HEF4050B
Hex non-inverting buffers
Rev. 10 — 23 June 2016
Product data sheet
1. General description
The HEF4050B provides six non-inverting buffers with high current output capability
suitable for driving TTL or high capacitive loads. Since input voltages in excess of the
buffers’ supply voltage are permitted, the buffers may also be used to convert logic levels
of up to 15 V to standard TTL levels. Their guaranteed fan-out into common bipolar logic
elements is shown in Table 3.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Accepts input voltages in excess of the supply voltage
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C
Complies with JEDEC standard JESD 13-B
3. Applications
LOCMOS (Local Oxidation CMOS) to DTL/TTL converter
HIGH sink current for driving two TTL loads
HIGH-to-LOW level logic conversion
HEF4050B
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +85 C.
Type number
Package
HEF4050BT
Name
Description
Version
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
5. Functional diagram
LQSXW
DDH
Fig 1.
Logic symbol
HEF4050B
Product data sheet
966
DDH
DDH
Fig 2.
Logic diagram for one gate
All information provided in this document is subject to legal disclaimers.
Fig 3.
Input protection circuit
Nexperia B.V. 2017. All rights reserved
2 of 12
HEF4050B
Nexperia
6. Pinning information
6.1 Pinning
9''
QF
QF
966
DDH
Fig 4.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
VDD
1
supply voltage
1Y to 6Y
2, 4, 6, 10, 12, 15
output
1A to 6A
3, 5, 7, 9, 11, 14,
input
VSS
8
ground supply voltage
n.c.
13, 16
not connected
7. Functional description
Table 3.
Guaranteed fan-out
Driven element
Guaranteed fan-out
Standard TTL
2
74 LS
9
74 L
16
HEF4050B
Product data sheet
3 of 12
HEF4050B
Nexperia
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
input/output current
Conditions
VI < 0.5 V
VO < 0.5 V or VO > VDD + 0.5 V
Min
Max
Unit
0.5
+18
V
10
0.5
+18
V
10
mA
10
mA
mA
IDD
supply current
50
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
Ptot
total power dissipation
500
mW
100
mW
Tamb 40 C to +85 C
[1]
SO16 package
P
[1]
power dissipation
per output
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
VDD
VI
Conditions
Min
Max
Unit
supply voltage
3
15
V
input voltage
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
10. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol
VIH
VIL
Parameter
HIGH-level input voltage
LOW-level input voltage
HEF4050B
Product data sheet
Conditions
IO < 1 A
IO < 1 A
Tamb = 25 C
Tamb = 85 C
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
VDD
Tamb = 40 C
Unit
4 of 12
HEF4050B
Nexperia
Table 6.
Static characteristics …continued
Symbol
VOH
Parameter
Conditions
HIGH-level output voltage IO < 1 A
LOW-level output voltage
VOL
IOH
Tamb = 85 C
Unit
Max
Min
Max
Min
Max
4.95
4.95
4.95
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
V
15 V
0.05
0.05
0.05
V
5V
1.7
1.4
1.1
mA
VO = 4.6 V
5V
0.52
0.44
0.36 mA
VO = 9.5 V
10 V
1.3
1.1
0.9
II
input leakage current
IDD
supply current
mA
VO = 13.5 V
15 V
3.6
3.0
2.4
mA
VO = 0.4 V
4.75 V
3.5
2.9
2.3
mA
VO = 0.5 V
10 V
12.0
10.0
8.0
mA
VO = 1.5 V
15 V
24.0
20.0
16.0
mA
15 V
0.3
0.3
1.0
A
5V
4.0
4.0
30
A
10 V
8.0
8.0
60
A
15 V
16.0
16.0
120
A
7.5
pF
IO = 0 A
input capacitance
CI
Tamb = 25 C
Min
5V
IO < 1 A
Tamb = 40 C
HIGH-level output current VO = 2.5 V
LOW-level output current
IOL
VDD
11. Dynamic characteristics
Table 7.
VSS = 0 V; Tamb = 25 C; for test circuit see Figure 6; unless otherwise specified.
