UTL6102G1W3S14AWG
UTL6102G1W3S14AWG
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN CIRC PLUG 6POS GOLD CRIMP
UTL6102G1W3S14AWG 数据手册
UTL SERIES UL/IEC Power + Control Supply Overview UTL Series | Typical applications............................................ 06 Features & Benefits ........................................... 07 Range overview ................................................. 08 General technical characteristics ....................... 10 Stripping instructions for crimp contacts ........... 46 Tooling for crimp contacts ................................. 50 Handle & interchangeable heads for crimp contacts .............................................. 52 Crimping control for crimp contacts .................. 53 Insertion tool & extraction tool for crimp contacts .............................................. 54 Stripping instructions and tooling for coax contacts ............................................... 55 Assembly instructions ........................................ 60 Mated connector length..................................... 65 Evaluation kit ..................................................... 67 Rated current & working voltage ....................... 71 UV resistance ..................................................... 72 UL94 + UL1977 .................................................. 73 IEC 61984 with IP code explained .................... 76 IEC 61140 explained ......................................... 77 What is NEMA Rating? ...................................... 79 Ethernet for the Layman .................................... 80 RS-485 for the Layman ...................................... 82 Customized solution & Overmolded cable assembly.............................. 14 3 Contacts + ground ......................................... 18 5 Contacts ......................................................... 22 6 Contacts ......................................................... 26 8 Contacts ......................................................... 30 Contacts Description ........................................................ 36 Contact plating selector guide .......................... 37 Contact selector guide ...................................... 38 Packaging .......................................................... 38 Crimp contacts .................................................. 39 #16 coaxial contacts .......................................... 41 PCB contacts ..................................................... 42 Appendices Appendices Connector Contacts Technical Information Technical Information Overview Connector Contents Glossary of terms ............................................... 85 Part number index.............................................. 86 3 UTL SERIES © 2019 SOURIAU - SOURIAU is a registered trademark UTL Series Overview Typical applications ................................................................................................. 06 Features & Benefits ................................................................................................. 07 Range overview ...................................................................................................... 08 General technical characteristics ............................................................................. 10 5 UTL Series | Overview Energy - Power Medical © krungchingpixs / Fotolia Telecom - Data infrastructure Instrumentation & Measurement 6 © Volodymyr Kyrylyuk / Fotolia Building Automation & Control © smart.art / Fotolia © Olivier Tuffé / Fotolia Stage & Light © Vibe Images / Fotolia © Pavel Losevsky / Fotolia Typical applications UTL Series | Overview Features & Benefits EASY TO USE EASY TO SUPPLY EASY TO CUSTOMIZE High level of UL & IEC qualification IP68/69K & UV Resistant IK07 Impact Resistant Moisture proof Overview EASY TO TRUST • • • • • Push-pull coupling • Blind mateable • Sensitive tactile and audible click • Worldwide distributor network • Short lead-time • Turnkey solution thanks to our overmold capabilities with your cable spec • Strong R&D team to develop customized solutions UTL MAKES YOUR LIFE EASIER 7 UTL Series | Overview Range PLUGS UTL6JC 4 pos (103G1) Protective shroud Screwed backshell only available for UTL size 10: connector layout 103G1 UTL5 4 pos (103G1) HARNESS Overmold (straight or right angle) Backshell UTLJC only for 4 pos (103G1) & 5 pos. (145) “Clip” backshell only available for UTLM size 14: connector layout 145 TYPES OF CONTACTS UTL6 UTL6JC only for 4 pos (103G1) & 5 pos. (145) Terminating Resistor 120Ω impedance Only for 6 pos. (102G1W3) & 8 pos. (122G1W5) Machined pin Machined sealed pin Stamped and formed pin Machined socket Machined sealed socket Stamped and formed socket Screw socket only for UTL145 8 EVALUATION KIT UTL Series | Overview overview RECEPTACLES Overview UTL1JC only for 4 pos (103G1) In line - UTL1 HARNESS Jam nut - UTL7 Overmold (straight or right angle) Square flange - UTL0 only for 4 pos. (103G1) Terminating Resistor 120Ω impedance Only for 6 pos. (102G1W3) & 8 pos. (122G1W5) 9 UTL Series | Overview Description • The UTL Series is a plastic connector range that meets industrial safety standards. • UTL can be used for power supply and power + control supply with DMX or RDM signal. • The «Key hole» of the coupling system allows blind mating. In dark conditions the mechanical discriminations allow easy mating to avoid connector damage. • The stainless steel latch coupling system is simple to use. With only 1 finger, connectors are mated with an audible click. • An optional protective shroud is also available to prevent the disconnection of the connectors without a tool. • The UTL Series is rated at IP68/69K even in dynamic conditions and remains sealed even when used continuously underwater or cleaned using a high pressure hose while the cable is moving. • The UTL Series uses an outdoor rated material per Underwriters Laboratories. • Cable assembly equipped with DMX + Power cables suitable for outdoor use (PUR or Neoprene outer jacket), please consult us for more information. Technical features Materials • Housing: Thermoplastic - Raw material standards: . UL94 . UL746 • Contacts: Copper alloy • Latch: Stainless steel Electrical • Connector specially designed to be engaged or disengaged in normal use when live or under load • First Mate Last Break contact mating on ground line • Signal lines (for UTL102G1W3 & UTL122G1W5): RS485 compliant, 2.5A 10V • Finger touch proof (connector equipped with socket contacts) • In accordance with: - Connector standards: . UL 1977: UL file number ECBT2.E169916 . IEC 61984: please consult us . C22.2 N°182.3: file number ECBT8. E169916 - Equipment standards: . IEC60065, IEC60598, IEC61076-2-103, IEC60320 10 Environmental • Temperature class (according to IEC61984): From -40°C to +105°C for connector • Flammability rating: UL 94: V-0 for connector UL94: 5VA for thermoplastic UL746C: 5 inch (127mm) end-product flame test • Salt spray: ≥1,000 hours • UV resistant: No mechanical degradation or important color variation due to environmental exposure (F1 material per the UL 746C) • Sealing: - IP68/69K mated with standard contacts - IP68/69K unmated with specific contacts - IP68 1 bar / 1 week - IP67 mated for evaluation kits - Moisture proof capability • Fluid resistance: - Gas and oil - Mineral oil - Acid bath - Basic bath - For other fluids, please consult us • Halogen free • RoHS compliant Mechanical COMPLIANT • Durability: - 250 mating in CBC (Current Breaking Capacity) use (UL1977; IEC61984) - 500 mating in COC use (IEC61984) - 1,000 matings & unmatings tested • Coupling system: - Sensitive and audible click - Blind mating • Touchproof: IP2X in unmated condition (connector equipped with socket contacts) • Shock: IK07 according to IEC62262 UTL Series | Overview Qualification time saving In today’s fast paced environment we are all buying electronic devices with confidence. To achieve such a high level of trust, the regulator had to put in place a wide variety of safety standards. Some are dedicated to the equipment, some to the connection. SOURIAU designed and qualified the UTL Series according to the UL 1977 and IEC 61984 but we also took into account additional requirements. + Additional Capabilities ❏ ❏ ❏ ❏ ❏ ❏ ❏ ❏ Overview UL 1977 & IEC 61 984 Qualified Impact resistance Stress relief Flame retardant Finger probe Aging Hot wire Bending Current breaking In this way, the UTL Series is also compliant with ALL equipment standards mentioned below. = Easy Equipment Qualification Now, the qualification of your equipment is much easier. UL201 Safety standard of industrial equipment UL 1995 Heating and cooling equipment UL 2238 Cable assemblies and fittings for industrial control and signal distribution IEC 60601 Medical equipment IEC 61010 Safety requirements for electrical equipment for measurement, control, and laboratory use IEC 60598 Street lights UL/IEC 60950 Information technology equipment 11 UTL SERIES © 2019 SOURIAU - SOURIAU is a registered trademark UTL Series Connector Customized solution & overmolded cable assembly ....................................... 14 3 Contacts + ground 103G1: 16A 500V.................................................................... 18 5 Contacts 145: 16A 500V........................................................ 22 6 Contacts 102G1W3: 16A 500V.................................................................... 24 8 Contacts 122G1W5: 16A 500V.................................................................... 30 13 UTL Series | Connector SOURIAU has been designing harsh environment connectors for over one century, year after year developing customized solutions based on dedicated technical specifications from our customers. Thanks to a strong R&T and R&D department and a certified laboratory, we're able to propose customized solutions; the only limit is your imagination! © ESB Professional / Shutterstock Customized solution capability Overmolded cable assembly SOURIAU has provided connectors for various applications for more than 90 years that have been used in the most extreme environments. Conscious about the difficulty in finding a quick and reliable harness manufacturer, we began our own in-house overmolded cable assembly production. It allows customers to reduce the number of suppliers and to take advantage of the “best in class” quality of the SOURIAU group. Overmolding is a process that further enhances the sealing properties and helps to minimize stress on the cable termination to the connector. In addition, the wires are encapsulated inside the molding which creates a barrier preventing liquid/moisture from entering the equipment through the connector or cable jacket if breached. 