Order this document
by MJE18002D2/D
SEMICONDUCTOR TECHNICAL DATA
POWER TRANSISTORS
2 AMPERES
1000 VOLTS
50 WATTS
The MJE18002D2 use a newly developed technology, so called H2BIP*, to design
the state of art transistor dedicated to the Electronic Light Ballast and PFC** circuit.
The main advantages brought by these new transistors are:
Improved Global Efficiency Due to the Low Base Drive Requirements
DC Current Gain Typically Centered at 45
Extremely Low Storage Time Variation, Thanks to the Antisaturation Network
Easy to Use Thanks to the Integrated Collector/Emitter Diode
The MOTOROLA “Sig Sixma” philosophy provides tight and reproductible
parameter distribution.
* High speed High gain BIPolar transistor
** Power Factor Control
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
CASE 221A–06
TO–220AB
MAXIMUM RATINGS
Rating
Symbol
Value
Unit
Collector–Emitter Sustaining Voltage
VCEO
450
Vdc
Collector–Base Breakdown Voltage
VCBO
1000
Vdc
Collector–Emitter Breakdown Voltage
VCES
1000
Vdc
Emitter–Base Voltage
VEBO
12
Vdc
Collector Current — Continuous
— Peak (1)
IC
ICM
2
5
Adc
Base Current — Continuous
Base Current — Peak (1)
IB
IBM
1
2
Adc
*Total Device Dissipation @ TC = 25_C
*Derate above 25°C
PD
50
0.4
Watt
W/_C
TJ, Tstg
– 65 to 150
_C
RθJC
RθJA
2.5
62.5
_C/W
TL
260
_C
Operating and Storage Temperature
THERMAL CHARACTERISTICS
Thermal Resistance — Junction to Case
Thermal Resistance — Junction to Ambient
Maximum Lead Temperature for Soldering Purposes:
1/8″ from case for 5 seconds
(1) Pulse Test: Pulse Width = 5 ms, Duty Cycle ≤ 10%.
This document contains information on a new product. Specifications and information herein are subject to change without notice.
Designer’s and SWITCHMODE are trademarks of Motorola, Inc.
Motorola, Inc. 1995
Motorola Bipolar Power Transistor Device Data
1
MJE18002D2
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ELECTRICAL CHARACTERISTICS (TC = 25°C unless otherwise noted)
Characteristic
Symbol
Min
Typ
VCEO(sus)
450
570
Max
Unit
OFF CHARACTERISTICS
(IC = 100 mA, L = 25 mH)
Collector Cutoff Current
(VCE = Rated VCEO, IB = 0)
Collector Cutoff Current (VCE = Rated VCES, VEB = 0)
Collector Cutoff Current (VCE = 500 V, VEB = 0)
@ TC = 25°C
@ TC = 125°C
@ TC = 125°C
Emitter–Cutoff Current
(VEB = 10 Vdc, IC = 0)
Vdc
ICEO
100
µAdc
ICES
100
500
100
µAdc
IEBO
100
µAdc
ON CHARACTERISTICS
Base–Emitter Saturation Voltage
(IC = 0.4 Adc, IB = 40 mAdc)
(IC = 1 Adc, IB = 0.2 Adc)
Collector–Emitter Saturation Voltage
DC Current Gain
(IC = 0.4 Adc, VCE = 1 Vdc)
(IC = 1 Adc, VCE = 1 Vdc)
VBE(sat)
Vdc
@ TC = 25°C
@ TC = 25°C
0.78
0.87
1
1.1
@ TC = 25°C
@ TC = 125°C
0.36
0.5
0.6
1
@ TC = 25°C
@ TC = 125°C
0.4
0.65
0.75
1.2
VCE(sat)
Vdc
hFE
@ TC = 25°C
@ TC = 125°C
14
8
25
15
@ TC = 25°C
@ TC = 125°C
6
4
10
6
DYNAMIC CHARACTERISTICS
Current Gain Bandwidth
(IC = 0.5 Adc, VCE = 10 Vdc, f = 1 MHz)
Output Capacitance
(VCB = 10 Vdc, IE = 0, f = 1 MHz)
Input Capacitance
(VEB = 8 Vdc)
fT
13
Cob
50
100
pF
Cib
340
500
pF
VEC
1.2
1.5
V
MHz
DIODE CHARACTERISTICS
Forward Diode Voltage
(IEC = 1 Adc)
@ TC = 25°C
(IEC = 0.2 Adc)
@ TC = 25°C
@ TC = 125°C
0.9
0.6
1.2
(IEC = 0.4 Adc)
@ TC = 25°C
@ TC = 125°C
1
0.6
1.3
tfr
Forward Recovery Time
(IF = 0.2 Adc, di/dt = 10 A/µs)
@ TC = 25°C
(IF = 0.4 Adc, di/dt = 10 A/µs)
@ TC = 25°C
517
(IF = 1 Adc, di/dt = 10 A/µs)
@ TC = 25°C
480
2
540
ns
MJE18002D2
