PHP45NQ10T
N-channel TrenchMOS standard level FET
Rev. 02 — 8 July 2010
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Higher operating power due to low
thermal resistance
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC convertors
Switched-mode power supplies
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source
voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
100
V
ID
drain current
Tmb = 25 °C; VGS = 10 V
47
A
Ptot
total power
dissipation
Tmb = 25 °C
150
W
VGS = 10 V; ID = 25 A;
Tj = 25 °C
22
25
mΩ
gate-drain charge VGS = 10 V; ID = 45 A;
VDS = 80 V; Tj = 25 °C
25
nC
Static characteristics
RDSon
drain-source
on-state
resistance
Dynamic characteristics
QGD
PHP45NQ10T
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
Simplified outline
Graphic symbol
mb
3
S
source
mb
D
mounting base; connected to
drain
D
G
mbb076
S
1 2 3
SOT78 (TO-220AB)
3. Ordering information
Table 3.
Type number
PHP45NQ10T
PHP45NQ10T
Product data sheet
Package
Name
Description
Version
TO-220AB
plastic single-ended package; heatsink mounted; 1 mounting
hole; 3-lead TO-220AB
SOT78
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PHP45NQ10T
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
drain-source voltage
100
V
VDGR
drain-gate voltage
Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ
100
V
VGS
gate-source voltage
ID
drain current
-20
V
VGS = 10 V; Tmb = 100 °C
33
A
VGS = 10 V; Tmb = 25 °C
47
A
188
A
IDM
peak drain current
pulsed; Tmb = 25 °C
Tmb = 25 °C
Ptot
total power dissipation
150
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
47
A
ISM
peak source current
pulsed; Tmb = 25 °C
188
A
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
VGS = 10 V; Tj(init) = 25 °C; ID = 40 A;
Vsup ≤ 25 V; unclamped; tp = 100 µs;
RGS = 50 Ω
260
mJ
IAS
non-repetitive avalanche
current
Vsup ≤ 25 V; VGS = 10 V; Tj(init) = 25 °C;
RGS = 50 Ω; unclamped
47
A
014aab202
100
Pder
80
014aab203
100
ID
80
60
60
40
40
100
150
200
100
150
Tmb (°C)
Fig 1.
Normalized total power dissipation as a
function of mounting base temperature
PHP45NQ10T
Product data sheet
200
Tmb (°C)
Fig 2.
Normalized continuous drain current as a
3 of 12
PHP45NQ10T
Nexperia
014aab204
103
IDM
(A)
014aab216
102
RDSon = VDS/ID
102
lAS
(A)
tp = 10 μs
100 μs
10
10 ms
DC
Tj prior to avalanche = 150 °C
100 ms
1
10−1
102
10
1
25 °C
10
1 ms
1
10−3
103
10−2
10−1
1
10
tAV (ms)
VDS (V)
Tmb = 25 °C; IDM is single pulse
Fig 3.
Safe operating area; continuous and peak drain
currents as a function of drain-source voltage
Fig 4.
Single-shot avalanche rating; avalanche
current as a function of avalanche period
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
thermal resistance
from junction to
mounting base
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
10−1
Unit
1
K/W
60
K/W
0.2
0.1
0.05
δ=
P
single pulse
10−2
tp
T
t
tp
T
10−6
Fig 5.
