA
NCR320Z
10
kΩ
NCR321Z
1.5
kΩ
RB
[1] 200
85
bias resistor
Iout
NCR320Z
VEN = 12 V; Vout = 1.4 V
[1] 9
10
11
mA
NCR321Z
VEN = 3.3 V; Vout = 1.4 V
[1] 9
10
11
mA
NCR320Z at Rext = 3 Ω
VEN = 12 V; Vout > 1.4 V
[1] -
250
mA
NCR321Z at Rext = 3 Ω
VEN = 3.3 V; Vout > 1.4 V
[1] -
250
mA
Vout, min
lowest sufficient output
voltage overhead:
Vout = VCC - VLED
Iout> 10 mA
1.4
V
ΔIout/(Iout x ΔTamb)
stabilized output current change over ambient temperature
Iout
ΔIout/(Iout x ΔVCC)
[1]
NCR320Z
VEN = 12 V; Vout > 2 V
[1] -
-0.27
%/K
NCR321Z
VEN = 3.3 V; Vout > 2 V
[1] -
-0.27
%/K
stabilized output current change over supply voltage
NCR320Z
[1] -
1
%/V
NCR321Z
[1] -
1
%/V
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
NCR320Z_NCR321Z
Product data sheet
6 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029390
0.3
aaa-029444
0.4
Iout
(A)
Iout
(A)
(1)
(2)
0.3
(1)
0.2
(2)
0.2
(3)
0.1
(4)
0.1
(5)
8
Vout (V)
VEN = 12 V; Tamb = 25 °C
(1) Rext = 3 Ω
(2) Rext = 4 Ω
(3) Rext = 6 Ω
(4) Rext = 10 Ω
(5) Rext = 20 Ω
(6) Rext = open
Fig. 6.
1
10
Rext
102
(1) Vout = 1.4 V
(2) Vout = 5.4 V
Fig. 7.
NCR320Z: Output current as a function of
external resistor; typical values
output voltage; typical values
aaa-029392
0.015
Iout
(A)
aaa-029393
0.07
Iout
(A)
0.06
(3)
(2)
(3)
0.05
0.010
(1)
(2)
0.04
(1)
0.03
0.005
0.02
0.01
8
Vout (V)
VEN = 12 V; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 8.
Product data sheet
4
8
Vout (V)
12
VEN = 12 V; Rext = 20 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
NCR320Z_NCR321Z
Fig. 9.
7 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029394
0.3
Iout
(A)
(3)
(2)
(1)
0.2
aaa-029395
0.015
Iout
(A)
(3)
0.010
(2)
(1)
0.1
8
Vout (V)
VEN = 12 V; Rext = 3 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
10
15
VEN (V)
Vout = 2 V; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 10. NCR320Z: Output current as a function of
aaa-029396
0.07
Iout
(A)
0.06
Fig. 11. NCR320Z: Output current as a function of
enable voltage; typical values
aaa-029397
0.3
(3)
Iout
(A)
(3)
(2)
(1)
0.05
(2)
(1)
0.2
0.04
0.03
0.1
0.02
0.01
10
15
VEN (V)
Vout = 2 V; Rext = 20 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Product data sheet
10
15
VEN (V)
Vout = 2 V; Rext = 3 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 12. NCR320Z: Output current as a function of
NCR320Z_NCR321Z
Fig. 13. NCR320Z: Output current as a function of
8 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029398
0.3
Iout
(A)
(1)
IEN
(mA)
(1)
0.2
aaa-029399
3
(2)
2
(2)
(3)
(3)
0.1
1
(4)
(5)
10
15
VEN (V)
Vout = 2 V; Tamb = 25 °C
(1) Rext = 3 Ω
(2) Rext = 4 Ω
(3) Rext = 6 Ω
(4) Rext = 10 Ω
(5) Rext = 20 Ω
(6) Rext = open
10
15
VEN (V)
Iout = 0 A; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 15. NCR320Z: Enable current as a function of
Fig. 14. NCR320Z: Output current as a function of
aaa-029400
0.3
Iout
(A)
Iout
(A)
(1)
0.2
aaa-029445
0.4
(2)
0.3
(1)
(2)
0.2
(3)
0.1
(4)
0.1
(5)
8
Vout (V)
12
VEN = 3.3 V; Tamb = 25 °C
(1) Rext = 3 Ω
(2) Rext = 4 Ω
(3) Rext = 6 Ω
(4) Rext = 10 Ω
(5) Rext = 20 Ω
(6) Rext = open
10
Rext
102
(1) Vout = 1.4 V
(2) Vout = 5.4 V
Fig. 17. NCR321Z: Output current as a function of
Fig. 16. NCR321Z: Output current as a function of
NCR320Z_NCR321Z
Product data sheet
9 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029402
0.015
Iout
(A)
aaa-029403
0.07
Iout
(A)
0.06
(3)
(2)
(1)
(3)
0.010
0.05
(2)
0.04
(1)
0.03
0.005
0.02
0.01
8
Vout (V)
VEN = 3.3 V; Rext = open
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
8
12
Vout (V)
VEN = 3.3 V; Rext = 20 Ω
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 18. NCR321Z: Output current as a function of
aaa-029404
0.3
(3)
(2)
Iout
(A)
(1)
0.2
Fig. 19. NCR321Z: Output current as a function of
aaa-029405
0.015
Iout
(A)
(3)
(2)
0.010
(1)
0.1
8
Vout (V)
12
VEN = 3.3 V; Rext = 3 Ω
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Product data sheet
2
3
4
VEN (V)
5
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 20. NCR321Z: Output current as a function of
NCR320Z_NCR321Z
Fig. 21. NCR321Z: Output current as a function of
10 / 18
NCR320Z / NCR321Z
Nexperia
aaa-029406
0.07
Iout
(A)
0.06
(3)
(2)
Iout
(A)
(3)
(2)
(1)
0.05
aaa-029407
0.3
(1)
0.2
0.04
0.03
0.1
0.02
0.01
2
3
4
VEN (V)
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
2
3
4
VEN (V)
5
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 22. NCR321Z: Output current as a function of
Fig. 23. NCR321Z: Output current as a function of
aaa-029408
0.3
Iout
(A)
aaa-029409
4
IEN
(mA)
(1)
(1)
3
(2)
(2)
0.2
(3)
2
(3)
0.1
(4)
1
(5)
4
VEN (V)
6
(1) Rext = 3 Ω
(2) Rext = 4 Ω
(3) Rext = 6 Ω
(4) Rext = 10 Ω
(5) Rext = 20 Ω
(6) Rext = open
4
VEN (V)
6