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
Characteristic
Symbol
Min
Typ
Max
Unit
100
94
150
ns
1.25
µs
SWITCHING CHARACTERISTICS: Resistive Load (D.C. ≤ 10%, Pulse Width = 20 µs)
Turn–on Time
Turn–off Time
IC = 1 Adc, IB1 = 0.2 Adc
IB2 = 0.5 Adc
VCC = 300 Vdc
@ TC = 25°C
@ TC = 125°C
ton
@ TC = 25°C
@ TC = 125°C
toff
0.95
1.5
SWITCHING CHARACTERISTICS: Inductive Load (Vclamp = 300 V, VCC = 15 V, L = 200 µH)
Fall Time
@ TC = 25°C
@ TC = 125°C
tf
130
120
175
ns
@ TC = 25°C
@ TC = 125°C
ts
0.55
0.7
0.65
µs
Crossover Time
@ TC = 25°C
@ TC = 125°C
tc
110
100
175
ns
Fall Time
@ TC = 25°C
@ TC = 125°C
tf
130
140
175
ns
@ TC = 25°C
@ TC = 125°C
ts
2.4
µs
Crossover Time
@ TC = 25°C
@ TC = 125°C
tc
275
350
350
ns
Fall Time
@ TC = 25°C
@ TC = 125°C
tf
100
100
150
ns
@ TC = 25°C
@ TC = 125°C
ts
1.05
1.45
1.2
µs
@ TC = 25°C
@ TC = 125°C
tc
100
115
150
ns
VCE(dsat)
7.4
Storage Time
Storage Time
Storage Time
IC = 0.4 Adc
IB1 = 40 mAdc
IB2 = 0.2 Adc
IC = 0.8 Adc
IB1 = 160 mAdc
IB2 = 160 mAdc
IC = 1 Adc
IB1 = 0.2 Adc
IB2 = 0.5 Adc
Crossover Time
2.1
3
DYNAMIC SATURATION VOLTAGE
Dynamic Saturation
Voltage:
Determined 1 µs and
3 µs respectively after
rising IB1 reaches
90% of final IB1
IC = 0.4 Adc
IB1 = 40 mA
VCC = 300 V
@ 1 µs
@ TC = 25°C
@ 3 µs
@ TC = 25°C
2.5
IC = 1 Adc
IB1 = 0.2 A
VCC = 300 V
@ 1 µs
@ TC = 25°C
11.7
@ 3 µs
@ TC = 25°C
1.3
V
3
MJE18002D2
PACKAGE DIMENSIONS
–T–
B
SEATING
PLANE
C
F
T
S
4
DIM
A
B
C
D
F
G
H
J
K
L
N
Q
R
S
T
U
V
Z
A
Q
1 2 3
U
H
K
Z
L
R
V
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION Z DEFINES A ZONE WHERE ALL
BODY AND LEAD IRREGULARITIES ARE
ALLOWED.
J
G
D
N
INCHES
MIN
MAX
0.570
0.620
0.380
0.405
0.160
0.190
0.025
0.035
0.142
0.147
0.095
0.105
0.110
0.155
0.018
0.025
0.500
0.562
0.045
0.060
0.190
0.210
0.100
0.120
0.080
0.110
0.045
0.055
0.235
0.255
0.000
0.050
0.045
0.080
STYLE 1:
PIN 1.
2.
3.
4.
MILLIMETERS
MIN
MAX
14.48
15.75
9.66
10.28
4.07
4.82
0.64
0.88
3.61
3.73
2.42
2.66
2.80
3.93
0.46
0.64
12.70
14.27
1.15
1.52
4.83
5.33
2.54
3.04
2.04
2.79
1.15
1.39
5.97
6.47
0.00
1.27
1.15
2.04
BASE
COLLECTOR
EMITTER
COLLECTOR
CASE 221A–06
TO–220AB
ISSUE Y
Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding
the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit,
and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters can and do vary in different
applications. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Motorola does
not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in
systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of
the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such
unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless
against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part.
Motorola and
are registered trademarks of Motorola, Inc. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer.
How to reach us:
USA / EUROPE: Motorola Literature Distribution;
P.O. Box 20912; Phoenix, Arizona 85036. 1–800–441–2447
JAPAN: Nippon Motorola Ltd.; Tatsumi–SPD–JLDC, Toshikatsu Otsuki,
6F Seibu–Butsuryu–Center, 3–14–2 Tatsumi Koto–Ku, Tokyo 135, Japan. 03–3521–8315
MFAX: RMFAX0@email.sps.mot.com – TOUCHTONE (602) 244–6609
INTERNET: http://Design–NET.com
HONG KONG: Motorola Semiconductors H.K. Ltd.; 8B Tai Ping Industrial Park,
51 Ting Kok Road, Tai Po, N.T., Hong Kong. 852–26629298
4
*MJE18002D2/D*
MJE18002D2/D
