HEF4555B-Q100
1-of-4 decoder/demultiplexer
Rev. 2 — 15 October 2018
Product data sheet
1. General description
The HEF4555B-Q100 contains two 1-of-4 decoders/demultiplexers. Each has two address inputs
(nA0 and nA1, an active LOW enable input (nE) and four mutually exclusive outputs which are
active HIGH (nY0 to nY3). When used as a decoder, nE when HIGH, forces nY0 to nY3 LOW.
When used as a demultiplexer, the appropriate output is selected by the information on nA0 and
nA1 with nE as data input. All unselected outputs are LOW.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually
ground). Unused inputs must be connected to VDD, VSS, or another input.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
• Specified from -40 °C to +85 °C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Complies with JEDEC standard JESD 13-B
3. Applications
Code conversion
Address decoding
Demultiplexing: when using the enable input as data input
4. Ordering information
Table 1. Ordering information
All types operate from -40 °C to +85 °C.
Type number
HEF4555BT-Q100
Package
Name
Description
Version
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4555B-Q100
Nexperia
5. Functional diagram
1Y0 4
2 1A0
nY0
1Y1 5
DECODER
3 1A1
1Y2 6
nA0
1Y3 7
nY1
1 1E
2Y0 12
14 2A0
nA1
2Y1 11
DECODER
13 2A1
nY2
2Y2 10
2Y3 9
nE
15 2E
nY3
001aae751
Fig. 1.
001aae753
Functional diagram
Fig. 2.
Logic diagram for one decoder/multiplexer
6. Pinning information
6.1. Pinning
HEF4555B
1E
1
16 VDD
1A0
2
15 2E
1A1
3
14 2A0
1Y0
4
13 2A1
1Y1
5
12 2Y0
1Y2
6
11 2Y1
1Y3
7
10 2Y2
VSS
8
9
2Y3
001aae752
Fig. 3.
Pin configuration SOT109-1 (SO16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1A0, 1A1, 2A0, 2A1
2, 3, 14, 13
address input
1E, 2E
1, 15
enable input (active LOW
1Y0, 1Y1, 1Y2, 1Y3, 2Y0, 2Y1, 2Y2, 2Y3
4, 5, 6, 7, 12, 11, 10, 9
output (active HIGH)
VDD
16
supply voltage
VSS
8
ground (GND)
HEF4555B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 10
HEF4555B-Q100
Nexperia
7. Functional description
Table 3. Function selection
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Inputs
Outputs
nE
nA0
nA1
nY0
nY1
nY2
nY3
L
L
L
H
L
L
L
L
H
L
L
H
L
L
L
L
H
L
L
H
L
L
H
H
L
L
L
H
H
X
X
L
L
L
L
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
input/output current
IDD
supply current
Tstg
Min
Max
Unit
-0.5
+18
V
±10
mA
-0.5
VDD + 0.5
±10
mA
±10
mA
50
mA
storage temperature
-65
+150
°C
Tamb
ambient temperature
-40
+85
°C
Ptot
total power dissipation
SO16 package
500
mW
P
power dissipation
per output
100
mW
[1]
Conditions
VI < -0.5 V or VI > VDD + 0.5 V
VO < -0.5 V or VO > VDD + 0.5 V
[1]
V
For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall rate
VDD = 5 V
3.75
μs/V
VDD = 10 V
0.5
μs/V
VDD = 15 V
0.08
μs/V
HEF4555B_Q100
Product data sheet
3 / 10
HEF4555B-Q100
Nexperia
10. Static characteristics
Table 6. Static characteristics
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level input voltage
LOW-level input voltage
Conditions
|IO| < 1 μA
|IO| < 1 μA;
VI = VSS or VDD
Tamb = -40 °C
Tamb = 25 °C
Tamb = 85 °C Unit
Min
Max
Min
Max
Min
Max
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
5V
|IO| < 1 μA
HIGH-level output voltage |IO| < 1 μA;
VI = VSS or VDD
LOW-level output voltage
VDD
15 V
0.05
0.05
0.05
V
HIGH-level output current VO = 2.5 V
5V
-1.7
-1.4
-1.1
mA
VO = 4.6 V
5V
-0.52
-0.44
-0.36 mA
VO = 9.5 V
10 V
-1.3
-1.1
-0.9
mA
VO = 13.5 V
15 V
-3.6
-3.0
-2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
LOW-level output current
II
input leakage current
VDD = 15 V
15 V
±0.3
±0.3
±1.0
μA
IDD
supply current
IO = 0 A;
VI = VSS or VDD
5V
μA
10 V
40
40
300
μA
15 V
80
80
600
μA
7.5
pF
CI
input capacitance
HEF4555B_Q100
Product data sheet
4 / 10
HEF4555B-Q100
Nexperia
11. Dynamic characteristics
Table 7. Dynamic characteristics
VSS = 0 V; Tamb = 25 °C; for test circuit see Fig. 5; unless otherwise specified.