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 25. NCR321Z: Enable current as a function of
Fig. 24. NCR321Z: Output current as a function of
NCR320Z_NCR321Z
Product data sheet
11 / 18
NCR320Z / NCR321Z
Nexperia
8. Application information
Figure 26 shows a typical application circuit for an LED driver. The constant current ensures a
constant brightness in all LEDs. The output current can be adjusted between 10 mA and 250 mA
by connecting resistor Rext. Figures 7 and 17 give a first indication for choosing the external resitor
Rext. The minimum input voltage is given by voltage drop at the LED's VLED and the maximum is
governed by the maximum power dissipation
VLED + Vout, min < VCC < Ptot /Iout + VLED
VCC
IEN
VEN
Iout
IOUT
REXT
Rext
GND
aaa-029337
Fig. 26. LED driver application diagram
NCR321Z can be used for PWM dimming or on/off function by driving the VEN pin. The enable
voltage depends on the drive current, see Figure 23. Figure 27 shows a typical application
where VEN is driven via a micro directly. To control more than one NCR321Z devices by one
microcontroller output, a shift register (for example 74AHC(T)594PW) can be used.
VCC
µC /
Logic
IEN
VEN
Iout
IOUT
REXT
Rext
GND
aaa-029336
Fig. 27. Application diagram: PWM dimming function
NCR320Z_NCR321Z
Product data sheet
12 / 18
NCR320Z / NCR321Z
Nexperia
To savely drive currents that are above the limits of the NCR32xZ, two or more devices can be
parallel connected as illustrated in Figure 28. When choosing the same values for the external
resistors, the drive current splits equally and the capability of handling excess power is doubled.
Both, NCR320Z and NCR321Z can be used in this configuration.
VCC
IEN
VEN
Iout
IEN
IOUT
VEN
Iout
IOUT
REXT
REXT
Rext
GND
Rext
GND
aaa-029364
Fig. 28. Application diagram: Parallelization
NCR320Z_NCR321Z
Product data sheet
13 / 18
NCR320Z / NCR321Z
Nexperia
9. Package outline
Table 9. Package outline
Plastic surface-mounted package with increased heatsink; 4 leads
D
SOT223
E
B
A
X
c
y
HE
v M A
b1
4
Q
A
A1
1
2
e1
3
Lp
bp
w M B
detail X
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
b1
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.8
1.5
0.10
0.01
0.80
0.60
3.1
2.9
0.32
0.22
6.7
6.3
3.7
3.3
4.6
2.3
7.3
6.7
1.1
0.7
0.95
0.85
0.2
0.1
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT223
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-10
06-03-16
SC-73
Fig. 29. Package outline SC-73 (SOT223)
NCR320Z_NCR321Z
Product data sheet
14 / 18
NCR320Z / NCR321Z
Nexperia
10. Soldering
Table 10. Soldering
7
3.85
3.6
3.5
0.3
1.3 1.2
(4×) (4×)
solder lands
4
solder resist
3.9
6.1 7.65
solder paste
occupied area
1
2
3
Dimensions in mm
2.3
2.3
1.2
(3×)
1.3
(3×)
6.15
sot223_fr
Fig. 30. Reflow soldering footprint for SC-73 (SOT223)
8.9
6.7
1.9
solder lands
4
solder resist
6.2
1
2
8.7
Dimensions in mm
3
1.9
(3×)
2.7
occupied area
preferred transport
direction during soldering
2.7
1.1
1.9
(2×)
sot223_fw
Fig. 31. Wave soldering footprint for SC-73 (SOT223)
NCR320Z_NCR321Z
Product data sheet
15 / 18
NCR320Z / NCR321Z
Nexperia
11. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change
notice
Supersedes
NCR320Z_NCR321Z v.1
20190204
Product data sheet
NCR320Z_NCR321Z
Product data sheet
16 / 18
NCR320Z / NCR321Z
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
12. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
NCR320Z_NCR321Z
Product data sheet
17 / 18
NCR320Z / NCR321Z
Nexperia
Contents
1. Product profile.............................................................. 1
1.1. General description......................................................1
1.2. Features and benefits..................................................1
1.3. Applications................................................................. 1
1.4. Quick reference data................................................... 2
2. Pinning information......................................................2
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Limiting values............................................................. 3
6. Thermal characteristics............................................... 4
7. Characteristics.............................................................. 6
8. Application information............................................. 12
9. Package outline.......................................................... 14
10. Soldering................................................................... 15
11. Revision history........................................................ 16
12. Legal information......................................................17
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 February 2019
NCR320Z_NCR321Z
Product data sheet
18 / 18