14 UTL Series | Connector UTL overmolded cable assembly Overmolding description O-ring Compound Connector Cable outer sheath PVC or PUR overmolding Connector with cable gland backshell If cable jacket is breached... GOOD ...water ingress unhampered, leading to damage. Overmolded connector If cable jacket is breached... BEST ...prevents water ingress via capillary action. Overmold design for illustration purpose only 15 UTL Series | Connector UTL overmolded cable assembly Description Cable - 3 + ground • Outer sheath: rubber compound EM2 in acc. to HD 22.1 that is VDE 0282 part 1 • Outer sheath color: black • Flame retardant in acc. to IEC 60332-1-2 resp. VDE 0482 part 332-1-2 • Resistant to Oil, Solvents, Water, Ozone, aging and abrasion Cable - 6 pos. • Signal: 1 x 2 x 0.22 + shielding Power: 3G1.5 • Outer sheath: PUR RAL9005 • Outer sheath color: black • Core section: 0.22 mm² and 1.5 mm² Cable - 8 pos. • Signal: 2 x 2 x 0.22 + shielding Power: 3G1.5 • Outer sheath: PUR RAL9005 • Outer sheath color: black • Core section: 0.22 mm² and 1.5 mm² Specifications PLATING SALT SPRAY TEMPERATURE Up to + 90° C (1) with 103G1 (4 pos) No plating ≥1000 H Up to + 80° C (1) with 102G1W3 (6 pos) Up to + 80° C (1) See page 17 for more information 16 (1) with 122G1W5 (8 pos) WATERPROOF COUPLING IP68/69K dynamic mated & unmated 1,000 matings/unmatings UTL Series | Connector UTL overmolded cable assembly Cable information Rated voltage: U0/U: 450/750 V Wire section: 3 + ground: 2.5 mm² 6 pos. & 8 pos.: 1.5 mm² (power), 0.22 mm² (signal) Temperature: 3 + ground: flexible use and fixed installation -25° C up to +60° C 6 pos. & 8 pos.: flexible use -15° C up to +70° C, fixed installation -30° C up to +70° C Harmonized reference: 3 + ground: H07 RNF 4G x 2.5 6 pos. & 8 pos.: Not Applicable Nomenclature Key Definitions of Cable Types S: Service Grade (also means extra hard service when not followed by J, V, or P) J: Hard Service V: Vacuum cleaner cord (also light duty cable) P: Parallel cord (also known as zip cord) – Always light duty E: Thermoplastic Elastomer (UL/NEC designation ONLY) O: Oil Resistant outer jacket OO: Oil Resistant outer jacket and insulation T: Thermoplastic W: Outdoor-includes sunlight resistant jacket and wet location rated conductors (formerly "W-A") H: Heater cable VW-1: Flame retardant (vertical grade) FT2: Flame retardant (horizontal grade) SVT: Thermoplastic insulated vacuum cleaner cord, with or without 3rd conductor for grounding purposes; 300V (PVC) SJT: Junior hard service, thermoplastic insulated conductors and jacket. 300V (PVC) SJTW: Same as SJT except outdoor rated. (PVC) SJTO: Same as SJT but oil resistant outer jacket. (PVC) SJTOW: Same as SJTO except outdoor rated. (PVC) ST: Hard service cord with all thermoplastic construction, 600V (PVC) STW: Same as ST except outdoor rated. (PVC) STO: Same as ST but with oil resistant outer jacket. (PVC) STOW: Same as STO except outdoor rated. (PVC) Connector Standardization of American Cable 17 UTL Series | Connector 103G1 (shell size 10, 3 + ground, 4x#16) Layout OR OR OR OR OR OR OR WITH OR Connector part number Plugs and receptacles have to be equipped with both contact genders. Ground lines will never be equipped with the same contacts as the neutral and phase. Part number Male insert Female insert Black color Grey color Black color Grey color Contact type Connector type Crimp or PCB contacts supplied separately see page 21 Square flange receptacle Jam nut receptacle In line receptacle without backshell In line receptacle with backshell Plug for panel mounting Plug for overmolding Plug threaded without backshell and O-ring Plug with backshell UTL0103G1P UTL7103G1P UTL1103G1P UTL1JC103G1P UTL5103G1P UTL6103G1P UTL6TH103G1P UTL6JC103G1P UTL0103G1P03 UTL7103G1P03 UTL1103G1P03 UTL6103G1P03 - UTL0103G1S UTL7103G1S UTL1103G1S UTL1JC103G1S UTL5103G1S UTL6103G1S UTL6TH103G1S UTL6JC103G1S UTL0103G1S03 UTL7103G1S03 UTL1103G1S03 UTL6103G1S03 - Strandard delivered packaging: individual bag. For bulk delivery of 100 pcs please add a "B" after the P or S (connector gender) and before the potential "03" digits. Overmolded cable assembly part number Nbr contacts Size Wire size Description Length* (FT) Part number 4 4 4 4 4 4 4 4 4 4 4 4 10 10 10 10 10 10 10 10 10 10 10 10 14 AWG 16 AWG 18 AWG 14 AWG 16 AWG 18 AWG 14 AWG 16 AWG 18 AWG 14 AWG 16 AWG 18 AWG D/E assembly 1 male plug & 1 female plug D/E assembly 1 male plug & 1 female plug D/E assembly 1 male plug & 1 female plug S/E assembly 1 female plug S/E assembly 1 female plug S/E assembly 1 female plug S/E assembly 1 male plug S/E assembly 1 male plug S/E assembly 1 male plug D/E assembly 1 male plug & 1 female in line receptacle D/E assembly 1 male plug & 1 female in line receptacle D/E assembly 1 male plug & 1 female in line receptacle 3 3 3 3 3 3 3 3 3 3 3 3 UTLMKT63G1PS3FT UTLMK63G1PS03FT00 UTLMK63G1PS03FT01 UTLMKT63G1S3FT UTLMK63G1S03FT00 UTLMK63G1S03FT01 UTLMKT63G1P3FT UTLMK63G1P03FT00 UTLMK63G1P03FT01 UTLMKT613G1SP3FT UTLMK613G1PS03FT00 UTLMK613G1PS03FT01 * Other lengths available: 6 and 12 foot only: e.g. UTLMKT63G1PS6FT for a 6 foot version 14 AWG jumper or UTLMK63G1PS06FT01 for a 6 foot version 18 AWG jumper. Contact us for custom length or design needs. Evaluation kit Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. For more information please see page 67. 18 3 + ground 16A/250-500V UTL Series | Connector per IEC 61984 103G1 (shell size 10, 3 + ground, 4x#16) Dimensions (for mated connector lengths see page 65) Square flange receptacle - UTL0 0.472" 1.181" In line receptacle - UTL1 & Jam nut receptacle - UTL7 1.181" 1.322" 0.787" Ø 3.2 1.125" 1.125" Ø 0.708" UTL1 UTL7 Front view Plug - UTL5 & UTL6TH 1.456" 0.492" Front view Plug for overmolding - UTL6 0.610" 1.047" 0.444" 0.610" Front view UTL6TH Plug with backshell - UTL6JC 1.051" 2.901" maxi 0.610" 1.027" 0.787" 1.137" 2.448" Cable diameter acceptance of backshell: from 0.275" to 0.475" Connector Front view In line receptacle - UTL1JC 1.181" 0.933" 1.027" Ø 0.610" UTL5 Cable diameter acceptance of backshell: from 0.275" to 0.475" Front view Front view Panel cut out Ø 0.874" Ø 0.874" 0.370" 7" 67 0.858" 0. 7" " 0 72 67 0. 0. 0.057" Jam nut receptacle - UTL7 maximum panel thickness: 0.196" Ø Ø Ø 1.055" 0.647" Plug for panel mounting - UTL5 maximum panel thickness: 0.236" Ø 0.129" 0.647" Square flange receptacle - UTL0 0.057" Note: all dimensions are in inch and for information only 19 UTL Series | Connector 103G1 (shell size 10, 3 + ground, 4x#16) Accessories and tooling Dustcap for plug IP67 Dustcap for receptacle Handle (without head) Tool kit IP67 Part number Part number Part number Part number UTL610DCG UTL10DCG SHANDLES TOOLKIT Dustcap for male receptacle Dustcap for female receptacle IP68/69K Head crimp tooling (without handle) Contacts IP68/69K Part number Part number UTL103G1PDCG68 UTL103G1SDCG68 Extraction tool #16 Insertion tool #16 Part number Part number RX2025GE1 RTM205 Cable gland backshell* Backshell housing* Part number of head Contact size RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RM/RC 16M25K RM/RC 14M25K RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + YORX090 RM/RC DX60xxD28 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* S16RCM1625* S16RCM1425* Standard contacts #16 Ø 0.062" Coaxial contacts M20S-1J #16 Ø 0.062" (1): Example of plating, for other plating options see page 38 * Heads to be used with handle PN: SHANDLES Part number Part number UTL10JC UTL10JCP1 + Handle = Head Complete set * Backshells delivered with UTL10SEAL for sealing with plug or receptacle O-ring Nut Protective shroud Part number Part number Part number Part number UTL610PS SWSFILLERPLUG UTL10SEAL UTL10NUT Can be used only with UTL5, UTL6JC, UTL6TH 20 Sealing plug See instruction page 59 3 + ground 16A/250-500V UTL Series | Connector per IEC 61984 103G1 (shell size 10, 3 + ground, 4x#16) Contacts Contact type AWG Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece Max insulator Ø 0.021" 0.039" 26-24 RM24M9K RC24M9K 0.031" 0.062" 22-20 RM20M13K(1) RC20M13K(1) 0.045" 0.070" 22-20 RM20M12K (1) RC20M12K 0.045" 0.086" 20-16 RM16M23K(1) RC16M23K(1) 0.070" 0.125" 16-14 RM14M30K RC14M30K (1) (1) (1) (1) (1) RM16M25K 0.090" 0.125" RC16M25K 0.070" 0.125" 16-14 RM14M25K RC14M25K 0.089" 0.125" 24 RM24M25K(3) RC24M25K(3) 0.025" 0.125" 26-24 SM24M1TK6(1)(2) SC24M1TK6(1)(2) - 0.035"- 0.062" 22-20 SM20M1TK6 (1)(2) SC20M1TK6 - 0.047"- 0.082" 18-16 SM16M1TK6(1)(2) SC16M1TK6(1)(2) - 0.125" SM16M11TK6 SC16M11TK6 - 0.118" SM14M1TK6(1)(2) SC14M1TK6(1)(2) - 0.125" RMDXK10D28 RCDXK1D28 - - Cable multipiece Coaxial* Max wire Ø RC28M1K(1) 14 Cable monocrimp see page 41 Twisted pair monocrimp PCB Female RM28M1K(1) 18-16 Twisted pair multipiece Male 30-28 20-16 Machined sealed (with O-Ring for IP68/69K unmated) Part number (1)(2) (1)(2) (1)(2) RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + YORX090 RCDXK1D28 + YORX090 - - RMDX60xxD28 RCDX60xxD28 - - For male insert - RM20M12E8K RC20M12E84K - For female insert - RM20M12E8K RC20M12E83K - Connector #16 - (1): Example of plating, for other plating options see page 38 / (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): Includes RM/RC24M25K contacts + a ferrule RR24M1K. The ferrule can also be ordered separately. See page 53 *: Coax contacts cannot be used in the ground cavity Note: all dimensions are in inch REMINDER Plugs and receptacles have to be equipped with both contact genders. EX: UTL6103G1P = 3 x SM16M1TK6 (signal) + 1 x SC16M1TK6 (ground) UTS 103 derating curves Electrical characteristics Current (A) 30 UL 16A 600V V0 13A 277V for CBC use CN 13A 600V 10A 277V for CBC use 28 25 23 Test conditions 20 18 15 Contact used: Machined contacts Wires used: 1.31mm² IEC 16A 500V 6KV 4 13A 250V 4KV 4 for CBC use 13 10 8 5 3 0 Current use 0 20 40 60 80 Ambient operating temperature (°C) Limited use 100 120 Not recommended use Derating curves based on a continuous current, for information only, please contact us for specific need. 21 UTL Series | Connector 145 (shell size 14, 5x#16) OR OR Layout WITH Connector part number Contact type Connector type Crimp contacts to be ordered separately see page 25 Screw termination contacts, delivered with connector (1) Part number Male insert Female insert Plug with backshell* - UTL6JC145S Plug without backshell - UTL6145S Jam-nut without backshell UTL7145P - Plug with backshell* - UTL6JC145SSCR Plug without backshell - UTL6145SSCR * Non removable backshell when mated. IP68/69K not guaranted if backshell removed. 