74ALVCH16646
16-bit bus transceiver/register; 3-state
Rev. 3 — 11 September 2018
Product data sheet
1. General description
The 74ALVCH16646 consists of 16 non-inverting bus transceiver circuits with 3-state outputs,
D-type flip-flops and control circuitry arranged for multiplexed transmission of data directly from
the internal registers. Data on the ‘A’ or ‘B’ bus will be clocked in the internal registers, as the
appropriate clock (nCPAB or nCPBA) goes to a HIGH logic level. Output enable (nOE) and
direction (nDIR) inputs are provided to control the transceiver function. In the transceiver mode,
data present at the high-impedance port may be stored in either the ‘A’ or ‘B’ register, or in both.
The select source inputs (nSAB and nSBA) can multiplex stored and real-time (transparent mode)
data. The direction (nDIR) input determines which bus will receive data when nOE is active (LOW).
In the isolation mode (nOE = HIGH), ‘A’ data may be stored in the ‘B’ register and/or ‘B’ data may
be stored in the ‘A’ register.
When an output function is disabled, the input function is still enabled and may be used to store
and transmit data. Only one of the two buses, ‘A’ or ‘B’ may be driven at a time.
To ensure the high impedance state during power up or power down, nOE should be tied to VCC
through a pullup resistor; the minimum value of the resistor is determined by the current-sinking/
current-sourcing capability of the driver.
Active bus-hold circuitry is provided to hold unused or floating data inputs at a valid logic level.
2. Features and benefits
Wide supply voltage range of 2.3 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Current drive ±24 mA at VCC = 3.0 V.
MULTIBYTE flow-through standard pin-out architecture
Low inductance multiple VCC and GND pins for minimize noise and ground bounce
All data inputs have bushold
Output drive capability 50 Ω transmission lines at 85 °C
Complies with JEDEC standards:
• JESD8-5 (2.3 V to 2.7 V)
• JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
• HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V
• CDM JESD22-C101E exceeds 1000 V
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
74ALVCH16646DGG −40 °C to +85 °C
TSSOP56
Description
Version
plastic thin shrink small outline package; 56 leads; SOT364-1
body width 6.1 mm
74ALVCH16646
Nexperia
4. Functional diagram
1A0
1A1
1A2
1A3
1A4
1A5
1A6
1A7
1OE
1DIR
1SAB
1SBA
1CPAB
1CPBA
5
52
6
51
8
49
9
48
10
47
12
45
13
44
14
43
1B0
2A0
1B1
2A1
1B2
2A2
1B3
2A3
1B4
2A4
1B5
2A5
1B6
2A6
1B7
2A7
56
19
38
21
36
23
34
24
33
2B1
2B2
2B3
2B4
VCC
2B5
2B6
2B7
data input
to internal circuit
27
2CPAB
55
40
31
2SBA
2
17
2B0
26
2SAB
54
41
29
2DIR
3
42
16
28
2OE
1
15
30
2CPBA
001aad245
aaa-029016
Fig. 1.
Logic symbol
1OE
1DIR
1CPBA
1SBA
1CPAB
1SAB
1A0
56
1
55
54
2
3
5
Fig. 2.
G3
2OE
3EN1[BA]
2DIR
3EN2[AB]
C4
2CPBA
G5
2SBA
C6
2CPAB
G7
1
2SAB
≥1
5
6D
1A1
1A2
1A3
1A4
1A5
1A6
1A7
6
5
7
1
7
4D
52
1B0
1
≥1
2A0
29
28
30
31
27
26
15
G10
10EN8[BA]
10EN9[AB]
C11
G12
C13
G14
8
≥1
13D
2
51
8
49
9
48
10
47
12
45
13
44
14
43
1B1
2A1
1B2
2A2
1B3
2A3
1B4
2A4
1B5
2A5
1B6
2A6
1B7
2A7
Bus hold circuit
16
12
11D
42
2B0
12 1
14
1 14
≥1
9
41
17
40
19
38
21
36
23
34
24
33
2B1
2B2
2B3
2B4
2B5
2B6
2B7
aaa-029017
Fig. 3.
IEEE logic symbol
74ALVCH16646
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 17
74ALVCH16646
Nexperia
nOE
nDIR
nSBA
nCPBA
nSAB
nCPAB
VCC
S
Y D1
MUX
D2
nAn
Q D
FFn
CP
VCC
D Q
FFn
CP
S
D1 Y
MUX
D2
nBn
8 IDENTICAL CHANNELS
aaa-029018
Fig. 4.
