8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
1811
UPDATE POSITION NO.
2/16/2009
JH
F
3087
UPDATE 'B' TOLERANCE ON DIMENSION TABLE AND
PCB LAYOUT DRAWING, ADD GEOMETRIC
10/31/2014
TOLERANCE ON TAIL
LH
F
F
A
PIN 1
LEFT
B
.050 1.27
.100 2.54
PIN 1 LEFT
E
E
.089 2.25
.177 4.50
.084 2.14
.030 0.76
.050 1.27
RECOMMENDED PCB LAYOUT
GRPB_ _1VWTC-RC
GRPB_ _1VWTC-RC
(STANDARD)
D
D
A
.030 0.76
.084 2.14
PIN 1
RIGHT
.089 2.25
.050 1.27
PIN 1 RIGHT
.177 4.50
GRPB_ _1VWTD-RC
(OPPOSITE BEND, ONLY APPICABLE ON EVEN PIN COUNTS)
.100 2.54
C
A
.050 1.27
C
GRPB_ _1VWTD-RC
.118 3.00
.039 1.00
B
A
.083 2.10
B
.016 0.40
.138 3.50
NOTES:
1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK
*PROCESSING TEMPERATURE: 260°C FOR 10 SECONDS
2. CONTACT MATERIAL: BRASS
3. PLATING: .000030"-.000050" NICKEL UNDERPLATE, GOLD FLASH OVERALL
4. OPERATING TEMPERATURE: -40°C TO +105°C
5. INSULATION RESISTANCE: 5000 MEGA OHM MIN
6. CONTACT RESISTANCE: 20 MILLI OHM MAX
7. DIELECTRIC WITHSTANDING: 500 VAC
8. CURRENT RATING: 1 AMP
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
7
6
.004[0.10]
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .012 [0.3]
.XXX= .008 [0.20]
.XXXX= .0040 [0.100]
DRAWN
DATE
NAME
08/13/07 RAH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
.050" SINGLE ROW MALE HEADER, SMT
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
2
GRPB_ _1VWT_-RC
DWG. NO.
10962
SHEET 1 OF 1
1
REV
F
FILE NAME: 10962, GRPB_ _1VWT_-RC
A
很抱歉,暂时无法提供与“GRPB141VWTD-RC”相匹配的价格&库存,您可以联系我们找货
