NCR420U / NCR421U
150 mA LED driver in SOT457
Rev. 1 — 10 December 2018
Product data sheet
1. Product profile
1.1. General description
LED driver consisting of resistor-equipped NPN transistor with two diodes on one chip in an
SOT457 (SC-74; TSOP6) plastic package.
Table 1. Product overview
Type number
Package
Nexperia
JEITA
NCR420U
SOT457
SC-74; TSOP6
NCR421U
SOT457
SC-74; TSOP6
1.2. Features and benefits
Stabilized output current of 10 mA without external resistor
Stabilized output current adjustable up to 150 mA when an external resistor is used
High current accuracy at supply voltage variation
Low voltage overhead of 1.4 V
Reduces component count and board space
High power dissipation of 750 mW
Supply voltage up to 40 V
Digital PWM input up to 10 kHz frequency for NCR421U
AEC-Q101 qualified
1.3. Applications
Constant current LED driver
Generic constant current source
Automotive applications (for example: interior lighting, dash board, instrumentation, number
plate light)
Increase stabilized output current by paralleling drivers
NCR420U / NCR421U
Nexperia
1.4. Quick reference data
Table 2. Quick reference data
Symbol
Parameter
Min
Typ
Max
Unit
NCR420U
40
V
NCR421U
4.5
V
Vout
output voltage
40
V
Iout
VEN
[1]
Conditions
enable voltage
NCR420U
Vout= 1.4 V;
VEN= 24 V
[1] 9
10
11
mA
NCR421U
Vout= 1.4 V;
VEN= 3.3 V
[1] 9
10
11
mA
Pulse test: tp ≤ 300 µs; δ ≤ 0.02
2. Pinning information
Table 3. Pinning
Pin
Symbol
Description
1
VEN
enable voltage
2
IOUT
output current
3
IOUT
output current
4
GND
ground
5
IOUT
output current
6
REXT
external resistor
Simplified outline
6
5
4
1
2
3
Symbol
REXT
IOUT
GND
VEN
IOUT
IOUT
SC-74; TSOP6
(SOT457)
aaa-029361
3. Ordering information
Table 4. Ordering information
Type
Package
number
Name
Description
Version
NCR420U
SC-74; TSOP6
plastic surface-mounted package; 6 leads
SOT457
NCR421U
SC-74; TSOP6
SOT457
4. Marking
NCR420U_NCR421U
Product data sheet
Table 5. Marking codes
Type number
Marking code
NCR420U
L6
NCR421U
L7
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 17
NCR420U / NCR421U
Nexperia
5. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Iout
stabilized output current if
200
mA
VEN
enable voltage
NCR420U
40
V
NCR421U
4.5
V
Vout
output voltage
40
V
VR
reverse voltage
[1] -
0.5
V
Ptot
total power dissipation
[2] -
475
mW
[3] -
650
mW
[4] -
750
mW
[5] -
1100
mW
Tamb ≤ 25 °C
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
[3]
[4]
[5]
Between all terminals.
Device mounted on an FR4 Printed-Circuit Board (PCB), single-side copper (35 µm), tin-plated and
standard footprint.
Device mounted on an FR4 Printed-Circuit Board (PCB), single-side copper (35 µm), tin-plated; mounting
2
pad for collector 1 cm .
Device mounted on an FR4 Printed-Circuit Board (PCB), 4-layer copper, tin-plated and standard footprint.
Device mounted on an FR4 Printed-Circuit Board (PCB), 4-layer copper, tin-plated; mounting pad for
2
collector 1 cm .
1.2
Ptot
(W)
aaa-029338
(1)
0.9
(2)
(3)
0.6
(4)
0.3
-25
25
75
125
175
Tamb (°C)
2
(1) FR4 PCB, 4-layer copper, 1 cm
(2) FR4 PCB, 4-layer copper, standard footprint
2
(3) FR4 PCB, single sided copper (35 µm), 1 cm
(4) FR4 PCB, single-sided copper (35 µm), standard footprint
Fig. 1.
