S-8243BAEFT-TB-G
S-8243BAEFT-TB-G
    ABLIC(艾普凌科)
    TSSOP16
    IC BAT MFUNC LI-ION 3-4C 16TSSOP
S-8243BAEFT-TB-G 数据手册
S-8243A/B Series N BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK DE SI G www.ablicinc.com Rev.3.1_01 © ABLIC Inc., 2002-2016 The S-8243A/B Series is a protection IC for lithium-ion rechargeable battery. The S-8243A Series protects 3-series, the S-8243B Series protects 4-series cell pack from the overcharge, overdischarge, overcurrent voltages. This IC has a high-accuracy battery protection circuit and a battery monitor amplifier, and also a voltage regulator which operates the microcomputer or gas gauge IC. Combining this IC and a microcomputer or a gas gauge IC allows to display the amount of charge remained in a battery. W  Features High-accuracy voltage detection for each cell  Overcharge detection voltage n (n = 1 to 4) 3.9 V to 4.4 V (50 mV step) Accuracy 25 mV  Overcharge hysteresis voltage n (n = 1 to 4) of overcharge detection 0.10 V to 0.40 V (50 mV step) or 0 V Accuracy 50 mV (Overcharge release voltage n (= Overcharge detection voltage n  Overcharge hysteresis voltage n) can be selected within the range 3.8 V to 4.4 V.)  Overdischarge detection voltage n (n = 1 to 4) 2.0 V to 3.0 V (100 mV step) Accuracy 80 mV  Overdischarge hysteresis voltage n (n = 1 to 4) of overdischarge detection 0.15 V to 0.70 V or 0 V (50 mV step) Accuracy 100 mV (Overdischarge release voltage n (= Overdischarge detection voltage n  Overdischarge hysteresis voltage n) can be selected within the range 2.0 V to 3.4 V.) (2) Three-level overcurrent protection including protection for short-circuiting  Overcurrent detection voltage 1 0.05 V to 0.3 V (50 mV step) Accuracy 25 mV  Overcurrent detection voltage 2 0.5 V Accuracy 100 mV  Overcurrent detection voltage 3 VDD / 2 Accuracy 15 % (3) Delay times for overcharge detection, overdischarge detection and overcurrent detection 1 can be set by external capacitors. (Delay times for overcurrent detection 2 and 3 are fixed internally.) (4) Charge/discharge operation can be controlled through the control pins. (5) High-accuracy battery monitor amp GAMP = VBATTERY  0.2 1.0% (6) Voltage regulator VOUT = 3.3 V 2.4 % (3 mA max.) (7) High-withstand voltage Absolute maximum rating: 26 V (8) Wide operating voltage range 6 V to 18 V (9) Wide operating temperature range: 40°C to 85C (10) Low current consumption  Operation mode 120 A max.  Power down mode 0.1 A max. (11) Lead-free, Sn 100%, halogen-free*1 RE C OM M EN DE D FO R NE (1) *1. Refer to “ Product Name Structure” for details.  Applications T  Lithium-ion rechargeable battery packs  Lithium polymer rechargeable battery packs NO  Package  16-Pin TSSOP 1 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Block Diagrams Rev.3.1_01 VDD Battery protection DOP DE SI G 1. S-8243A Series VREG DOP,COP, RVCM,RVSM control Voltage regulator W COP Delay NE 200 nA Delay Delay 660 k FO VMP 660 k VREG 1.4 M R Delay 440 k CTL1 CTL2 1.4 M VREG 1.4 M Battery selection CTL3 D 1.4 M EN DE VC1 VBATOUT OM 1 M CCT CDT T Remark1. Diodes in the figure are parasitic diodes. 2. Numerical values are typical values. NO Battery monitor amp 5 M VSS 2 CTL4 1.4 M 1 M RE C VC3 1.4 M 5 M M VC2 VREG Figure 1 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 VDD Battery protection DOP DE SI G N 2. S-8243B Series VREG DOP, COP, RVCM, RVSM control Voltage regulator W COP Delay 200 nA NE Delay Delay 660k R FO 660 k VREG 1.4 M Delay 440 k VMP CTL1 Battery selection CTL2 1.4 M VREG 1.4 M CTL3 1.4 M VREG DE D VC1 EN VC2 1.4 M CTL4 1.4 M Battery monitor amp 1 M 5 M VBATOUT 5 M M 1 M OM VC3 RE C CCT CDT VSS NO T Remark1. Diodes in the figure are parasitic diodes. 2. Numerical values are typical values. Figure 2 3 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Product Name Structure x xx FT -  TB x DE SI G 1. Product Name S-8243 Rev.3.1_01 Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office IC direction in tape specifications*1 W Package name (abbreviation) FT: 16-Pin TSSOP NE Serial code*2 Sequentially set from AA to ZZ R Product series name A: 3-cell B: 4-cell FO *1. Refer to the tape drawing. *2. Refer to “3. Product Name List”. D 2. Package Drawing Code Tape Reel Environmental code = G Environmental code = U FT016-A-P-SD FT016-A-P-SD FT016-A-C-SD FT016-A-C-SD FT016-A-R-SD FT016-A-R-S1 EN 16-Pin TSSOP Package DE Package Name 3. Product Name List Overcharge hysteresis voltage [VHC] Overdischarge detection voltage [VDL] Overdischarge hysteresis voltage [VHD] 4.350 0.025 V 4.350 0.025 V 0.15 0.05 V 0.35 0.05 V 2.40 0.08 V 2.40 0.08 V 0.20 0.10 V 0V RE C S-8243AACFT-TB-x S-8243AADFT-TB-x Overcharge detection voltage [VCU] OM Product name / Item M Table 1 S-8243A Series (For 3-Serial Cell) Product name / Item NO T S-8243BADFT-TB-x S-8243BAEFT-TB-x S-8243BAFFT-TB-x S-8243BAHFT-TB-x Overcharge detection voltage Overcurrent 0 V battery detection voltage1 charging [VIOV1] function 0.20 0.025 V 0.20 0.025 V Available Available Table 2 S-8243B Series (For 4-Serial Cell) [VCU] Overcharge hysteresis voltage [VHC] Overdischarge detection voltage [VDL] Overdischarge hysteresis voltage [VHD] 4.350 0.025 V 4.350 0.025 V 4.250 0.025 V 4.315 0.025 V 0.25 0.05 V 0.15 0.05 V 0.25 0.05 V 0.20 0.05 V 2.40 0.08 V 2.40 0.08 V 2.40 0.08 V 2.00 0.08 V 0V 0.20 0.10 V 0V 0.15 0.10 V Overcurrent 0 V battery detection voltage1 charging [VIOV1] function 0.25 0.025 V 0.20 0.025 V 0.20 0.025 V 0.20 0.025 V Available Available Available Available Remark 1. Change in the detection voltage is available in products other than listed above. Contact our sales office. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 N  Pin Configuration 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 VREG CTL1 CTL2 CTL3 CTL4 VBATOUT CCT CDT W VDD DOP COP VMP VC1 VC2 VC3 VSS DE SI G 16-Pin TSSOP Top view NE Figure 3 Table 3 Pin description (S-8243A Series) Description EN DE D FO R Input pin for positive power supply, Connection pin for battery 1’s positive voltage Connection pin for discharge control FET gate (CMOS output) Connection pin for charge control FET gate (Nch open drain output) Pin for voltage detection between VDD-VMP pin (Pin for overcurrent detection) No connection Connection pin for battery 1’s negative voltage, for battery 2’s positive voltage Connection pin for battery 2’s negative voltage, for battery 3’s positive voltage Input pin for negative power supply, Connection pin for battery 3’s negative voltage Connection pin to capacitor for overdischarge detection delay, for overcurrent detection delay 1 Connection pin to capacitor for overcharge detection delay Output pin for battery voltage and offset voltage Pin for selecting output from VBATOUT pin Pin for selecting output from VBATOUT pin Control pin for charge / discharge FET Control pin for charge / discharge FET Output pin for voltage regulator (3.3 V) M Symbol VDD DOP COP VMP VC1 VC2 VC3 VSS CDT CCT VBATOUT CTL4 CTL3 CTL2 CTL1 VREG OM Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Symbol 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 VDD DOP COP VMP VC1 VC2 VC3 VSS CDT CCT VBATOUT CTL4 CTL3 CTL2 CTL1 VREG Description Input pin for positive power supply, Connection pin for battery 1’s positive voltage Connection pin for discharge control FET gate (CMOS output) Connection pin for charge control FET gate (Nch open drain output) Pin for voltage detection between VDD-VMP pin (Pin for overcurrent detection) Connection pin for battery 1’s negative voltage, for battery 2’s positive voltage Connection pin for battery 2’s negative voltage, for battery 3’s positive voltage Connection pin for battery 3’s negative voltage, for battery 4’s positive voltage Input pin for negative power supply, Connection pin for battery 4’s negative voltage Connection pin to capacitor for overdischarge detection delay, for overcurrent detection delay 1 Connection pin to capacitor for overcharge detection delay Output pin for battery voltage and offset voltage Pin for selecting output from VBATOUT pin Pin for selecting output from VBATOUT pin Control pin for charge / discharge FET Control pin for charge / discharge FET Output pin for voltage regulator (3.3 V) NO T RE C Pin No. Table 4 Pin description (S-8243B Series) 5 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Absolute Maximum Ratings VMP pin Input voltage DOP pin output voltage COP pin output voltage VREG pin output voltage CTL1 pin input voltage CTL2 to CTL4 pin input voltage Cell voltage output voltage VMP VDOP VCOP VOUT VCTL1 VCTLn VBATOUT Power dissipation PD V VSS0.3 to VSS26 VSS0.3 to VDD0.3 VSS0.3 to VSS26 VSS0.3 to VDD0.3 VSS0.3 to VDD0.3 VSS0.3 to VOUT0.3 VSS0.3 to VOUT0.3 300 (When not mounted on board) 1100*1 40 to 85 40 to 125 V V V V V V V mW mW C C FO Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm  76.2 mm  t1.6 mm (2) Board name: JEDEC STANDARD51-7 VSS0.3 to VDD0.3 W VIN NE Input voltage Applied Pins  VC1, VC2, VC3, CCT, CDT VMP DOP COP VREG CTL1 CTL2, CTL3, CTL4 VBATOUT     (Ta = 25C unless otherwise specified) Absolute Maximum Ratings Unit VSS0.3 to VSS26 V R Symbol VDS DE SI G Table 5 Item Input voltage VDD Rev.3.1_01 DE D Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1000 EN Power Dissipation (PD) [mW] 1200 800 RE C OM M 600 400 200 0 0 50 100 150 Ambient Temperature (Ta) [C] NO T Figure 4 Power Dissipation of Package (When Mounted on Board) 6 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Electrical Characteristics Symbol Conditions VCUn 3.9 V to 4.4 V, 50 mV Step VHCn 0.10 V to 0.40 V, and 0 V VDLn 2.0 V to 3.0 V, 100 mV Step VHDn 0.15 V to 0.70 V, and 0 V Overcurrent detection voltage 1 VIOV1 0.05 V to 0.3 V, 50 mV Step VM voltage based on VDD VM voltage based on VDD  Min. VCUn 0.025 VHCn 0.05 VDLn 0.08 VHDn 0.10 VIOV1 0.025 0.40 VDD0.425 VCUn VHCn VDLn NE Item BATTERY PROTECTION Overcharge detection voltage n n=1, 2, 3 Overcharge hysteresis voltage n n = 1, 2, 3 Overdischarge detection voltage n = 1, 2, 3 Overdischarge hysteresis voltage n = 1, 2, 3 (Ta = 25C unless otherwise specified) Typ. Max. Unit Test circuit W Table 6 (1 / 2) DE SI G 1. S-8243A Series VHDn VIOV1 VCUn 0.025 VHCn 0.05 VDLn 0.08 VHDn 0.10 VIOV1 0.025 0.60 VDD0.575 V 4 V 4 V 4 V 4 V 4 NO T RE C OM M EN DE D FO R Overcurrent detection voltage 2 VIOV2 0.50 V 4 Overcurrent detection voltage 3 VIOV3 VDD0.5 V 4 Temperature coefficient for Ta = 5C to 55C*3 TCOE1 1.0 0 1.0 mV/C 4 *1 detection and release voltage Temperature coefficient for Ta = 5C to 55C*3 TCOE2 0.5 0 0.5 mV/C 4 *2 overcurrent detection voltage 0 V BATTERY CHARGING FUNCTION (The 0 V battery function is either "0 V battery charging is allowed." or "0 V battery charging is inhibited." depending upon the product type.) 0 V battery charge starting charger V0CHA 0 V battery charging available  0.8 1.5 V 7 voltage 0 V battery charge inhibition battery V0INH 0 V battery charging unavailable 0.4 0.7 1.1 V 7 voltage INTERNAL RESISTANCE Internal resistance between RVDM V1 = V2 = V3 = 3.5 V 500 1100 2400 k 8 VMP and VDD Internal resistance between RVSM V1 = V2 = V3 = 1.8 V 300 700 1500 k 8 VMP and VSS VOLTAGE REGULATOR Output voltage VOUT VDD = 14 V, IOUT = 3 mA 3.221 3.300 3.379 V 2 Line regulation VOUT1 VDD = 6 V18 V, IOUT = 3 mA  5 15 mV 2 Load regulation VOUT2 VDD = 14 V, IOUT = 5 A3 mA  15 30 mV 2 BATTERY MONITOR AMP Input offset voltage n VOFFn V1 = V2 = V3 = 3.5 V 60 165 270 mV 3 n = 1, 2, 3 Voltage gain n GAMPn V1 = V2 = V3 = 3.5 V 0.20.99 0.2 0.21.01  3 n = 1, 2, 3 INPUT VOLTAGE, OPERATING VOLTAGE Operating voltage between VDSOP  6  18 V 4 VDD and VSS CTL1 input voltage for High VCTL1H  VDD0.8   V 6 CTL1 input voltage for Low VCTL1L    VDD0.2 V 6 CTLn input voltage for High VCTLnH  VOUT0.9  VOUT V 3, 6 n = 2, 3, 4 CTLn input voltage for Low VCTLnL    VOUT0.1 V 3, 6 n = 2, 3, 4 7 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Table 6 (2 / 2) Symbol Remarks Min. Typ. Max. Unit Test circuit 65 120 A 1  0.1 A 1 0 0.3 A 3 2.0 7.2 A 3 1.0 4.0 A 3 0.4 0.2  A 5  2.5 5 A 9 5 2.5  A 9  10   0.1  A A 9 9 10   A 9 10 100 100       A A A 9 9 9 V1 = V2 = V3 = 3.5 V, VMP = VDD  IPDN V1 = V2 = V3 = 1.5 V, VMP = VSS  IVCnN V1 = V2 = V3 = 3.5 V 0.3 IVC2 V1 = V2 = V3 = 3.5 V  IVC3 V1 = V2 = V3 = 3.5 V  ICTL1L V1 = V2 = V3 = 3.5 V, VCTL1 = 0 V ICTLnH VCTLn = VOUT ICTLnL VCTLn = 0 V ICOH ICOL VCOP = 24 V VCOP = VSS0.5 V Source current DOP IDOH VDOP = VDD0.5 