74AUP2G07GXZ
74AUP2G07GXZ
    NEXPERIA(安世)
    X1-DFN1010-6
    IC BUF NON-INVERT 3.6V 6X2SON
74AUP2G07GXZ 数据手册
74AUP2G07 Low-power dual buffer with open-drain output Rev. 8 — 17 September 2015 Product data sheet 1. General description The 74AUP2G07 provides two non-inverting buffers with open-drain output. The output of the device is an open drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static-power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP2G07 Nexperia Low-power dual buffer with open-drain output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP2G07GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP2G07GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP2G07GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP2G07GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP2G07GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AUP2G07GX 40 C to +125 C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1  0.8  0.35 mm SOT1255 4. Marking Table 2. Marking Type number Marking code[1] 74AUP2G07GW p7 74AUP2G07GM p7 74AUP2G07GF p7 74AUP2G07GN p7 74AUP2G07GS p7 74AUP2G07GX p7 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <   $ <  $   < < $   $ < *1' PQE Fig 1. Logic symbol 74AUP2G07 Product data sheet PQD PQE Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 Fig 3. Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved 2 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output 6. Pinning information 6.1 Pinning $83* $   < *1'   9&& $   < $83* $   < *1'   9&& $   < DDG 7UDQVSDUHQWWRSYLHZ DDG Fig 4. Pin configuration SOT363 Fig 5. Pin configuration SOT886 $83* $83* $  $   < *1'   9&& $   < *1' <    $ DDG  < DDD 7UDQVSDUHQWWRSYLHZ Fig 6. 9&&  7UDQVSDUHQWWRSYLHZ Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1255 (X2SON6) 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 74AUP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 3 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output 7. Functional description Table 4. Function table[1] Input Output nA nY L L H Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF state. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions VI < 0 V [1] VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC [1] Min Max Unit 0.5 +4.6 V 50 - 0.5 +4.6 50 - 0.5 +4.6 - 20 mA mA V mA V ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot [1] [2] Tamb = 40 C to +125 C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SC-88 package: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For X2SON6 and XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74AUP2G07 Product data sheet Conditions Active mode and Power-down mode VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 Min Max Unit 0.8 3.6 V 0 3.6 V 0 3.6 V 40 +125 C 0 200 ns/V © Nexperia B.V. 2017. All rights reserved 4 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.31 V Tamb = 25 C VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage VI = VIH or VIL 0.3  VCC V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.7 - pF CO output capacitance VO = GND; VCC = 0 V - 0.9 - pF VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V - V Tamb = 40 C to +85 C VIH VIL HIGH-level input voltage LOW-level input voltage 74AUP2G07 Product data sheet 2.0 - VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 5 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V 0.3  VCC V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A VCC = 0.8 V 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V - V Tamb = 40 C to +125 C VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage 2.0 - VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - VI = VIH or VIL 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOZ OFF-state output current VI = VIH; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A 74AUP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 6 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions Min Typ[1] 40 C to +125 C Max Min Max (85 C) Unit Max (125 C) CL = 5 pF tpd propagation delay nA to nY; see Figure 8 [2] - 11.6 - - - - ns VCC = 1.1 V to 1.3 V VCC = 0.8 V 2.1 4.1 7.5 1.7 9.1 10.0 ns VCC = 1.4 V to 1.6 V 1.6 3.0 5.1 1.3 6.1 6.7 ns VCC = 1.65 V to 1.95 V 1.6 2.7 4.0 1.2 5.0 5.5 ns VCC = 2.3 V to 2.7 V 1.1 2.1 3.2 0.9 4.0 4.4 ns VCC = 3.0 V to 3.6 V 1.4 2.2 2.8 1.1 3.3 3.6 ns CL = 10 pF tpd propagation delay nA to nY; see Figure 8 [2] - 14.7 - - - - ns VCC = 1.1 V to 1.3 V VCC = 0.8 V 3.0 5.1 9.0 2.4 11.2 12.3 ns VCC = 1.4 V to 1.6 V 2.3 3.8 6.1 2.0 7.4 8.1 ns VCC = 1.65 V to 1.95 V 2.4 3.6 4.8 1.8 6.1 6.7 ns VCC = 2.3 V to 2.7 V 1.7 2.8 3.8 1.3 4.8 5.3 ns VCC = 3.0 V to 3.6 V 2.2 3.1 4.2 1.6 4.5 5.0 ns CL = 15 pF tpd propagation delay nA to nY; see Figure 8 VCC = 0.8 V 74AUP2G07 Product data sheet [2] - 17.7 - - - - ns VCC = 1.1 V to 1.3 V 3.5 6.1 10.4 3.2 13.1 14.5 ns VCC = 1.4 V to 1.6 V 3.0 4.5 6.8 2.6 8.6 9.4 ns VCC = 1.65 V to 1.95 V 2.8 4.4 6.7 2.2 7.8 8.6 ns VCC = 2.3 V to 2.7 V 2.4 3.4 4.5 1.9 5.3 5.8 ns VCC = 3.0 V to 3.6 V 2.2 4.0 5.7 1.9 6.1 6.7 ns All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 7 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 26.7 - - - - ns VCC = 1.1 V to 1.3 V 4.8 9.0 15.6 4.3 18.8 20.7 ns CL = 30 pF propagation delay nA to nY; see Figure 8 tpd [2] VCC = 0.8 V VCC = 1.4 V to 1.6 V 4.1 6.7 9.4 3.7 11.8 13.0 ns VCC = 1.65 V to 1.95 V 3.8 6.8 9.7 3.2 11.0 12.1 ns VCC = 2.3 V to 2.7 V 3.7 5.2 6.7 3.0 7.1 7.8 ns VCC = 3.0 V to 3.6 V 3.6 6.4 9.7 2.8 10.4 11.4 ns VCC = 0.8 V - 0.5 - - - - pF VCC = 1.1 V to 1.3 V - 0.6 - - - - pF VCC = 1.4 V to 1.6 V - 0.6 - - - - pF VCC = 1.65 V to 1.95 V - 0.7 - - - - pF VCC = 2.3 V to 2.7 V - 0.9 - - - - pF VCC = 3.0 V to 3.6 V - 1.2 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [3][4] [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPZL and tPLZ. [3] All specified values are the average typical values over all stated loads. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N where: fi = input frequency in MHz; VCC = supply voltage in V; N = number of inputs switching. 74AUP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 8 of 19 74AUP2G07 Nexperia Low-power dual buffer with open-drain output 12. Waveforms 9, 90 Q$LQSXW 90 *1' W 3=/ W 3/= 9&& Q
74AUP2G07GXZ 价格&库存
很抱歉,暂时无法提供与“74AUP2G07GXZ”相匹配的价格&库存,您可以联系我们找货