NCR420U_NCR421U
Product data sheet
Power derating curve
3 / 17
NCR420U / NCR421U
Nexperia
6. Thermal characteristics
Table 7. Thermal characteristics
Symbol Parameter
Conditions
Rth(j-a)
in free air
Rth(j-sp)
[1]
[2]
[3]
[4]
thermal resistance from
junction to ambient
Min
Typ
Max
Unit
[1] -
265
K/W
[2] -
190
K/W
[3] -
165
K/W
[4] -
115
K/W
50
K/W
junction to solder point
Device mounted on an FR4 PCB, single-sided copper (35 µm), tin-plated and standard footprint.
Device mounted on an FR4 PCB, single-sided copper (35 µm), tin-plated; mounting pad
2
Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, 4-layer copper, tin-plated; mounting pad for collector 1 cm .
aaa-010054
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB; single-sided copper; tin-plated and standard footprint
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-010055
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.33
0.2
0.1
10
0.05
0.02
0.01
1
10-5
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB; 4-layer copper; tin-plated and standard footprint
Fig. 3.
NCR420U_NCR421U
Product data sheet
4 / 17
NCR420U / NCR421U
Nexperia
7. Characteristics
Table 8. Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)CEO
collector-emitter
breakdown voltage
IC = 1 mA; IB = 0 A
40
V
hFE
DC current gain
VCE =1 V; IC = 50 mA
350
Rint
internal resistor
IRint = 10 mA
95
105
Ω
VRint
voltage drop at internal
resistor Rint
Iout = 10 mA
[1] 0.85
0.95
1.05
V
IEN
enable current
NCR420U
VEN = 24 V
[1] -
1.2
mA
NCR421U
VEN =3.3 V
[1] -
1.2
mA
NCR420U
kΩ
NCR421U
1.5
kΩ
RB
85
bias resistor
Iout
Iout
NCR420U
VEN = 24 V; Vout = 1.4 V
[1] 9
10
11
mA
NCR421U
VEN = 3.3 V; Vout = 1.4 V
[1] 9
10
11
mA
NCR420U at Rext = 5.1 Ω VEN = 24 V; Vout > 2 V
[1] -
150
mA
NCR421U at Rext = 5.1 Ω VEN = 3.3 V; Vout > 2 V
[1] -
150
mA
1.4
V
Vout, min
lowest sufficient output
voltage overhead:
Vout = VCC - VLED
ΔIout/(Iout x ΔTamb)
stabilized output current change over ambient temperature
ΔIout/(Iout x ΔVCC)
[1]
[1] 200
Iout> 10 mA
NCR420U
[1] -
-0.27
%/K
NCR421U
[1] -
-0.27
%/K
stabilized output current change over supply voltage
NCR420U
[1] -
1
%/V
NCR421U
[1] -
1
%/V
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
NCR420U_NCR421U
Product data sheet
5 / 17
NCR420U / NCR421U
Nexperia
aaa-029339
0.20
aaa-029436
0.25
Iout
(A)
Iout
(A)
(2)
0.20
0.15
(1)
(1)
0.15
(2)
0.10
(3)
0.10
(4)
0.05
(5)
0.05
(6)
8
Vout (V)
1
10
Rext
102
VEN = 40 V; Tamb = 25 °C
(1) Vout = 1.4 V
(2) Vout = 5.4 V
(1) Rext = 6 Ω
(2) Rext = 8 Ω
(3) Rext = 10 Ω
(4) Rext = 15 Ω
(5) Rext = 30 Ω
(6) Rext = open
Fig. 4.
Fig. 5.
NCR420U: Output current as a function of
external resistor; typical values
output voltage; typical values
aaa-029341
0.015
Iout
(A)
(3)
(3)
(2)
(1)
0.05
(2)
0.010
aaa-029342
0.07
Iout
(A)
0.06
0.04
(1)
0.03
0.005
0.02
0.01
8
Vout (V)
VEN = 40 V; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 6.
Product data sheet
4
8
Vout (V)
12
VEN = 40 V; Rext = 20 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
NCR420U_NCR421U
Fig. 7.
