PESD2ETH-D
Ultra low capacitance double rail-to-rail ESD protection diode
14 December 2017
Product data sheet
1. General description
Ultra low capacitance double rail-to-rail ElectroStatic Discharge (ESD) protection diode in a small
SOT457 Surface-Mounted Device (SMD) plastic package. The device is designed to protect two
high-speed data lines or high-frequency signal lines from the damage caused by ESD and other
transients. The device integrates two ultra low capacitance rail-to-rail diodes and one additional
ESD protection diode to ensure signal line protection even if no supply voltage is available.
2. Features and benefits
ESD protection of two high-speed data lines
Ultra low capacitance: CD = 1.3 pF
ISO 10605 (330 pF, 2 kΩ) up to 15 kV
ESD protection up to 8 kV
AEC-Q101 qualified
3. Applications
100BASE-T1 / OPEN Allicance BroadR-Reach automotive Ethernet
Low-Voltage Differential Signaling (LVDS) automotive
USB 2.0 automotive
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5.5
V
diode capacitance
f = 1 MHz; VR = 0 V; Tamb = 25 °C
[1]
16
pF
diode capacitance
[2]
1.3
1.5
pF
Zener diode
Cd
Per channel
Cd
[1]
[2]
Measured from pin 5 to ground.
Measured from pin 4 or 6 to ground.
PESD2ETH-D
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
I/O 1
input/output 1
2
GND
ground
3
I/O 2
input/output 2
4
I/O 2
input/output 2
5
VCC
supply voltage
6
I/O 1
input/output 1
Simplified outline
6
1
5
2
Graphic symbol
4
3
TSOP6 (SOT457)
1
6
2
5
3
4
006aab349
6. Ordering information
Table 3. Ordering information
Type number
PESD2ETH-D
Package
Name
Description
Version
TSOP6
plastic, surface-mounted package (SC-74)
SOT457
7. Marking
Table 4. Marking codes
Type number
Marking code
PESD2ETH-D
L8
PESD2ETH-D
Product data sheet
All information provided in this document is subject to legal disclaimers.
14 December 2017
Nexperia B.V. 2017. All rights reserved
2 / 12
PESD2ETH-D
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
IPPM
rated peak pulse current
tp = 8/20 µs
2.5
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
VESD
electrostatic discharge
voltage
8
kV
10
kV
[1]
[2]
[3]
[1]
IEC 61000-4-2; contact discharge
[2] [3]
MIL-STD-883 (human body model)
Measured from pin 1,3,4 or 6 to GND.
According to IEC61000-4-5.
Device stressed with ten non-repetitive ESD pulses.
001aaa631
001aaa630
120
IPP
100 %
100 % IPP; 8 µs
IPP
80
90 %
e-t
50 % IPP; 20 µs
40
10 %
t (µs)
t
tr = 0.6 ns to 1 ns
40
30 ns
60 ns
Fig. 1.
8/20 µs pulse waveform according to
IEC 61000-4-5
PESD2ETH-D
Product data sheet
Fig. 2.
ESD pulse waveform according to
IEC 61000-4-2
14 December 2017
3 / 12
PESD2ETH-D
Nexperia
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5.5
V
VF
forward voltage
IF = 1 mA; Tamb = 25 °C
0.7
V
IRM
reverse leakage
current
VR = 5.5 V; Tamb = 25 °C
[1]
1
100
nA
VCL
clamping voltage
IPPM = 2.5 A; 8/20 µs; Tamb = 25 °C
[1]
11.8
V
Rdyn
dynamic resistance
IR = 10 A; Tamb = 25 °C
[1] [2]
1.1
Ω
VBR
breakdown voltage
IR = 1 mA; Tamb = 25 °C
[3]
6
9
V
Cd
diode capacitance
[3]
16
pF
diode capacitance
[4]
1.3
1.5
pF
Zener diode
Per channel
Cd
[1]
[2]
[3]
[4]
Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI / ESD STM5.5.1-2008.
aaa-027919
1.4
Cd
(pF)
1.2
aaa-027920
IPP
(A)
15
1.0
10
0.8
Rdyn = 1.1 Ω
0.6
5
0.4
Fig. 3.
2
3
4
VR (V)
Input/output to ground capacitance as a
function of reverse voltage
PESD2ETH-D
Product data sheet
-5
5
Fig. 4.
