S-5743NBH1A-M3T4U
S-5743NBH1A-M3T4U
    ABLIC(艾普凌科)
    TO236-3
    MAGNETIC SWITCH BIPOLAR SOT23-3S
S-5743NBH1A-M3T4U 数据手册
S-5743 A Series www.ablic.com 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 © ABLIC Inc., 2015-2019 This IC, developed by CMOS technology, is a high-accuracy hall effect latch IC that operates with high temperature and high-withstand voltage. The output voltage changes when this IC detects the intensity level of magnetic flux density and a polarity change. Using this IC with a magnet makes it possible to detect the rotation status in various devices. This IC includes an output current limit circuit. High-density mounting is possible by using the small SOT-23-3S package. Due to its high-accuracy magnetic characteristics, this IC enables the user to reduce the operational variation in the system. ABLIC Inc. offers a "magnetic simulation service" that provides the ideal combination of magnets and our Hall effect ICs for customer systems. Our magnetic simulation service will reduce prototype production, development period and development costs. In addition, it will contribute to optimization of parts to realize high cost performance. For more information regarding our magnetic simulation service, contact our sales office.  Features • Pole detection: • Output logic*1: • Output form: • Magnetic sensitivity*1: • Chopping frequency: • Output delay time: • Power supply voltage range: • Built-in regulator • Built-in output current limit circuit • Operation temperature range: • Lead-free (Sn 100%), halogen-free Bipolar latch VOUT = "L" at S pole detection VOUT = "H" at S pole detection Nch open-drain output BOP = 0.5 mT typ. BOP = 1.5 mT typ. BOP = 2.2 mT typ. BOP = 3.0 mT typ. fC = 500 kHz typ. tD = 8.0 μs typ. VDD = 2.7 V to 26.0 V Ta = −40°C to +125°C *1. The option can be selected.  Applications • Power tool • Home appliance • DC brushless motor • Housing equipment • Industrial equipment  Package • SOT-23-3S 1 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Block Diagram VDD OUT Regulator Chopping stabilized amplifier Output current limit circuit VSS *1. Parasitic diode Figure 1 2 *1 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Product Name Structure 1. Product name S-5743 N B x x A - M3T4 U Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and IC packing specifications*1 M3T4: SOT-23-3S, Tape Operation temperature A: Ta = −40°C to +125°C Magnetic sensitivity 9: BOP = 0.5 mT typ. 0: BOP = 1.5 mT typ. 8: BOP = 2.2 mT typ. 1: BOP = 3.0 mT typ. Output logic L: VOUT = "L" at S pole detection H: VOUT = "H" at S pole detection Pole detection B: Bipolar latch Output form N: Nch open-drain output *1. Refer to the tape drawing. 2. Package Table 1 Package Name SOT-23-3S 3. Package Drawing Codes Dimension MP003-D-P-SD Tape MP003-D-C-SD Reel MP003-D-R-SD Product name list Table 2 Product Name Output Form Pole Detection Output Logic S-5743NBL9A-M3T4U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection S-5743NBL0A-M3T4U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection S-5743NBL8A-M3T4U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection S-5743NBL1A-M3T4U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection S-5743NBH9A-M3T4U Nch open-drain output Bipolar latch VOUT = "H" at S pole detection S-5743NBH1A-M3T4U Nch open-drain output Bipolar latch VOUT = "H" at S pole detection Remark Please contact our sales office for products other than the above. Magnetic Sensitivity (BOP) 0.5 mT typ. 1.5 mT typ. 2.2 mT typ. 3.0 mT typ. 0.5 mT typ. 3.0 mT typ. 3 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Pin Configuration 1. SOT-23-3S