74ALVCH16500DGGS
74ALVCH16500DGGS
    NEXPERIA(安世)
    TSSOP56_14.1X6.2MM
    标准收发器 18位通用总线收发器;3-state
74ALVCH16500DGGS 数据手册
74ALVCH16500 18-bit universal bus transceiver; 3-state Rev. 3 — 11 December 2017 1 Product data sheet General description The 74ALVCH16500 is a high-performance CMOS product. This device is an 18-bit universal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. Data flow in each direction is controlled by output enable (OEAB and OEBA), latch enable (LEAB and LEBA), and clock (CPAB and CPBA) inputs. For A-to-B data flow, the device operates in the transparent mode when LEAB is HIGH. When LEAB is LOW, the A data is latched if CPAB is held at a HIGH or LOW logic level. If LEAB is LOW, the A data is stored in the latch/flip-flop on the HIGH-to-LOW transition of CPAB. When OEAB is HIGH, the outputs are active. When OEAB is LOW, the outputs are in the high-impedance state. Data flow for B-to-A is similar to that of A-to-B but uses OEBA, LEBA and CPBA. The output enables are complimentary (OEAB is active HIGH, and OEBA is active LOW). To ensure the high impedance state during power up or power down, OEBA should be tied to VCC through a pullup resistor and OEAB should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sinking/current-sourcing capability of the driver. Active bus-hold circuitry is provided to hold unused or floating data inputs at a valid logic level. 2 Features and benefits • • • • • • • • CMOS low power consumption MultiByte flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimum noise and ground bounce Direct interface with TTL levels (2.7 V to 3.6 V) Bus hold on data inputs Output drive capability 50 Ω transmission lines at 85 °C Current drive ±24 mA at 3.0 V Complies with JEDEC standards: – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V – CDM JESD22-C101E exceeds 1000 V 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 3 Ordering information Table 1. Ordering information Type number Package Temperature range 74ALVCH16500DGG -40 °C to +85 °C 4 Name Description Version TSSOP56 plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 Functional diagram OEAB CPBA 1 55 2 LEAB OEBA 3 5 6 8 9 10 12 13 14 15 16 17 19 20 21 23 24 26 1 2 55 A0 B0 A1 B1 A2 B2 A3 B3 A4 B4 A5 B5 A6 B6 A7 B7 A8 B8 A9 B9 A10 B10 A11 B11 A12 B12 A13 B13 A14 B14 A15 B15 A16 B16 A17 B17 OEAB OEBA LEAB LEBA CPAB CPBA CPBA 54 LEBA 52 27 30 28 51 49 3 A0 48 47 A1 45 A2 44 A3 43 A4 42 A5 41 A6 40 A7 38 A8 37 A9 36 A10 34 A11 33 A12 31 A13 A14 27 A15 28 A16 30 A17 5 EN1 2C3 C3 G2 EN4 5C6 C6 G5 3D 1 1 4 1 6D 54 52 6 51 8 49 9 48 10 47 12 45 13 44 14 43 15 42 16 41 17 40 19 38 20 37 21 36 23 34 24 33 26 31 B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 B16 B17 aaa-027849 aaa-027848 Figure 1. Logic symbol Figure 2. IEC logic symbol VCC data input to internal circuit 001aal733 Figure 3. Bus hold circuit 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state OEAB CPBA LEBA CPAB LEAB OEBA An C1 C1 1D 1D C1 C1 1D 1D Bn 18 IDENTICAL CHANNELS to 17 other channels aaa-027850 Figure 4. Logic diagram (one section) 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 5 Pinning information 5.1 Pinning 74ALVCH16500 OEAB 1 56 GND LEAB 2 55 CPAB A0 3 54 B0 GND 4 53 GND A1 5 52 B1 A2 6 51 B2 VCC 7 A3 8 50 VCC 49 B3 A4 9 48 B4 A5 10 47 B5 GND 11 46 GND A6 12 45 B6 A7 13 44 B7 A8 14 43 B8 A9 15 42 B9 A10 16 41 B10 A11 17 40 B11 GND 18 39 GND A12 19 38 B12 A13 20 37 B13 A14 21 36 B14 VCC 22 A15 23 35 VCC 34 B15 A16 24 33 B16 GND 25 32 GND A17 26 31 B17 OEBA 27 30 CPBA LEBA 28 29 GND aaa-027851 Figure 5. Pin configuration for TSSOP56 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15, A16, A17 3, 5, 6, 8, 9, 10, 12, 13, 14, 15, 16, 17, 19, 20, 21, 23, 24, 26 data inputs/outputs B0, B1, B2, B3, B4, B5, B6, B7, B8, B9, B10, B11, B12, B13, B14, B15, B16, B17 54, 52, 51, 49, 48, 47, 45, 44, 43, 42, 41, 40, 38, 37, 36, 34, 33, 31 data outputs/inputs OEAB 1 A to B output enable input (active HIGH) OEBA 27 B to A output enable input (active LOW) LEAB, LEBA 2, 28 A to B / B to A latch enable inputs (active HIGH) CPBA, CPAB 30, 55 B to A / A to B clock inputs (active LOW) GND 4, 11, 18, 25, 29, 32, 39, 46, 53, 56 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6 Functional description Table 3. Function selection Operating mode [1] [2] Inputs Outputs OEAB LEAB CPAB An Bn Disabled L H X X Z Transparent H H X H H H H X L L H ↓ X h H H ↓ X l L H L ↓ h H H L ↓ l L H L H or L X H H L H or L X L Latch data & display Clock data & display Hold data & display [1] A-to-B data flow is shown; B-to-A flow is similar but uses OEBA, LEBA, and CPBA. [2] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the enable or clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the enable or clock transition; X = don’t care; ↓ = HIGH-to-LOW enable or clock transition; Z = high-impedance OFF-state. 