Max
δ = 0.5
0.02
10−3
Typ
014aab205
1
Zth j-mb
(K/W)
Min
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
PHP45NQ10T
Product data sheet
4 of 12
PHP45NQ10T
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
89
V
V(BR)DSS
drain-source
breakdown voltage
VGS(th)
gate-source threshold
voltage
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
100
V
ID = 1 mA; VDS = VGS; Tj = -55 °C
6
V
ID = 1 mA; VDS = VGS; Tj = 175 °C
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C
2
3
4
V
VDS = 100 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
0.02
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
0.02
100
nA
VGS = 10 V; ID = 25 A; Tj = 175 °C
68
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C
22
25
mΩ
ID = 45 A; VDS = 80 V; VGS = 10 V;
Tj = 25 °C
61
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
69
ns
tf
fall time
58
ns
LD
internal drain
inductance
3.5
nH
from drain lead to centre of die ;
Tj = 25 °C
4.5
nH
from source lead to source bond pad ;
Tj = 25 °C
7.5
nH
LS
internal source
inductance
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C
VDS = 50 V; RL = 1.8 Ω; VGS = 10 V;
RG(ext) = 5.6 Ω; Tj = 25 °C
from tab to centre of die ; Tj = 25 °C
13
nC
25
nC
2600
pF
340
pF
195
pF
18
ns
72
ns
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C
0.87
1.2
V
trr
reverse recovery time
82
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 25 V; Tj = 25 °C
0.26
µC
PHP45NQ10T
Product data sheet
5 of 12
PHP45NQ10T
Nexperia
014aab206
40
ID
(A)
RDS(on) 4 4.2
(Ω)
VGS(V) = 10
30
014aab207
0.16
4.4
4.6
4.8
0.12
8
6
5
0.08
4.8
4.6
10
6
0.04
8
4.4
4
0.8
1.2
4.2
1.6
2
VDS(V)
8
12
16
Tj = 25 °C
Output characteristics: drain current as a
function of drain-source voltage; typical values
014aab208
50
ID
(A)
40
Fig 7.
Drain-source on-state resistance as a function
of drain current; typical values
014aab209
50
gfs
(S)
40
30
Tj = 25 °C
Tj = 175 °C
30
Tj = 175 °C
10
10
Tj = 25 °C
4
10
40
50
ID (A)
VGS (V)
VDS > ID x RDSon
Fig 8.
ID (A)
Tj = 25 °C
Fig 6.
VGS (V) = 10
VDS > ID x RDSon
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
014aab210
2.9
Fig 9.
Forward transconductance as a function of
014aab211
5
VGS(th)
(V)
4
a
maximum
2.1
3
typical
2
minimum
1.3
1
0.5
−60
180
180
Tj (°C)
Tj (°C)
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
PHP45NQ10T
Product data sheet
Fig 11. Gate-source threshold voltage as a function of
6 of 12
PHP45NQ10T
Nexperia
014aab212
10−1
lD
(A)
10−2
014aab213
104
C
(pF)
Ciss
103
10−3
Coss
minimum
10−4
typical
maximum
102
Crss
10−5
10−6
2
3
4
10
10−1
5
1
102
10
VDS (V)
VGS (V)
Tj = 25 °C; VDS = VGS
Fig 12. Sub-threshold drain current as a function of
gate-source voltage
014aab214
16
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
014aab215
50
IF
(A)
40
VGS
(V)
12
30
8
VDD = 20 V
VDD = 80 V
Tj = 175 °C
Tj = 25 °C
10
60
80
0.8
1.2
QG (nC)
VSDS (V)
Tj = 25 °C; ID = 45 A
VGS = 0 V
Fig 14. Gate-source voltage as a function of gate
charge; typical values
PHP45NQ10T
Product data sheet
Fig 15. Source (diode forward) current as a function of
source-drain (diode forward) voltage; typical
values
7 of 12
PHP45NQ10T
Nexperia
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
e
c
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig 16. Package outline SOT78 (TO-220AB)
PHP45NQ10T
Product data sheet
8 of 12
PHP45NQ10T
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date Data sheet status
Change notice Supersedes
PHP45NQ10T v.2
20100708
Modifications:
Product data sheet
PHB_PHP_PHW45NQ10T v.1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number PHP45NQ10T separated from data sheet PHB_PHP_PHW45NQ10T v.1.
PHB_PHP_PHW45NQ10T v.1 19990801
PHP45NQ10T
Product data sheet
Product specification
9 of 12
PHP45NQ10T
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
PHP45NQ10T
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in the
Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
10 of 12
PHP45NQ10T
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHP45NQ10T
Product data sheet
11 of 12
Nexperia
PHP45NQ10T
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 08 July 2010
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PHP45NQ10T,127