Table 3 Top view Pin No. 1 2 Symbol Description 1 VSS GND pin 2 VDD Power supply pin 3 OUT Output pin 3 Figure 2  Absolute Maximum Ratings Table 4 Item Symbol (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit Output current IOUT VSS − 0.3 to VSS + 28.0 20 Output voltage VOUT VSS − 0.3 to VSS + 28.0 V Operation ambient temperature Topr −40 to +125 °C Storage temperature Tstg −40 to +150 °C Power supply voltage VDD V mA Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 5 Item Symbol Condition Board A Board B *1 Junction-to-ambient thermal resistance SOT-23-3S θJA Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 4 Refer to " Power Dissipation" and "Test Board" for details. Min. Typ. Max. Unit − − − − − 200 165 − − − − − − − − °C/W °C/W °C/W °C/W °C/W 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Electrical Characteristics Table 6 Item (Ta = +25°C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit Symbol Power supply voltage Current consumption Output voltage Leakage current Output limit current Output delay time Chopping frequency Start up time Output rise time Output fall time VDD IDD VOUT ILEAK IOM tD fC tPON tR tF − Average value IOUT = 10 mA Output transistor Nch, VOUT = 26.0 V VOUT = 12.0 V − − − C = 20 pF, R = 820 Ω C = 20 pF, R = 820 Ω 2.7 − − − 22 − − − − − 12.0 3.0 − − − 8.0 500 20 − − 26.0 4.0 0.4 1 70 − − − 2.0 2.0 V mA V μA mA μs kHz μs μs μs − 1 2 3 3 − − 4 5 5 S pole Magnetic flux density applied to this IC (B) BOP 0 BRP N pole tD tD tF Output voltage (VOUT) (Product with VOUT = "L" at S pole detection) tR 90% 10% tD tD tR tF 90% Output voltage (VOUT) (Product with VOUT = "H" at S pole detection) 10% Figure 3 Operation Timing 5 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Magnetic Characteristics 1. Product with BOP = 0.5 mT typ. Table 7 (Ta = +25°C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 Release point*2 Hysteresis width*3 2. Symbol S pole N pole BOP BRP BHYS Condition − − BHYS = BOP − BRP Min. −0.5 −1.5 − Typ. 0.5 −0.5 1.0 Max. 1.5 0.5 − Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 1.5 mT typ. Table 8 (Ta = +25°C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 Release point*2 Hysteresis width*3 3. Symbol S pole N pole BOP BRP BHYS Condition − − BHYS = BOP − BRP Min. 0.5 −2.5 − Typ. 1.5 −1.5 3.0 Max. 2.5 −0.5 − Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 2.2 mT typ. Table 9 (Ta = +25°C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 Release point*2 Hysteresis width*3 4. Symbol S pole N pole BOP BRP BHYS Condition − − BHYS = BOP − BRP Min. 1.2 −3.2 − Typ. 2.2 −2.2 4.4 Max. 3.2 −1.2 − Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 3.0 mT typ. Table 10 (Ta = +25°C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 Release point*2 Hysteresis width*3 Symbol S pole N pole BOP BRP BHYS Condition − − BHYS = BOP − BRP Min. 2.0 −4.0 − Typ. 3.0 −3.0 6.0 Max. 4.0 −2.0 − Unit mT mT mT Test Circuit 4 4 4 *1. BOP: Operation point BOP is the value of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (S pole) is increased (by moving the magnet closer). VOUT retains the status until a magnetic flux density of the N pole higher than BRP is applied. *2. BRP: Release point BRP is the value of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (N pole) is increased (by moving the magnet closer). VOUT retains the status until a magnetic flux density of the S pole higher than BOP is applied. *3. BHYS: Hysteresis width BHYS is the difference of magnetic flux density between BOP and BRP. Remark 6 The unit of magnetic density mT can be converted by using the formula 1 mT = 10 Gauss. 