1: Screw termination version (from AWG18 to AWG14) or crimp version. Strandard delivered packaging: individual bag. For bulk delivery of 100 pcs please add a "B" after the P or S (connector gender) and before the potential "03" digits. Overmolded cable assembly Please consult us. 22 5 contacts 16A/250-500V UTL Series | Connector per IEC 61984 145 (shell size 14, 5x#16) Dimensions (for mated connector lengths see page 66) Jam nut receptacle - UTL7 1.354" 1.417" 0.562" 1.472" 1.240" Connector Front view Plug with backshell - UTL6 0.594" 1.228" 2.748" Ø 0.393" mini Ø 0.669" maxi 3.976" Front view Panel cut out Plug without backshell - UTL6 Jam nut receptacle - UTL7 1.925" Ø 1.181" Ø 0" 00 1. 0.940" Maximun panel thickness: 0.196" 0.594" 1.228" 0.814" 0.059" Front view Note: all dimensions are in inch and for information only 23 UTL Series | Connector 145 (shell size 14, 5x#16) Tooling Handle (without head) Tool kit Head crimp tooling (without handle) Contacts Part number Part number SHANDLES TOOLKIT + Handle = Head Complete set Extraction tool #16 Insertion tool #16 Part number Part number RX2025GE1 RTM205 Accessories 24 Backshell Backshell Part number Part number UTL14JC UTL14JCP1 RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) Contact size Standard contacts #16 Ø 0.062" (1): Example of plating, for other plating options see page 38 * Heads to be used with handle PN: SHANDLES Part number of head S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* 5 contacts 16A/250-500V UTL Series | Connector per IEC 61984 145 (shell size 14, 5x#16) Contacts Contact type AWG Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece Max insulator Ø 0.021" 0.039" 26-24 RM24M9K RC24M9K 0.031" 0.062" 22-20 RM20M13K(1) RC20M13K(1) 0.045" 0.070" 22-20 RM20M12K (1) RC20M12K 0.045" 0.086" 20-16 RM16M23K(1) RC16M23K(1) 0.070" 0.125" 16-14 RM14M30K RC14M30K (1) (1) (1) (1) (1) RM16M25K 0.090" 0.125" RC16M25K 0.070" 0.125" 16-14 RM14M25K RC14M25K 0.089" 0.125" 24 RM24M25K(3) RC24M25K(3) 0.025" 0.125" 26-24 SM24M1TK6(1)(2) SC24M1TK6(1)(2) - 0.035"- 0.062" 22-20 SM20M1TK6 (1)(2) SC20M1TK6 - 0.047"- 0.082" 18-16 SM16M1TK6(1)(2) SC16M1TK6(1)(2) - 0.125" SM16M11TK6 SC16M11TK6 - 0.118" SM14M1TK6(1)(2) SC14M1TK6(1)(2) - 0.125" RMDXK10D28 RCDXK1D28 - - Cable multipiece Coaxial* Max wire Ø RC28M1K(1) 14 Cable monocrimp see page 41 Twisted pair monocrimp Female RM28M1K(1) 18-16 Twisted pair multipiece Male 30-28 20-16 Machined sealed (with O-Ring for IP68/69K unmated) Part number (1)(2) (1)(2) (1)(2) RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + YORX090 RCDXK1D28 + YORX090 - - RMDX60xxD28 RCDX60xxD28 - Connector #16 - (1): Example of plating, for other plating options see page 38 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): Includes RM/RC24M25K contacts + a ferrule RR24M1K. The ferrule can also be ordered separately. See page 53 *: Coax contacts cannot be used in the ground cavity Note: all dimensions are in inch Electrical characteristics UTL145 derating curves Current (A) 30 UL 16A 600V V0 13A 277V for CBC use CN 13A 600V 10A 277V for CBC use Test conditions 28 25 23 Contact used: Machined contacts Wires used: #16 contacts wired onto 1.5mm² or AWG16 conductors 20 18 15 13 10 8 5 IEC 16A 500V 4KV 4 13A 250V 2.5KV 4 for CBC use 3 0 0 Theoretic current use 20 40 60 80 Ambient operating temperature (°C) Limited use 100 120 Not recommended use Derating curves based on a continuous current, for information only, please contact us for specific need. 25 UTL Series | Connector 102G1W3 (shell size 10, 3x#16 + 3x#20) OR OR Layout WITH Connector part number Plugs and receptacles have to be equipped with both contact genders. Ground lines will never be equipped with the same contacts as the neutral and phase. Part number Contact type Connector type Female insert Black color Black color Plug UTL6102G1W3P UTL6102G1W3S Jam nut receptacle UTL7102G1W3P UTL7102G1W3S In line receptacle UTL1102G1W3P UTL1102G1W3S Terminating Resistor plug - 120Ω UTL6102G1W3PCDMX UTL6102G1W3SCDMX Terminating Resistor receptacle - 120Ω UTL1102G1W3PCDMX UTL1102G1W3SCDMX Crimp contacts supplied separately see page 29 Contacts included Male insert The Terminating Resistor is only designed to ensure the 120 Ohms impedance on the signal lines, no contact loaded in the power positions. #20 contacts and plastic plate are not removable. Strandard delivered packaging: individual bag. For bulk delivery of 100 pcs please add a "B" after the P or S (connector gender) and before the potential "03" digits. Overmolded cable assembly part number Layout Wire size 14 AWG 102G1W3 16 AWG Overmolded harnesses, straight ending Connector Length* (FT ) Part number D/E assembly 1 male plug & 1 female plug 3 UTL6V2G1W3PS03FT0 S/E assembly 1 female plug 3 UTL6V2G1W3S03FT0 S/E assembly 1 male plug 3 UTL6V2G1W3P03FT0 D/E assembly 1 male plug & 1 female in line receptacle 3 UTL61V2G1W3PS03FT0 D/E assembly 1 male plug & 1 female plug 3 UTL6V2G1W3PS03FT1 S/E assembly 1 female plug 3 UTL6V2G1W3S03FT1 S/E assembly 1 male plug 3 UTL6V2G1W3P03FT1 D/E assembly 1 male plug & 1 female in line receptacle 3 UTL61V2G1W3PS03FT1 * Other stock lengths available: 6 and 12 foot only: e.g. UTL6V2G1W3P06FT0 for a 6 foot version 14 AWG Contact us for custom length or design needs. Evaluation kit Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. For more information please see page 68. 26 6 contacts 16A/500V UTL Series | Connector per IEC 61984 102G1W3 (shell size 10, 3x#16 + 3x#20) Dimensions (for mated connector lengths see page 65) Plug for overmolding - UTL6 0.787" 1.106" 0.444" 0.610" Ø 0.610" 1.125" Front view Front view Jam nut receptacle - UTL7 Terminating Resistor plug 0.787" 0.610" 0.944" 2.559" maxi 1.125" 0.551" 0.893" 1.240" Connector 1.240" 0.944" In line receptacle - UTL1 Front view Front view Panel cut out Terminating Resistor receptacle Jam nut receptacle - UTL7 Ø 0.874" Ø 7" 67 0. Front view 0.647" Maximun panel thickness: 0.196" 0.787" 1.125" 2.559" maxi 0.057" Note: all dimensions are in inch and for information only 27 UTL Series | Connector 102G1W3 (shell size 10, 3x#16 + 3x#20) Accessories and tooling Dustcap for plug IP67 Dustcap for receptacle Handle (without head) Tool kit IP67 Part number Part number Part number Part number UTL610DCG UTL10DCG SHANDLES TOOLKIT Dustcap for male receptacle Dustcap for female receptacle IP68/69K Head crimp tooling (without handle) IP68/69K Contacts Part number Part number UTL102G1W3PDCG68 UTL102G1W3SDCG68 Extraction tool #16 Insertion tool #16 Part number Part number RX2025GE1 RTM205 Extraction tool #20 Part number of head Contact size RM/RC 24W3K(1) RM/RC 20W3K(1) RM/RC 18W3K(1) SM/SC 24WL3(1)(2) SM/SC 20WL3(1)(2) RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + YORX090 RM/RC DX60xxD28 S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #20 Ø 0.039" Standard contacts #16 Ø 0.062" Coaxial contacts M20S-1J #16 Ø 0.062" (1): Example of plating, for other plating options see page 38 * Heads to be used with handle PN: SHANDLES Part number RX20D44 28 + Handle (2): loose contact = Head Complete set 6 contacts 16A/500V UTL Series | Connector per IEC 61984 102G1W3 (shell size 10, 3x#16 + 3x#20) Contacts #20 Contact type AWG 26-24 22-20 Machined Crimp 20-18 26-24 26-24 Stamped & Formed reeled contacts See note (2) for loose piece 22-20 22-20 Part number Max wire Ø Max insulator Ø RC24W3K(1) RC20W3K(1) RC18W3K(1) 0.031" 0.062" 0.045" 0.062" 0.051" 0.082" SM24W3TK6(1)(2) SM24W3S26(1)(2) SM20W3TK6(1)(2) SM20W3S26(1)(2) SC24W3TK6(1)(2) SC24W3S25(1)(2) SC20W3TK6(1)(2) SC20W3S25(1)(2) - 0.035"- 0.062" - 0.035"- 0.062" - 0.047"- 0.082" - 0.047"- 0.082" RM28M1K(1) RM24M9K(1) RM20M13K(1) RM20M12K(1) RM16M23K(1) RM14M30K(1) RC28M1K(1) RC24M9K(1) RC20M13K(1) RC20M12K(1) RC16M23K(1) RC14M30K(1) 0.021" 0.039" 0.031" 0.062" 0.045" 0.070" 0.045" 0.086" 0.070" 0.125" 0.090" 0.125" SM24M1TK6(1)(2) SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) SC24M1TK6(1)(2) SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"- 0.062" - 0.047"- 0.082" - 0.125" - 0.118" - 0.125" RMDXK10D28 RMDX60xxD28 RMDXK10D28 + YORX090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + YORX090 RCDX60xxD28 - - - - - - Male Female RM24W3K(1) RM20W3K(1) RM18W3K(1) 30-28 26-24 22-20 Machined 22-20 Crimp 20-16 16-14 26-24 22-20 Stamped & Formed reeled contacts 18-16 See note (2) for loose piece 18-16 14 Coaxial* Cable multipiece Cable monocrimp Twisted pair multipiece see page 41 Twisted pair monocrimp - (1): Example of plating, for other plating options see page 38 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 *: Coax contacts cannot be used in the ground cavity Note: all dimensions are in inch REMINDER Plugs and receptacles have to be equipped with both contact genders. EX: UTL6102W3G1P = 2 x SM16M1TK6 (power) + 1 x SC16M1TK6 (ground) + 3 x SM20W3TK6 (signal) Electrical characteristics UTL102G1W3 derating curves Current (A) 30 UL 16A 600V V0 13A 277V for CBC use CN 13A 600V 10A 277V for CBC use IEC 16A 500V 6KV 4 13A 250V 4KV 4 for CBC use Test conditions Contact used: Machined contacts Wires used: #16 contacts wired onto 1.5mm² or 16AWG conductors #20 contacts wired onto 0.5mm² or 20AWG conductors and powered at 2.5 Amps 28 25 23 20 18 15 13 10 8 5 3 0 0 20 40 60 80 Ambient operating temperature (°C) 100 120 Theoretic current use Limited use Not recommended use Derating curves based on a continuous current, for information only, please contact us for specific need. 29 Connector #16 UTL Series | Connector 122G1W5 (shell size 12, 3x#16 + 5x#20) OR OR Layout WITH Connector part number Plugs and receptacles have to be equipped with both contact genders. Ground lines will never be equipped with the same contacts as the neutral and phase. Contact type Part number Connector type Male insert with female ground Female insert with male ground Crimp contacts supplied separately see page 33 Plug UTL6122G1W5P UTL6122G1W5S Jam nut receptacle UTL7122G1W5P UTL7122G1W5S In line receptacle UTL1122G1W5P UTL1122G1W5S UTL6122G1W5PCDMX UTL6122G1W5SCDMX Contacts included Terminating Resistor plug - 120Ω Terminating Resistor receptacle - 120Ω UTL1122G1W5PCDMX UTL1122G1W5SCDMX The Terminating Resistor is only designed to ensure the 120 Ohms impedance on the signal lines, no contact loaded in the power positions. #20 contacts and plastic plate are not removable. Strandard delivered packaging: individual bag. For bulk delivery of 100 pcs please add a "B" after the P or S (connector gender) and before the potential "03" digits. Overmolded cable assembly part number Layout Wire size 14 AWG 122G1W5 16 AWG Overmolded harnesses, straight ending Connector Length* (FT ) Part number D/E assembly 1 male plug & 1 female plug 3 UTL6122G1W5PS03FT0 S/E assembly 1 female plug 3 UTL6122G1W5S03FT0 S/E assembly 1 male plug 3 UTL6122G1W5P03FT0 D/E assembly 1 male plug & 1 female in line receptacle 3 UTL6V122G1W5PS03F0 D/E assembly 1 male plug & 1 female plug 3 UTL6122G1W5PS03FT1 S/E assembly 1 female plug 3 UTL6122G1W5S03FT1 S/E assembly 1 male plug 3 UTL6122G1W5P03FT1 D/E assembly 1 male plug & 1 female in line receptacle 3 UTL6V122G1W5PS03F1 * Other stock lengths available: 6 and 12 foot only: e.g. UTL6V122G1W5PS06F0 for a 6 foot version 14 AWG Contact us for custom length or design needs. Evaluation kit Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. For more information please see page 69. 