DATA SHEET
CURRENT SENSOR - LOW TCR
4 Termination
PS Series
5%, 1%, 0.5%
0306/0612
Product specification – July 17, 2019 V.1
Supersedes Date of Mar. 06, 2003
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SERIES
PS
2
11
0306/0612
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes PS
series 4-terminal current sensor
- low TCR chip resistors with
lead-free terminations made by
metal alloy process.
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Battery pack
Inverter/Converter (DCDC/AC-DC/DC-AC)
Consumer electronics
Laptops
GLOBAL PART NUMBER
PS XXXX X X X XX XXXX L
(1)
(2) (3) (4) (5)
(6)
(7)
(1) SIZE
0306 / 0612
(2) TOLERANCE
D=± 0.5% (10mΩ & 20mΩ)
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
FEATURES
This product with lead-free
terminations meet RoHS
requirements
High component and
equipment reliability
Ultra low resistance and
narrow tolerance suitable for
current detection
K= Embossed taping reel
R = Paper taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
M
F
L
G
P
= ± 75ppm/°C
= ± 100ppm/°C
= ± 150ppm/°C
= ± 200ppm/°C
= ± 300ppm/°C
(5) TAPING REEL
07 / 7W / 7T= 7 inch dia. Reel and specific rated power.
Detailed power rating are shown in the Table 2.
(6) RESISTANCE VALUE
0.5mΩ to 100mΩ
There are 3~5 digits indicated the resistance value. Letter R is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of global
part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance code rule
Example
0R001 = 1mΩ
0RXXX
(0UX)
0R1 = 100mΩ
0U5 = 0.5mΩ
ORDERING EXAMPLE
The ordering code of a PS0306
1W chip resistor, value 0.003 Ω
with ± 1% tolerance, supplied in 7inch tape reel is:
PS0306FRL0R003L
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
www.yageo.com
Jul. 17, 2019 V.1
SERIES
PS
3
11
0306/0612
MARKING
PS0306/0612
Bar marking
YNSC137
Fig. 1
Outlines
L
L
B4
W
B5
B4
W
Top
Bottom
Side
Marking layer
Overcoat
Resistive layer
H
Overcoat
Ceramic substrate
Termination
YNSC136_2
Fig. 2 Chip resistor outlines
DIMENSION
Table 1
TYPE
PS0306
PS0612
L (mm)
W (mm)
B1/S1 (mm) B2/S2 (mm) B3/S3 (mm)
0.80± 0.15
1.60± 0.20
1.10± 0.20
0.25± 0.10
1.60+0.15/-0.20 3.20± 0.20
2.20± 0.20
0.50± 0.20
B4 (mm)
B5 (mm)
H (mm)
0.25± 0.10
0.20± 0.10
0.40± 0.20
0.50± 0.20
0.50± 0.20
0.45± 0.20
0.70± 0.20
(0.5~1mΩ) 0.70± 0.20
(2~10mΩ) 0.60± 0.20
(12~100mΩ) 0.50± 0.20
Note:
1. For relevant physical dimensions, please refer to construction outlines.
2. Please contact with sales offices, distributors and representatives in your region before ordering.
www.yageo.com
Jul. 17, 2019 V.1
PS
SERIES
4
11
0306/0612
ELECTRICAL CHARACTERISTICS
Table 2
SERIES SIZE
POWER RATING
TOLERANCE
1/4W
0306
1/3W
1/2W
Fig. 4 Chip resistor outlines
PS
0612
± 0.5%(10, 20mΩ)
± 1%,
± 5%
1W
RESISTANCE RANGE
TEMPERATURE COEEFICIENT
OF RESISTANCE
2mΩ ≤ R < 5mΩ
± 150ppm/°C
5mΩ ≤ R ≤ 100mΩ
± 75ppm/°C
± 100ppm/°C
0.5mΩ
± 300ppm/°C
1mΩ
± 100ppm/°C
± 150ppm/°C
2mΩ ≤ R ≤ 9mΩ
± 100ppm/°C
14mΩ ≤ R ≤ 100mΩ
± 100ppm/°C
10mΩ ≤ R ≤ 13mΩ
± 200ppm/°C
Note: Please contact with sales offices, distributors and representatives in your region before ordering.
