PXP011-20QX
20 V, P-channel Trench MOSFET
5 January 2021
Product data sheet
1. General description
P-channel enhancement mode Field-Effect Transistor (FET) in an MLPAK33 (SOT8002) SurfaceMounted Device (SMD) plastic package using Trench MOSFET technology.
2. Features and benefits
Low threshold voltage
MLPAK33 package (3.3 x 3.3 mm footprint)
3. Applications
High-side load switch
Battery management
DC-to-DC conversion
Switching circuits
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
-20
V
VGS
gate-source voltage
-12
12
V
ID
drain current
-17.2
A
VGS = -4.5 V; ID = -10.5 A; Tj = 25 °C
9.1
11.4
mΩ
VGS = -2.5 V; ID = -8 A; Tj = 25 °C
14.8
19.7
mΩ
VGS = -4.5 V; Tamb = 25 °C; t ≤ 5 s
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and mounting pad for drain 6 cm .
PXP011-20QX
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
S
source
2
S
source
3
S
source
4
G
gate
5
D
drain
6
D
drain
7
D
drain
8
D
drain
Simplified outline
1
2
3
Graphic symbol
4
D
G
S
017aaa257
8
7
6
5
MLPAK33 (SOT8002-1)
6. Ordering information
Table 3. Ordering information
Type number
Package
PXP011-20QX
Name
Description
Version
MLPAK33
plastic thermal enhanced surface mounted package; mini leads;
8 terminals; pitch 0.65 mm; 3.3 x 3.3 x 0.8 mm body
SOT8002-1
7. Marking
Table 4. Marking codes
Type number
Marking code
PXP011-20QX
9AV
PXP011-20QX
Product data sheet
All information provided in this document is subject to legal disclaimers.
5 January 2021
Nexperia B.V. 2021. All rights reserved
2 / 14
PXP011-20QX
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
-20
V
VGS
gate-source voltage
-12
12
V
ID
drain current
[1]
-17.2
A
[1]
-10.5
A
VGS = -4.5 V; Tamb = 100 °C
[1]
-6.6
A
VGS = -4.5 V; Tsp = 25 °C
-56.6
A
-93
A
IDM
peak drain current
Tamb = 25 °C; single pulse; tp ≤ 10 µs
Ptot
total power dissipation
[1]
4.8
W
Tamb = 25 °C
[1]
1.8
W
50
W
Tsp = 25 °C
Tj
junction temperature
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
-1.7
A
Source-drain diode
IS
[1]
source current
Tamb = 25 °C
[1]
2
aaa-030137
120
Pder
Ider
80
80
40
40
Fig. 1.
aaa-030138
120
-25
25
75
Normalized total power dissipation as a
function of ambient temperature
PXP011-20QX
Product data sheet
125
175
Tamb (°C)
Fig. 2.
-25
75
125
175
Tamb (°C)
Normalized continous drain current as a
5 January 2021
25
3 / 14
PXP011-20QX
Nexperia
-103
ID
(A)
-102
aaa-032542
tp
Limit RDSon = VDS / ID
-10
1 ms
10 ms
DC; Tsp = 25 °C
-1
100 ms
-10-1
-10-2
-10-3
-10-4
-10-1
Fig. 3.
DC; Tamb = 25 °C;
6 cm2
-1
-10
-102
VDS (V)
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
PXP011-20QX
Product data sheet
5 January 2021
4 / 14
PXP011-20QX
Nexperia
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
Conditions
thermal resistance from in free air
junction to ambient
in free air; t ≤ 5 s
Rth(j-sp)
[1]
[2]
junction to solder point
Min
Typ
Max
Unit
[1]
145
185
K/W
[2]
55
70
K/W
[2]
21
26
K/W
1.5
2.5
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 6 cm .
aaa-031353
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.50
0.25
10
0.33
0.20
0.10
0.05
0.02
1
0.75
0.01
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
102
Zth(j-a)
(K/W)
aaa-031354
duty cycle = 1
0.50
10
0.25
0.75
0.33
0.20
0.10
0.05
0.02
0.01
1
10-3
10-2
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 5.