V Sink current DOP Source current VBATOUT Sink current VBATOUT IDOL IVBATH IVBATL VDOP = VSS0.5 V VBATOUT = VDD0.5 V VBATOUT = VSS0.5 V NE R FO D DE Applied to S-8243AACFT and S-8243AADFT W IOPE DE SI G Item INPUT CURRENT Current consumption at not monitoring VBATOUT Current consumption at power down Current for VCn at not monitoring VBATOUT (n = 2, 3) Current for VC2 at monitoring of VBATOUT Current for VC3 at monitoring of VBATOUT Current for CTL1 at Low Current for CTLn at High n = 2,3,4 Current for CTLn at Low n = 2,3,4 OUTPUT CURRENT Leak current COP Sink current COP N Rev.3.1_01 NO T RE C OM M EN Item Symbol Conditions Min. Typ. Max. Unit Test circuit DELAY TIME Overcharge detection delay time tCU CCT = 0.1 F 0.5 1.0 1.5 s 5 Overdischarge detection delay time tDL CDT = 0.1 F 50 100 150 ms 5 Overcurrent detection delay time 1 tlOV1 CDT = 0.1 F 5 10 15 ms 5 Overcurrent detection delay time 2 tlOV2  1.5 2.5 4.0 ms 4 Overcurrent detection delay time 3 tlOV3  100 300 600 s 4 *1. Temperature coefficient for detection and release voltage is applied to overcharge detection voltage n, overcharge release voltage n, overdischarge detection voltage n, and overdischarge release voltage n. *2. Temperature coefficient for overcurrent detection voltage is applied to over current detection voltage 1 and 2. *3. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by design, not tested in production. 8 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Symbol Conditions VCUn 3.9 V to 4.4 V, 50 mV Step VHCn 0.10 V to 0.40 V, and 0 V VDLn 2.0 V to 3.0 V, 100 mV Step VHDn 0.15 V to 0.70 V, and 0 V VIOV1 Overcurrent detection voltage 2 VIOV2 0.05 V to 0.3 V, 50 mV Step VM voltage based on VDD VM voltage based on VDD Overcurrent detection voltage 3 VIOV3  VCUn 0.025 VHCn 0.05 VDLn 0.08 VHDn 0.10 VIOV1 0.025 0.40 VDD 0.425 R Overcurrent detection voltage 1 Min. (Ta = 25C unless otherwise specified) Typ. Max. Unit Test circuit VCun VHCn VDLn VHDn NE Item DETECTION VOLTAGE Overcharge detection voltage n n = 1, 2, 3, 4 Overcharge hysteresis voltage n n = 1, 2, 3, 4 Overdischarge detection voltage n = 1, 2, 3, 4 Overdischarge hysteresis voltage n = 1, 2, 3, 4 W Table 7 (1 / 2) DE SI G N 2. S-8243B Series VIOV1 0.50 VDD 0.5 VCUn 0.025 VHCn 0.05 VDLn 0.08 VHDn 0.10 VIOV1 0.025 0.60 VDD 0.575 V 4 V 4 V 4 V 4 V 4 V 4 V 4 NO T RE C OM M EN DE D FO Temperature coefficient for Ta = 5C to 55C*3 TCOE1 1.0 0 1.0 mV/C 4 *1 detection and release voltage Temperature coefficient for Ta = 5C to 55C*3 TCOE2 0.5 0 0.5 mV/C 4 *2 overcurrent detection voltage 0 V BATTERY CHARGING FUNCTION (The 0 V battery function is either "0 V battery charging is allowed." or "0 V battery charging is inhibited." depending upon the product type.) 0 V battery charge starting charger V0CHA 0 V battery charging allowed  0.8 1.5 V 7 voltage 0 V battery charge inhibition battery V0INH 0 V battery charging inhibited 0.4 0.7 1.1 V 7 voltage INTERNAL RESISTANCE Internal resistance between RVDM V1 = V2 = V3 = V4 = 3.5 V 500 1100 2400 k 8 VMP and VDD Internal resistance between RVSM V1 = V2 = V3 = V4 = 1.8 V 300 700 1500 k 8 VMP and VSS VOLTAGE REGULATOR Output voltage VOUT VDD = 14V, IOUT = 3 mA 3.221 3.300 3.379 V 2 Line regulation VOUT1 VDD = 6 V18 V, IOUT = 3 mA  5 15 mV 2 Load regulation VOUT2 VDD = 14 V, IOUT = 5 A3 mA  15 30 mV 2 BATTERY MONITOR AMP Input offset voltage n VOFFn V1 = V2 = V3 = V4 = 3.5 V 60 165 270 mV 3 n = 1, 2, 3, 4 Voltage gain n GAMPn V1 = V2 = V3 = V4 = 3.5 V 0.20.99 0.2 0.21.01  3 n = 1, 2, 3, 4 INPUT VOLTAGE, OPERATING VOLTAGE Operating voltage between VDSOP  6  18 V 4 VDD and VSS CTL1 input voltage for High VCTL1H  VDD0.8   V 6 CTL1 input voltage for Low VCTL1L    VDD0.2 V 6 CTLn input voltage for High VCTLnH  VOUT0.9  VOUT V 3, 6 n = 2, 3, 4 CTLn input voltage for Low VCTLnL    VOUT0.1 V 3, 6 n = 2, 3, 4 9 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Remarks Min. Unit Test circuit 120 A 1  0.1 A 1 0 0.3 A 3 3.2 10.4 A 3 2.0 7.2 A 3 1.0 4.0 A 3 0.4 0.2  A 5  2.5 5 A 9 5 2.5  A 9  10 10 10 100 100       0.1      A A A A A A 9 9 9 9 9 9 Conditions Min. Typ. Max. Unit Test circuit   0.5 50 5 1.5 100 1.0 100 10 2.5 300 1.5 150 15 4.0 600 s ms ms ms s 5 5 5 4 4 V1 = V2 = V3 = V4 = 3.5 V, VMP = VDD  IPDN V1 = V2 = V3 = V4 = 1.5 V, VMP = VSS  IVCnN V1 = V2 = V3 = V4 = 3.5 V 0.3 IVC1 V1 = V2 = V3 = V4 = 3.5 V  IVC2 V1 = V2 = V3 = V4 = 3.5 V  IVC3 V1 = V2 = V3 = V4 = 3.5 V, VCTL1 = 0 V  ICTL1L V1 = V2 = V3 = V4 = 3.5 V, VCTL1 = 0 V ICTLnH VCTLn = VOUT ICTLnL VCTLn = 0 V ICOH ICOL IDOH IDOL IVBATH VCOP = 24 V VCOP = VSS0.5 V VDOP = VDD0.5 V VDOP = VSS0.5 V VBATOUT = VDD0.5 V IVBATL VBATOUT = VSS0.5 V 65 NE FO D Max. W IOPE Typ. DE SI G Symbol DE Item INPUT CURRENT Current consumption at not monitoring VBATOUT Current consumption at power down Current for VCn at not monitoring VBATOUT (n = 2, 3) Current for VC1 at monitoring of VBATOUT Current for VC2 at monitoring of VBATOUT Current for VC3 at monitoring of VBATOUT Current for CTL1 at Low Current for CTLn at High n = 2, 3, 4 Current for CTLn at Low n = 2, 3, 4 OUTPUT CURRENT Leak current COP Sink current COP Source current DOP Sink current DOP Source current VBATOUT Sink current VBATOUT R Table 7 (2 / 2) N Rev.3.1_01 Symbol CCT = 0.1 F CDT = 0.1 F CDT = 0.1 F M tCU tDL tlOV1 tlOV2 tlOV3 OM Item DELAY TIME Overcharge detection delay time Overdischarge detection delay time Overcurrent detection delay time 1 Overcurrent detection delay time 2 Overcurrent detection delay time 3 EN Applied to S-8243BAEFT, S-8243BAFFT, S-8243BAHFT RE C Applied to S-8243BADFT NO T Item Symbol Conditions Min. Typ. Max. Unit Test circuit DELAY TIME Overcharge detection delay time tCU CCT = 0.1 F 0.5 1.0 1.5 s 5 Overdischarge detection delay time tDL CDT = 0.1 F 55.5 111 222 ms 5 Overcurrent detection delay time 1 tlOV1 CDT = 0.1 F 3.31 6.62 13.2 ms 5 Overcurrent detection delay time 2 tlOV2  1.5 2.5 4.0 ms 4 Overcurrent detection delay time 3 tlOV3  100 300 600 s 4 *1. Temperature coefficient for detection and release voltage is applied to overcharge detection voltage n, overcharge release voltage n, overdischarge detection voltage n, and overdischarge release voltage n. *2. Temperature coefficient for overcurrent detection voltage is applied to over current detection voltage 1 and 2. *3. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by design, not tested in production. 10 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Test Circuits DE SI G In this chapter test methods are explained for the case of S-8243B Series, which is designed for 4-serial cell pack. For the case of S-8243A Series, which is designed for 3-serial cell, voltage source V2 should be shorted, V3 should be read as V2, and V4 as V3. 1. Current consumption (Test circuit 1) W Current consumption at not monitoring VBATOUT, IOPE, is a current measured at the VSS pin when V1 = V2 = V3 = V4 = 3.5 V and VMP = VDD. Current consumption at power down, IPDN, is a current measured at the VSS pin when V1 = V2 = V3 = V4 = 1.5 V and VMP = VSS. 2. Voltage regulator (Test circuit 2) FO R NE Output voltage of the regulator VOUT is a voltage measured at the VREG pin when VDD = VMP = 14 V and IOUT = 3 mA. Line regulation of the voltage regulator VOUT1 is defined by the equation VOUT1 = VOUT2VOUT1 where VOUT1 is the output voltage when VDD = VMP = 6 V and IOUT = 3 mA, and VOUT2 is the output voltage when VDD = VMP = 18 V and IOUT = 3 mA. Load regulation of the regulator is defined by the equation VOUT2 = VOUT3VOUT where VOUT3 is the output voltage when VDD = VMP = 14 V and IOUT = 5 A. 3. Battery monitor amp and pin current for VC1 to VC3 (Test circuit 3) DE D Voltage gain of the battery monitor amp for each cell is defined by the input offset voltage and the measurement result provided from the VBATOUT pin for the combination of the CTL3 pin and CTL4 pin expressed by the following table at the condition where V1 = V2 = V3 = V4 = 3.5 V. Pin current for VC1 to VC3, IVCn and IVCnN are at the same time measured. Table 8 CTL4 pin status VCTL3H min. VCTL3H min. VCTL3H min. Open Open Open VCTL3L max. VCTL3L max. VCTL4H min. Open VCTL4L max. VCTL4H min. Open VCTL4L max. VCTL4H min. Open VBATOUT pin output OM M EN CTL3 pin status VOFF1 VBAT1 VOFF2 VBAT2 VOFF3 VBAT3 VOFF4 VBAT4 VCn (n = 1, 2, 3) pin current IVC1 at VC1 pin  IVC2 at VC2 pin  IVC3 at VC3 pin  IVCnN at VCn pin (n = 1, 2, 3)  NO T RE C Voltage gain of the battery monitor amp for each cell is calculated by the equation GAMPn = (VBATnVOFFn) / Vn (n = 1 to 4) 11 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 DE SI G N 4. Overcharge detection voltages, overcharge hysteresis voltages, overdischarge detection voltages, overdischarge hysteresis voltages, and overcurrent detection voltages (Test circuit 4) 4. 1 Overcharge detection voltages, overcharge hysteresis voltages, overdischarge detection voltages and overdischarge hysteresis voltages NE W In the following VMP = VDD and the CDT pin is open. The COP pin and the DOP pin should provide “Low”, which is a voltage equal to VDD  0.1 V or lower, in the condition that V1 = V2 = V3 = V4 = 3.5 V. The overcharge detection voltage VCU1 is defined by the voltage at which COP pin voltage becomes “High”, which is a voltage equal to VDD  0.9 V or higher, when the voltage V1 is gradually increased from the starting condition V1 = 3.5 V. The overcharge release voltage VCL1 is defined by the voltage at which COP pin voltage becomes “Low” when the voltage V1 is gradually decreased. The overcharge hysteresis voltage VHC1 is then defined by the difference between the overcharge detection voltage VCU1 and the overcharge release voltage VCL1. FO R The overdischarge detection voltage VDL1 is defined by the voltage at which DOP pin voltage becomes “High” when the voltage V1 is gradually decreased from the starting condition V1 = 3.5 V. The overdischarge release voltage VDU1 is defined by the voltage at which DOP pin voltage becomes “Low” when the voltage V1 is gradually increased. The overdischarge hysteresis voltage VHD1 is then defined by the difference between the overdischarge release voltage VDU1 and the overdischarge detection voltage VDL1. Other overcharge detection voltage VCUn, overcharge hysteresis voltage VHCn, overdischarge detection voltage VDLn, and overdischarge hysteresis voltage VHDn ( for n = 2 to 4) are defined in the same manner as in the case for n = 1. 4. 2 Overcurrent detection voltages DE D Starting condition is V1 = V2 = V3 = V4 = 3.5 V, VMP = VDD, and the CDT pin is open. The DOP pin voltage thus provides “Low” The overcurrent detection voltage 1, VIOV1 is defined by the voltage difference VDD  VMP at which the DOP pin voltage becomes “High” when the voltage of VMP pin is decreased. M EN Starting condition for measuring the overcurrent detection voltage 2 and 3 is V1 = V2 = V3 = V4 = 3.5 V, VMP = VDD and the CDT pin voltage VCDT = VSS . The DOP pin voltage thus provides “Low”. The overcurrent detection voltage 2, VIOV2 is defined by the voltage difference VDDVMP at which the DOP pin voltage becomes “High” when the voltage of VMP pin is decreased. OM The overcurrent detection delay time 2, tIOV2 is a time needed for the DOP pin to become “High” from “Low” when the VMP pin voltage is changed quickly to VIOV2 min.0.2 V from the starting condition VMP = VDD. The overcurrent detection voltage 3, VIOV3 is defined by the voltage of the VMP pin at which the DOP pin voltage becomes “High” when the voltage of VMP pin is decreased at the speed 10 V / ms. NO T RE C The overcurrent detection delay time 3, tIOV3 is a time needed for the DOP pin to become “High” from “Low” when the VMP pin voltage is changed quickly to VIOV3 min.0.2 V from the starting condition VMP = VDD. 12 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Starting condition is V1 = V2 = V3 = V4 = 3.5 V and VMP = VDD. Current that flows between the CTL1 pin and VSS is the CTL1 pin current ICTL1L. DE SI G N 5. CTL1 pin current, overcharge detection delay time, overdischarge detection delay time, and overcurrent detection delay time 1 (Test circuit 5) The overcharge detection delay time tCU is a time needed for the COP pin voltage to change from “Low” to “High” just after the V1 voltage is rapidly increased from 3.5 V to 4.5 V. The overdischarge detection delay time tDL is a time needed for the DOP pin voltage to change from “Low” to “High” just after the V1 voltage is rapidly decreased from 3.5 V to 1.5 V. 6. Input voltages for CTL1 and CTL2 (Test circuit 6) NE W The overcurrent detection delay time 1 is a time needed for the DOP pin voltage to change from “Low” to “High” just after the VMP pin voltage is decreased from VDD to VDD0.35 V when V1 = 3.5 V. D FO R Starting condition is V1 = V2 = V3 = V4 = 3.5 V. Pin voltages of the COP and the DOP should be “High” when VCTL1 = VCTL1H min. and CTL2 is OPEN. Pin voltages of the COP and the DOP should be “Low” when VCTL1 = VCTL1L max. and CTL2 is OPEN. Pin voltage of the COP is “High” and the pin voltage of the DOP is “Low” when VCTL1 = VCTL1L max. and VCTL2 = VCTL2H min. Pin voltage of the COP is “Low” and the pin voltage of the DOP is “High” when VCTL1 = VCTL1L max. and VCTL2 = VCTL2L max. DE 7. 