Symbol
tPHL
Parameter
Conditions
HIGH to LOW
propagation delay
nA to nY;
see Figure 5
LOW to HIGH
propagation delay
nA to nY;
see Figure 5
VDD
Extrapolation formula
Min
Typ
Max
26 ns + (0.18 ns/pF)CL
35
70
ns
16 ns + (0.08 ns/pF)CL
ns
12 ns + (0.05 ns/pF)CL
15
30
ns
28 ns + (0.55 ns/pF)CL
55
110
ns
14 ns + (0.23 ns/pF)CL
25
55
ns
12 ns + (0.16 ns/pF)CL
ns
7 ns + (0.35 ns/pF)CL
25
50
ns
3 ns + (0.14 ns/pF)CL
10
ns
2 ns + (0.09 ns/pF)CL
7
14
ns
10 ns + (1.00 ns/pF)CL
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
5V
[1]
10 V
15 V
tPLH
5V
[1]
10 V
15 V
HIGH to LOW
see Figure 5
output transition time
tTHL
5V
[1]
10 V
15 V
LOW to HIGH
see Figure 5
tTLH
[1]
5V
[1]
Unit
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
HEF4050B
Product data sheet
5 of 12
HEF4050B
Nexperia
Table 8.
Dynamic power dissipation PD
PD can be calculated from the formulas shown. VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol
PD
Parameter
dynamic power
dissipation
VDD
Typical formula for PD (W)
where:
5V
PD = 3800 fi + (fo CL) VDD
10 V
PD = 11600 fi + (fo CL) VDD2
fo = output frequency in MHz,
15 V
PD = 65900 fi + (fo CL)
CL = output load capacitance in pF,
2
fi = input frequency in MHz,
VDD2
VDD = supply voltage in V,
(fo CL) = sum of the outputs.
12. Waveforms
WU
9,
WI
LQSXW
90
9
W3/+
92+
W3+/
90
RXWSXW
92/
W7/+
W7+/
DDL
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 5.
Table 9.
Input to output propagation delays
Measurement points
Input
Output
VM
VI
VM
0.5VDD
0 V to VDD
0.5VDD
HEF4050B
Product data sheet
6 of 12
HEF4050B
Nexperia
9''
9,
92
'87
57
DDJ
Test data is given in Table 10.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 6.
Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Input
VDD
VI
VM
tr, tf
CL
5 V to 15 V
VDD
0.5VI
20 ns
50 pF
HEF4050B
Product data sheet
Load
7 of 12
HEF4050B
Nexperia
13. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
Z 0
ES
GHWDLO;
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
Fig 7.
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Package outline SOT109-1 (SO16)
HEF4050B
Product data sheet
8 of 12
HEF4050B
Nexperia
14. Abbreviations
Table 11.
Abbreviations
Acronym
Description
DTL
Diode Transistor Logic
DUT
Device Under Test
LOCMOS
TTL
Transistor-Transistor Logic
15. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
HEF4050B v.10
20160623
Product data sheet
HEF4050B v.9
Modifications:
HEF4050B v.9
Modifications:
HEF4050B v.8
Modifications:
Table 4: condition for input clamping current changed (typo corrected).
Table 5: maximum value for input voltage changed (typo corrected).
20160324
HEF4050B v.8
Type number HEF4050BP (SOT38-4) removed.
20111118
Product data sheet
Product data sheet
HEF4050B v.7
Table 6: IOH minimum values changed to maximum
Table 11: DUT added
HEF4050B v.7
20091201
Product data sheet
HEF4050B v.6
HEF4050B v.6
20090723
Product data sheet
HEF4050B v.5
HEF4050B v.5
20081111
Product data sheet
HEF4050B v.4
HEF4050B v.4
20080702
Product data sheet
HEF4050B_CNV v.3
HEF4050B_CNV v.3
19950101
Product specification
HEF4050B_CNV v.2
HEF4050B_CNV v.2
19950101
HEF4050B
Product data sheet
9 of 12
HEF4050B
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
HEF4050B
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
10 of 12
HEF4050B
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
HEF4050B
Product data sheet
11 of 12
Nexperia
HEF4050B
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 23 June 2016
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
HEF4050BP,652 HEF4050BT,652 HEF4050BT,653
