NJM4558
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM4558 is a dual high-gain operational amplifier with
internal compensation circuit and constructed on a single silicon
chip. It offers excellent characteristics by combining the
parameters adjusted for a monolithic chip. The channel separation
characteristic is suitable for measuring instruments.
■ FEATURES
● Operating Voltage
● High Voltage Gain
● High Input Resistance
● Bipolar Technology
● Package Outline
■ PACKAGE OUTLINE
NJM4558D
( DIP8 )
NJM4558M
NJM4558V
( SSOP8 )
NJM4558L
( SIP8 )
( DMP8 )
( ±4V~±18V )
( 100dB typ. )
( 5MΩ typ. )
DIP8, DMP8, SIP8
SOP8 JEDEC 150mil,
SSOP8
NJM4558E
( SOP8 )
■ PIN CONFIGURATION
( Top View )
1
8
A
2
A
B
7
B
3
4
6
5
NJM4558D, NJM4558M,
NJM4558E, NJM4558V
1
2
3
4
5
NJM4558L
6
7
8
PIN FUNCTION
1. A OUTPUT
2. A - INPUT
3. A +INPUT
4. V
5. B +INPUT
6. B - INPUT
7. B OUTPUT
8. V
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
V+
- INPUT
+ INPUT
OUTPUT
V-
Ver.2019-02-21
-1-
NJM4558
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
+ V /V
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 30
± 15 ( note1 )
( DIP8 ) 500
( DMP8 ) 300
( SOP8 ) 300
( SSOP8 ) 250
( SIP8 ) 800
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note1 ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( V+/V-=±15V,Ta=25˚C )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Resistance
Large Signal Voltage Gain
Maximum Output Voltage Swing 1
Maximum Output Voltage Swing 2
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Operating Current
Slew Rate
Equivalent Input Noise Voltage (note2)
Gain Bandwidth Product
SYMBOL
VIO
IIO
IB
RIN
AV
VOM1
VOM2
VICM
CMR
SVR
ICC
SR
VNI
GB
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥10kΩ
RL≥2kΩ
RS≤10kΩ
RS≤10kΩ
RIAA,RS=2.2kΩ,30kHz LPF
MIN.
0.3
86
± 12
± 10
± 12
70
76.5
TYP.
0.5
5
25
5
100
± 14
± 13
14
90
90
3.5
1
1.4
3
MAX.
6
200
500
5.7
UNIT
mV
nA
nA
MΩ
dB
V
V
V
dB
dB
mA
V/μs
μVrms
MHz
(note2) In regard to Noise Standard, NJRC is preparing for special D Rank type products (VNI=1.8µV max.) except for SSOP package.
-2-
Ver.2019-02-21
NJM4558
■ TYPICAL CHARACTERISTICS
Open Loop Voltage Gain vs. Frequency
Maximum Output Voltage Swing vs. Frequency
V+/V-=±15V, RL=2kΩ, Ta=25ºC
30
Maximum Output Voltage Swing Vopp [V]
Open Loop Voltage Gain Av [dB]
120
100
80
60
40
10
100
1k
10k
100k
1M
25
10
5
10M
1
10
Frequency f [Hz]
28
26
24
22
16
14
10k
Equivalent Input Noise Voltage en [nV/√Hz]
Maximum Output Voltage Swing V opp [V]
30
1k
Load Resistance RL [Ω]
100k
V+/V-=±15V, RS=50Ω, AV=60dB, Ta=25ºC
100
10
1
1
10
100
Frequency f [Hz]
V+/V-=±15V, RL=10kΩ
15
Maximum Output Voltage Swing [V]
9
8
7
6
5
4
3
2
1
Ver.2019-02-21
-25
50
75
100
Ambient Temperature Ta [ºC]
1k
Maximum Output Voltage Swing vs. Temperature
V+/V-=±15V
-50
1M
1000
Operating Current vs. Temperature
Operating Current Icc [mA]
10k
Equivalent Input Noise Voltage vs. Frequency
V /V =±15V, Ta=25ºC
12
100
1k
Frequency f [Hz]
Load Resistance
100
125
-9
+VOM
14
-10
13
-11
12
-12
-12
11
-13
-13
-VOM
-14
10
-50
-25
50
75
100
-14
125
-3-
NJM4558
Input Offset Voltage vs. temperature
Input Bias Current vs. Temperature
V+/V-=±15V
2
45
1.5
40
Input Bias Current IB [nA]
Input Offset Voltage VIO [mV]
V+/V-=±15V
1
0.5
-1
-1.5
35
30
25
10
-2
5
-50
-25
50
75
100
125
-50
vs. Operating Voltage
-25
50
75
100
Operating Current vs. Operating Voltage
RL=2kΩ, Ta=25ºC
Ta=25ºC
15
9
8
10
Operating Current ICC [mA]
125
+VOM
5
-VOM
-10
7
6
5
4
3
2
1
-15
±6
±8
±10
±12
±14
+ Operating Voltage V /V [V]
±16
±2
±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2019-02-21
很抱歉,暂时无法提供与“NJM4558DD”相匹配的价格&库存,您可以联系我们找货
