Wire Wound Chip Common Mode Choke Coil – SDCW-U Series
Operating Temp. : -40℃~+85℃
FEATURES
Winding type realizes small size and low profile
Prevention of common mode noise at high frequency
Excellent solderability
APPLICATIONS
Super speed differential signal lines for USB3.0.
PRODUCT IDENTIFICATION
SDCW
2012
U
①
②
③
②
①
SDCW
Type
Winding Type
Common Mode Choke
Coil
-900
④
⑤
Impedance
Nominal Value
90Ω
T
F
⑥
⑦
③
External Dimensions (L×W) (mm)
1210 [0504]
1.2×1.0
2012 [0805]
2.0×1.2
U
④
Number of Lines
2
⑤
Example
900
-2
⑦
⑥
Hazardous Substance
Free Products
Packing
T
Code
For Super
Speed Differential
Signal Lines
Tape & Reel
F
SHAPE AND DIMENSIONS
SDCW1210U TYPE
Recommended Land Pattern
Unit: mm
SDCW2012U TYPE
Sunlord
Specifications subject to change without notice. Please check our website for latest information.
Unit: mm
Revised 2021/05/15
Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SPECIFICATIONS
SDCW1210U TYPE
Part Number
Units
Symbol
SDCW1210U-2-140TF
SDCW1210U-2-600TF
SDCW1210U-2-900TF
Common Mode
Impedance @100MHz
Ω
Z
14±25%
60±25%
90±25%
Max. DC
Resistance
Ω
DCR
0.12
0.40
0.50
Max. Rated
Current
mA
Ir
600
300
280
Common Mode
Impedance @100MHz
Ω
Z
90±25%
Max. DC
Resistance
Ω
DCR
0.40
Max. Rated
Current
mA
Ir
280
Rated Voltage
Volts
V DC
Min. Insulation
Resistance
MΩ
IR
10
10
10
SDCW2012U TYPE
Part Number
Units
Symbol
SDCW2012U-2-900TF
Rated Voltage
Volts
V DC
Min. Insulation
Resistance
MΩ
IR
10
※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales.
EQUIVALENT CIRCUIT
TYPICAL ELECTRICAL CHARACTERISTICS
Impedance vs. Frequency
SDCW1210U TYPE
Frequency(MHz)
Sunlord
SDCW2012U TYPE
Frequency(MHz)
Revised 2021/05/15
Insertion Loss
SDCW1210U TYPE
SDCW2012U TYPE
SDCW2012U-2-900TF
Frequency(MHz)
Differential Mode Impedance Characteristics
SDCW2012U-2-900TF
Sunlord
Eye Diagram in USB3.0
SDCW2012U-2-900TF
Revised 2021/05/15
很抱歉,暂时无法提供与“SDCW2012U-2-900TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43680
- 100+0.39780
- 500+0.35880
- 1000+0.31980
- 2000+0.29380
- 4000+0.28600
- 国内价格
- 5+0.64084
- 50+0.53284
- 150+0.47884
- 500+0.43834
- 2000+0.36720
- 4000+0.35100