0 V battery charge starting charger voltage and 0 V battery charge inhibition battery voltage (Test circuit 7) One of the 0 V battery charge starting charger voltage and 0 V battery charge inhibition battery voltage is applied to each product according to the 0 V battery charging function. EN Starting condition is V1 = V2 = V3 = V4 = 0 V for a product in which 0 V battery charging is available. The COP pin voltage should be lower than V0CHA max.1 V when the VMP pin voltage VMP = V0CHA max. NO T RE C OM M Starting condition is V1 = V2 = V3 = V4 = V0INH for a product in which 0 V battery charging is inhibited. The COP pin voltage should be higher than VMP1 V when the VMP pin voltage VMP = 24 V. 13 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 N 8. Internal resistance (Test circuit 8) DE SI G The resistance between VDD and VMP is RVDM and is calculated by the equation RVDM = VDD / IVDM where IVDM is a VMP pin current after VMP is changed to VSS from the starting condition V1 = V2 = V3 = V4 = 3.5 V and VMP = VDD. The resistance between VSS and VMP is RVSM and is calculated by the equation RVSM = VDD / IVSM where IVSM is a VMP pin current at the condition V1 = V2 = V3 = V4 = 1.8 V and VMP = VDD. 9. Pin current for CTL2 to CTL4, COP, DOP, VBATOUT (Test circuit 9) NE W Starting condition is V1 = V2 = V3 = V4 = 3.5 V. Pin current for CTL2 at “High” is ICTL2H and is obtained by setting VCTL2 = VOUT. Pin current for CTL2 at “Low” is ICTL2L and is obtained by setting VCTL2 = VSS. Pin current for CTL3 and CTL4 can be obtained in the same manner as in the CTL2. R Pin current for COP at “High” is ICOH and is obtained by setting V1 = V2 = V3 = V4 = 6 V, VMP = VDD, and VCOP = VDD. And pin current for COP at “Low” is ICOL and is obtained by setting V1 = V2 = V3 = V4 = 3.5 V, VMP = VDD, and VCOP = 0.5 V. Pin current for DOP at “Low” is IDOL and is obtained by setting V1 = V2 = V3 = V4 = 3.5 V, VMP = VDD, and VDOP = 0.5 V. And pin current for COP at “High” is ICOH and is obtained by setting V1 = V2 = V3 =V4 = 3.5 V, VMP = VDD1 V, and VDOP = VDD0.5 V. V4 A 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT 9 DE V3 CTL1 15 CTL2 14 EN V2 2 DOP 3 COP VREG 16 1 VDD D VREG 16 1 VDD V1 FO Pin current for VBATOUT at “High” is IVBATH and is obtained by setting CTL3 and CTL4 are open and VBATOUT = VOFF30.5 V. And pin current for VBATOUT at “Low” is IVBATL and is obtained by setting VBATOUT = VOFF30.5 V. 2 DOP CTL1 15 3 COP CTL2 14 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT 9 V C11 F C11 F M Test circuit 1 2 DOP 3 COP V2 V3 V4 4 VMP CTL1 15 CTL3 13 5 VC1 CTL4 12 V2 6 VC2 VBATOUT 11 V3 T NO V1 A A 7 VC3 1 VDD VREG 16 2 DOP CTL1 15 3 COP CTL2 14 CTL2 14 A 8 VSS 14 R11 M VREG 16 RE C V1 Test circuit 2 OM 1 VDD CCT 10 CDT V 9 IOUT V4 V V 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT 9 C11 F C11 F Test circuit 3 Test circuit 4 Figure 5 (1 / 2) VREG 16 2 DOP CTL1 15 3 COP 4 VMP V1 5 VC1 V2 V3 V4 R11 M A CTL2 14 CTL3 13 V1 CTL4 12 6 VC2 VBATOUT 11 V2 7 VC3 CCT 10 V3 8 VSS CDT V 9 V4 V V3 V CTL1 15 3 COP CTL2 14 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 V2 CCT 10 7 VC3 V4 V1 R V2 8 VSS CDT 9 D C11 F CTL1 15 A 3 COP CTL2 14 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT V1 V2 V3 A VBATOUT 11 CCT 10 8 VSS CDT 9 C11 F V3 V4 A VREG 16 2 DOP CTL1 15 3 COP CTL2 14 4 VMP CTL3 13 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT 9 C11 F Test circuit 8 A A A 9 OM V4 6 VC2 7 VC3 EN VREG 16 CTL4 12 M 1 VDD 2 DOP CTL3 13 5 VC1 DE Test circuit 7 A CTL2 14 4 VMP 1 VDD VREG 16 FO V1 CTL1 15 3 COP Test circuit 6 R11 M 2 DOP VREG 16 NE Test circuit 5 1 VDD 1 VDD 2 DOP W C30.1 F C20.1 F C11 F DE SI G 1 VDD N BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 C11 F Test circuit 9 NO T RE C Figure 5 (2 / 2) 15 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Operation Rev.3.1_01 DE SI G 1. Battery protection circuit Remark Refer to “ Battery Protection IC Connection Example”. Battery protection protects batteries from overcharge and overdischarge, and also protects external FETs from overcurrent. 1. 1 Normal status W When the voltage of each of the batteries is in the range from VDLn to VCUn and the discharge current is lower than a specified value (the VMP pin voltage is lower than VIOV1), the charging and discharging FETs are turned on. NE 1. 2 Overcharge status R When the voltage of one of the batteries becomes higher than VCUn and the state continues for tCU or longer, the COP pin becomes high impedance and is pulled up to EB pin voltage by an external resistor, and the charging FET is turned off to stop charging. The overcharge status is released when one of the following two conditions holds. (a) The voltage of each of the batteries becomes lower than VCUn  VHCn. (b) VDDVMPVIOV1 (A load is connected, and discharging starts.) FO 1. 3 Overdischarge status DE 1. 3. 