30 8 contacts 16A/500V UTL Series | Connector per IEC 61984 122G1W5 (shell size 12, 3x#16 + 5x#20) Dimensions (for mated connector lengths see page 66) Plug for overmolding - UTL6 In line receptacle - UTL1 0.787" 0.551" 1.106" 0.444" 0.610" 1.043" 1.255" 1.240" Ø 1.133" Jam nut receptacle - UTL7 1.240" 0.551" Connector Front view Front view Terminating Resistor plug 0.787" 0.610" 1.043" 1.062" 1.255" 2.755" maxi Ø28.8 Front view Front view Panel cut out Terminating Resistor receptacle Jam nut receptacle - UTL7 Ø 1.062" Ø 5" 87 0. Front view 0.826" Maximun panel thickness: 0.196" 0.787" 1.255" 2.755" maxi 0.059" Note: all dimensions are in inch and for information only 31 UTL Series | Connector 122G1W5 (shell size 12, 3x#16 + 5x#20) Accessories and tooling Dustcap for plug IP67 Dustcap for receptacle Handle (without head) Tool kit IP67 Part number Part number Part number Part number UTL612DCG UTL12DCG SHANDLES TOOLKIT Extraction tool #16 Insertion tool #16 Head crimp tooling (without handle) Contacts Part number Part number RX2025GE1 RTM205 Part number of head Contact size RM/RC 24W3K(1) RM/RC 20W3K(1) RM/RC 18W3K(1) SM/SC 24WL3(1)(2) SM/SC 20WL3(1)(2) RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + YORX090 RM/RC DX60xxD28 S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #20 Ø 0.039" Standard contacts #16 Ø 0.062" Coaxial contacts M20S-1J #16 Ø 0.062" (1): Example of plating, for other plating options see page 38 * Heads to be used with handle PN: SHANDLES + Handle 32 (2): loose contact = Head Complete set 8 contacts 16A/500V UTL Series | Connector per IEC 61984 122G1W5 (shell size 12, 3x#16 + 5x#20) Contacts #20 Contact type AWG 26-24 22-20 Machined Crimp 20-18 26-24 26-24 Stamped & Formed reeled contacts See note (2) for loose piece 22-20 22-20 Part number Max wire Ø Max insulator Ø RC24W3K(1) RC20W3K(1) RC18W3K(1) 0.031" 0.062" 0.045" 0.062" 0.051" 0.082" SM24W3TK6(1)(2) SM24W3S26(1)(2) SM20W3TK6(1)(2) SM20W3S26(1)(2) SC24W3TK6(1)(2) SC24W3S25(1)(2) SC20W3TK6(1)(2) SC20W3S25(1)(2) - 0.035"- 0.062" - 0.035"- 0.062" - 0.047"- 0.082" - 0.047"- 0.082" RM28M1K(1) RM24M9K(1) RM20M13K(1) RM20M12K(1) RM16M23K(1) RM14M30K(1) RC28M1K(1) RC24M9K(1) RC20M13K(1) RC20M12K(1) RC16M23K(1) RC14M30K(1) 0.021" 0.039" 0.031" 0.062" 0.045" 0.070" 0.045" 0.086" 0.070" 0.125" 0.090" 0.125" SM24M1TK6(1)(2) SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) SC24M1TK6(1)(2) SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"- 0.062" - 0.047"- 0.082" - 0.125" - 0.118" - 0.125" RMDXK10D28 RMDX60xxD28 RMDXK10D28 + YORX090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + YORX090 RCDX60xxD28 - - - - - - Male Female RM24W3K(1) RM20W3K(1) RM18W3K(1) 30-28 26-24 22-20 Machined 22-20 Crimp 20-16 16-14 26-24 22-20 Stamped & Formed reeled contacts 18-16 See note (2) for loose piece 18-16 14 Coaxial Cable multipiece Cable monocrimp Twisted pair multipiece see page 41 Twisted pair monocrimp - (1): Example of plating, for other plating options see page 38 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 *: Coax contacts cannot be used in the ground cavity Note: all dimensions are in inch REMINDER Plugs and receptacles have to be equipped with both contact genders. EX: UTL6122G1W5P = 2 x SM16M1TK6 (power) + 1 x SC16M1TK6 (ground) + 5 x SM20W3TK6 (signal) Electrical characteristics UTL122G1W5 derating curves Current (A) 30 UL 16A 600V V0 13A 277V for CBC use CN 13A 600V 10A 277V for CBC use IEC 16A 500V 6KV 4 13A 250V 4KV 4 for CBC use Test conditions Contact used: Machined contacts Wires used: #16 contacts wired onto 2.5mm² or 14AWG conductors #20 contacts wired onto 0.5mm² or 20AWG conductors and powered at 2.5 Amps 28 25 23 20 18 15 13 10 8 5 3 0 0 20 40 60 80 Ambient operating temperature (°C) 100 120 Theoretic current use Limited use Not recommended use Derating curves based on a continuous current, for information only, please contact us for specific need. 33 Connector #16 UTL SERIES © 2019 SOURIAU - SOURIAU is a registered trademark UTL Series Contacts Description ................................................................................................................ 36 Contact plating selector guide .................................................................................. 37 Contact selector guide .............................................................................................. 38 Packaging .................................................................................................................. 38 Crimp contacts .......................................................................................................... 39 #16 coaxial contacts .................................................................................................. 41 PCB contacts ............................................................................................................. 42 35 UTL Series | Contacts Contacts Description The UTL series is delivered without contacts (crimp version). This series offers the unique possibility to use the same contact in any layout as long as it receives the same active part size. This provides the benefit of standardization and subsequent reduced inventory costs. In addition, it eliminates the need for added tooling and simplifies the assembly process. SOURIAU contacts are designed for simple snap-in installation and further eliminate the need for insertion tooling. Crimp contacts are available in different versions: • Machined • Stamped & Formed The UTL series 3 + ground can be equipped with PCB contacts 36 • Coaxial UTL Series | Contacts Contacts Contact plating selector guide Once the contact size has been selected, the next step is to decide on which type to use. SOURIAU offers two main types of electrical contacts: • Machined • Stamped & Formed Machined contacts are generally chosen as a better solution for power applications or when lower quantities are needed. Stamped & formed contacts offer the ability to be crimped automatically which makes them more suitable for high volume production applications. The next decision to make is: What plating should I choose? The graph below can help guide you to plating recommendations based on application, mating cycles and current/voltage needs. Note: do not mix different plating (i.e. tin plated pin contacts with gold plated socket contacts). Number of cycles Vibration 250 100 0.4μm of gold min Contacts Gold flash Silver Tin Current / Voltage 1Amp 5mV Contact size #20 #12 #16 #8 37 UTL Series | Contacts Contacts Plating selector guide Contacts supplied separately Electrical characteristics: contact resistance #20 Ø 0.039" #16 Ø 0.062" Machined < 6mΩ Stamped and Formed < 6mΩ Machined < 3mΩ Stamped and Formed < 6mΩ Stamped & Formed contacts Contact size #20 Ø 0.039" #16 Ø 0.062" Plating description Plating code Active area Other areas S25 (female) 0,75μm Gold mini over Nickel Gold flash over Nickel S26 (male) 0,75μm Gold mini over Nickel Gold flash over Nickel TK6 0,5μm - 2,5μm Sn pre-plated - S31 Gold Flash over Nickel S18 0,75μm Gold mini over Nickel Crimped area: 1.3µ Tin mini over Nickel Other areas: 1.3µ Tin mini D70 0,13μm Gold mini over Nickel Gold flash over Nickel TK6 0,5μm - 2,5μm Sn pre-plated - Machined contacts Contact size Plating code Plating description #20 Ø 0.039" K 0.4 μm Gold over 2 μm Nickel mini K 0.4 μm Gold over 2 μm Nickel mini J Gold Flash over Nickel 2 μm mini #16 Ø 0.062" Active area T Tin 3 μm (-0/+2) over 1.3 μm Nickel mini D28* 0.75 μm mini Gold over 2 μm Nickel mini * For Coax contacts only Packaging - Size contacts #20 & #16 Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts): Machined contacts* Stamped & Formed • 25 pieces loose package • 3,000 pieces reeled • 50 pieces bulk package • 1,000 pieces bulk package * Note : 1,000 pieces bulk package available by adding 1000 at the end of the part number: e.g. RC16M23K1000 2,000 pieces reeled package available by adding K at the begining of the part number: e.g. KRC16M23K 38 • 2,000 pieces reeled Size #16 only UTL Series | Contacts Crimp contacts Standard version Contact size #16 Ø 0.062" Stamped & Formed Wire size Type Machined #20 Ø 0.039" Machined Part number AWG mm² Male 26-24 0.13-0.20 RM24W3K SM24W3- (1) Stamped & Formed 26-24 0.13-0.25 Machined 22-20 0.32-0.52 Stamped & Formed 22-20 0.35-0.5 SM24WL3- - RC18W3K RC28M1RC24M9SC24M1-(1) SC24ML1-(2) RC20M13RC20M12SC20M1-(1) SC20ML1-(2) RC16M23- 0.051" 0.082" max K 0.021" 0.043" K, J 0.031" 0.062" K, J Stamped & Formed 22-20 0.35-0.5 Machined 20-16 0.52-1.5 Machined Sealed contact 20-16 0.52-1.5 RM16M25K Machined Sealed contact 24 0.25 16-14 1.5-2.5 Stamped & Formed 14 2.0-2.5 Machined Sealed contact 16-14 1.5-2.5 TK6 S25 (female) S26 (male) SC20WL3-(2) 0.32-0.52 Machined 0.046"- 0.081" SM20WL3-(2) 22-20 0.8-1.5 K - Machined 18-16 0.062" max SC20W3-(1) 0.13-0.25 Stamped & Formed 0.035"- 0.062" SC24W3- SM20W3-(1) 26-24 0.8-1.5 K TK6 S25 (female) S26 (male) 0.045" 0.13-0.2 18-16 0.062" max - RC20W3K 26-24 Stamped & Formed 0.031" (1) RM20W3K Machined 0.50-0.93 0.05-0.08 RC24W3K - Stamped & Formed 20-18 30-28 Female Max insulator Ø SC24WL3-(2) (2) RM18W3K RM28M1RM24M9SM24M1-(1) SM24ML1-(2) RM20M13RM20M12SM20M1-(1) SM20ML1-(2) RM16M23- Machined Machined Available plating see page 38 Max wire Ø 0.035"-0.050" 0.035"- 0.062" TK6, S31, S18 0.045" 0.070" 0.086" K, J 0.046"- 0.081" 0.046"- 0.081" TK6, S31, S18 0.070" 0.125" K, J RC16M25K 0.070" 0.125" K RM24M25K(3) RM24M25K(3) 0.025" 0.125" K SM16M1SM16ML1-(2) SM16M11-(1) SM16ML11-(2) RM14M30SM14M1-(1) SM14ML1-(2) SC16M1SC16ML1-(2) SC16M11-(1) SC16ML11-(2) RC14M30SC14M1-(1) SC14ML1-(2) 0.118" No insulation grip TK6, S31, S18 RM14M25K RC14M25K (1) (1) Contacts Machined & sealed 0.078"- 0.118" 0.081"- 0.118" TK6, S31, S18 0.090" 0.125" K, J 0.125" No insulation grip TK6, S31, S18 0.090" 0.125" K (1): Contact reeled (2): Loose contact. Exemple: RM24W3K - Size #20, Machined, AWG24 wire. (3): Includes RM/RC24M25K contacts + a ferrule RR24M1K. The ferrule can also be ordered separately. See page 53 REMINDER Plugs and receptacles have to be equipped with both contact genders. Examples: UTL6122W3G1P = 2 x SM16M1TK6 (power) + 1 x SC16M1TK6 (ground) + 5 x SM20W3TK6 (signal) Note: all dimensions are in inch and for information only 39 UTL Series | Contacts Crimp