FR101G-FR107G
Technical Data
Data Sheet N0442, Rev. A
FR101G THRU FR107G
FAST RECOVERY GLASS PASSIVATED RECTIFIERS
Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Amperes
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Fast switching for high efficiency
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed: 260 C/10
seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension
Glass passivated chip junction
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
DO-41
Circuit Diagram
Mechanical Data
Case: JEDEC DO-41 molded plastic body
Terminals: Plated axial leads, solderable per
MIL-STD-202, Method 208
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight: 0.34 grams
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Characteristic
Symbol
FR
FR
FR
101G 102G 103G
FR
104G
FR
105G
5
100
3
70
2
400
1
280
4
600
2
420
VRRM
VDC
Maximum RMS voltage
VRMS
Maximum average forward rectified current
0.375”(9.5mm) lead length at @TA =55°C
I(AV)
1.0
A
Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
1.3
V
Maximum DC reverse current
At Rated DC Blocking Voltage
IRM
5.0
100
µA
@TA = 25°C
@TA = 100°C
35
250
8
1000
5
700
1
V
trr
Typical Junction Capacitance (Note 2)
CJ
15
pF
Typical Thermal Resistance Junction to
Ambient (Note 3)
RθJA
40
°C/W
TJ, TSTG
-65 to +150
°C
Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
500
1
V
Maximum reverse recovery time (Note 1)
Operating junction and storage temperature range
150
6
800
4
560
Units
Maximum repetitive peak reverse voltage
Maximum DC blocking voltage
50
1
200
7
140
FR
FR
106G 107G
ns
FR101G-FR107G
Technical Data
Ratings and Characteristics Curves
FR101G-FR107G
Technical Data
Mechanical Dimensions DO-41
SYMBOL
Ordering Information
Device
FR101G-FR107G
Package
DO-41
(Pb-Free)
Millimeters
Inches
Min.
Max.
Min.
Max.
A
25.4
1.000
B
4.06
5.21
0.160
0.205
C
0.71
0.864
0.028
0.034
D
2.00
2.72
0.079
0.107
Marking Diagram
Shipping
Where XXXXX is YYWWL
FR101G
SSG
YY
WW
L
5000pcs / tape
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
= Part Name
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Carrier Tape Specification DO-41
SYMBOL
Millimeters
Min.
Max.
A
4.50
5.50
B
50.9
53.9
Z
1.20
T
5.60
6.40
E
0.80
IL1-L2I
1.0
FR101G-FR107G
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“FR105GTA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+0.37710
- 100+0.33740
- 250+0.28280
- 500+0.25470
- 550+0.20210
- 1525+0.19100