1 Power-down function D When the voltage of one of the batteries becomes lower than VDLn and the state continues for tDL or longer, the DOP pin voltage becomes VDD level, and the discharging FET is turned off to stop discharging. This is the overdischarge status. M EN In the overdischarge status, when the VMP pin voltage is VIOV3 or lower, the power-down function starts to operate and almost every circuit in the S-8243A/B Series stops working. When the power-down function is operating, the VMP pin is pulled down to VSS level by the internal resistor RVSM. The conditions of each output pin are as follows. (a) COP High-Z Charging FET is turned off (b) DOP VDD Discharging FET is turned off (c) VREG VSS Voltage regulator circuit is off (d) VBATOUT VSS Battery voltage monitor amp circuit is off OM The power down function is released when the following condition holds. (a) VMP>VIOV3 (A charger is connected, and charging starts.) RE C The overdischarge status is released when the following condition holds. (a) The voltage of each of the batteries is VDLn or higher, and the VMP pin voltage is VDD / 2 or higher. (A charger is connected.) 1. 4 Overcurrent status NO T The S-8243A/B Series has three overcurrent detection levels (VIOV1, VIOV2 and VIOV3) and three overcurrent detection delay times (tIOV1, tIOV2 and tIOV3) corresponding to each overcurrent detection levels. When the discharging current becomes higher than a specified value (the voltage between VDD and VMP is greater than VIOV1) and the state continues for tIOV1 or longer, the S-8243A/B Series enters the overcurrent status in which the DOP pin voltage becomes VDD level to turn off the discharging FET to stop discharging, the COP pin becomes high impedance and is pulled up to EB pin voltage by an external resistor to turn off the charging FET to stop charging, and the VMP pin is pulled up to VDD voltage by the internal resistor RVDM. Operation of two other overcurrent detection levels (VIOV2 and VIOV3) and overcurrent detection delay times (tIOV2 and tIOV3) is the same as that for VIOV1 and tIOV1. The overcurrent status is released when the following condition holds. (a) VMP> {VIOV3 / (1VIOV3)  3 / 52 / 5}  RVDM (A load is released, and the impedance between the EB and EB pin becomes higher. ) 16 N BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 1. 5 0 V battery charging function DE SI G Regarding the charging of a self-discharged battery (0 V battery) the S-8243A/B Series has two functions from which one should be selected. (a) 0 V battery charging is allowed (0 V battery charging is available) When a charger voltage is higher than V0CHA, 0 V battery can be charged. (b) 0 V battery charging is forbidden (0 V battery charging is impossible) When the voltage of one of the batteries is lower than V0INH, 0 V battery can not be charged. W Caution When the VDD pin voltage is lower than minimum of VDSOP, the operation of S-8243A/B Series is not guaranteed. 1. 6 Delay time setting NE Overcharge detection delay times (tCU1 to tCU4) are determined by the external capacitor at the CCT pin. Overdischarge detection delay times (tDL1 to tDL4) and overcurrent detection delay time 1 (tIOV1) are determined by the external capacitor at CDT pin. Overcurrent detection delay time 2, 3 (tIOV2, tIOV3) are fixed internally. FO R S-8243AAC, S-8243AAD, S-8243BAE, S-8243BAF, S-8243BAH min. typ. max. tCU [s] = Delay factor ( 5 10 15 )  CCT [F] tDL [ms] = Delay factor ( 500 1000 1500 )  CDT [F] tIOV1 [ms] = Delay factor ( 50 100 150 )  CDT [F] = Delay factor ( = Delay factor ( = Delay factor ( typ. 10 1110 66.2 max. 15 )  CCT [F] 2220 )  CDT [F] 132 )  CDT [F] EN 2. Voltage regulator circuit min. 5 555 33.1 DE tCU [s] tDL [ms] tIOV1 [ms] D S-8243BAD Built-in voltage regulator can be used to drive a micro computer, etc. The voltage regulator supplies voltage of 3.3 V (3 mA maximum) and an external capacitor is needed. M Caution When the power-down function operates, the voltage regulator output is pulled down to the VSS level by an internal resistor. OM 3. Battery monitor amp circuit Battery monitor amp sends information of the batteries to a microcomputer. The battery monitor amp output is controlled and selected by CTL3 and CTL4 pins to give the following two voltages. RE C (a) VBATn = GAMPn  VBATTERYn  VOFFn where GAMPn is the n-th voltage gain of the amp, VBATTERYn is the n-th battery voltage, and VOFFn is the n-th offset voltage of the amp. (b) N-th offset voltage VOFFn Each battery voltage VBATTERYn (n = 1 to 4) is thus calculated by following equation. VBATTERYn = (VBATn  VOFFn) / GAMPn (n = 1, 2, 3, 4) NO T After the state of CTL3 and CTL4 are changed, a time between 25 s and 250 s is needed for the battery monitor amp to become stable. Caution When the power-down function operates, the battery monitor amp output is pulled down to the VSS level by an internal resistor. 17 Rev.3.1_01 N BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series 4. CTL pins DE SI G The S-8243A/B Series has four control pins. The CTL1 and CTL2 pins are used to control the COP and DOP pin output voltages. CTL1 takes precedence over CTL2. CTL2 takes precedence over the battery protection circuit. The CTL3 and CTL4 pins are used to control the VBATOUT pin output voltage. Table 9 CTL1 and CTL2 Mode Output CTL1 pin CTL2 pin External discharging FET External charging FET High High OFF OFF High Open OFF OFF High Low OFF OFF Open High OFF OFF Open Open OFF OFF Open Low OFF OFF Normal*1 OFF*2 Low High Normal*1 Normal*1 Low Open Normal*1 Low Low OFF *1. States are controlled by voltage detection circuit. *2. Off state is brought after the overcharge detection delay time tCU. FO R NE W Input Table 10 CTL3 and CTL4 Mode OM M EN DE D Input Output CTL3 pin CTL4 pin VBATOUT (A series) VBATOUT (B series) High High V1 Offset V1 Offset High Open V1  0.2  V1 Offset V1  0.2  V1 Offset High Low Don’t use. V2 Offset Open High Don’t use. V2  0.2  V2 Offset Open*1 Open*1 V2 Offset V3 Offset Open Low V2  0.2  V2 Offset V3  0.2  V3 Offset Low High V3 Offset V4 Offset Low Open V3  0.2  V3 Offset V4  0.2  V4 Offset Low Low Don’t use. Don’t use. *1. CTL3 and CTL4 pins should be open when a microcomputer is not used. NO T RE C Caution Please note unexpected behavior might occur when electrical potential difference between the CTL pin (“L” level) aMSS is generated through the external filter (RVSS and CVSS) as a result of input voltage fluctuations. 