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI Conditions input voltage Min Max Unit -0.5 +4.6 V data inputs [1] -0.5 control inputs [1] -0.5 [1] -0.5 VO output voltage IIK input clamping current VI < 0 V IOK output clamping current IO output current ICC VCC + 0.5 V +4.6 V VCC + 0.5 V -50 - mA VO > VCC or VO < 0 V - ±50 mA VO = 0 V to VCC - ±50 mA supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 600 mW Ptot total power dissipation Tamb = -40 °C to +85 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For TSSOP56 packages: above 55 °C derate linearly with 8 mW/K. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage for maximum speed performance at CL = 30 pF 2.3 2.7 V for maximum speed performance at CL = 50 pF 3.0 3.6 V VI input voltage 0 VCC V VO output voltage 0 VCC V Tamb ambient temperature in free air -40 +85 °C Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V - 20 ns/V VCC = 3.0 V to 3.6 V - 10 ns/V 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Parameter Conditions Min VIH HIGH-level input voltage VCC = 2.3 to 2.7 V 1.7 1.2 - V VCC = 2.7 to 3.6 V 2.0 1.5 - V LOW-level input voltage VCC = 2.3 to 2.7 V - 1.2 0.7 V VCC = 2.7 to 3.6 V - 1.5 0.8 V HIGH-level output voltage VI = VIH or VIL IO = -100 μA; VCC = 2.3 V to 3.6 V VCC - 0.2 VCC - V IO = -6 mA; VCC = 2.3 V VCC - 0.3 VCC - 0.08 - V IO = -12 mA; VCC = 2.3 V VCC - 0.6 VCC - 0.26 - V IO = -12 mA; VCC = 2.7 V VCC - 0.5 VCC - 0.14 - V IO = -12 mA; VCC = 3.0 V VCC - 0.6 VCC - 0.09 - V IO = -24 mA; VCC = 3.0 V VCC - 1.0 VCC - 0.28 - V IO = 100 μA; VCC = 2.3 V to 3.6 V - GND 0.20 V IO = 6 mA; VCC = 2.3 V - 0.07 0.40 V IO = 12 mA; VCC = 2.3 V - 0.15 0.70 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V - 0.1 5 μA VIL VOH VOL LOW-level output voltage Typ [1] Symbol Max Unit VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 2.3 V to 3.6 V IBHL bus hold LOW current VCC = 2.3 V; VI = 0.7 V 45 - - μA VCC = 3.0 V; VI = 0.8 V 75 150 - μA bus hold HIGH current VCC = 2.3 V; VI = 1.7 V -45 - - μA VCC = 3.0 V; VI = 2.0 V -75 -175 - μA IBHLO bus hold LOW overdrive current VCC = 3.6 V 500 - - μA IBHHO bus hold HIGH overdrive current VCC = 3.6 V -500 - - μA IOZ OFF-state output current VCC = 2.7 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 μA ICC supply current VCC = 2.3 to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 μA ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 2.3 V to 3.6 V - 150 750 μA CI input capacitance - 4.0 - pF CI/O input/output capacitance - 8.0 - pF IBHH [1] All typical values are measured at Tamb = 25 °C. 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 10. Symbol tpd Parameter propagation delay Conditions An to Bn; Bn to An; Figure 6 VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V enable time OEBA to An; Figure 8 VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V disable time OEBA to An; Figure 8 VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 ns - 3.1 4.7 ns 1.0 2.9 4.2 ns 1.0 3.6 6.2 ns - 3.4 5.5 ns 1.0 3.1 4.9 ns 1.0 3.7 6.6 ns - 3.8 6.6 ns 1.1 3.3 5.5 ns 1.0 3.1 6.2 ns - 3.3 6.2 ns 1.0 2.8 5.2 ns ns 1.0 2.7 5.7 ns - 2.7 5.4 ns 1.0 2.5 4.6 ns 1.0 2.8 5.4 ns - 3.3 4.6 ns 1.0 3.2 4.3 ns [2] VCC = 2.3 V to 2.7 V 74ALVCH16500 5.2 [2] VCC = 2.3 V to 2.7 V OEAB to Bn; Figure 8 3.1 [2] VCC = 2.3 V to 2.7 V tdis Unit [2] VCC = 2.3 V to 2.7 V OEAB to Bn; Figure 8 Max [2] VCC = 2.3 V to 2.7 V ten 1.0 [1] [2] VCC = 2.3 V to 2.7 V CPAB to Bn; CPBA to An; Figure 7 Typ [2] VCC = 2.3 V to 2.7 V LEAB to Bn; LEBA to An; Figure 7 Min ns 1.0 2.7 6.1 ns - 3.6 5.7 ns 1.5 3.2 5.0 ns © Nexperia B.V. 2017. All rights reserved. 