74HC05
Hex inverter with open-drain outputs
Rev. 02 — 18 June 2009
Product data sheet
1. General description
The 74HC05 is a high-speed Si-gate CMOS device that complies with JEDEC standard
no. 7A.
The 74HC05 contains six inverters.The outputs of the 74HC05 are open-drain and can be
connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH
wired-AND functions. The open-drain outputs require pull-up resistors to perform correctly.
2. Features
n Wide operating voltage 2.0 V to 6.0 V
n Input levels:
u For 74HC05: CMOS level
n Latch-up performance exceeds 100 mA per JESD 78 Class II level A
n ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u CDM JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74HC05D
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
74HC05PW
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HC05BQ
−40 °C to +125 °C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74HC05
Nexperia
4. Functional diagram
1
1A
1Y 2
3
2A
2Y 4
5
3A
3Y 6
9
4A
4Y 8
11
5A
5Y 10
13
6A
6Y 12
VCC
Y
A
GND
mna525
Fig 1.
001aaj979
Logic symbol
Fig 2.
Logic diagram (one gate)
5. Pinning information
5.1 Pinning
74HC05
1A
1
14 VCC
1Y
2
13 6A
2A
3
12 6Y
2Y
4
11 5A
3A
5
10 5Y
3Y
6
GND
7
9
4A
8
4Y
001aaj980
Fig 3.
Pin configuration SOT108-1 (SO14)
74HC05_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
74HC05
Nexperia
1
1A
terminal 1
index area
74HC05
2
13 6A
2A
3
12 6Y
2Y
4
5
6
11 5A
2A
3
12 6Y
3A
2Y
4
11 5A
3Y
3A
5
10 5Y
8
1Y
13 6A
3Y
6
9
4A
4Y
14 VCC
2
7
1
1Y
GND
7
8
4Y
GND
1A
14 VCC
74HC05
GND(1)
10 5Y
9
4A
001aak277
Transparent top view
001aak276
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 4.
Pin configuration SOT402-1 (TSSOP14)
Fig 5.
Pin configuration SOT762-1 (DHVQFN14)
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 6A
1, 3, 5, 9, 11, 13
data input
1Y to 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nY
L
Z
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
−0.5
+7
V
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
mA
[1]
−0.5
VCC + 0.5 V V
VO
output voltage
74HC05_2
Product data sheet
3 of 13
74HC05
Nexperia
Table 4.
Limiting values …continued
Symbol
Parameter
Conditions
Min
Max
Unit
IO
output current
VO < VCC + 0.5 V
25
mA
ICC
supply current
50
mA
IGND
ground current
−50
mA
Tstg
storage temperature
−65
+150
°C
500
mW
[2]
total power dissipation
Ptot
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 °C.
For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 °C.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
Conditions
Min
Typ
Max
Unit
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
Min
VIH
VIL
VOL
HIGH-level
input voltage
−40 °C to +85 °C −40 °C to +125 °C Unit
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level
input voltage
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
LOW-level
output voltage
VI = VIH or VIL
IO = 20 µA; VCC = 2.0 V
0.1
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
0.1
V
V
IO = 20 µA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
74HC05_2
Product data sheet
4 of 13
74HC05
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
IOZ
OFF-state
output current
per input pin; VI = VIL;
VO = VCC or GND;
other inputs at VCC or GND;
VCC = 6.0 V; IO = 0 A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
CI
input
capacitance
Typ
Max
0.1
Min
0.5
Max
1
Min
Max
µA
1
5.0
10
µA
2.0
µA
3.5
pF
10. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Max
(85 °C)
Max
(125 °C)
115
135
ns
VCC = 4.5 V
11
18
23
27
ns
VCC = 6.0 V
10
15
ns
22
90
115
135
ns
VCC = 4.5 V
9
18
23
27
ns
VCC = 6.0 V
8
15
ns
VCC = 2.0 V
18
75
95
110
ns
VCC = 4.5 V
6
15
19
22
ns
5
13
16
19
ns
4
pF
LOW to OFF-state nA to nY; see Figure 6
propagation delay
VCC = 2.0 V
tPLZ
OFF-state to LOW nA to nY; see Figure 6
propagation delay
VCC = 2.0 V
tPZL
HIGH to LOW
output transition
time
tTHL
see Figure 6
VCC = 6.0 V
power dissipation
capacitance
CPD
[1]
per inverter; VI = GND to VCC;
VCC = 5.0 V
[1]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(0.5 × CL × VO2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
VO = output voltage in V (output HIGH);
VCC = supply voltage in V;
N = number of inputs switching;
RL = load resistance in MΩ;
CL = load capacitance in pF;
74HC05_2
Product data sheet
5 of 13
74HC05
Nexperia
11. Waveforms
VI
nA input
VM
GND
tPLZ
tPZL
VCC
90 %
nY output
VM
VOL
10 %
VX
tTHL
001aaj981
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Table 8.
The input nA to output nY propagation delays and output transition times
Measurement points
Input
Output
VM
VM
VX
0.5VCC
0.5VCC
0.1VCC
74HC05_2
Product data sheet
6 of 13
74HC05
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
RT
S1
open
DUT
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = Load resistance.
Fig 7.
Table 9.
Test circuit for measuring switching times
Test data
Input
Load
S1 position
VI
tr, tf
CL
RL
tPZL, tPLZ
VCC
6 ns
50 pF
1 kΩ
VCC
74HC05_2
Product data sheet
7 of 13
74HC05
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74HC05_2
Product data sheet
8 of 13
74HC05
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 9. Package outline SOT402-1 (TSSOP14)
74HC05_2
Product data sheet
9 of 13
74HC05
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 10. Package outline SOT762-1 (DHVQFN14)
74HC05_2
Product data sheet
10 of 13
74HC05
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC05_2
20090618
Product data sheet
74HC05_1
Modifications:
74HC05_1
Added type numbers 74HC05PW (TSSOP14 package) and 74HC05BQ (DHVQFN14
package)
20090427
Product data sheet
74HC05_2
Product data sheet
11 of 13
74HC05
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC05_2
Product data sheet
12 of 13
Nexperia
74HC05
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Date of release: 18 June 2009
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC05BQ,115 74HC05D,112 74HC05PW,118 74HC05PW,112 74HC05D,118