18 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 N  Timing Charts DE SI G 1. Overcharge detection, Overdischarge detection VCUn VCLn Battery voltage VDUn VDLn W (n = 1 to 4) VDD NE DOP pin voltage VSS High-Z VSS VIOV3 DE VMP pin voltage M VBATOUT pin *1 voltage EN VSS VOUT VBAT High-Z D VDD VIOV1 FO COP pin voltage R VEB+ OM VSS VDD VOUT RE C VREG pin voltage VSS Charger connected T Load connected *2 Overdischarge detection delay time (tDL) NO Status Overcharge detection delay time (tCU) *1. State depends on CTL3 and CTL4 input levels. Refer to Figure 9. *2. : Normal status, : Overcharge status, : Overdischarge status, : Power down status Remark The charger is assumed to charge with a constant current. VEB+ indicates the open voltage of the charger. Figure 6 19 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 VHC VCU VCL DE SI G Battery voltage N 2. Overcurrent detection VDU VDL VHD W VDD NE DOP pin voltage VSS COP pin voltage VBAT VSS VREG pin voltage D OM VDD EN VBATOUT *2 pin voltage *1 VRETURN M VOUT High-Z DE VDD VIOV1 VIOV2 VIOV3 VSS High-Z FO High-Z VSS VMP pin voltage R VEB+ VOUT RE C VSS Charger connected Load connected *3 T Status Overcurrent detection delay time 1 ( tIOV1) Overcurrent detection delay time 2 ( tIOV2) Overcurrent detection delay time 3 ( tIOV3) NO *1. VRETURN = VDD / 6 (typ.) *2. State depends on CTL3 and CTL4 input levels. Refer to Figure 9. *3. : Normal status, : Overcurrent status Remark The charger is assumed to charge with a constant current. VEB+ indicates the open voltage of the charger. Figure 7 20 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 DOP pin Voltage VDD VDD VDD VDD VDD VDD High-Z High-Z High-Z High-Z High-Z High-Z VSS VEB+ COP pin Voltage VOUT VDD EN VOUT OPEN M VSS RE C VSS OM VDD OPEN *1 DE VDD VOUT Normal D VOUT VSS CTL2 pin Voltage *1 FO VSS CTL1 pin Voltage Normal R VBAT VBATOUT *2 pin Voltage VREG pin Voltage High-Z VDD NE VSS Normal*1 Normal*1 W VDD DE SI G N 3. CTL1, CTL2 pin voltage *1. State depends on each battery voltage and the VMP pin voltage. *2. State depends on CTL3 and CTL4 input levels. Refer to Figure 9. NO T Figure 8 21 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series DE SI G N 4. CTL3, TL4 pin voltage VDD DOP pin *1 voltage (1) (1) (1) (1) (1) (1) (1) (1) (1) (1) (1) (1) V1  0.2 Don’t use Don’t use (1) VSS VREG pin voltage VOUT OPEN V3  0.2 Don’t use NE (1) V2 offset V2 offset FO D V2 offset V2  0.2 V1  0.2 V1 offset V2  0.2 V2 offset V3 offset V3 offset V3  0.2 V3 offset V3 offset V4  0.2 V4 offset V4 offset Don’t use RE C VSS (1) OM VOUT CTL3 pin voltage (1) M VSS VDD (1) EN VDD V1 offset DE VOUT S-8243B (4-serial cell) VBAT VBATOUT VOFF pin voltage V1 offset VSS (1) R VSS VOUT S-8243A (3-serial cell) VBAT VBATOUT VOFF pin voltage V1 offset VSS W VEB+ COP pin *1 voltage Rev.3.1_01 VDD CTL4 pin voltage VOUT OPEN T VSS NO *1. State depends on CTL1 and CTL2 and each battery voltage and the VMP pin voltage. Refer to Figure 6 to 8. 22 Figure 9 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Battery Protection IC Connection Example Discharging FET DE SI G 1. S-8243A Series Charging FET EB+ RCOP RVMP CTL1 RDOP 1 VDD VREG 16 2 DOP CTL1 15 CVREG 3 COP CTL2 14 4 VMP CTL3 13 W RCTL1 RCTL2 CVC2 RVC3 RCTL3 CTL4 12 RCTL4 6 VC2 VBATOUT 11 7 VC3 CCT 10 RVBAT CVC3 CVSS R RVC2 S-8243A NE 5 VC1 Microcomputer 8 VSS 9 FO RVSS CDT CCCT CCDT EB- DE D Figure 10 Table 11 Constants for External Components Part Typ. Range 0.51 to 1*1 1 RVC2 1 0.51 to 1*1 2 RVC3 1 2.2 to 10*1 3 RVSS 10 4 RDOP 5.1 2 to 10 5 RCOP 1 0.1 to 1 6 RVMP 5.1 1 to 10 7 RCTL1 1 1 to 100 8 RCTL2 1 1 to 10 9 RCTL3 1 1 to 10 10 RCTL4 1 1 to 10 11 RVBAT 0 0 to 100 0.047 to 0.22*1 12 CVC2 0.047 0.047 to 0.22*1 13 CVC3 0.047 2.2 to 10*1 14 CVSS 4.7 15 CCCT 0.1 More than 0.01 16 CCDT 0.1 More than 0.02 17 CVREG 4.7 0.68 to 10 *1. Please set up a filter constant to be RVSS  CVSS  22 F   and to be RVC2  CVC2 = RVC3  CVC3 = RVSS  CVSS. Unit k k  k M k k k k k k F F F F F F NO T RE C OM M EN No. Caution1. No resistance should be inserted in the power supply pin VDD. 2. The above constants are subject to change without prior notice. 3. It has not been confirmed whether the operation is normal or not in circuits other than the above example of connection. In addition, the example of connection shown above and the constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 23 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Charging FET DE SI G Discharging FET N 2. S-8243B Series Rev.3.1_01 EB+ RCOP RVMP CTL1 RDOP 1 VDD VREG 16 2 DOP CTL1 15 CVREG RCTL1 3 COP CTL2 14 4 VMP CTL3 13 RVC1 CVC2 RVC2 RCTL3 5 VC1 CTL4 12 6 VC2 VBATOUT 11 7 VC3 CCT 10 RCTL4 RVBAT CVC3 CVSS 8 VSS CDT 9 CCCT R RVC3 S-8243B Microcomputer NE CVC1 W RCTL2 RVSS FO CCDT EB- D Figure 11 DE Table 12 Constants for External Components NO T RE C OM M EN No. Part Typ. Range 0.51 to 1*1 1 RVC1 1 0.51 to 1*1 2 RVC2 1 0.51 to 1*1 3 RVC3 1 2.2 to 10*1 4 RVSS 10 5 RDOP 5.1 2 to 10 6 RCOP 1 0.1 to 1 7 RVMP 5.1 1 to 10 8 RCTL1 1 1 to 100 9 RCTL2 1 1 to 10 10 RCTL3 1 1 to 10 11 RCTL4 1 1 to 10 12 RVBAT 0 0 to 100 0.047 to 0.22*1 13 CVC1 0.047 0.047 to 0.22*1 14 CVC2 0.047 0.047 to 0.22*1 15 CVC3 0.047 2.2 to 10*1 16 CVSS 4.7 17 CCCT 0.1 More than 0.01 18 CCDT 0.1 More than 0.02 19 CVREG 4.7 0.68 to 10 *1. Please set up a filter constant to be RVSS  CVSS  22 F   and to be RVC1  CVC1 = RVC2  CVC2 = RVC3  CVC3 = RVSS  CVSS. Unit k k k  k M k k k k k k F F F F F F F Caution1. No resistance should be inserted in the power supply pin VDD. 2. The above constants are subject to change without prior notice. 3. It has not been confirmed whether the operation is normal or not in circuits other than the above example of connection. In addition, the example of connection shown above and the constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 24 Rev.3.1_01 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series N  Precautions DE SI G  Pay attention to the operating conditions for input/output voltage and load current so that the power loss in the IC does not exceed the package power dissipation.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. NO T RE C OM M EN DE D FO R NE W  ABLIC Inc. shall not be responsible for any patent infringement by products including the S-8243A/B Series, the method of using the S-8243A/B Series in such products, the product specifications or the country of destination thereof. 