Symbol
Parameter
Conditions
VDD
Extrapolation formula
tPHL
HIGH to LOW
nAn to nYn;
propagation delay see Fig. 4
5V
10 V
15 V
tPLH
LOW to HIGH
nAn to nYn;
tt
[1]
[2]
transition time
nYn; see Fig. 4
Max
Unit
[1] 88 ns + (0.55 ns/pF)CL
115
230
ns
34 ns + (0.23 ns/pF)CL
45
90
ns
22 ns + (0.16 ns/pF)CL
30
65
ns
125
250
ns
10 V
39 ns + (0.23 ns/pF)CL
50
95
ns
15 V
22 ns + (0.16 ns/pF CL
30
65
ns
140
280
ns
5V
[1] 113 ns + (0.55 ns/pF)CL
10 V
44 ns + (0.23 ns/pF)CL
55
105
ns
15 V
32 ns + (0.16 ns/pF)CL
40
75
ns
150
295
ns
5V
nE to nYn;
see Fig. 4
Typ
[1] 98 ns + (0.55 ns/pF)CL
5V
nE to nYn;
see Fig. 4
Min
[1] 123 ns + (0.55 ns/pF)CL
10 V
55
110
ns
15 V
40
75
ns
[1][2] 10 ns + (1.00 ns/pF)CL
5V
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
Transition time tt is the same as the HIGH to LOW and LOW to HIGH transition times tTHL and tTLH.
Table 8. Dynamic power dissipation PD
PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C.
Symbol
Parameter
VDD
Typical formula for PD (μW)
PD
dynamic power
dissipation
5V
PD = 4500 × fi + Σ(fo × CL) × VDD
HEF4555B_Q100
Product data sheet
10 V
PD = 18800 × fi + Σ(fo × CL) ×
15 V
PD = 45700 × fi + Σ(fo × CL) ×
Where:
2
2
VDD
2
VDD
fi = input frequency in MHz,
fo = output frequency in MHz,
CL = output load capacitance in pF,
VDD = supply voltage in V,
Σ(fo × CL) = sum of the outputs.
5 / 10
HEF4555B-Q100
Nexperia
11.1. Waveforms and test circuit
VDD
VM
nAn, nE input
GND
tPHL
VOH
tPLH
90 %
VM
nYn output
10 %
VOL
tTHL
tTLH
001aal114
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 4.
Inputs nAn, nE to output nYn propagation delay and nYn output transition time
Table 9. Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
VI
negative
pulse
tW
90 %
90 %
VM
VM
10 %
0V
10 %
tf
tr
VI
positive
pulse
0V
tr
VDD
tf
90 %
G
90 %
VM
VM
10 %
10 %
tW
VI
VO
DUT
CL
RT
001aaj781
001aag182
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance;
CL = Load capacitance including jig and probe capacitance;
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator;
VEXT = External voltage for measuring switching times.
Fig. 5.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VDD
VI
tr = tf
CL
5 V to 15 V
VDD
≤ 20 ns
50 pF
HEF4555B_Q100
Product data sheet
Load
6 / 10
HEF4555B-Q100
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 6.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
HEF4555B_Q100
Product data sheet
7 / 10
HEF4555B-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
HEF4555B_Q100 v.2
20181015
Product data sheet
HEF4555B_Q100 v.1
Modifications:
HEF4555B_Q100 v.1
HEF4555B_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
20131021
Product data sheet
8 / 10
HEF4555B-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
HEF4555B_Q100
Product data sheet
9 / 10
HEF4555B-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................1
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Package outline.......................................................... 7
13. Abbreviations.............................................................. 8
14. Revision history..........................................................8
15. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 October 2018
HEF4555B_Q100
Product data sheet
10 / 10
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
HEF4555BT-Q100J