contacts First Mate Last Break contacts Contact size Type #16 Ø 0.062" Longer male contact (+0.039") for First Mate Last Break Connection Machined #16 Ø 0.062" Shorter female contact (-0.027") for Last Mate First Break Connection Machined Wire size Part number Female Color band Max wire Ø (inch) Max insulator Ø (inch) Front Rear - Red AWG mm² Male 30-28 0.05-0.08 RM28M1GE1- 0.021" 0.039" 26-24 0.13-0.2 RM24M9GE1- 0.031" 0.062" Red Red 22-20 0.32-0.52 RM20M12GE1- 0.045" 0.086" Blue Red 20-16 0.52-1.5 RM16M23GE1- 0.070" 0.125" - Red 16-14 1.5-2.5 RM14M30GE1- 30-28 0.05-0.08 - 0.089" - - Red RC28M1GE7- 0.021" 0.039" - Blue 26-24 0.13-0.2 RC24M9GE7- 0.031" 0.062" Red Blue 22-20 0.32-0.52 RC20M12GE7- 0.045" 0.086" Blue Blue 18-16 0.92-1.5 RC16M23GE7- 0.070" 0.125" - Blue 16-14 1.5-2.5 RC14M30GE7- 0.089" - - Blue - Available plating see p. 38 K K How to make FMLB / LMFB* connection Contact 1 Contact 2 Standard male contact Standard female contact Longer male contact Standard male contact Standard female contact Shorter female contact FMLB LMFB * FMLB: First Mate Last Break / LMFB: Last Mate First Break 40 First Mate Last Break contacts should be chosen only if the cavity is not marked with the ground symbol. For cavities marked with the ground symbol, standard contacts will fulfill the same role as a first mate, last break contact used in a standard cavity. Ground symbol UTL Series | Contacts #16 coaxial contacts Coaxial contact range Note: Coax contacts cannot be used in the ground cavity We provide 2 types of coaxial contacts suitable for 50 or 75Ω, coaxial cable or twisted pair cable. Monocrimp coaxial contact • The monocrimp one-piece coaxial contacts offer high reliability plus the economic advantage of a 95% reduction in installation time over conventional assembly methods. • This economy is achieved by simultaneously crimping both the inner conductor and outer braid or drain wire. Multipiece crimp coaxial contact • The inner conductor and outer braid is crimped individually. • The thermoplastic insulating bushing in the outer body is designed to accept and permanently retain the inner contact. • An outer ferrule is used to connect the braid to the outer contact and provide cable support to ensure against bending and vibration. Contacts Suitable for coaxial cable or twisted cable • For jacket diameter from 0.025" to 0.1057" Inner conductor from 30 AWG to 24 AWG • For jacket diameter from 0.070" to 0.120" Inner conductor up to 0.096" diameter Contacts for coaxial cable summary Contact range Contact type Male contact Female contact Multipiece RMDXK10D28 RCDXK1D28 Monocrimp RMDX60xxD28 RCDX60xxD28 Contacts for twisted pairs cable summary Contact type Contact range Male contact Female contact Multipiece RMDXK10D28 + YORX090 RCDXK1D28 + YORX090 Monocrimp RMDX60xxD28 RCDX60xxD28 41 UTL Series | Contacts PCB contacts for 3 + ground (103G1) PCB contacts for 3 + ground (103G1) PCB soldering UTL range can be carried out with a wave soldering process, but not reflow soldering process. All high temperature processes are prohibited. Contact size Connector type #16 Ø 0.062" Part number contact Plating see page 38 Male Female Male insert RM20M12E8K RC20M12E84K Female insert RM20M12E8K RC20M12E83K K Nominal length Dimension of dipsolder contacts out of connector (contacts to be ordered separately). UTL7 female UTL7 male 0.181" 0.114" Note: The 6 pos. & 8 pos. layouts do not support PCB contacts 42 0.181" 0.188" UTL Series | Contacts Contacts Notes 43 UTL SERIES © 2019 SOURIAU - SOURIAU is a registered trademark UTL Series Technical Information Stripping instructions for crimp contacts ................................................................. 46 Tooling for crimp contacts ....................................................................................... 50 Handle & interchangeable heads for crimp contacts .............................................. 52 Crimping control for crimp contacts ........................................................................ 53 Insertion tool & extraction tool for crimp contacts .................................................. 54 Stripping instructions and tooling for coax contacts................................................ 55 Assembly instructions .............................................................................................. 60 Mated connector length .......................................................................................... 65 Evaluation kit 3 contacts + ground .......................................................................... 67 Evaluation kit 6 contacts .......................................................................................... 68 Evaluation kit 8 contacts .......................................................................................... 69 Evaluation kit – Assembly instructions ..................................................................... 70 Rated current & working voltage ............................................................................. 71 UV resistance ........................................................................................................... 72 UL94 + UL1977 ........................................................................................................ 73 IEC 61984 & IP codes explained ............................................................................. 76 IEC 61140 explained ............................................................................................... 78 What is NEMA rating? ............................................................................................. 79 Ethernet for the Layman .......................................................................................... 80 RS-485 for the Layman ............................................................................................ 82 45 UTL Series | Technical Information Stripping instructions for crimp contacts Stripping & cutting dimensions of outer jacket • Female insulator: Strip external cable sheath, adjust ground cable length • Male insulator: Strip external cable sheath, adjust signal cable lengths • Then, strip individual wire according to the recommended stripping length below • Crimp contacts (see page 49) 3 + ground UTL0103G1P - UTL1103G1P - UTL5103G1P UTL6103G1P - UTL6TH103G1P - UTL7103G1P UTL0103G1S - UTL1103G1S - UTL5103G1S UTL6103G1S - UTL6TH103G1S - UTL7103G1S 1.259" Ground line Female contact 0.984" L* L* Phase lines Female contacts Phase lines Male contacts 0.984" 1.181" UTL6JC103G1P UTL6JC103G1S 2.362" Ground line Female contact 2.086" 2.047" L* Phase lines Male contacts UTL1JC103G1P Ground line Female contact 1.653" 46 L* 2.244" Phase lines Female contacts UTL1JC103G1S 1.929" * see page 49 Ground line Male contact 1.614" L* Phase lines Male contacts Ground line Male contact L* 1.811" Phase lines Female contacts Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B UTL Series | Technical Information Stripping instructions for crimp contacts Stripping & cutting dimensions of outer jacket • Female insulator: Strip external cable sheath, adjust ground cable length • Male insulator: Strip external cable sheath, adjust signal cable lengths • Then, strip individual wire according to the recommended stripping length below • Crimp contacts (see page 49) 5 pos. UTL6145P - UTL7145P - UTL1145P UTL6145S - UTL7145S - UTL1145S 1.417" 1.377" Ground line L* L* 1.456" UTL6JC145SSCR 1.535" L* Technical Information Ground line 1.456" 6 pos. UTL6102G1W3P - UTL7102G1W3P - UTL1102G1W3P 1.417" Ground line Female contact UTL6102G1W3S - UTL7102G1W3S - UTL1102G1W3S 1.023" L* Ground line Male contact 1.181" 1.200" Power lines Male contacts Power lines Female contacts Drain 0.984" * see page 49 L* Drain Signal lines Male contacts 0.984" Signal lines Female contacts Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 47 UTL Series | Technical Information Stripping instructions for crimp contacts Stripping & cutting dimensions of outer jacket • Female insulator: Strip external cable sheath, adjust ground cable length • Male insulator: Strip external cable sheath, adjust signal cable lengths • Then, strip individual wire according to the recommended stripping length below • Crimp contacts (see page 49) 8 pos. UTL6122G1W5P - UTL7122G1W5P - UTL1122G1W5P 1.850" Ground line Female contacts UTL6122G1W5S - UTL7122G1W5S - UTL1122G1W5S 1.496" L* Ground line Male contacts 1.614" 1.692" Power lines Male contacts Power lines Female contacts Drain Drain Signal lines Male contacts 1.417" * see page 49 48 L* Signal lines Female contacts 1.456" Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B UTL Series | Technical Information Stripping instructions for crimp contacts Wire stripping length Part number Male Stripping length L (inch) Female Machined contact #20 - Ø 0.039" RM24W3- / RM20W3RM18W3- RC24W3- / RC20W3RC18W3- 0.188" #16 - Ø 0.062" L RM28M1- / RM24M9RM20M13- / RM20M12- RC28M1- / RC24M9RC20M13- / RC20M12- RM16M23- /RM14M30- RC16M23- /RC14M30- 0.279" RM16M25- /RM14M25- RC16M25- /RC14M25- 0.212" / 0.204" RM24M25- RC24M25- 0.212" / 0.204" Stamped & formed 0.188" #20 - Ø 0.039" SM24W3- / SM24WL3SM20W3- / SM20WL3- With insulation support SC24W3- / SC24WL3SC20W3- / SC20WL3- 0.157" #16 - Ø 0.062" L SM24M1- / SM24ML1SM20M1- / SM20ML1- SC24M1- / SC24ML1SC20M1- / SC20ML1- 0.157" SM16M11- / SM16ML11- SC16M11- / SC16ML11- 0.183" Without insulation support #16 - Ø 0.062" L Note: See page 38 for plating options and other contact details SM16M1- / SM16ML1- SC16M1- / SC16ML1- 0.250" SM14M1- / SM14ML1- SC14M1- / SC14ML1- 0.250" Technical Information Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B Screw termination version Female Screw contact delivered with connector Stripping length L (inch) #16 (Ø 0.062") 0.228" L Section: 1.5²mm or AWG16 max, 0.5²mm or AWG20 min. - Insulate diameter: Ø 0.157" maxi. - Cable diameter : Ø 0.354" to Ø 0.669" maxi 49 UTL Series | Technical Information Tooling for crimp contacts Automatic crimping tools Mecal is a leader in manufacturing tooling for crimping terminals over a stripped wire. Established in 1976, Mecal has become one of the world's leading companies dedicated to the design and manufacture of semi automatic production tools for strip fed, open barrel crimp terminals, serving the Automotive, Telecom and Datacom industries. SOURIAU designs, manufactures and markets high performance - high reliability interconnect solutions for severe environments dedicated to the Aerospace, Defense/Space, Heavy Industry (Railway & Mass Transit, Nuclear, Oil & Gas) and Industrial Equipment markets. SOURIAU has a worldwide presence with R & D centers and production sites in Europe, USA, Japan and India. The Company is deeply involved in the environmental protection with industrial sites following ISO 14001 and RoHS products. SOURIAU has been working in partnership with Mecal for many years. With sales offices located in all major industrial regions of the world, the combined strengths of both organizations has resulted in a truly global solution to all your production tooling needs. If you need automatic crimping tool, don't hesitate to contact Mecal. Mini Applicator Stripper Presses Mecal sales network: http://www.mecal.net SOURIAU doesn't propose automatic crimp tooling. For tooling development, please contact directly Mecal or your tooling supplier. 