Logic diagram (one section)
74ALVCH16646
Product data sheet
3 / 17
74ALVCH16646
Nexperia
5. Pinning information
5.1. Pinning
74ALVCH16646
1DIR
1
56 1OE
1CPAB
2
55 1CPBA
1SAB
3
54 1SBA
GND
4
53 GND
1A0
5
52 1B0
1A1
6
51 1B1
VCC
7
50 VCC
1A2
8
49 1B2
1A3
9
48 1B3
1A4 10
47 1B4
GND 11
46 GND
1A5 12
45 1B5
1A6 13
44 1B6
1A7 14
43 1B7
2A0 15
42 2B0
2A1 16
41 2B1
2A2 17
40 2B2
GND 18
39 GND
2A3 19
38 2B3
2A4 20
37 2B4
2A5 21
36 2B5
VCC 22
35 VCC
2A6 23
34 2B6
2A7 24
33 2B7
GND 25
32 GND
2SAB 26
31 2SBA
2CPAB 27
30 2CPBA
2DIR 28
29 2OE
aaa-029019
Fig. 5.
Pin configuration for TSSOP56 (SOT364-1)
74ALVCH16646
Product data sheet
4 / 17
74ALVCH16646
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7
5, 6, 8, 9, 10, 12, 13, 14
data input/output
2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7
15, 16, 17, 19, 20, 21, 23, 24
data input/output
1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7
52, 51, 49, 48, 47, 45, 44, 43
data output/input
2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7
42, 41, 40, 38, 37, 36, 34, 33
data output/input
1OE, 2OE
56, 29
output enable input (active-LOW)
1DIR, 2DIR
1, 28
direction control input
1SAB, 2SAB
3, 26
delect input A-to-B
1CPAB, 2CPAB
2, 27
clock input A-to-B
1SBA, 2SBA
54, 31
select input B-to-A
1CPBA, 2CPBA
55, 30
clock input B-to-A
GND
4, 11, 18, 25, 32, 39, 46, 53
ground (0 V)
VCC
7, 22, 35, 50
supply voltage
6. Functional description
Table 3. Function selection
H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH clock transition;
Operating mode
Inputs
Data I/O
nOE
nDIR
nCPAB
nCPBA
nSAB
nSBA
nAn
nBn
store A, B unspecified[1]
X
X
X
X
X
input
unspecified[1]
store B, A unspecified[1]
X
X
X
X
X
unspecified[1] input
store A and B data, isolation
H
X
X
X
input
input
hold storage
H
X
H or L
H or L
X
X
input
input
real-time B data to A bus
L
L
X
X
X
L
output
input
stored B data to A bus
L
L
X
H or L
X
H
output
input
real-time A data to B bus
L
H
X
X
L
X
input
output
stored A data to B bus
L
H
H or L
X
H
X
input
output
[1]
The data output functions may be enabled or disabled by various signals at the OE and DIR inputs. Data input functions are always
enabled, i.e., data at the bus inputs will be stored on every LOW-to-HIGH transition on the clock inputs.