1
10
102
tp (s)
2
103
PXP011-20QX
Product data sheet
5 January 2021
5 / 14
PXP011-20QX
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = -250 µA; VGS = 0 V; Tj = 25 °C
-20
V
VGSth
gate-source threshold
voltage
ID = -250 µA; VDS = VGS; Tj = 25 °C
-0.7
-0.9
-1.25
V
IDSS
drain leakage current
VDS = -20 V; VGS = 0 V; Tj = 25 °C
-1
µA
IGSS
gate leakage current
VGS = -12 V; VDS = 0 V; Tj = 25 °C
-0.1
µA
VGS = 12 V; VDS = 0 V; Tj = 25 °C
0.1
µA
RDSon
resistance
9.1
11.4
mΩ
VGS = -4.5 V; ID = -10.5 A; Tj = 150 °C
12.9
16.2
mΩ
14.8
19.7
mΩ
gfs
forward
transconductance
VDS = -10 V; ID = -10.5 A; Tj = 25 °C
52
S
RG
gate resistance
f = 1 MHz
2.3
Ω
VDS = -10 V; ID = -10.5 A; VGS = -4.5 V;
Tj = 25 °C
43.4
65.1
nC
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
6.9
nC
QGS(th)
pre-threshold gatesource charge
3.7
nC
QGS(th-pl)
post-threshold gatesource charge
3.2
nC
QGD
gate-drain charge
14.2
nC
VGSpl
gate-source plateau
voltage
-1.7
V
Ciss
input capacitance
4200
pF
Coss
output capacitance
VDS = -10 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
630
pF
Crss
reverse transfer
capacitance
580
pF
td(on)
turn-on delay time
11
ns
tr
rise time
33
ns
td(off)
turn-off delay time
69
ns
tf
fall time
44
ns
VDS = -10 V; ID = -8 A; VGS = -4.5 V;
RG(ext) = 5 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = -1.7 A; VGS = 0 V; Tj = 25 °C
-0.7
-1.2
V
trr
reverse recovery time
28
ns
recovered charge
IS = -1.7 A; dIS/dt = 100 A/µs;
VGS = -4.5 V; VDS = -10 V; Tj = 25 °C
Qr
17
nC
ta
reverse recovery rise
time
13
ns
tb
reverse recovery fall
time
15
ns
PXP011-20QX
Product data sheet
5 January 2021
6 / 14
PXP011-20QX
Nexperia
aaa-032543
-40
-2.5 V
ID
(A)
-2 V
ID
(A)
-4.5 V
-30
aaa-032544
-10-3
-10-4
min
VGS = -1.8 V
-20
typ
max
-10-5
-10
-1.6 V
-1.4 V
Fig. 6.
-2
-3
-4
VDS (V)
-10-6
-5
-1
-1.5
VGS (V)
-2
Tj = 25 °C
VDS = -5 V; Tj = 25 °C
Output characteristics: drain current as a
Fig. 7.
function of drain-source voltage; typical values
Sub-threshold drain current as a function of
gate-source voltage
aaa-032545
80
-1.8 V
RDSon
-2 V
RDSon
60
60
40
40
VGS = -2.5 V
aaa-032546
80
Tj = 150 °C
-4.5 V
Tj = 25 °C
-20
-30
ID (A)
Tj = 25 °C
Fig. 8.
Product data sheet
-2
-4
-6
-8
-10
VGS (V)
ID = -10.5 A
Drain-source on-state resistance as a function
of drain current; typical values
PXP011-20QX
Fig. 9.
