PHP18NQ10T,127
PHP18NQ10T,127
    NEXPERIA(安世)
    TO-220AB
    MOSFETs 100V 79W DIP TO220AB 18A N-Channel
PHP18NQ10T,127 数据手册
Philips Semiconductors Product specification N-channel TrenchMOS transistor FEATURES PHP18NQ10T, PHB18NQ10T PHD18NQ10T SYMBOL QUICK REFERENCE DATA • ’Trench’ technology • Low on-state resistance • Fast switching • Low thermal resistance d VDSS = 100 V ID = 18 A g RDS(ON) ≤ 90 mΩ s GENERAL DESCRIPTION N-channel enhancement mode field-effect power transistor in a plastic envelope using ’trench’ technology. Applications:• d.c. to d.c. converters • switched mode power supplies The PHP18NQ10T is supplied in the SOT78 (TO220AB) conventional leaded package. The PHB18NQ10T is supplied in the SOT404 (D2PAK) surface mounting package. The PHD18NQ10T is supplied in the SOT428 (DPAK) surface mounting package. PINNING PIN SOT404 (D2PAK) SOT78 (TO220AB) DESCRIPTION 1 gate 2 drain 1 3 source tab tab tab 2 1 23 tab SOT428 (DPAK) 1 2 3 1 3 drain LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134) SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VDSS VDGR VGS ID Drain-source voltage Drain-gate voltage Gate-source voltage Continuous drain current Tj = 25 ˚C to 175˚C Tj = 25 ˚C to 175˚C; RGS = 20 kΩ IDM PD Tj, Tstg Pulsed drain current Total power dissipation Operating junction and storage temperature - 55 100 100 ± 20 18 13 72 79 175 V V V A A A W ˚C Tmb = 25 ˚C; VGS = 10 V Tmb = 100 ˚C; VGS = 10 V Tmb = 25 ˚C Tmb = 25 ˚C 1 It is not possible to make connection to pin:2 of the SOT404 or SOT428 packages. August 1999 1 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T AVALANCHE ENERGY LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134) SYMBOL PARAMETER EAS Non-repetitive avalanche energy IAS Peak non-repetitive avalanche current CONDITIONS MIN. MAX. UNIT - 70 mJ - 18 A Unclamped inductive load, IAS = 11 A; tp = 100 µs; Tj prior to avalanche = 25˚C; VDD ≤ 25 V; RGS = 50 Ω; VGS = 10 V; refer to fig:15 THERMAL RESISTANCES SYMBOL PARAMETER Rth j-mb Rth j-a Thermal resistance junction to mounting base Thermal resistance junction to ambient CONDITIONS MIN. SOT78 package, in free air SOT404 & SOT428 packages, pcb mounted, minimum footprint TYP. MAX. UNIT - - 1.9 K/W - 60 50 - K/W K/W ELECTRICAL CHARACTERISTICS Tj= 25˚C unless otherwise specified SYMBOL PARAMETER CONDITIONS V(BR)DSS VGS = 0 V; ID = 0.25 mA; VGS(TO) Drain-source breakdown voltage Gate threshold voltage MIN. Tj = -55˚C VDS = VGS; ID = 1 mA Tj = 175˚C Tj = -55˚C RDS(ON) IGSS IDSS Drain-source on-state VGS = 10 V; ID = 9 A resistance Gate source leakage current VGS = ± 10 V; VDS = 0 V Zero gate voltage drain VDS = 100 V; VGS = 0 V current Tj = 175˚C Tj = 175˚C 100 89 2 1 - TYP. MAX. UNIT 3 80 10 0.05 - 4 6 90 243 100 10 500 V V V V V mΩ mΩ nA µA µA Qg(tot) Qgs Qgd Total gate charge Gate-source charge Gate-drain (Miller) charge ID = 18 A; VDD = 80 V; VGS = 10 V - 21 4 8 - nC nC nC td on tr td off tf Turn-on delay time Turn-on rise time Turn-off delay time Turn-off fall time VDD = 50 V; RD = 2.7 Ω; VGS = 10 V; RG = 5.6 Ω Resistive load - 6 36 18 12 - ns ns ns ns Ld Ld Internal drain inductance Internal drain inductance - 3.5 4.5 - nH nH Ls Internal source inductance Measured tab to centre of die Measured from drain lead to centre of die (SOT78 package only) Measured from source lead to source bond pad - 7.5 - nH Ciss Coss Crss Input capacitance Output capacitance Feedback capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz - 633 103 61 - pF pF pF August 1999 2 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T REVERSE DIODE LIMITING VALUES AND CHARACTERISTICS Tj = 25˚C unless otherwise specified SYMBOL PARAMETER VSD Continuous source current (body diode) Pulsed source current (body diode) Diode forward voltage trr Qrr Reverse recovery time Reverse recovery charge IS ISM August 1999 CONDITIONS MIN. TYP. MAX. UNIT - - 18 A - - 72 A IF = 18 A; VGS = 0 V - 0.92 1.2 V IF = 18 A; -dIF/dt = 100 A/µs; VGS = 0 V; VR = 25 V - 55 135 - ns nC 3 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T