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
0.5m Ω ≤ R ≤ 10m Ω -55℃ to +155℃
12m Ω ≤ R ≤ 100m Ω -55℃ to +125℃
PS0612
PS0306 -55℃ to +125℃
POWER RATING
Standard rated power at 70°C
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
125
155
Fig. 3 Maximum dissipation (P max ) in percentage of rated power
as a function of the operating ambient temperature (T amb)
(P * R)
Where
V = Continuous rated DC or
AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
www.yageo.com
Jul. 17, 2019 V.1
SERIES
PS
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
PS0306
5
11
0306/0612
PS0612
Paper taping reel (R)
7" (178 mm)
5,000
Embossed taping reel (K)
7" (178 mm)
4,000
PAPER TAPE
Fig. 4 Paper Tape
Table 4 Dimensions of paper tape for relevant chip resistors size
SIZE
PS0306
Unit: mm
SYMBOL
A0
B0
W
E
F
P0
P1
P2
1.10± 0.15
1.90± 0.15
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
Ø D0
T
1.5± 0.10
0.80± 0.10
www.yageo.com
Jul. 17, 2019 V.1
SERIES
PS
6
11
0306/0612
EMBOSSED TAPE
Fig. 8 Embossed Tape
Table 5 Dimensions of embossed tape for relevant chip resistors size
SIZE
SYMBOL
A0
Unit: mm
B0
W
E
PS0612 1.91± 0.05 3.65± 0.05 8.00+0.30/-0.10 1.75± 0.10
F
P0
P1
P2
3.50± 0.05 4.00± 0.10 4.00± 0.10 2.00± 0.05
Ø D0
T
1.5± 0.10 0.88± 0.05
www.yageo.com
Jul. 17, 2019 V.1
PS
SERIES
7
11
0306/0612
REEL SPECIFICATION
Fig. 5 Reel
Table 6 Dimensions of reel specification for relevant chip resistors size
SIZE
QUANTITY
REEL SIZE
8 mm
TAPE WIDE
PER REEL
SYMBOL
Unit: mm
A
N
W1
W2 MAX.
PS0306
5000
7"(Ø 178 mm)
178.0± 5
60.0± 2
9.0± 0.2
12.0± 0.2
PS0612
4000
7"(Ø 178 mm)
178.0± 5
60.0± 2
9.0± 0.2
12.0± 0.2
www.yageo.com
Jul. 17, 2019 V.1
SERIES
PS
8
11
0306/0612
SOLDERING PROFILES
For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”.
FOOTPRINT
Fig. 6 Single resistor chips recommended dimensions of footprints
Table 7 Footprint dimensions
SIZE
FOOTPRINT
DIMENSIONS CODE
Unit: mm
a
b
c
d
e
t(um)
PS0306
0.40
1.75
0.35
0.20
0.20
105
PS0612
1.00
3.50
0.80
0.38
0.75
105
www.yageo.com
Jul. 17, 2019 V.1
PS
SERIES
9
11
0306/0612
TESTS AND REQUIREMENTS
Table 8 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Life/
Operational Life/
Endurance
MIL-STD-202-method 108
IEC 60115-1 4.25.1
1,000 hours at 70± 2 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
High
Temperature
Exposure/
Endurance at
Upper Category
Temperature
IEC 60068-2-2
1,000 hours at 125 °C &155 °C ,unpowered
± (1%+0.0005 Ω)
Moisture
Resistance
MIL-STD-202-method 106
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for 10d
with 25 °C / 65 °C 95% R.H, without steps 7a &
7b, unpowered
± (0.5%+0.0005 Ω)
± (1%+0.0005 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202-method 107
-55/+125 °C
± (1%+0.0005 Ω)
Note: Number of cycles required is 300.
Devices mounted
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
Short Time
Overload
IEC60115-1 4.13
Board Flex/
Bending
IEC 60068-2-21
5 times of rated power for 5 seconds at room
temperature
± (1%+0.0005 Ω)
Chips mounted on a 90mm glass epoxy resin
PCB(FR4)
2 mm bending
Bending time: 60± 5 seconds
± (1%+0.0005 Ω)
No visible damage
No visible damage
www.yageo.com
Jul. 17, 2019 V.1
PS
SERIES
10
11
0306/0612
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Solderability
- Wetting
J-STD-002 test B
Electrical Test not required
Well tinned (≥95% covered)
Magnification 50X
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155 °C
dry heat
2nd step: leadfree solder bath at 245± 3 °C
Dipping time: 3± 0.5 seconds
- Resistance to
Soldering Heat
IEC 60068-2-58
Condition B, no pre-heat of samples
± (0.5%+0.0005 Ω)
Leadfree solder, 260 °C,
10 seconds immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Jul. 17, 2019 V.1
PS
SERIES
11
11
0306/0612
REVISION HISTORY
REVISION
DATE
Version 1TYPE July 16, 2019
CHANGE NOTIFICATION
-POWER
DESCRIPTION
RESISTANCE RANGE
TOLERANCE
- Extend resistor value
1/10W, 1/5W, 3/10W, 2/5W, 1/2W
0603
Mar. 06, 2017
1/8W, 1/4W, 1/3W, 1/2W
0805
1/4W, 1/2W
1206
Version 0
OF RESISTANCE
5 mΩ ≦ R < 100 mΩ
- New datasheet for current sensor - low TCR 4 terminal PS series
4 mΩ ≦ R < 100 mΩ
3 mΩ ≦ R < 100 mΩ
1/2W, 1W
PF
The resistors are constructed
using outstanding TCR level
material, which makes Yageo PF
resistors excellent for current
sensing application in battery
charger circuit & DC-DC
converter.
The composition of the resistive
2010 material is adjusted to give the
approximate required resistance
and is covered with a protective
coating, which printed with the
resistance value.
Finally, the three external
terminations (Ni / matte Tin) are
added, as shown in Fig. 4.
2512
4527
± 1%
± 2%
5 mΩ ≦ R < 100 mΩ
±75 ppm/°C
± 5%
1W, 2W
1 mΩ ≦ R < 100 mΩ
3W
1 mΩ ≦ R ≦ 50 mΩ
2W, 3W, 5W
6 mΩ ≦ R < 1Ω
NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Jul. 17, 2019 V.1