of gate-source voltage; typical values
5 January 2021
7 / 14
PXP011-20QX
Nexperia
aaa-032547
-40
aaa-032548
2
ID
(A)
a
-30
1.5
-20
1
-10
0.5
Tj = 150 °C
Tj = 25 °C
-1
-2
-3
VGS (V)
-4
120
Tj (°C)
180
VDS = -5 V
Fig. 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
aaa-032549
-2
Fig. 11. Normalized drain-source on-state resistance
as a function of junction temperature; typical
values
aaa-032550
104
VGS(th)
(V)
Ciss
C
(pF)
-1.5
max
-1
103
typ
Coss
Crss
min
-0.5
120
Tj (°C)
102
-10-1
180
Product data sheet
-10
VDS (V)
-102
Fig. 12. Gate-source threshold voltage as a function of
PXP011-20QX
-1
Fig. 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
5 January 2021
8 / 14
PXP011-20QX
Nexperia
aaa-032551
-5
VGS
(V)
VDS
-4
ID
-3
VGS(pl)
-2
VGS(th)
VGS
-1
QGS2
QGS1
QG (nC)
QGS
60
003aaa508
Fig. 15. Gate charge waveform definitions
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
003aal160
aaa-032552
-1.75
IS
(A)
-1.5
ID
(A)
-1.25
trr
ta
QGD
QG(tot)
tb
-1
Tj = 150 °C
0.25 IRM
Tj = 25 °C
-0.5
IRM
-0.25
t (s)
Fig. 16. Reverse recovery timing definition
-0.8
VSD (V)
-1.2
VGS = 0 V
Fig. 17. Source current as a function of source-drain
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 18. Duty cycle definition
PXP011-20QX
Product data sheet
5 January 2021
9 / 14
PXP011-20QX
Nexperia
12. Package outline
MLPAK33: plastic thermal enhanced surface mounted package; mini leads; 8 terminals;
SOT8002-1
X
b
(8x)
1
e
(6x)
v
w
C A B
C
y C
4
K
L1
(4x)
E2
L2
8
5
D2
B
A
A
8
5
θ
E
E1
E3
c
1
4
detail X
D
5 mm
scale
Dimensions (mm are the original dimensions)
A
b
max 0.90 0.35
nom 0.80 0.30
min 0.70 0.25
mm
c
D
D1
Seating Plane
y1 C
D1
Unit
C
D2
e
E
E1
E2
E3
K
0.18 3.50 3.25 2.65
3.50 3.10 1.99 0.25
0.65
0.15 3.30 3.15 2.55 0.65 3.30 3.00 1.89 0.20
(ref)
0.12 3.10 3.05 2.45
3.10 2.90 1.79 0.15
L1
L2
θ
0.40 0.58 12°
0.25 0.43 10°
0.10 0.28 8°
y
y1
0.05 0.05
v
w
0.1
0.05
sot8002-1_po
Outline
version
References
IEC
JEDEC
EIAJ
European
projection
Issue date
19-12-19
20-01-09
SOT8002-1
Fig. 19. Package outline MLPAK33 (SOT8002-1)
PXP011-20QX
Product data sheet
5 January 2021
10 / 14
PXP011-20QX
Nexperia
13. Soldering
Footprint information for reflow soldering of MLPAK33 package
SOT8002-1
3.55
2.60
2.45
2.35
0.50
2.68 2.58
0.20
3.25 3.80 4.05
0.70
0.95
0.52 0.62
0.20
0.70 0.60 0.50
0.30
0.65
0.40
0.15
0.50
0.25
2.65
recommended stencil thickness: 0.1 mm
occupied area
solder resist
solder lands
solder paste
Dimensions in mm
Issue date
19-12-20
sot8002-1_fr
Fig. 20. Reflow soldering footprint for MLPAK33 (SOT8002-1)
PXP011-20QX
Product data sheet
5 January 2021
11 / 14
PXP011-20QX
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PXP011-20QX v.1
Product data sheet
PXP011-20QX
Product data sheet
20210105
5 January 2021
12 / 14
PXP011-20QX
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PXP011-20QX
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
5 January 2021
13 / 14
PXP011-20QX
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 5
10. Characteristics............................................................ 6
11. Test information.......................................................... 9
12. Package outline........................................................ 10
13. Soldering................................................................... 11
14. Revision history........................................................12
15. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 5 January 2021
PXP011-20QX
Product data sheet
5 January 2021
14 / 14
