DATA SHEET
WIRELESS COMPONENTS
Ceramic Chip Antenna
ANT3216LL00R2400A
2.4 - 2.5 GHZ
Product Specification – March 27, 2013 V.0
3216 Series
Product specification
WIRELESS COMPONENTS
2
6
FEATURES
z Compact size
z Omni-directional radiation
z Tape & reel automatic
mounting
z Reflow process compatible
z RoHS compliant
ORDERING INFORMATION
APPLICATIONS
z 2.4 GHz WiFi device
z Bluetooth gadget
z Zigbee device
z ISM band equipment
(1) PRODUCT
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
PART NUMBER
ANT 3216 L L00 R 2400A
(1)
(2)
(3)
(4)
(5)
(6)
ANT = Antenna
(2) SIZE
3216 = 3.2 × 1.6 mm
(3) ANTENNA TYPE
L,F,A = Chip Antenna
(4) SERIAL NO.
L00
(5) PACKING TYPE
R = Tape and Reel
(6) WORKING FREQUENCY
2400 = 2.4GHz
PHYCOMP CTC
CAN4311712002453K
12NC
431171200245
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
3
6
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Working Frequency
2.4 - 2.5 GHz
Bandwidth
160 MHz
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Peak Gain
5.05 dBi (Typ.)
Impedance
50Ω
Operating Temperature
-40 ~105℃
Maximum Power
1W
Termination
Ni / Sn (Environmentally-Friendly Leadless)
Resistance to Soldering Heats
260℃ , 10sec.
NOTE
1. The specification is defined on Yageo evaluation board
DIMENSIONS
Table 2 Machinical Dimension
DIMENSION
L (mm)
3.20 ±0.15
W (mm)
1.60 ±0.15
T (mm)
1.20 ±0.15
C (mm)
0.40 ±0.20
OUTLINES
Top View
Side View
L
W
S1
T
S2
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
S1
Feeding Point
S2
Soldering Point
Bottom View
C
YNH0010
Fig. 1 Antenna outlines
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
4
6
REFERENCE DESIGN OF EVALUATION BOARD
30
10
18
Fig. 2 Outlook and dimension of evaluation board
Unit : mm
2.0
Matching Circuit
2.5
0.4
Top Layer
Bottom Layer
1.8
Unit : mm
3.5
YNH0011
Fig. 3 Details of soldering Pad
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
5
6
ELECTRICAL PERFORMANCES
Return loss
(dB)
YNH0012
50
30
10
−10
1
3
−30
2
−50
2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3.0
f (GHz)
Marker data
1. 2.37GHz, -10dB
2. 2.45GHz, -27.3dB
3. 2.53GHz, -10dB
Fig. 4 Return loss
Gain (dBi)
5.00 −
Z axle
0.00 −
X
Y
− 5.00 −
− 10.00 −
Z
− 15.00 −
− 20.00 −
− 25.00 −
Evaluation board and XYZ direction
X axle
Y axle
− 30.00 −
− 35.00 −
Max gain = 5.05 dBi, at (180, 60)
MEG (mean effective gain)= 0.45dBi
Directivity (dB) = 7.15
Efficiency = -1.50dB, 70.74%
YNH0013
Fig. 5 Radiation pattern
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
6
6
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
Version 0
Mar. 27, 2013
DESCRIPTION
- New datasheet for Ceramic Chip Antenna, 2.4-2.5 GHz application,
size 3216 series
www.yageo.com
Mar. 27, 2013 V0
很抱歉,暂时无法提供与“ANT3216LL00R2400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.48961
- 100+0.45761
- 300+0.42561
- 500+0.39361
- 2000+0.37761
- 5000+0.36801