15
30
VCL (V)
Dynamic resistance with positive clamping;
typical values; Input/output to ground
14 December 2017
10
4 / 12
PESD2ETH-D
Nexperia
aaa-027921
5
IPP
(A)
Rdyn = 0.9 Ω
-10
-15
-20
-25
Fig. 5.
-20
-15
-10
-5
VCL (V)
Dynamic resistance with negative clamping; typical values; Input/output to ground
ESD TESTER
4 GHz DIGITAL
OSCILLOSCOPE
RG 223/U
50 Ω coax
Rd
40 dB
ATTENUATOR
Cs
50 Ω
DUT
(DEVICE
UNDER
TEST)
IEC 61000-4-2 ed.2
Cs = 150 pF; Rd = 330 Ω
10
2
V
(kV) 8
V
(kV) 0
6
-2
4
-4
2
-6
-2
-10
40
50
t (ns)
60
70
-10
-10
unclamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
40
50
t (ns)
60
70
unclamped -8 kV ESD pulse waveform
aaa-003952
Fig. 6.
ESD clamping test setup and waveforms
PESD2ETH-D
Product data sheet
14 December 2017
5 / 12
PESD2ETH-D
Nexperia
aaa-027922
250
VCL
(V)
200
150
50
VCL at 30 ns = -4.0 V
100
VCL at 30 ns = 16.2 V
50
-50
-50
-150
-100
-150
-10
Fig. 7.
aaa-027923
150
VCL
(V)
100
40
50
-200
-10
60
70
t (ns)
Clamped +8kV pulse waveform (IEC61000-4-2
network)
Fig. 8.
40
50
60
70
t (ns)
Clamped -8kV pulse waveform (IEC61000-4-2
network)
10. Application information
connector
TDN
100BASE-T1
BroadR-Reach PHY
common
mode choke
TJA1100
TDP
PESD2ETH-(A)D
aaa-027932
Fig. 9.
Application diagram: BroadR-Reach PHY / 100BASE-T1
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge
transients. The following guidelines are recommended:
1.
2.
3.
4.
5.
6.
7.
8.
PESD2ETH-D
Product data sheet
Place the device as close to the input terminal or connector as possible.
Minimize the path length between the device and the protected line.
Keep parallel signal paths to a minimum.
Avoid running protected conductors in parallel with unprotected conductors.
Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops.
Minimize the length of the transient return path to ground.
Avoid using shared transient return paths to a common ground point.
Use ground planes whenever possible. For multilayer PCBs, use ground vias.
14 December 2017
6 / 12
PESD2ETH-D
Nexperia
11. Test information
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
PESD2ETH-D
Product data sheet
14 December 2017
7 / 12
PESD2ETH-D
Nexperia
12. Package outline
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
mm
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig. 10. Package outline TSOP6 (SOT457)
PESD2ETH-D
Product data sheet
14 December 2017
8 / 12
PESD2ETH-D
Nexperia
13. Soldering
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
sot457_fr
Fig. 11. Reflow soldering footprint for TSOP6 (SOT457)
5.3
1.5
(4×)
solder lands
1.475
0.45
(2×)
5.05
1.475
solder resist
occupied area
Dimensions in mm
preferred transport
direction during soldering
1.45
(6×)
2.85
sot457_fw
Fig. 12. Wave soldering footprint for TSOP6 (SOT457)
PESD2ETH-D
Product data sheet
14 December 2017
9 / 12
PESD2ETH-D
Nexperia
14. Revision history
Table 7. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PESD2ETH-D v.1
20171214
Product data sheet
PESD2ETH-D
Product data sheet
14 December 2017
10 / 12
PESD2ETH-D
Nexperia
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
15. Legal information
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to the accuracy
or completeness of information included herein and shall have no liability for
the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’ aggregate and cumulative liability towards customer
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PESD2ETH-D
Product data sheet
Trademarks
14 December 2017
11 / 12
PESD2ETH-D
Nexperia
16. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Characteristics..............................................................4
10. Application information............................................. 6
11. Test information......................................................... 7
12. Package outline.......................................................... 8
13. Soldering..................................................................... 9
14. Revision history........................................................10
15. Legal information..................................................... 11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 December 2017
PESD2ETH-D
Product data sheet
14 December 2017
12 / 12