50 UTL Series | Technical Information Tooling for crimp contacts Crimp tool table Standard contacts Contact size #20 Ø 0.039" #16 Ø 0.062" (1) loose contact Part number RM/RC 24W3K RM/RC 20W3K RM/RC 18W3K SM 24WL3S*(1) SC 24WL3S*(1) SM/SC 20WL3S*(1) RM/RC 28M1* RM/RC 24M9* RM/RC 20M13* RM/RC 20M12* RM/RC 16M23* RM/RC 14M30* SM/SC 24ML1* SM/SC 20ML1* SM/SC 16ML1* SM/SC 14ML1* SM/SC 16ML11* Head* Handles* Insertion tool Extraction tools - RX20D44 RTM205 RX2025GE1 S20RCM S20SCM20 S16RCM20 SHANDLES S16RCM16 S16RCM14 S16SCM20 S16SCML1 S16SCML11 * endurance of SHANDLES & Head tools = 50,000 cycles Contact size #16 Ø 0.062" Sealed contact #16 Ø 0.062" Longer RM contact Tool with separate locator Part number (1) Hand tools* (SHANDLES) head Hand tool RM/RC 24M25K S16RCM1625 - - - RM/RC 16M25K S16RCM1625 - - - RM/RC 14M25K S16RCM1425 - - - S16RCM20 - - - RM16M23GE1K S16RCM16 MH860 MH86186 6/8 RM14M30GE1K S16RCM14 RM28M1GE1K RM24M9GE1K Positioner + locator setting RC28M1GE7K #16 Ø 0.062" Shorter RC contact RC24M9GE7K RC20M13GE7K RC20M12GE7K RC16M23GE7K RC14M30GE7K (1) see page 38 for plating options and other contact details Insertion tool Extraction tool RTM205 RX2025GE1 Technical Information Specific contacts 4/6 S16RCM20 5/6 MH860 MH86164G S16RCM16 S16RCM14 5/7 6/8 M317 UH25 3 * endurance of SHANDLES & Head tools = 50,000 cycles 51 UTL Series | Technical Information Handle & interchangeable heads for crimp contacts Crimping with SOURIAU tooling 1) Fully close then release the tool, keep it open. Open the 2 pins. 2) Choose the adapter head (sold separately), keep vertical and slide it into the handle until the mechanical stop. 3) Close the two pins simultaneously to maintain the head. 4) Strip the cable properly by checking the recommended size in the catalog on pages 46 to 48. GOOD WRONG 5) Place conductors, with no deterioration, in the contact bucket. All strands to be located in the crimp bucket. 6) Position the contact in the bottom of the tool by checking its orientation. Maintain the wire in position. 7) Tighten sharply the handles to the end of the mechanism (max 175 N). After handles are opened, extract the contact. 8) Control the quality of crimping (see page 53). Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 52 WRONG UTL Series | Technical Information Crimping control for crimp contacts Crimping - No health risk from heavy metal and flux steam - Preservation of conductor flexibility behind the crimped connection - No burned, discolored and overheated wire insulation - Good connections with reproducible electrical and mechanical performances - Easy production control. To ensure that the crimp tooling is performing according to original specifications, it is important to carry out regular checks. A common way to check the performance of tooling is with a simple pull test, ideally using a dedicated electric pull tester. Minimum recommended pull forces are indicated in the tables below: W Active contact part Machined contacts size #20 Ø0.039" S&F contacts size #20 Ø0.039" Machined contacts size #16 Ø0.062" S&F contacts size #16 Ø0.062" Contact type RM24W3K RC24W3K RM20W3K RC20W3K RM18W3K RC18W3K SM24WL3TK6* SC24WL3TK6* SM20WL3TK6* SC20WL3TK6* RM28M1K* RC28M1K* RM24M9K* RC24M9K* RM20M13K* RC20M13K* RM20M12K* RC20M12K* Die location on heads RM16M23K* RC16M23K* RM24M25K RC24M25K RM16M25K RC16M25K RM14M25K RC14M25K RM14M30K* RC14M30K* SM24ML1TK6* SC24ML1TK6* SM20ML1TK6* SC20ML1TK6* SM16ML11TK6* SC16ML11TK6* SM16ML1TK6* SC16ML1TK6* SM14ML1TK6* SC14ML1TK6* * example of plating, for other plating see page 38 Stamped & Formed contact W 20 18 16 Wire section range 26 AWG 24 AWG 22 AWG 20 AWG 20 AWG 18 AWG 26 AWG 24 AWG 22 AWG 20 AWG 30 AWG 28 AWG 26 AWG 24 AWG 22 AWG 20 AWG 22 AWG 20 AWG 20 AWG 18 AWG 16 AWG Section (mm²) 0.12 min 0.25 max 0.32 min 0.50 max 0.50 max 0.82 max 0.12 min 0.25 max 0.32 min 0.50 max 0.05 min 0.08 max 0.12 min 0.25 max 0.32 min 0.50 max 0.32 min 0.50 max 0.50 max 0.82 max 1.50 max 20 24 AWG 0.25max 32 N 0.065" 0.085" 118 16 16 14 16 14 0.82 max 1.50 max 1.50 min 2.50 min 1.50 min 2.50 min 0.12 min 0.25 max 0.32 min 0.50 max 0.82 min 1.50 max 0.82 min 1.50 max 90 N 150 N 150 N 230 N 150 N 230 N 15 N 32 N 40 N 60 N 90 N 150 N 90 N 150 N 0.070" 0.077" 0.082" 0.090" 0.082" 0.090" 0.089" 0.095" 0.105" 0.109" 0.105" 0.109" 0.033" 0.059" 0.040" 0.060" 18 16 18 16 18 AWG 16 AWG 16 AWG 14 AWG 16 AWG 14 AWG 26 AWG 24 AWG 22 AWG 20 AWG 18 AWG 16 AWG 18 AWG 16 AWG 0.051" 0.053" 0.058" 0.066" 0.082" 0.082" 0.079" 0.080" 14 14 AWG 2.50 max 230 N 0.070" 0.101" 26/24 22/20 20/18 26/24 22/20 30/28 26/24 22/20 26/24 22/20 Tensile straight Height (inch) Width (inch) test (mini) H (±0.002") W (±0.002") 15 N 0.037" 0.050" 32 N 40 N 0.049" 0.070" 60 N 60 N 0.053" 0.073" 90 N 15 N 0.031" 0.058" 32 N 40 N 0.039" 0.060" 60 N 11 N 0.044" 0.055" 11 N 15 N 0.045" 0.055" 32 N 40 N 60 N 0.049" 0.069" 40 N 60 N 60 N 0.065" 0.085" 90 N 0.070" 0.089" 150 N 0.077" 0.095" Tooling head part number S20RCM S20SCM20 S16RCM20 Technical Information Machined contact H H One of the key factors which affects the performance of a connector is the way contacts are terminated. Crimped connections are today seen as the best solution to ensure quality throughout the lifetime of the product. Here are some reasons why we recommend this method of termination for UTL connectors: Advantages (Extract from the IEC 60352-2): - Efficient processing of connections at each production level - Processing by fully-automatic or semi- automatic crimping machines, or with hand operated tools - No cold-soldered joints - No degradation of the spring characteristic of female contacts by the soldering temperature S16RCM16 16RCM1625 S16RCM1625 S16RCM1425 S16RCM14 S16SCM20 S16SCML11 S16SCML1 Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 53 UTL Series | Technical Information Insertion tool for crimp contacts Contact size #16 Part number RTM205  RTM205 Extraction tool for crimp contacts Contact size Part number #20 RX20D44 #16 RX2025GE1 RX20D44 RX2025GE1 Contact extraction instructions Place the tool into the cavity from front face of the connector, push on the handle, then remove the contact. #20 female contact are not removable. 54 UTL Series | Technical Information #16 coaxial contacts Twisted pair cable monocrimp contact cabling Ø over jacket (inch) Cable type AWG26 (7x0.16) Ø over jacket G Outer maxi ØD Inner conductor ØG 0.041" 0.018" Part number Male RMDX6031D28 Female RCDX6031D28 Inner + outer tool Crimp tool S-80J + SL-105J M20S-1J Cable strip length (inch) A B C 0.185" 0.236" 0.157" Cable strip length See cable strip lengths D C B A 0.629" mini Male coax contact Female coax contact G Braid crimp (G) to be measured with die set fully closed Technical Information G Inner conductor crimp (G) to be measured with die set fully closed Tooling for coaxial contacts M20S-1J Die and Stop Bushing 55 UTL Series | Technical Information #16 coaxial contacts Coax cable with monocrimp contact cabling Cable type Impedance Ohm Ø over jacket (inch) Outer Outer Dielectric maxi braid ØF ØD ØE Inner conductor ØD RG174/U 1.968" 0.114" 0.088" 0.059" 0.018" RG188A/U 1.968" 0.109" 0.077" 0.059" 0.020" RG316/U 1.968" 0.098" 0.080" 0.059" 0.020" Part number Male RMDX6032D28 Female RCDX6032D28 Male RMDX6036D28 Female RCDX6036D28 Male RMDX6036D28 Female RCDX6036D28 Inner + outer tool M20S-1J S-80J + SL-105J 0.200" 0.236" 0.459" M20S-1J S-80J + SL-105J 0.200" 0.236" 0.459" M20S-1J S-80J + SL-105J 0.200" 0.236" 0.459" Ø over jacket G F E Cable strip length (inch) Crimp tool A Cable strip length D See cable strip lengths A B C Male coax contact Female coax contact Tooling for coaxial contacts M20S-1J Die and Stop Bushing 56 B C UTL Series | Technical Information #16 coaxial contacts Twisted pair cable multipiece contact cabling Cable type Ø over jacket (inch) Inner Outer maxi conductor ØD ØG AWG26 (7x0.16) 0.041" 0.018" Crimp tool Part number Male RMDXK10D28 + YORX090 Female RCDXK10D28 + YORX090 M20S-1J Inner tool Outer tool Cable strip length (inch) A B C S26D2J S22-1J 0.312" 0.312" 0.312" + + SL46D2K SL47-1J 0.250" 0.250" 0.312" Multipiece kit details Outer contact RMDXK10D28 or RCDXK1D28 Inner contact Outer hyring includes Inner supporting sleeve Male cable strip length Ø over jacket G D Female cable strip length B C B C A A 0.629" mini 0.629" mini Female contact YORX090 Inner supporting sleeve Inner pin Outer female contact Technical Information Outer hyring Male contact Outer male contact Inner socket Inner supporting sleeve YORX090 Outer hyring Tooling for coaxial contacts M20S-1J Die and Stop Bushing 57 UTL Series | Technical Information #16 coaxial contacts Twisted pair cable multipiece male contact cabling Cable type Impedance Ohm Ø over jacket (inch) Outer Outer Dielectric maxi braid ØF ØD ØE Inner conductor ØD RG174/U 50 0.114" 0.088" 0.059" 0.018" RG188/U 50 0.109" 0.077" 0.059" 0.020" RG161/U 70 0.082" - 0.057" 0.011" RG179A/U RG179B/U 75 0.105" 0.083" 0.062" 0.011" RG187/U 75 0.109" 0.077" 0.059" 0.011" RG178A/U 50 0.075" 0.053" 0.033" 0.011" RG196/U 50 0.079" - 0.033" 0.011" Crimp tool Part number Inner tool Cable strip length (inch) Outer tool A 0.296" 0.359" 0.690" Multipiece kit details Cable strip length Outer contact RMDXK10D28 includes Inner contact A Outer hyring Dielectric diameter Inner supporting sleeve B C Contact assembly with dielectric diameter over 0.055" - without inner supporting sleeve Outer male contact Inner socket Step 1: - Assemble outer hyring onto cable - Assemble inner socket to inner conductor and crimp Outer hyring Step 2: - Insert the assembly into the outer male contact until the inner socket snaps into place - The cable braid (shield) should now cover the barrel of the outer male contact as shown Step 3: - Slide outer hyring forward against spring and crimp in place as shown Locking louver typical Grounding louver typical Contact assembly with dielectric diameter under 0.055" - with inner supporting sleeve Outer male contact Inner socket Step 1: - Assemble outer hyring onto cable - Assemble supporting sleeve over dielectric and under braid - Assemble inner socket to inner conductor, push back against sleeve and crimp Supporting sleeve 58 Outer hyring C 0.172" 0.312" 0.625" M20S-1J S26D2J S22-1J see + + page 57 SL46D2K SL47-1J RMDXK10D28 B Inner supporting sleeve Step 2: - Insert the assembly into the outer male contact until the inner socket snaps into place - The cable braid (shield) should now cover the barrel of the outer male contact as shown Outer hyring Step 3: - Slide outer hyring forward against spring and crimp in place as shown Locking louver typical Grounding louver typical UTL Series | Technical Information #16 coaxial contacts Twisted pair cable multipiece female contact cabling Cable type Impedance Ohm Ø over jacket (inch) Outer Outer Dielectric maxi braid ØF ØD ØE Inner conductor ØD RG174/U 50 0.114" 0.088" 0.059" 0.018" RG188/U 50 0.109" 0.077" 0.059" 0.020" RG161/U 70 0.082" - 0.057" 0.011" RG179A/U RG179B/U 75 0.105" 0.083" 0.062" 0.011" RG187/U 75 0.109" 0.077" 0.059" 0.011" RG178A/U 50 0.075" 0.053" 0.033" 0.011" RG196/U 50 0.079" - 0.033" 0.011" Part number RCDXK1D28 Crimp tool Inner tool Outer tool M20S-1J see page 57 S26D2J + SL46D2K S22-1J + SL47-1J Cable strip length (inch) A C 0.172" 0.438" 0.250" 0.438" Multipiece kit details Cable strip length Outer contact RCDXK1D28 includes Inner contact A Outer hyring Dielectric diameter Inner supporting sleeve C Contact assembly with dielectric diameter over 0.055" - without inner supporting sleeve Step 1: - Assemble outer hyring onto cable - Assemble inner pin to inner conductor and crimp Outer female contact Inner pin Step 2: - Insert the assembly into the outer female contact until the inner pin snaps into place - The cable braid (shield) should now cover the barrel of the outer female contact as shown Technical Information Outer hyring Step 3: - Slide outer hyring forward against spring and crimp in place as shown Contact assembly with dielectric diameter under 0.055" - with inner supporting sleeve Outer hyring Step 1: - Assemble outer hyring onto cable - Assemble supporting sleeve over dielectric and under braid - Assemble inner pin to inner conductor, push back against sleeve and crimp Outer hyring Supporting sleeve Inner pin Step 2: - Insert the assembly into the outer female contact until the inner pin snaps into place - The cable braid (shield) should now cover the barrel of the outer female contact as shown Outer female contact Step 3: - Slide outer hyring forward against spring and crimp in place as shown Supporting sleeve 59 UTL Series | Technical Information Assembly instructions UTL0 assembly (Mounting suggestion) • Strip wires • Crimp contacts • Place all the contacts inside the corresponding cavities • Manually push each contact, or use our tool (RTM205 for #16 contacts), until audible click. Check each contact retention, with two finger retraction • Place receptacle in the panel cut-out (see dimension page 19 for UTL103G1) • Secure receptacle with M3 screws (not supplied), torque 0.7 Nm maxi Receptacle flange O-ring Panel Panel UTL6 or UTL1 assembly • Strip wires • Crimp contacts • Place all the contacts inside the corresponding cavities • Manually push each contact, or use our tool (RTM205 for #16 contacts), until audible click. Check each contact retention, with two finger retraction • Do an overmolding on the wired set or use heat shrink boot UTL6 UTL1 Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 60 UTL6 UTL1 UTL Series | Technical Information Assembly instructions UTL7 assembly (Mounting suggestion) • Slide nut over the wires • Strip wires • Crimp contacts • Place all the contacts inside the corresponding cavities • Manually push each contact, or use our tool (RTM205 for #16 contacts), until audible click. Check each contact retention, with two finger retraction • Seat o-ring, place receptacle in the panel cut-out (see dimension page 19 for UTL103G1, page 23 for UTL145, page 27 for UTL102G1W3 or page 31 for UTL122G1W5) • Tighten jam nut torque: 2.5 Nm maxi, tightening tool: 7/8" Jam nut O-ring Panel thickness: 0.236" maxi Final view O-ring UTL6145 with backshell assembly Screw version Wires Backshell Plug Nut Screwcontacts Technical Information • Slide backshell on the cable • Strip wires • For screw termination version: place each stripped wire in the contact and tighten the screw, advised torque 20 Ncm • For crimp termination version: crimp contacts on wires and insert contacts in the cavities • Check wire retention by a slight two finger retraction • Then click the backshell on the plug rear side • Tighten the cable gland on the backshell, indicative torque: 3 Nm • Finally tighten the nut on the cable gland, wrench size 30, indicative torque: 8 Nm maxi (coupling torque will depend of the cable type) Torque: 20 Ncm Screwdriver: 0,4x2 mm Audible "Click" Backshell wrench Nut wrench Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 61 UTL Series | Technical Information Assembly instructions Protective shroud assembly UTL6JC & UTL6TH (Mounting suggestion) • No tool is required to assemble the Protective Shroud UTL10PS on the plug. • Take care about the orientation of the protective shroud • Put the protective shroud on the appropriate area until a click is heard • By a visual control, make sure that the Protective Shroud is well oriented and inserted • Please note that we don't recommend to dismantling the protective shroud after assembly Protective shroud Audible "Click" • The aim of the Protective Shroud is to not be able to disconnect the plug without a tool • To disconnect the plug, when Protective Shroud is used, please use a screw driver and put the screw driver into the hole of the protective shroud Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 62 • Then push on the screwdriver and pull slightly on the plug do disconnect it Assembly instructions UTL1JC103G1 & UTL6JC103G1 assembly (Mounting suggestion) UTL6TH Backshell housing Cable gland housing O-ring Nut UTL1 • Screw the nut of the cable gland by using a wrench (size 25). Recommended coupling torque 5 Nm ➎ • Please note that the coupling torque of the nut is for information only and may need to be adjusted according to your cable specification (diameter, flexibility, outer jacket material for example). SOURIAU cannot be responsible in case the coupling torque is not adapted to the cable specification ➌ ➊ ➍ ➋ ➎ Technical Information • Slide nut over the wires ➊ • Strip wires • Crimp contacts • Place all the contacts inside the corresponding cavities • Manually push each contact, or use our tool (RTM205 for #16 contacts), until audible click. Check each contact retention, with two finger retraction ➋ • Check the presence and the appropriate positioning of the connector O-ring • Screw backshell housing at the rear of the connector until the mechanical stop (recommended coupling torque 2.5 Nm). You can use a dummy receptacle in order to facilitate this assembly operation ➌ • Then check the presence and the appropriate positioning of the cable gland gasket • Screw the cable gland housing at the rear of the backshell housing by using a wrench (size 25) with the recommended coupling torque 3 Nm ➍ Note: Assembly operations mentioned above shall not interfere or to be in contradiction with the IPC-WHMA-A-620B 63 UTL Series | Technical Information Assembly instructions SWSFILLERPLUG mounting for 3 + ground Push the sealing plug into each connector cavity to seal until a mechanical stop. UTL0 0.275" mini 0.622" mini 0.346" mini Male Female 0.472" mini UTL7 & UTL1 0.354" mini 0.700" mini 0.421" mini Male Female 0.551" mini UTL6 0.629" mini 0.354" mini Male Note: all dimensions are in inch 64 0.291" mini 0.488" mini Female UTL Series | Technical Information 3.425" Mated connector length 103G1 (shell size 10, 3 + ground, 4x#16) & 102G1W3 (shell size 10, 3x#16 + 3x#20) UTL0 + UTL6 overmolded UTL7 + UTL6 overmolded 3.110" maxi 3.070" maxi UTL1 + UTL6 overmolded 4.881" maxi UTL5 + UTL1JC UTL7 + UTL6JC Right angle overmolded plug Technical Information 4.015" maxi 4.015" maxi Right angle overmolded receptacle 2.874" maxi 2.913" maxi 2.204" maxi 2.125" maxi Note: all dimensions are in inch 65 UTL Series | Technical Information Mated connector length 122G1W5 (shell size 12, 3x#16 + 5x#20) UTL7 + UTL6 overmolded UTL1 overmolded + UTL6 overmolded 5.314" maxi 3.582" maxi 145 (shell size 14, 5x#16) UTL1 or UTL7 + UTL6 2.047" UTL1 or UTL7 + UTL6JC 4.133" Note: all dimensions are in inch 66 UTL Series | Technical Information Evaluation kit 3 contacts + ground part number (103G1) Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. mm² UTL6103G1W3S UTL1103G1W3P UTL1103G1W3S UTL7103G1W3P UTL7103G1W3S UTL0103G1W3P UTL0103G1W3S SM20ML1S31 SC20ML1S31 SM16ML1S31 SC16ML1S31 SM14ML1S31 SC14ML1S31 Male power 20 0.5 1 - - - - - - - 4 2 - - - - Plug Male power 16 1.5 1 - - - - - - - - - 4 2 - - UTL6103G1P14AWG Plug Male power 14 2.5 1 - - - - - - - - - - - 4 2 UTL6103G1S20AWG Plug Female power 20 0.5 - 1 - - - - - - 2 4 - - - - UTL6103G1S16AWG Plug Female power 16 1.5 - 1 - - - - - - - - 2 4 - - UTL6103G1S14AWG Plug Female power 14 2.5 - 1 - - - - - - - - - - 2 4 UTL1103G1P20AWG Inline receptacle Male power 20 0.5 - - 1 - - - - - 4 2 - - - - UTL1103G1P16AWG Inline receptacle Male power 16 1.5 - - 1 - - - - - - - 4 2 - - UTL1103G1P14AWG Inline receptacle Male power 14 2.5 - - 1 - - - - - - - - - 4 2 UTL1103G1S20AWG Inline receptacle Female power 20 0.5 - - - 1 - - - - 2 4 - - - - UTL1103G1S16AWG Inline receptacle Female power 16 1.5 - - - 1 - - - - - - 2 4 - - UTL1103G1S14AWG Inline receptacle Female power 14 2.5 - - - 1 - - - - - - - - 2 4 UTL7103G1P20AWG Jam nut receptacle Male power 20 0.5 - - - - 1 - - - 4 2 - - - - UTL7103G1P16AWG Jam nut receptacle Male power 16 1.5 - - - - 1 - - - - - 4 2 - - UTL7103G1P14AWG Jam nut receptacle Male power 14 2.5 - - - - 1 - - - - - - - 4 2 UTL7103G1S20AWG Jam nut receptacle Female power 20 0.5 - - - - - 1 - - 2 4 - - - - UTL7103G1S16AWG Jam nut receptacle Female power 16 1.5 - - - - - 1 - - - - 2 4 - - UTL7103G1S14AWG Jam nut receptacle Female power 14 2.5 - - - - - 1 - - - - - - 2 4 UTL0103G1P20AWG Square flange receptacle Male power 20 0.5 - - - - - - 1 - 4 2 - - - - UTL0103G1P16AWG Square flange receptacle Male power 16 1.5 - - - - - - 1 - - - 4 2 - - UTL0103G1P14AWG Square flange receptacle Male power 14 2.5 - - - - - - 1 - - - - - 4 2 UTL0103G1S20AWG Square flange receptacle Female power 20 0.5 - - - - - - - 1 2 4 - - - - UTL0103G1S16AWG Square flange receptacle Female power 16 1.5 - - - - - - - 1 - - 2 4 - - UTL0103G1S14AWG Square flange receptacle Female power 14 2.5 - - - - - - - 1 - - - - 2 4 Evaluation kit is the solution for a quick prototyping, please note that the IP level of the evaluation kit is IP67. Part number Connector