6 / 17
NCR420U / NCR421U
Nexperia
aaa-029343
0.20
Iout
(A)
aaa-029344
0.015
Iout
(A)
0.15
(3)
(2)
(1)
(3)
0.010
(2)
(1)
0.10
0.005
0.05
8
Vout (V)
VEN = 40 V; Rext = 6 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 8.
aaa-029345
VEN (V)
30
Fig. 9.
enable voltage; typical values
aaa-029346
0.20
Iout
(A)
(3)
0.15
(2)
0.05
10
Vout = 2 V; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
0.07
Iout
(A)
0.06
(2)
(1)
(1)
0.04
0.10
0.03
0.02
0.05
0.01
VEN (V)
30
Vout = 2 V; Rext = 20 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Product data sheet
VEN (V)
30
Vout = 2 V; Rext = 6 Ω
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 10. NCR420U: Output current as a function of
NCR420U_NCR421U
Fig. 11. NCR420U: Output current as a function of
7 / 17
NCR420U / NCR421U
Nexperia
aaa-029347
0.15
(1)
Iout
(A)
IEN
(mA)
(2)
0.10
aaa-029348
3
2
(3)
(1)
(2)
(3)
0.05
1
(4)
(5)
(6)
VEN (V)
Vout = 2 V; Tamb = 25 °C
(1) Rext = 6 Ω
(2) Rext = 8 Ω
(3) Rext = 10 Ω
(4) Rext = 30 Ω
(5) Rext = 60 Ω
(6) Rext = open
VEN (V)
40
Iout = 0 A; Rext = open
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 13. NCR420U: Enable current as a function of
Fig. 12. NCR420U: Output current as a function of
aaa-029349
0.20
Iout
(A)
aaa-029437
0.20
(2)
Iout
(A)
0.15
(1)
0.15
(1)
(2)
0.10
0.10
(3)
(4)
0.05
(5)
(6)
8
Vout (V)
12
VEN = 3.3 V; Tamb = 25 °C
(1) Rext = 6 Ω
(2) Rext = 8 Ω
(3) Rext = 10 Ω
(4) Rext = 15 Ω
(5) Rext = 30 Ω
(6) Rext = open
10
Rext
102
(1) Vout = 1.4 V
(2) Vout = 5.4 V
Fig. 15. NCR421U: Output current as a function of
Fig. 14. NCR421U: Output current as a function of
NCR420U_NCR421U
Product data sheet
8 / 17
NCR420U / NCR421U
Nexperia
aaa-029351
0.015
Iout
(A)
(3)
0.010
(2)
aaa-029352
0.06
(3)
(2)
(1)
Iout
(A)
0.04
(1)
0.005
8
Vout (V)
VEN = 3.3 V; Rext = open
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
8
12
VEN = 3.3 V; Rext = 20 Ω
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 16. NCR421U: Output current as a function of
aaa-029353
0.20
Iout
(A)
Fig. 17. NCR421U: Output current as a function of
aaa-029354
0.015
Iout
(A)
0.15
Vout (V)
(3)
(2)
(1)
(3)
0.010
(2)
(1)
0.10
0.005
0.05
8
Vout (V)
12
VEN = 3.3 V; Rext = 6 Ω
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Product data sheet
2
3
4
VEN (V)
5
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 18. NCR421U: Output current as a function of
NCR420U_NCR421U
Fig. 19. NCR421U: Output current as a function of
9 / 17
NCR420U / NCR421U
Nexperia
aaa-029355
0.06
(3)
(2)
(1)
Iout
(A)
aaa-029356
0.20
Iout
(A)
0.15
(3)
(2)
(1)
0.04
0.10
0.02
0.05
2
3
4
VEN (V)
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
2
3
4
VEN (V)
5
(1) Rext = 85 °C
(2) Rext = 25 °C
(3) Rext = -40 °C
Fig. 20. NCR421U: Output current as a function of
Fig. 21. NCR421U: Output current as a function of
aaa-029357
0.15
(1)
Iout
(A)
aaa-029358
3
IEN
(mA)
(2)
0.10
(1)
2
(3)
(2)
(3)
0.05
1
(4)
(5)
(6)
2
3
4
VEN (V)
5
(1) Rext = 6 Ω
(2) Rext = 8 Ω
(3) Rext = 10 Ω
(4) Rext = 30 Ω
(5) Rext = 60 Ω
(6) Rext = open
2
3
4
VEN (V)
5
(1) Tamb = 85 °C
(2) Tamb = 25 °C
(3) Tamb = -40 °C
Fig. 23. NCR421U: Enable current as a function of
Fig. 22. NCR421U: Output current as a function of
NCR420U_NCR421U
Product data sheet
10 / 17
NCR420U / NCR421U
Nexperia
8. Application information
Figure 24 shows a typical application circuit for an LED driver. The constant current ensures a
constant brightness in all LEDs. The output current can be adjusted between 10 mA and 150 mA
by connecting resistor Rext. Figures 5 and 15 give a first indication for choosing the external resitor
Rext. The minimum input voltage is given by voltage drop at the LED's VLED and the maximum is
