FGG.00.303.CLAD35
www.lemo.com
SUMMARY
# Wires
Low voltage
3
Image is for illustrative purpose only
Series
00
Termination type
Male solder
IP rating
50
AWG wire size
34.00 - 28.00
Cable Ø
2.80 - 3.50 mm
Status
active
Matching parts
EGG.00.303.CLL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
3.41 g
Performance
Configuration
00.303 : 3 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
3 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.4 mm (0.016in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.05 mm^2 (AWG 30)
R (max): 8.7 mOhm
Vtest (contact-shell): 950 V (AC), 1300 V (DC)
Vtest (contact-contact): 800 V (AC), 1100 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
6.4
28.5
20.5
5.5
5
in.
0,25
1,12
0,81
0,22
0,20
RECOMMENDED BY LEMO
Tools
Caps:
BFG.00.100.PCSG
Cables
CMN.03.T28.031PGCE
PVC
CMN.03.T28.031PGZE
CMN.03.T28.031PNCE
GREY
Grey
PVC
Black
CMN.03.T28.031PNZE
2/3
3050
PVC
Black
3081
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.00.303.CLAD35”相匹配的价格&库存,您可以联系我们找货