Normalised Power Derating, PD (%) 10 100 Transient thermal impedance, Zth j-mb (K/W) 90 80 D = 0.5 1 70 0.2 60 0.1 50 0.05 40 0.1 P D 0.02 30 20 single pulse T 10 0.01 1E-06 0 0 25 50 75 100 125 Mounting Base temperature, Tmb (C) 150 175 1E-04 1E-03 1E-02 1E-01 1E+00 Pulse width, tp (s) Fig.1. Normalised power dissipation. PD% = 100⋅PD/PD 25 ˚C = f(Tmb) Fig.4. Transient thermal impedance. Zth j-mb = f(t); parameter D = tp/T Drain Current, ID (A) 20 Normalised Current Derating, ID (%) 100 VGS = 10V 8V 18 90 Tj = 25 C 16 80 6V 14 70 12 60 50 10 40 8 30 6 20 4 10 5.4 V 5.2 V 5V 4.8 V 2 0 0 25 50 75 100 125 Mounting Base temperature, Tmb (C) 150 4.6 V 175 0 0.2 0.4 0.6 0.8 1 1.2 1.4 Drain-Source Voltage, VDS (V) 0.2 RDS(on) = VDS/ ID 1.8 2 Drain-Source On Resistance, RDS(on) (Ohms) 4.8V 0.18 tp = 10 us 4.6V 5.2 V 5V 0.16 10 Tj = 25 C 5.4 V 0.14 100 us 1 1.6 Fig.5. Typical output characteristics, Tj = 25 ˚C. ID = f(VDS) Peak Pulsed Drain Current, IDM (A) D.C. 4.4 V 0 Fig.2. Normalised continuous drain current. ID% = 100⋅ID/ID 25 ˚C = f(Tmb); conditions: VGS ≥ 10 V 100 1E-05 D = tp/T tp 6V 0.12 0.1 1 ms 10 ms 0.08 8V 100 ms 0.06 VGS = 10V 0.04 0.02 0.1 0 1 10 100 Drain-Source Voltage, VDS (V) 1000 0 Fig.3. Safe operating area. Tmb = 25 ˚C ID & IDM = f(VDS); IDM single pulse; parameter tp August 1999 2 4 6 8 10 12 Drain Current, ID (A) 14 16 18 20 Fig.6. Typical on-state resistance, Tj = 25 ˚C. RDS(ON) = f(ID) 4 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T Drain current, ID (A) 4.5 20 VDS > ID X RDS(ON) 18 Threshold Voltage, VGS(TO) (V) 4 16 3.5 14 3 12 maximum typical 2.5 10 minimum 2 8 175 C 6 1.5 Tj = 25 C 4 1 0.5 2 0 0 0 1 2 3 4 5 6 7 8 9 10 -60 -40 -20 Gate-source voltage, VGS (V) 20 40 60 80 100 120 140 160 180 Junction Temperature, Tj (C) Fig.7. Typical transfer characteristics. ID = f(VGS) 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 Fig.10. Gate threshold voltage. VGS(TO) = f(Tj); conditions: ID = 1 mA; VDS = VGS Transconductance, gfs (S) Drain current, ID (A) 1.0E-01 VDS > ID X RDS(ON) Tj = 25 C 1.0E-02 175 C minimum 1.0E-03 typical 1.0E-04 maximum 1.0E-05 1.0E-06 0 2 4 6 8 10 12 14 Drain current, ID (A) 16 18 0 20 Fig.8. Typical transconductance, Tj = 25 ˚C. gfs = f(ID) 0.5 1 1.5 2 2.5 3 3.5 Gate-source voltage, VGS (V) 4 4.5 5 Fig.11. Sub-threshold drain current. ID = f(VGS); conditions: Tj = 25 ˚C; VDS = VGS Normalised On-state Resistance 2.9 2.7 2.5 2.3 2.1 1.9 1.7 1.5 1.3 1.1 0.9 0.7 0.5 10000 Capacitances, Ciss, Coss, Crss (pF) Ciss 1000 Coss 100 Crss 10 -60 -40 -20 0 20 40 60 80 100 120 140 160 180 Junction temperature, Tj (C) 0.1 Fig.9. Normalised drain-source on-state resistance. RDS(ON)/RDS(ON)25 ˚C = f(Tj) August 1999 1 10 Drain-Source Voltage, VDS (V) 100 Fig.12. Typical capacitances, Ciss, Coss, Crss. C = f(VDS); conditions: VGS = 0 V; f = 1 MHz 5 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T Maximum Avalanche Current, IAS (A) 100 Gate-source voltage, VGS (V) 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID = 18A Tj = 25 C 10 VDD = 20 V 25 C VDD = 80 V 1 0 2 4 6 8 0.1 0.001 10 12 14 16 18 20 22 24 26 28 30 Gate charge, QG (nC) Tj prior to avalanche = 150 C 0.01 0.1 1 10 Avalanche time, tAV (ms) Fig.13. Typical turn-on gate-charge characteristics. VGS = f(QG) Fig.15. Maximum permissible non-repetitive avalanche current (IAS) versus avalanche time (tAV); unclamped inductive load Source-Drain Diode Current, IF (A) 20 VGS = 0 V 18 16 14 12 175 C 10 8 Tj = 25 C 6 4 2 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 Source-Drain Voltage, VSDS (V) Fig.14. Typical reverse diode current. IF = f(VSDS); conditions: VGS = 0 V; parameter Tj August 1999 6 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T MECHANICAL DATA Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220 E SOT78 A A1 P q D1 D L1 L2(1) Q b1 L 1 2 e e 3 c b 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) (1) UNIT A A1 b b1 c D D1 E mm 4.5 4.1 1.39 1.27 0.9 0.7 1.3 1.0 0.7 0.4 15.8 15.2 6.4 5.9 10.3 9.7 e L L1 2.54 15.0 13.5 3.30 2.79 L2 max. P q Q 3.0 3.8 3.6 3.0 2.7 2.6 2.2 Note 1. Terminals in this zone are not tinned. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 97-06-11 TO-220 Fig.16. SOT78 (TO220AB); pin 2 connected to mounting base (Net mass:2g) Notes 1. This product is supplied in anti-static packaging. The gate-source input must be protected against static discharge during transport or handling. 2. Refer to mounting instructions for SOT78 (TO220AB) package. 3. Epoxy meets UL94 V0 at 1/8". August 1999 7 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T MECHANICAL DATA Plastic single-ended surface mounted package (Philips version of D2-PAK); 3 leads (one lead cropped) SOT404 A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 OUTLINE VERSION D max. D1 E 11 1.60 1.20 10.30 9.70 e Lp HD Q 2.54 2.90 2.10 15.40 14.80 2.60 2.20 REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 98-12-14 99-06-25 SOT404 Fig.17. SOT404 surface mounting package. Centre pin connected to mounting base. Notes 1. This product is supplied in anti-static packaging. The gate-source input must be protected against static discharge during transport or handling. 2. Refer to SMD Footprint Design and Soldering Guidelines, Data Handbook SC18. 3. Epoxy meets UL94 V0 at 1/8". August 1999 8 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T MOUNTING INSTRUCTIONS Dimensions in mm 11.5 9.0 17.5 2.0 3.8 5.08 Fig.18. SOT404 : soldering pattern for surface mounting. August 1999 9 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T MECHANICAL DATA Plastic single-ended surface mounted package (Philips version of D-PAK); 3 leads (one lead cropped) SOT428 seating plane y A E A2 A A1 b2 D1 mounting base E1 D HE L2 2 L1 L 1 3 b1 w M A b c e e1 0 10 20 mm scale DIMENSIONS (mm are the original dimensions) A UNIT max. mm 2.38 2.22 A1(1) A2 b b1 max. b2 c 0.65 0.45 0.89 0.71 0.89 0.71 1.1 0.9 5.36 5.26 0.4 0.2 D1 E D max. max. max. 6.22 5.98 4.81 4.45 6.73 6.47 E1 min. 4.0 e e1 2.285 4.57 HE max. L 10.4 9.6 2.95 2.55 L1 min. L2 w y max. 0.5 0.7 0.5 0.2 0.2 Note 1. Measured from heatsink back to lead. OUTLINE VERSION REFERENCES IEC JEDEC EIAJ SOT428 EUROPEAN PROJECTION ISSUE DATE 98-04-07 Fig.19. SOT428 surface mounting package. Centre pin connected to mounting base. Notes 1. This product is supplied in anti-static packaging. The gate-source input must be protected against static discharge during transport or handling. 2. Refer to SMD Footprint Design and Soldering Guidelines, Data Handbook SC18. 3. Epoxy meets UL94 V0 at 1/8". August 1999 10 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T MOUNTING INSTRUCTIONS Dimensions in mm 7.0 7.0 2.15 1.5 2.5 4.57 Fig.20. SOT428 : soldering pattern for surface mounting. August 1999 11 Rev 1.000 Philips Semiconductors Product specification N-channel TrenchMOS transistor PHP18NQ10T, PHB18NQ10T PHD18NQ10T DEFINITIONS Data sheet status Objective specification This data sheet contains target or goal specifications for product development. Preliminary specification This data sheet contains preliminary data; supplementary data may be published later. Product specification This data sheet contains final product specifications. Limiting values Limiting values are given in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of this specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information Where application information is given, it is advisory and does not form part of the specification.  Philips Electronics N.V. 1999 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, it is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent or other industrial or intellectual property rights. LIFE SUPPORT APPLICATIONS These products are not designed for use in life support appliances, devices or systems where malfunction of these products can be reasonably expected to result in personal injury. Philips customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting from such improper use or sale. August 1999 12 Rev 1.000
PHP18NQ10T,127 价格&库存
很抱歉,暂时无法提供与“PHP18NQ10T,127”相匹配的价格&库存,您可以联系我们找货