governed by the maximum power dissipation
VLED + Vout, min < VCC < Ptot /Iout + VLED
VCC
IEN
VEN
Iout
IOUT
REXT
Rext
GND
aaa-029337
Fig. 24. LED driver application diagram
NCR421U can be used for PWM dimming or on/off function by driving the VEN pin. The enable
voltage depends on the drive current, see Figure 21. Figure 25 shows a typical application
where VEN is driven via a micro directly. To control more than one NCR421U devices by one
microcontroller output, a shift register (for example 74AHC(T)594PW) can be used.
VCC
µC /
Logic
IEN
VEN
Iout
IOUT
REXT
Rext
GND
aaa-029336
Fig. 25. Application diagram: PWM dimming function
NCR420U_NCR421U
Product data sheet
11 / 17
NCR420U / NCR421U
Nexperia
To savely drive currents that are above the limits of the NCR42xU, two or more devices can be
parallel connected as illustrated in Figure 26. When choosing the same values for the external
resistors, the drive current splits equally and the capability of handling excess power is doubled.
Both, NCR420U and NCR421U can be used in this configuration.
VCC
IEN
VEN
Iout
IEN
IOUT
VEN
Iout
IOUT
REXT
REXT
Rext
GND
Rext
GND
aaa-029364
Fig. 26. Application diagram: Parallelization
NCR420U_NCR421U
Product data sheet
12 / 17
NCR420U / NCR421U
Nexperia
9. Package outline
Table 9. Package outline
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
SOT457
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig. 27. Package outline SC-74; TSOP6 (SOT457)
NCR420U_NCR421U
Product data sheet
13 / 17
NCR420U / NCR421U
Nexperia
10. Soldering
Table 10. Soldering
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
sot457_fr
Fig. 28. Reflow soldering footprint for SC-74; TSOP6 (SOT457)
5.3
1.5
(4×)
solder lands
1.475
0.45
(2×)
5.05
1.475
solder resist
occupied area
Dimensions in mm
preferred transport
direction during soldering
1.45
(6×)
2.85
sot457_fw
Fig. 29. Wave soldering footprint for SC-74; TSOP6 (SOT457)
NCR420U_NCR421U
Product data sheet
14 / 17
NCR420U / NCR421U
Nexperia
11. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change
notice
Supersedes
NCR420U_NCR421U v.1
20181210
Product data sheet
NCR420U_NCR421U
Product data sheet
15 / 17
NCR420U / NCR421U
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
12. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
NCR420U_NCR421U
Product data sheet
16 / 17
NCR420U / NCR421U
Nexperia
Contents
1. Product profile.............................................................. 1
1.1. General description......................................................1
1.2. Features and benefits..................................................1
1.3. Applications................................................................. 1
1.4. Quick reference data................................................... 2
2. Pinning information......................................................2
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Limiting values............................................................. 3
6. Thermal characteristics............................................... 4
7. Characteristics.............................................................. 5
8. Application information............................................. 11
9. Package outline.......................................................... 13
10. Soldering................................................................... 14
11. Revision history........................................................ 15
12. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 December 2018
NCR420U_NCR421U
Product data sheet
17 / 17
