ASSEMBLY P/N
CUSTOMER APPROVAL
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
NOTES:
1. FINISHED ASSEMBLIES AND LOOSE PARTS BAGGED WITH AN INSTRUCTION SHEET
2. LABEL WITH CONXALL PART NUMBER, DATE CODE AND P/N BARCODE PLACED ON BAG
3. SEE DRAWING HPSFMISTD FOR HOLE PATTERNS
4. FOR FIELD INSTALLATION, SEE INSTRUCTION SHEET 2 OF 2.
5. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE
6. DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS
APPROVED BY:
DATE:
.750
19.1
(2) #4x3/8 IN
SELF TAPPING SCREWS
MAT'L: STAINLESS STEEL
CABLE STRAP
MAT'L: NYLON, BLACK
CUSTOMER PRINT
.770
19.6
18 KEY
11
SF8982-9SG-5XX
(9) #26
SF8982-10SG-5XX
(10) #26
SF8982-11SG-5XX
(11) #26
SF8982-12SG-5XX
(12) #26
SF8982-13SG-5XX
(13) #26
SF8982-14SG-5XX
(14) #26
SF8982-15SG-5XX
(15) #26
SF8982-16SG-5XX
(16) #26
SF8982-17SG-5XX
(17) #26
SF8982-18SG-5XX
(18) #26
520 = BACKSHELL WITH Ø.220 [5.6] GROMMET I.D.
530 = BACKSHELL WITH Ø.330 [8.4] GROMMET I.D.
1.429
36.3
.375
9.5
.967
24.6
.997
25.3
INSERT
MAT'L: PBT, BLACK
.141
3.6
1
17
12
12
10
2
9
3
16
4
14
8
7
15
5
6
2.30
58.4
11
17
2
10
3
9
16
8
5
INSULATOR TUBE
MAT'L: MYLAR
ADAPTER HOUSING
MAT'L: NICKEL PLATED BRASS
BACKSHELL
MAT'L: NYLON, BLACK
WASHER
MAT'L: NYLON
SF8982-18SG-5XX SHOWN
WITHOUT HARDWARE
18
1
13
4
14
13
WIRE VIEW
NO. OF CONTACT
HOUSING
15
7
FACE VIEW
SF8982-18SG-5XX
SHOWN
O-RING
MAT'L: SILICONE, RED
(X) #26 SOCKET CONTACTS, SOLDER
MAT'L: GOLD PLATED COPPER ALLOY
6
COPPER TAPE
1
PART
NUMBER:
SF8982-XSG-5XX
11
10
2
9
10
2
3 9
8
4
7
5
6
7
18
9
18
13
8
7
6
5
4
WIRE VIEW
SF8982-14SG-5XX
4
7
18
4
7
6
14
5
WIRE VIEW
SF8982-15SG-5XX
4
7
10
6
7
15
6
14
5
WIRE VIEW
SF8982-16SG-5XX
13
4
6
5
SF8982-13SG-5XX
ASSEMBLED VIEW
FOR CUSTOMER REFERENCE
12
17
4
16
1
A
2
10
3 9
8
3
WIRE VIEW
SF8982-12SG-5XX
2
2
7
WIRE VIEW
12
10
8
5
11
3 9
8
8
1
17
2.515
63.9
1
3 9
5
6
11
2
16
2
SF8982-11SG-5XX
12
10
11
10
WIRE VIEW
1
3 9
16
8
5
11
2
2
1
3 9
SF8982-10SG-5XX
1
10
10
WIRE VIEW
SF8982-9SG-5XX
11
4
18
11
3 9
8
WIRE VIEW
1
11
3
16
15
6
14
WIRE VIEW
PNK
PNK
RES-79 CHANGED TO RES-78. O-RING 4290S REPLACES SF6290S-1.
DRAWING CREATED PER PDR 17011
DATE
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
5
SF8982-17SG-5XX
RELEASED PER PDR 17011
9-28-18
1-30-18
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
4
7
02-01-19
REV. INIT.
13
8
MA
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
1-30-18
PNK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 2
FILE:
SF8982-XSG-5XX
DIRECTORY:
SLW
CABLE-TO-CABLE ASSEMBLY
(9-18) #26 SOCKET CONTACTS, SOLDER
SHIELDED MINI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
SF8982-XSG-5XX
REV
A
CABLE SHIELD
CABLE CONDUCTORS
CABLE
HOUSING ADAPTER
CABLE WIRING AND ASSEMBLY INSTRUCTIONS:
INSULATOR TUBE
STEP 1. SLIDE HOUSING ADAPTER, INSULATOR TUBE, AND BACKSHELL KIT, ONTO CABLE IN THE ORDER SHOWN.
STEP 2. STRIP CABLE JACKET AND WIRES TO LENGTH. EXCESS CABLE SHIELD MUST BE TRIMMED OR
WRAPPED AROUND WIRES. IF PRESENT, USE THE DRAIN WIRE TO WRAP THE CABLE SHIELD IN PLACE.
STEP 3. SOLDER WIRES TO CONTACTS.
INLINE
CONNECTOR
.125
3.2
DRAIN WIRE (IF PRESENT)
.625
15.9
CUSTOMER PRINT
1.125
28.6
BACKSHELL KIT
CONDUCTIVE TAPE WRAPPED
ONTO INSULATOR TUBE
STEP 4. THREAD HOUSING ADAPTER ONTO CONNECTOR AND TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE.
STEP 5. PEEL-OFF THE BACKING OF THE CONDUCTIVE TAPE AND WRAP IT AROUND THE INSULATOR AS SHOWN.
.080
2
CONDUCTIVE TAPE WRAPPED TIGHTLY ONTO CABLE SHIELD
PART
NUMBER:
SF8982-XSG-5XX
STEP 6. SLIDE INSULATOR/CONDUCTIVE TAPE INTO THE BACK OF THE CONNECTOR.
FORM FREE END OF CONDUCTIVE TAPE TIGHTLY ONTO THE SHIELD OF THE CABLE.
STEP 7. SLIDE AND THREAD THE BACKSHELL KIT ONTO CONNECTOR. TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE.
STEP 8. TIGHTEN THE TWO BACKSHELL SCREWS TO SECURE THE CABLE IN THE BACKSHELL.
COMPLETED ASSEMBLY
A
MA
04-03-19
PNK
9-28-18
PNK
1-30-18
REV. INIT.
DATE
AND DECIMALS.
TOLERANCES:
ANGLES ±1°
FRACTIONS ±1/16
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
1-30-18
PNK
CHECKED BY:
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
FILE NAME
SHEET
2 OF 2
DIRECTORY:
SLW
SHIELDED MINI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
SF8982-XSG-5XX
REV
A
很抱歉,暂时无法提供与“SF8982-18SG-530”相匹配的价格&库存,您可以联系我们找货
