74AXP2G07GMH
74AXP2G07GMH
    NEXPERIA(安世)
    X2-DFN1409-6
    集成电路缓冲非转换2.75V XSON6_1X1.45MM
74AXP2G07GMH 数据手册
74AXP2G07 Low-power dual buffer with open-drain output Rev. 2 — 16 September 2015 Product data sheet 1. General description The 74AXP2G07 is a dual non-inverting buffer with open-drain outputs. Schmitt-trigger action at the inputs makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 0.7 pF (typical) Low dynamic power consumption; CPD = 1.0 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP2G07GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP2G07GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP2G07GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AXP2G07GX 40 C to +85 C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1  0.8  0.35 mm SOT1255 4. Marking Table 2. Marking codes Type number Marking code[1] 74AXP2G07GM r7 74AXP2G07GN r7 74AXP2G07GS r7 74AXP2G07GX r7 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <   $ <  $   < < $   $ < *1' PQE Fig 1. Logic symbol 74AXP2G07 Product data sheet PQE Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 September 2015 PQD Fig 3. Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved 2 of 17 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 6. Pinning information 6.1 Pinning $;3* $   $;3* < $  *1'   9&& *1' $   <  <   $ DDD  < DDD 7UDQVSDUHQWWRSYLHZ Fig 4. 9&&  7UDQVSDUHQWWRSYLHZ Pin configuration SOT886, SOT1115 and SOT1202 Fig 5. Pin configuration SOT1255 (X2SON6) 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input Output nA nY L L H Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF state. 74AXP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 September 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - 0.5 +3.3 50 - 0.5 +3.3 mA V mA VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C V The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74AXP2G07 Product data sheet Min Max Unit 0.7 2.75 V 0 2.75 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C 0 200 ns/V VCC = 0.7 V to 2.75 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 September 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min HIGH-level input voltage VIH LOW-level input voltage VIL LOW-level output voltage VOL Unit Typ 25 C Max 25 C Max 85 C VCC = 0.75 V to 0.85 V 0.75VCC - - - V VCC = 1.1 V to 1.95 V 0.65VCC - - - V VCC = 2.3 V to 2.7 V 1.6 - - - V VCC = 0.75 V to 0.85 V - - 0.25VCC 0.25VCC V VCC = 1.1 V to 1.95 V - - 0.35VCC 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 0.7 V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V - 0.001 0.1 0.5 A II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] IOZ OFF-state output current VI = VIL; VO = 0 V to 2.75 V [1] - 0.02 0.1 0.5 A IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off VI or VO = 0 V or 2.75 V; leakage current VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply current VI = VCC  0.5 V; IO = 0 A; VCC = 2.5 V - 2 100 150 A [1] Typical values are measured at VCC = 1.2 V. 74AXP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 September 2015 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 12. Symbol Parameter propagation delay tpd Tamb = 25 C Conditions Tamb = 40 C to +85 C Unit Min Typ[1] Max Min Max 3 11 31 2 82 ns VCC = 1.1 V to 1.3 V 2.2 4.8 7.3 2.0 7.6 ns VCC = 1.4 V to 1.6 V 1.8 3.6 5.1 1.6 5.4 ns VCC = 1.65 V to 1.95 V 1.5 3.4 5.1 1.3 5.5 ns VCC = 2.3 V to 2.7 V 1.2 2.6 3.7 1.1 3.9 ns - - - 0.9 - ns nA to nY; see Figure 6 [2][3] VCC = 0.75 V to 0.85 V VCC = 2.7 V; see Figure 6 [4] tt transition time CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance - 0.7 - - - pF CPD power dissipation fi = 1 MHz; VI = 0 V to VCC capacitance VCC = 0.75 V to 0.85 V VO = 0 V; VCC = 0 V [5] - 0.9 - - - pF VCC = 1.1 V to 1.3 V - 1.0 - - - pF VCC = 1.4 V to 1.6 V - 1.0 - - - pF VCC = 1.65 V to 1.95 V - 1.1 - - - pF VCC = 2.3 V to 2.7 V - 1.3 - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPZL and tPLZ. [3] For additional propagation delay (tPZL) values at different load capacitances, see Figure 7 to Figure 11. [4] tt is the same as tTZL. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching. 74AXP2G07 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 September 2015 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AXP2G07 Nexperia Low-power dual buffer with open-drain output 12. Waveforms 9, Q$LQSXW 90 *1' W3/= W3=/ 9&&  Q
74AXP2G07GMH 价格&库存
很抱歉,暂时无法提供与“74AXP2G07GMH”相匹配的价格&库存,您可以联系我们找货
