HEF4030B-Q100
Quad 2-input EXCLUSIVE-OR gate
Rev. 1 — 13 November 2013
Product data sheet
1. General description
The HEF4030B-Q100 is a quad 2-input EXCLUSIVE-OR gate. The outputs are fully
buffered for the highest noise immunity and pattern insensitivity to output impedance.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
MIL-STD-833, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Complies with JEDEC standard JESD 13-B
3. Ordering information
Table 1.
All types operate from 40 C to +125 C
Type number
HEF4030BT-Q100
Package
Name
Description
Version
SO14
plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
HEF4030B-Q100
Nexperia
4. Functional diagram
A
Y
B
DDD
Fig 1.
Functional diagram
Fig 2.
mna788
Logic diagram (one gate)
5. Pinning information
5.1 Pinning
+()%4
9''
966
DDD
Fig 3.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A
1, 5, 8, 12
data input
1B, 2B, 3B, 4B
2, 6, 9, 13
data input
1Y, 2Y, 3Y, 4Y
3, 4, 10, 11
data output
VSS
7
ground (0 V)
VDD
14
supply voltage
HEF4030B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 11
HEF4030B-Q100
Nexperia
6. Functional description
Table 3.
Functional table[1]
Input
Output
nA
nB
nY
L
L
L
L
H
H
H
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
Min
0.5
+18
V
VI < 0.5 V or VI > VDD + 0.5 V
10
mA
0.5
VO < 0.5 V or VO > VDD + 0.5 V
Max
VDD + 0.5
Unit
V
10
mA
II/O
input/output current
10
mA
IDD
supply current
50
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+125
C
Ptot
total power dissipation
Tamb = 40 C to + 125 C
[1]
SO14
P
[1]
power dissipation
per output
500
mW
100
mW
For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VDD
supply voltage
Conditions
Min
Typ
Max
Unit
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+125
C
t/V
input transition rise and fall rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
HEF4030B_Q100
Product data sheet
3 of 11
HEF4030B-Q100
Nexperia
9. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD; unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level
input voltage
LOW-level
input voltage
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
0.05
V
VO = 2.5 V
5V
1.7
1.4
1.1
1.1
mA
VO = 4.6 V
5V
0.64
0.5
0.36
0.36
mA
VO = 9.5 V
10 V
1.6
1.3
0.9
0.9
mA
VO = 13.5 V
15 V
4.2
3.4
2.4
2.4
mA
VO = 0.4 V
5V
0.64
0.5
0.36
0.36
mA
VO = 0.5 V
10 V
1.6
1.3
0.9
0.9
mA
VO = 1.5 V
15 V
4.2
3.4
2.4
2.4
mA
15 V
0.1
0.1
1.0
1.0
A
all valid input 5 V
combinations; 10 V
IO = 0 A
15 V
0.25
0.25
7.5
7.5
A
0.5
0.5
15.0
15.0
A
1.0
1.0
30.0
30.0
A
7.5
pF
IO < 1 A
IO < 1 A
LOW-level
output voltage
IO < 1 A
LOW-level
output current
input leakage
current
IDD
supply current
input
capacitance
HEF4030B_Q100
Product data sheet
Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit
Max
IO < 1 A
HIGH-level
output current
VDD
Min
HIGH-level
output voltage
II
CI
Conditions
4 of 11
HEF4030B-Q100
Nexperia
10. Dynamic characteristics
Table 7.
Tamb = 25 C; for waveforms see Figure 4; for test circuit, see Figure 5; unless otherwise specified.
Symbol Parameter
HIGH to LOW propagation delay
tPHL
LOW to HIGH propagation delay
tPLH
VDD
Min
Typ
Max
Unit
57 + 0.55 CL
5V
85
175
ns
24 + 0.23 CL
10 V
35
75
ns
22 + 0.16 CL
15 V
30
55
ns
47 + 0.55 CL
5V
75
150
ns
19 + 0.23 CL
10 V
30
65
ns
17 + 0.16 CL
15 V
25
50
ns
5V
60
120
ns
9 + 0.42 CL
10 V
30
60
ns
6 + 0.28 CL
15 V
ns
HIGH to LOW output transition time 10 + 1.00 CL
tTHL
LOW to HIGH output transition time 10 + 1.00 CL
tTLH
[1]
Extrapolation formula[1]
5V
60
120
ns
9 + 0.42 CL
10 V
30
60
ns
6 + 0.28 CL
15 V
ns
The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF).
Table 8.
Dynamic power dissipation
VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol Parameter
PD
dynamic power dissipation
VDD
Typical formula
Where
5V
PD = 1100 fi + (fo CL) VDD (W)
2
10 V PD = 4900 fi + (fo CL) VDD2 (W)
fi = input frequency in MHz;
fo = output frequency in MHz;
15 V PD = 14400 fi + (fo CL) VDD2 (W) CL = output load capacitance in pF;
(fo CL) = sum of the outputs;
VDD = supply voltage in V.
HEF4030B_Q100
Product data sheet
5 of 11
HEF4030B-Q100
Nexperia
11. Waveforms
WU
9,
WI
90
Q$Q%LQSXW
9
W3+/
92+
W3/+
90
Q
很抱歉,暂时无法提供与“HEF4030BT-Q100J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.90877
- 10+5.12568
- 100+3.83240
- 500+3.01371
- 1000+2.42046
- 2500+2.05265
- 5000+2.01705
- 国内价格
- 1+5.90877
- 10+5.12568
- 100+3.83240
- 500+3.01371
- 1000+2.42046
- 2500+2.05265
- 5000+2.01705