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Test Circuits A R 820 Ω VDD VDD S-5743 OUT A Series VSS S-5743 OUT A Series VSS Figure 4 Figure 5 Test Circuit 1 S-5743 OUT A Series VSS Figure 6 V Test Circuit 3 VDD S-5743 OUT A Series VSS Figure 8 S-5743 OUT A Series VSS A Figure 7 V Test Circuit 2 VDD VDD A R 820 Ω V Test Circuit 4 R 820 Ω C 20 pF V Test Circuit 5 7 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Standard Circuit VDD CIN 0.1 μF R 820 Ω S-5743 A Series OUT VSS Figure 9 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 8 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Operation 1. Direction of applied magnetic flux This IC detects the magnetic flux density which is vertical to the marking surface. Figure 10 shows the direction in which magnetic flux is being applied. N S Marking surface Figure 10 2. Position of Hall sensor Figure 11 shows the position of Hall sensor. The center of this Hall sensor is located in the area indicated by a circle, which is in the center of a package as described below. The following also shows the distance (typ. value) between the marking surface and the chip surface of a package. Top view The center of Hall sensor, in this φ0.3 mm 1 2 3 0.315 mm (typ.) Figure 11 9 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series 3. Basic operation This IC changes the output voltage (VOUT) according to the level of the magnetic flux density (N pole or S pole) and a polarity change applied by a magnet. 3. 1 Product with VOUT = "L" at S pole detection When the magnetic flux density of the S pole perpendicular to the marking surface exceeds the operation point (BOP) after the S pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "H" to "L". When the N pole of a magnet is moved closer to the marking surface of this IC and the magnetic flux density of the N pole is higher than the release point (BRP), VOUT changes from "L" to "H". In case of BRP < B < BOP, VOUT retains the status. Figure 12 shows the relationship between the magnetic flux density and VOUT. VOUT BHYS H L N pole 0 BRP BOP S pole Magnetic flux density (B) Figure 12 3. 2 Product with VOUT = "H" at S pole detection When the magnetic flux density of the S pole perpendicular to the marking surface exceeds BOP after the S pole of a magnet is moved closer to the marking surface of this IC, V OUT changes from "L" to "H". When the N pole of a magnet is moved closer to the marking surface of this IC and the magnetic flux density of the N pole is higher than BRP, VOUT changes from "H" to "L". In case of BRP < B < BOP, VOUT retains the status. Figure 13 shows the relationship between the magnetic flux density and VOUT. VOUT BHYS H L N pole BRP 0 BOP Magnetic flux density (B) Figure 13 10 S pole 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series 4. Timing chart Figure 14 shows the timing chart at power-on for product with VOUT = "L" at S pole detection. The initial output voltage at rising of power supply voltage (VDD) is "H". In case of B > BOP at the time when the start up time (tPON) is passed after rising of VDD, this IC outputs "L". In case of B < BOP at the time when tPON is passed after rising of VDD, this IC maintains "H". Power supply voltage (VDD) tPON Output voltage (VOUT) (B > BOP) "H" Output voltage (VOUT) (B < BOP) "H" "L" Latching Figure 14 11 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Precautions • If the impedance of the power supply is high, the IC may malfunction due to a supply voltage drop caused by feedthrough current. Take care with the pattern wiring to ensure that the impedance of the power supply is low. • Note that the IC may malfunction if the power supply voltage rapidly changes. When the IC is used under the environment where the power supply voltage rapidly changes, it is recommended to judge the output voltage of the IC by reading it multiple times. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • Although this IC has a built-in output current limit circuit, it may suffer physical damage such as product deterioration under the environment where the absolute maximum ratings are exceeded. • The application conditions for the power supply voltage, the pull-up voltage, and the pull-up resistor should not exceed the power dissipation. • Large stress on this IC may affect the magnetic characteristics. Avoid large stress which is caused by the handling during or after mounting the IC on a board. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 12 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Characteristics (Typical Data) Operation point, release point (BOP, BRP) vs. Temperature (Ta) S-5743NBx9A 1.5 VDD = 12.0 V 1.0 BOP 0.5 0.0 −0.5 −1.0 BRP BOP, BRP [mT] 25 VDD = 26.0 V 50 75 Ta [°C] 100 125 1. 4 VDD = 12.0 V VDD = 2.7 V BRP −4.0 −40 −25 2. 0 VDD = 2.7 V −2.0 VDD = 2.7 V VDD = 12.0 V S-5743NBx8A 4.0 BOP 2.0 0.0 VDD = 26.0 V VDD = 2.7 V −1.5 −40 −25 1. 3 1. 2 BOP, BRP [mT] BOP, BRP [mT] 1. 1 BOP, BRP [mT] 1. VDD = 26.0 V VDD = 26.0 V 25 50 75 Ta [°C] 100 1.0 0.0 −1.0 VDD = 12.0 V VDD = 12.0 V −2.0 BRP −3.0 −40 −25 125 VDD = 26.0 V VDD = 26.0 V VDD = 2.7 V 0 25 50 75 Ta [°C] 100 125 S-5743NBx1A 6.0 VDD = 12.0 V BOP 4.0 2.0 0.0 −2.0 VDD = 2.7 V VDD = 2.7 V −4.0 BRP −6.0 −40 −25 VDD = 12.0 V 0 S-5743NBx0A 3.0 VDD = 2.7 V BOP 2.0 VDD = 26.0 V VDD = 26.0 V VDD = 12.0 V 0 25 50 75 Ta [°C] 100 125 Operation point, release point (BOP, BRP) vs. Power supply voltage (VDD) 2. 1 S-5743NBx9A 2. 2 S-5743NBx0A 2. 3 S-5743NBx8A 2. 4 S-5743NBx1A 13 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series 3. Current consumption (IDD) vs. Temperature (Ta) 4. Current consumption (IDD) vs. Power supply voltage (VDD) 6. Output delay time (tD) vs. Power supply voltage (VDD) 8. Output voltage (VOUT) vs. Power supply voltage (VDD) 6.0 IDD [mA] 5.0 VDD = 12.0 V 4.0 VDD = 26.0 V 3.0 2.0 VDD = 2.7 V 1.0 0.0 −40 −25 5. 0 25 50 75 Ta [°C] 100 125 Output delay time (tD) vs. Temperature (Ta) 20 tD [μs] 15 10 VDD = 12.0 V VDD = 26.0 V VDD = 2.7 V 5 0 −40 −25 7. 0 25 50 75 Ta [°C] 100 125 Output voltage (VOUT) vs. Temperature (Ta) IOUT = 10 mA 14 IOUT = 10 mA 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.1.4_00 S-5743 A Series  Power Dissipation SOT-23-3S Tj = +150°C max. Power dissipation (PD) [W] 1.0 0.8 B A 0.6 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Ambient temperature (Ta) [°C] Board Power Dissipation (PD) A B C D E 0.63 W 0.76 W − − − 15 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. 2.9±0.2 1 2 3 +0.1 0.16 -0.06 0.95±0.1 1.9±0.2 0.4±0.1 No. MP003-D-P-SD-1.1 TITLE SOT233S-A-PKG Dimensions No. MP003-D-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.1 +0.25 ø1.0 -0 0.23±0.1 4.0±0.1 1.4±0.2 3.2±0.2 1 2 3 Feed direction No. MP003-D-C-SD-1.0 TITLE SOT233S-A-Carrier Tape No. MP003-D-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP003-D-R-SD-1.0 TITLE SOT233S-A-Reel No. MP003-D-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-5743NBH1A-M3T4U 价格&库存
很抱歉,暂时无法提供与“S-5743NBH1A-M3T4U”相匹配的价格&库存,您可以联系我们找货
S-5743NBH1A-M3T4U
  • 3000+5.132433000+0.61967
  • 6000+4.811666000+0.58094
  • 9000+4.571089000+0.55189
  • 15000+4.4107015000+0.53253
库存:5451
S-5743NBH1A-M3T4U
  • 1+12.860521+1.55272
  • 10+9.6215410+1.16166
  • 25+7.6972325+0.92933
  • 100+7.05701100+0.85203
  • 500+5.93447500+0.71650
  • 1000+5.292791000+0.63903
库存:5451