74ALVCH16646
Product data sheet
5 / 17
74ALVCH16646
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
IIK
input clamping current
VI < 0 V
IOK
output clamping current
IO (sink/source)
output sink or source current
ICC
IGND
Min
Max
Unit
-0.5
+4.6
V
data inputs
[1]
-0.5
control inputs
[1]
-0.5
[1]
-0.5
VCC + 0.5 V
+4.6
V
VCC + 0.5 V
-50
mA
VO > VCC or VO < 0 V
±50
mA
VO = 0 V to VCC
±50
mA
supply current
100
mA
ground current
-100
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
600
mW
[1]
[2]
Tamb = −40 °C to +85 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP56 packages: above 55 °C derate linearly with 8 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
Min
Max
Unit
for maximum speed performance; 30 pF
output load
2.3
2.7
V
for maximum speed performance; 50 pF
output load
3.0
3.6
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
10
ns/V
74ALVCH16646
Product data sheet
6 / 17
74ALVCH16646
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Tamb = -40 °C to +85 °C
Symbol
Parameter
Conditions
Min
Typ[1]
Max
VIH
HIGH-level
input voltage
VCC = 2.3 V to 2.7 V
1.7
1.2
V
VCC = 2.7 V to 3.6 V
2.0
1.5
V
LOW-level
input voltage
1.2
0.7
V
1.5
0.8
V
HIGH-level
output voltage
VI = VIH or VIL
IO = -100 μA; VCC = 2.3 V to 3.6 V
VCC - 0.2
VCC
V
IO = -6 mA; VCC = 2.3 V
VCC - 0.3
VCC - 0.08
V
IO = -12 mA; VCC = 2.3 V
VCC - 0.6
VCC - 0.26
V
IO = -12 mA; VCC = 2.7 V
VCC - 0.5
VCC - 0.14
V
IO = -12 mA; VCC = 3.0 V
VCC - 0.6
VCC - 0.09
V
IO = -24 mA; VCC = 3.0 V
VCC - 1.0
VCC - 0.28
V
IO = 100 μA; VCC = 2.3 V to 3.6 V
GND
0.20
V
IO = 6 mA; VCC = 2.3 V
0.07
0.40
V
IO = 12 mA; VCC = 2.3 V
0.15
0.70
V
IO = 12 mA; VCC = 2.7 V
0.14
0.40
V
IO = 24 mA; VCC = 3.0 V
0.27
0.55
V
VIL
VOH
VOL
LOW-level
output voltage
Unit
VI = VIH or VIL
II
input
leakage current
VCC = 2.3 V to 3.6 V; VI = VCC or GND
0.1
5
μA
IOZ
OFF-state
output current
VCC = 2.7 V to 3.6 V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
μA
ICC
supply current
VCC = 2.3 V to 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
40
μA
ΔICC
additional
supply current
VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V;
IO = 0 A
150
750
μA
IBHL
bus hold LOW
current
VCC = 2.3 V; VI = 0.7 V
45
μA
VCC = 3.0 V; VI = 0.8 V
75
150
μA
bus hold HIGH
current
VCC = 2.3 V; VI = 1.7 V
-45
μA
VCC = 3.0 V; VI = 2.0 V
-75
-175
μA
IBHLO
bus hold LOW
overdrive current
VCC = 3.6 V
500
μA
IBHHO
bus hold HIGH
overdrive current
VCC = 3.6 V
-500
μA
CI
input capacitance
3.0
pF
IBHH
[1]
All typical values are measured at Tamb = 25 °C.
74ALVCH16646
Product data sheet
7 / 17
74ALVCH16646
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit, see Fig. 11.
Symbol Parameter
Conditions
tpd
nAn to nBn; nBn to nAn; see Fig. 6
propagation delay
Min
Typ [1]
Max
Unit
1.0
2.7
4.8
ns
VCC = 2.7 V
1.0
2.8
4.5
ns
1.0
2.6
3.9
ns
1.0
3.4
5.6
ns
VCC = 2.7 V
1.4
3.1
5.2
ns
1.4
2.9
4.5
ns
1.0
3.4
6.8
ns
VCC = 2.7 V
1.3
3.5
6.4
ns
1.3
3.1
5.3
ns
1.0
3.3
6.5
ns
VCC = 2.7 V
1.0
3.2
6.2
ns
1.0
2.3
5.1
ns
1.0
3.4
7.8
ns
VCC = 2.7 V
1.4
3.4
6.2
ns
1.4
3.0
5.1
ns
1.6
2.8
5.7
ns
VCC = 2.7 V
1.0
3.1
5.0
ns
1.0
2.9
4.7
ns
1.5
3.0
6.5
ns
VCC = 2.7 V
1.4
3.3
6.0
ns
1.4
2.5
5.3
ns
3.3
1.2
ns
VCC = 2.7 V
3.3
1.0
ns
3.3
0.7
ns
1.6
0.2
ns
VCC = 2.7 V
1.7
0.2
ns
1.4
0.3
ns
[2]
nCPAB to nBn; nCPBA to nAn; see Fig. 7
nSAB to nBn; nSBA to nAn; see Fig. 8
ten
enable time
nOE to nAn; nOE to nBn; see Fig. 10
nDIR to nAn; nDIR to nBn; see Fig. 10
tdis
disable time
tw
tsu
pulse width
set-up time
74ALVCH16646
Product data sheet
[3]
[3]
[4]
[4]
nCPAB HIGH or LOW; nCPBA HIGH or LOW;
see Fig. 7
nAn to nCPAB; nBn to nCPBA; see Fig. 9
8 / 17
74ALVCH16646
Nexperia
Symbol Parameter
Conditions
th
hold time
fmax
maximum frequency
Min
Typ [1]
Max
0.6
0.1
ns
VCC = 2.7 V
0.4
0.1
ns
0.7
0.2
ns
150
300
MHz
VCC = 2.7 V
150
320
MHz
150
320
MHz
output enabled
36
pF
output disabled
4
pF
nCPAB; nCPBA; see Fig. 7
CPD
[1]
[2]
[3]
[4]
[5]
power dissipation
capacitance
Unit
per channel; VI = GND to VCC
[5]
Typical values are measured at Tamb = 25 °C
Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V
Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V
tpd is the same as tPHL and tPLH.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N +∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
10.1. Waveforms and test circuit
VI
nAn, nBn input
VM
VM
tPHL
tPLH
GND
VOH
nBn, nAn output
VM
VOL
VM
aaa-027928
See Table 8 for measurement points.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 6.