8 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state Symbol Parameter Conditions tw pulse width LEAB HIGH; LEBA HIGH; Figure 7 [1] Min Typ Max Unit VCC = 2.3 V to 2.7 V 3.3 0.8 - ns VCC = 2.7 V 3.3 0.7 - ns VCC = 3.0 V to 3.6 V 3.3 0.9 - ns VCC = 2.3 V to 2.7 V 3.3 2.0 - ns VCC = 2.7 V 3.3 1.4 - ns VCC = 3.0 V to 3.6 V 3.3 1.1 - ns VCC = 2.3 V to 2.7 V 1.7 0.1 - ns VCC = 2.7 V 1.4 0.1 - ns VCC = 3.0 V to 3.6 V 1.3 0.2 - ns VCC = 2.3 V to 2.7 V 1.9 0.1 - ns VCC = 2.7 V 1.6 −0.2 - ns VCC = 3.0 V to 3.6 V 1.4 0.3 - ns VCC = 2.3 V to 2.7 V 1.7 0.2 - ns VCC = 2.7 V 1.6 0.3 - ns VCC = 3.0 V to 3.6 V 1.3 −0.1 - ns VCC = 2.3 V to 2.7 V 2.0 0.2 - ns VCC = 2.7 V 1.8 0.1 - ns VCC = 3.0 V to 3.6 V 1.5 0.1 - ns VCC = 2.3 V to 2.7 V 150 333 - MHz VCC = 2.7 V 150 333 - MHz 150 340 - MHz output enabled - 21 - pF output disabled - 3 - pF CPAB, CPBA HIGH or LOW; Figure 7 tsu set-up time An to CPAB; Bn to CPBA; Figure 9 An to LEAB; Bn to LEBA; Figure 9 th hold time An to CPAB; Bn to CPBA; Figure 9 An to LEAB; Bn to LEBA; Figure 9 fmax maximum frequency CPAB, CPBA; Figure 7 VCC = 3.0 V to 3.6 V CPD power dissipation capacitance per latch; VI = GND to VCC [3] [1] Typical values are measured at Tamb = 25 °C Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V [2] tpd is the same as tPHL and tPLH; ten is the same as tPZH and tPZL; tdis is the same as tPHZ and tPLZ. [3] CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 10.1 Waveforms and test circuit VI An, Bn input VM VM tPHL tPLH GND VOH Bn, An output VM VM VOL 001aal734 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. The input An, Bn to output Bn, An propagation delay times. CPBA, CPAB input 1/fmax VI VM LEBA, LEAB GND input VM VM tW tPHL tPLH VOH VM An, Bn output VM VOL aaa-027852 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. Latch enable input LEAB, LEBA and clock input CPAB, CPBA to output Bn, An propagation delay times; pulse width and fmax of CPAB and CPBA OEAB input VI VM OEBA input An, Bn output LOW-to-OFF OFF-to-LOW VM GND tPLZ tPZL VCC VM VX VOL tPHZ An, Bn output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-027853 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 8. 3-state enable and disable times. 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state An, Bn input VI VM GND tsu VI CPBA, CPAB, LEBA, LEAB input GND VM th VM tsu VM VM th VM aaa-027854 The shaded areas indicate when the input is permitted to change for predictable output performance. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 9. Data set-up and hold times for An, Bn inputs to LEAB, LEBA, CPAB and CPBA inputs. Table 8. Measurement points Supply voltage Input VCC VI VM VM VX VY 2.3 V to 2.7 V VCC 0.5 VCC 0.5 VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVCH16500 Product data sheet Output All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤2.5 ns 50 pF 500 Ω open 2 × VCC GND 74ALVCH16500 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 11 Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT364-1 (TSSOP56) 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16500 v.3 20171211 Product data sheet - 74ALVCH16500 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Figure 2: IEC logic symbol updated 74ALVCH16500 v.2 19980924 Product specification - 74ALVCH16500 v.1 74ALVCH16500 v.1 19980831 Product specification - - 74ALVCH16500 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVCH16500 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVCH16500 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 11 December 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 17 74ALVCH16500 Nexperia 18-bit universal bus transceiver; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 5 Functional description ........................................5 Limiting values .................................................... 6 Recommended operating conditions ................ 6 Static characteristics .......................................... 7 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 10 Package outline .................................................13 Abbreviations .................................................... 14 Revision history ................................................ 14 Legal information .............................................. 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 December 2017 Document identifier: 74ALVCH16500
74ALVCH16500DGGS 价格&库存
很抱歉,暂时无法提供与“74ALVCH16500DGGS”相匹配的价格&库存,您可以联系我们找货