25 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 N  The Example of Application Circuit DE SI G 1. S-8243A Series EB VREG CTL1 REG VREG 16 VCC S-8243A CTL1 15 3 COP CTL2 14 CTL2 4 VMP CTL3 13 CTL3 6 VC2 VBATOUT 11 7 VC3 CCT 10 8 VSS CDT VREG CTL4 VREG VCELL1 THON 9 LED5 DISP VOUT ESCL NE CTL4 12 LED3 Bq2063 LED4 2 DOP 5 VC1 LED2 W 1 VDD LED1 ESCD VCC A0 SCL A2 WP GND S-24C A1 SDA SMBC SMBus SMBD R VT FO RB1 VSS HDQ SR2 SR1 SRC D EB DE Figure 12 EN 2. S-8243B Series VREG CTL1 REG VCC CTL1 15 3 COP CTL2 14 CTL2 4 VMP CTL3 13 CTL3 VOUT VCC A0 5 VC1 CTL4 12 CTL4 ESCL SCL 6 VC2 VBATOUT 11 VCELL1 ESCD SDA A2 WP GND M 2 DOP OM 26 LED2 VREG 16 7 VC3 CCT 10 8 VSS CDT LED3 VREG Bq2063 LED4 VREG THON 9 LED5 DISP S-24C A1 SMBC SMBD SMBus VT HDQ RB1 T NO Caution LED1 1 VDD S-8243B RE C EB+ VSS SR2 SR1 SRC EB- Figure 13 The above connection example will not guarantee successful operation. Perform thorough evaluation using the actual application. BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 N  Characteristics (Typical Data) S-8243BAF IOPEVDD 120 100 80 80 IOPE [A] 100 60 40 60 40 20 20 0 0 0 4 8 12 16 20 40 20 0 24 VDD [V] S-8243BAF S-8243BAF IPDNVDD IPDNTemp 0.10 0.08 IPDN [A] 0.08 FO 0.06 0.06 0.04 0.04 0.02 0.00 0.00 40 20 8 12 16 20 VDD [V] 24 0 20 40 60 80 Ta [°C] DE 4 D 0.02 0 60 80 R 0.10 IPDN [A] 20 40 Ta [°C] NE IOPE [A] IOPETemp 120 W S-8243BAF DE SI G 1. Current consumption 2. Overcharge detection/release voltage, overdischarge detection/release voltage, overcurrent detection voltages, and delay times EN 4.05 3.99 3.95 40 20 0 20 40 60 80 Ta [°C] 20 40 60 80 2.425 2.400 2.375 2.350 2.325 2.300 40 20 Ta [°C] S-8243BAF VIOV1VDD 0.225 0.220 0.215 0.210 0.205 0.200 0.195 0.190 0.185 0.180 0.175 10 12 0 20 40 60 80 Ta [°C] S-8243BAF VIOV1 [V] VIOV1 [V] VDLTemp 0 VDUTemp 2.500 2.475 2.450 3.97 20 40 60 80 T VDL [V] S-8243BAF NO S-8243BAF VDU [V] VCL [V] M 0 4.01 Ta [°C] 2.48 2.46 2.44 2.42 2.40 2.38 2.36 2.34 2.32 40 20 VCLTemp 4.03 OM 4.275 4.270 4.265 4.260 4.255 4.250 4.245 4.240 4.235 4.230 4.225 40 20 S-8243BAF VCU Temp RE C VCU [V] S-8243BAF 14 VDD [V] 16 0.225 0.220 0.215 0.210 0.205 0.200 0.195 0.190 0.185 0.180 0.175 40 20 VIOV1Temp 0 20 40 60 80 Ta [°C] 27 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series 0.40 S-8243BAF 0.40 VIOV3VDD 0.575 0.55 VIOV3 / VDD VIOV2 [V] 0.45 0.50 0.50 0.55 0.60 14 VDD [V] S-8243BAF 0.575 12 14 S-8243BAF tCUCCT 15 0.550 16 VDD [V] tCU  Temp CCT = 0.1 F NE VIOV3Temp 10 20 40 60 80 Ta [°C] S-8243BAF 0.475 0.425 40 20 0 16 0.500 W 12 0.525 0.450 0.60 10 2.5 0.475 R tCU [s] 0.500 10 5 0.450 0.425 0 40 20 0 20 40 60 80 0 0.4 0.8 1.0 0.5 0.0 40 20 1.0 0 DE CCT [F] S-8243BAF S-8243BAF tDLCDT 250 tDL  Temp CDT = 0.1 F EN 1500 0.6 1.5 D Ta [°C] 0.2 tCU [s] 2.0 0.525 FO VIOV3 / VDD S-8243BAF 0.550 0.45 VIOV2 [V] VIOV2  Temp VDD Reference N VIOV2VDD VDD Reference DE SI G S-8243BAF Rev.3.1_01 20 40 60 80 Ta [°C] S-8243BAF tIOV1CDT 150 tDL [ms] M 0 0 0.2 OM tDL [ms] 500 0.4 0.6 0.8 tIOV1 [ms] 200 1000 150 100 0 0 40 20 0 1.0 NO 5 40 20 0 28 tIOV2  Temp 4.0 Ta [°C] 0.6 0.8 1.0 tIOV3  Temp 600 500 3.5 3.0 2.5 400 300 200 1.5 20 40 60 80 0.4 S-8243BAF S-8243BAF 2.0 0 0.2 CDT [F] tIOV3 [s] 10 0 20 40 60 80 Ta [°C] tIOV2 [ms] 15 T tIOV1 [ms] 20 RE C 25 tIOV1  Temp CDT = 0.1 F 50 50 CDT [F] S-8243BAF 100 40 20 0 20 40 60 80 Ta [°C] 100 40 20 0 20 40 60 80 Ta [°C] BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 ICOHVCOP 0.10 ICOL [mA] 0.06 0.04 0.02 0.00 0 4 8 ICOLVCOP 40 35 30 25 20 15 10 5 0 0 12 16 20 24 3.5 S-8243BAF 3 25 20 15 10 5 0 4 5 3.6 5.4 R 2 7.2 FO IDOL [mA] IDOH [mA] 1 1.8 14.0 IDOLVDOP 40 35 30 D 0 0 3.5 7.0 10.5 14.0 VDOP [V] DE VDOP [V] 4. Voltage regulator S-8243BAF EN S-8243BAF VOUT  Temp 3.6 3.5 3.8 3.3 3.2 3.1 3.0 0 20 40 60 80 RE C 40 20 VOUT [V] M 3.4 OM VOUT [V] 10.5 S-8243BAF IDOHVDOP 0 7.0 VCOP [V] NE VCOP [V] VOUTVDD VDD = 024 V, Ta = 25°C 4.0 VOUTIOUT V1 = V2 = V3 = V4 = VBAT IOUT = 5 A 3.0 3.3 100 A 2.8 10 mA 18 V 2.0 2.3 VDD = 6 V 0.0 0 4 8 12 16 20 24 10 V 14 V 1.0 3 mA VDD [V] Ta [°C] S-8243BAF VOUT [V] ICOH [A] 0.08 DE SI G S-8243BAF W S-8243BAF N 3. COP / DOP pin current 0 20 40 60 80 100 IOUT [mA] S-8243BAF 4.0 VOUTIOUT 2.0 NO VOUT [V] T 3.0 85°C 25°C 1.0 Ta = 40°C 0.0 0 20 40 60 80 100 IOUT [mA] 29 BATTERY PROTECTION IC FOR 3-SERIAL OR 4-SERIAL CELL PACK S-8243A/B Series Rev.3.1_01 VOFFVBAT V1 = V2 = V3 = V4 = VBAT 180 S-8243BAF 180 175 160 VOFF3 170 VOFF2 165 160 VOFF3 155 VOFF4 150 150 1 2 3 4 5 VOFF1 40 20 0 VBAT [V] 20 R GAMP4 FO GAMP3 0.200 0.199 GAMP2 GAMP1 0.198 40 20 0 20 40 60 80 NO T RE C OM M EN DE Ta [°C] 0.200 NE GAMP  Temp GAMP4 GAMP2 GAMP1 0.198 40 60 80 Ta [°C] D GAMP 0.201 GAMP3 0.199 VOFF4 S-8243BAF 0.202 GAMP VOFF2 GAMPVBAT V1 = V2 = V3 = V4 = VBAT 0.201 W VOFF1 165 155 30 0.202 175 170 VOFF [mV] VOFF [mV] S-8243BAF VOFF  Temp DE SI G S-8243BAF N 5. Battery monitor amp 1 2 3 4 VBAT [V] 5 N 9 1 8 R NE W 16 DE SI G 5.1±0.2 DE D FO 0.17±0.05 0.22±0.08 OM M EN 0.65 NO T RE C No. FT016-A-P-SD-1.2 TITLE TSSOP16-A-PKG Dimensions FT016-A-P-SD-1.2 No. ANGLE UNIT mm ABLIC Inc. +0.1 N 4.0±0.1 ø1.5 -0 0.3±0.05 8.0±0.1 1.5±0.1 NE ø1.6±0.1 W DE SI G 2.0±0.1 (7.2) +0.4 16 8 9 Feed direction No. FT016-A-C-SD-1.1 NO T RE C OM M EN 1 DE D 6.5 -0.2 FO R 4.2±0.2 TITLE TSSOP16-A-Carrier Tape No. FT016-A-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. NE W DE SI G N 21.4±1.0 FO R 17.4±1.0 D 2±0.5 ø13±0.2 OM M EN ø21±0.8 DE Enlarged drawing in the central part +2.0 17.4 -1.5 NO T RE C No. FT016-A-R-SD-2.0 TITLE TSSOP16-A- Reel FT016-A-R-SD-2.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 2,000 NE W DE SI G N 21.4±1.0 FO R 17.4±1.0 D 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part +2.0 17.4 -1.5 No. FT016-A-R-S1-1.0 TITLE TSSOP16-A- Reel No. FT016-A-R-S1-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. EN DE D FO R NE W DE SI G N 1. M 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. OM 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE C 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. T 14. For more details on the information described herein, contact our sales office. NO 2.0-2018.01 www.ablicinc.com
S-8243BAEFT-TB-G 价格&库存
很抱歉,暂时无法提供与“S-8243BAEFT-TB-G”相匹配的价格&库存,您可以联系我们找货