Input (nAn, nBn) to output (nBn, nAn) propagation delays
74ALVCH16646
Product data sheet
9 / 17
74ALVCH16646
Nexperia
1/fmax
VI
nCPAB, nCPBA
input
VM
VM
VM
GND
tW
tPHL
tPLH
VOH
nBn, nAn output
VM
VM
VOL
aaa-029020
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Clock input (nCPAB; nCPBA) to data output (nBn; nAn) propagation delays,
clock pulse width (nCPAB; nCPBA) and maximum clock frequency (nCPAB; nCPBA)
VI
nSAB, nSBA input
VM
VM
tPHL
tPLH
GND
VOH
nBn, nAn output
VM
VM
VOL
aaa-029021
Fig. 8.
Select source inputs (nSAB; nSBA) to data output (nBn; nAn) propagation delays
VI
nAn, nBn input
VM
VM
VM
VM
GND
VI
tsu
th
VM
nCPBA, nCPAB input
GND
tsu
th
VM
aaa-029022
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 9.
Data set-up and hold times for nAn, nBn inputs to nCPAB and nCPBA inputs
74ALVCH16646
Product data sheet
10 / 17
74ALVCH16646
Nexperia
nOE, nDIR
input
nDIR
VI
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-029023
Fig. 10. 3-state enable and disable times.
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
2.3 V to 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74ALVCH16646
Product data sheet
11 / 17
74ALVCH16646
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 11. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74ALVCH16646
Product data sheet
Load
VEXT
12 / 17
74ALVCH16646
Nexperia
BUS B
BUS A
BUS B
BUS A
11. Application information
aaa-028366
aaa-028367
nOE
nDIR
nCPAB
nCPBA
nSAB
nSBA
nOE
nDIR
nCPAB
nCPBA
nSAB
nSBA
L
L
X
X
X
L
L
H
X
X
L
X
BUS A
BUS B
Fig. 13. Real time bus transfer bus A to bus B
BUS B
BUS A
Fig. 12. Real time bus transfer bus B to bus A
aaa-028368
aaa-028369
nOE
nDIR
nCPAB
nCPBA
nSAB
nSBA
X
X
X
X
X
nOE
X
X
X
X
X
L
H
X
X
X
L
Fig. 14. Storage from bus A, B or A and B
74ALVCH16646
Product data sheet
nDIR
nCPAB
nCPBA
nSAB
nSBA
L
X
H
H or L
H or L
X
H
X
H
X
Fig. 15. Transfer stored data to bus A or B
13 / 17
74ALVCH16646
Nexperia
12. Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 16. Package outline SOT364-1 (TSSOP56)
74ALVCH16646
Product data sheet
14 / 17
74ALVCH16646
Nexperia
13. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVCH16646 v.3
20180911
Product data sheet
74ALVCH16646 v.2
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74ALVCH16646 v.2
19980903
Product specification
74ALVCH16646 v.1
74ALVCH16646 v.1
19980903
74ALVCH16646
Product data sheet
15 / 17
74ALVCH16646
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVCH16646
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
16 / 17
74ALVCH16646
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 5
6. Functional description................................................. 5
7. Limiting values............................................................. 6
8. Recommended operating conditions..........................6
9. Static characteristics....................................................7
10. Dynamic characteristics............................................ 8
10.1. Waveforms and test circuit........................................ 9
11. Application information............................................13
12. Package outline........................................................ 14
13. Abbreviations............................................................ 15
14. Revision history........................................................15
15. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 September 2018
74ALVCH16646
Product data sheet
17 / 17