type Gender UTL6103G1P20AWG Plug UTL6103G1P16AWG Wire section 67 Technical Information AWG UTL6103G1W3P Kit contains UTL Series | Technical Information Evaluation kit 6 contacts part number (102G1W3) Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. AWG mm² UTL6102G1W3P UTL6102G1W3S UTL1102G1W3P UTL1102G1W3S UTL7102G1W3P UTL7102G1W3S Heat shrink boot SM20WL3S26 SC20WL3S25 SM24WL3S26 SC24WL3S25 SM16ML1S31 SC16ML1S31 SM14ML1S31 SC14ML1S31 Kit contains Male power 16 1.5 1 - - - - - 1 1 - 3 - 3 2 - - Plug Male power 14 2.5 1 - - - - - 1 1 - 3 - - - 3 2 UTL6102G1W3S16AWG Plug Female power 16 1.5 - 1 - - - - 1 - 1 - 3 2 3 - - UTL6102G1W3S14AWG Plug Female power 14 2.5 - 1 - - - - 1 - 1 - 3 - - 2 3 UTL1102G1W3P16AWG Inline receptacle Male power 16 1.5 - - 1 - - - 1 1 - 3 - 3 2 - - UTL1102G1W3P14AWG Inline receptacle Male power 14 2.5 - - 1 - - - 1 1 - 3 - - - 3 2 UTL1102G1W3S16AWG Inline receptacle Female power 16 1.5 - - - 1 - - 1 - 1 - 3 2 3 - - UTL1102G1W3S14AWG Inline receptacle Female power 14 2.5 - - - 1 - - 1 - 1 - 3 - - 2 3 UTL7102G1W3P16AWG Jam nut receptacle Male power 16 1.5 - - - - 1 - - 1 - 3 - 3 2 - - UTL7102G1W3P14AWG Jam nut receptacle Male power 14 2.5 - - - - 1 - - 1 - 3 - - - 3 2 UTL7102G1W3S16AWG Jam nut receptacle Female power 16 1.5 - - - - - 1 - - 1 - 3 2 3 - - UTL7102G1W3S14AWG Jam nut receptacle Female power 14 2.5 - - - - - 1 - - 1 - 3 - - 2 3 Evaluation kit is the solution for a quick prototyping, please note that the IP level of the evaluation kit is IP67. Part number Connector type Gender UTL6102G1W3P16AWG Plug UTL6102G1W3P14AWG 68 Wire section UTL Series | Technical Information Evaluation kit 8 contacts part number (122G1W5) Evaluation kit is composed of 1 connector, contacts and 1 heat shrink boot for a quick and easy assembly production. mm² UTL6122G1W5S UTL1122G1W5P UTL1122G1W5S UTL7122G1W5P UTL7122G1W5S Heat shrink boot SM20WL3S26 SC20WL3S25 SM24WL3S26 SC24WL3S25 SM16ML1S31 SC16ML1S31 SM14ML1S31 SC14ML1S31 Male power 16 1.5 1 - - - - - 1 2 - 5 - 3 2 - - Plug Male power 14 2.5 1 - - - - - 1 2 - 5 - - - 3 2 UTL6122G1W5S16AWG Plug Female power 16 1.5 - 1 - - - - 1 - 2 - 5 2 3 - - UTL6122G1W5S14AWG Plug Female power 14 2.5 - 1 - - - - 1 - 2 - 5 - - 2 3 UTL1122G1W5P16AWG Inline receptacle Male power 16 1.5 - - 1 - - - 1 2 - 5 - 3 2 - - UTL1122G1W5P14AWG Inline receptacle Male power 14 2.5 - - 1 - - - 1 2 - 5 - - - 3 2 UTL1122G1W5S16AWG Inline receptacle Female power 16 1.5 - - - 1 - - 1 - 2 - 5 2 3 - - UTL1122G1W5S14AWG Inline receptacle Female power 14 2.5 - - - 1 - - 1 - 2 - 5 - - 2 3 UTL7122G1W5P16AWG Jam nut receptacle Male power 16 1.5 - - - - 1 - - 2 - 5 - 3 2 - - UTL7122G1W5P14AWG Jam nut receptacle Male power 14 2.5 - - - - 1 - - 2 - 5 - - - 3 2 UTL7122G1W5S16AWG Jam nut receptacle Female power 16 1.5 - - - - - 1 - - 2 - 5 2 3 - - UTL7122G1W5S14AWG Jam nut receptacle Female power 14 2.5 - - - - - 1 - - 2 - 5 - - 2 3 Evaluation kit is the solution for a quick prototyping, please note that the IP level of the evaluation kit is IP67. Part number Connector type Gender UTL6122G1W5P16AWG Plug UTL6122G1W5P14AWG Wire section 69 Technical Information AWG UTL6122G1W5P Kit contains UTL Series | Technical Information Evaluation kit • Assembly instructions The boot is semi-flexible and heat-shrinkable with a moldable adhesive inner lining. • Place the heat shrink boot over the cable • Strip the cable jacket (see pages 46 to 48) • Strip the individual wires (see page 49) • Crimp the contacts (see pages 52 & 53) ➊ • Place the contacts in their cavities, checking the retention by slightly pulling the cable ➋ • Clean the connector surface and the cable jacket with isopropyl alcohol (Note: It is advised to rub the jacket with sand paper and clean the jacket before shrinking the boot) • Position the boot over the rear threads ➌ • Heat the boot with a heat gun: minimum shrink temp: 80°C - minimum full recovery temp: 110°C make sure to apply the heat evenly around the boot. Starting by applying the heat from the rear of the connector. ë Do not apply excessive heat, as it will damage the connector and/or boot. • Let the boot cool down ➎ • Check for good retention and the boot glue grip ➏. 70 ➊ ➋ ➌ ➍ ➎ ➏ UTL Series | Technical Information Rated current & working voltage Current carrying capacity The current carrying capacity of a connector is limited by the thermal properties of materials used in its construction. The amount of current that can be handled depends on the size of cable used, the ambient temperature and the heat that is generated inside the connector. Part 3 of the IEC 60512 standard determines through a derating curve, the maximum current permissible, which varies from one layout to another (Fig.1 & Fig.2). Wire size plays an important role as well, since they help to dissipate heat and avoid overheating (Fig.1 & Fig.2). Please note that the curve should be adjusted when dealing with potential hot spots, which can occur as a result of unequal loading of current across a number of contacts. As a general rule, it is best to avoid locating power handling contacts in the middle of the connector; try to locate them towards the edge where heat can be dissipated more effectively. Eventually you should find a level which represents the permissible operating range: Fig.1: UTL103G1 – 1.5 mm² wires 30 28 25 25 23 23 20 20 Current (A) Current (A) 28 18 15 13 10 18 15 13 10 8 8 5 5 3 3 0 Fig.2: UTL103G1 – 2.5 mm² wires 30 0 20 40 60 80 Ambient operating temperature (°C) Theoretic current use 100 Limited use 120 0 0 20 40 60 80 100 Ambient operating temperature (°C) 120 Not recommended use Technical Information The rated current is defined as uninterrupted continuous current that a connector can take when all contacts are energized simultaneously without exceeding the maximum limit of temperature. The ground contact is never loaded. 71 UTL Series | Technical Information UV resistance UV resistance Solar radiation affects all materials, but plastics can be susceptible to extreme degradation over time. The choice of materials for the UTL series was therefore a critical consideration. All over the world we are not exposed to the same amount of energy given by the sun. The chart shown here clearly illustrates this. So we performed test according to the ISO 4892-2 and simulated 5 years exposure to outdoor environments (temperature, humidity, etc...). Yearly mean of daily irradiation in UV (280-400 nm) on horizontal plane (J/cm²) (1990-2004) 90° 60° 30° 0° - 30° - 60° - 90° - 180° 72 - 120° - 90° - 60° - 30° 0° 30° 60° 90° 120° 150° 180° 190 170 180 150 160 140 130 120 110 100 90 80 70 60 50 40 30 20 J/cm² 0 In addition, to that we asked UL to perform UV test per the UL746C. Our material has been rated F1 which is the highest level in this standard. - 150° 10 After this period there was no significant colour variation, no crazing, no cracking and no major variation of mechanical properties. UTL Series | Technical Information UL94 + UL1977 Underwriter laboratories There are two main standards for industrial connectors: UL94 & UL1977 UL 94: Tests for Flammability of Plastic Materials for Parts in Devices and Appliances This standard is dedicated to plastics flammability. It characterizes how the material burns in various orientation and thicknesses. Whereas most of our competitors are using a 50W test to classify the ability of their solution to withstand fire, SOURIAU decided to increase this to a 500W test. New regulations tend to emphasize the importance of burning behavior making the 50W test less and less relevant. The UTL series has been rated at 5VA. Procedure: Bar specimens are to be 4.921" long by 0.511" wide, and provided in the minimum thickness. Plaque specimens are to be 5.905" by 5.905" and provided in the minimum thickness. Thicker specimens may also be provided and shall be tested if the results obtained on the minimum thickness indicate inconsistent test results. The maximum thickness is not to exceed 0.511". 5VA Afterflame time plus afterglow time after fifth flame application for each individual bar specimen ≤60s Cotton indicator ignited by flaming particles or drops from any bar specimen No Burn-through (hole) of any plaque specimen No 0.511" Material O ve ra 5VA Vertical burning: • The specimen is clamped from the upper 0.236" of the specimen, with the longitudinal axis vertical, so that the lower end of the specimen is 11.810" above a horizontal layer of not more than 0.08 g of absorbent cotton thinned to approximately 1.968" x 1.968" and a maximum thickness of 0.236". • The 500W flame is then to be applied to one of the lower corners of the specimen so that the tip of the blue cone is within 0 to 0.118" of the specimen edge. • Apply the flame for 5±0.5 seconds and then remove for 5±0.5 seconds. Repeat the operation until the specimen has been subjected to five applications of the test flame. he ig ht of fla m e In ne co r b ne lue 45° 11.810" Cotton 5.905" Material Center 0.511" 5VA Horizontal burning: • Support the plaque specimen by a clamp in the horizontal plane. • The flame is then to be applied to the centre of the bottom surface of the plaque so that the tip of the blue cone is within 0 to 0.118" of the plaque surface. • Apply the flame for 5±0.5 seconds and then remove for 5±0.5 seconds. Repeat the operation until the plaque specimen has been subjected to five applications of the test flame. • After the fifth application of the test flame, and after all flaming or glowing combustion has ceased, it is to be observed whether or not the flame penetrated (burned through) the plaque material. In addition, no opening greater than 0.118" shall appear after the test. ll 4.921" Technical Information Conditions 45° 73 UTL Series | Technical Information UL94 + UL1977 Underwriter laboratories UL1977 There are several standards which deal with plug and receptacle. Each of them is only for a small area of applications. It could be telecommunication, etc. The UL 1977 covers single and multipole connectors intended for factory assembly. Requirements apply to devices taking into account intensity and voltage. The categories are as follows: 30 V (42 V peak) 0 600 V 0 Type 0 Type 1A 8.3 A Type 2 31 A Tybe 1B Type 3 200 A Type 4 1000 A According to above table, the level of performance that has to be reached could be different. Most of them are explained in the following page. Insulating materials: Material uses for electrical insulation, as a minimum, have to comply with the characteristics shown below: • Minimum ratings for polymeric materials Type Flame rating Relative thermal index (RTI) Electrical/mechanical w/o impact */** 0 - 50/50 1A HB 50/50 1B HB 50/50 2 HB 50/50 3 HB 50/50 4 HB 50/50 * The RTI of the material shall not be lower than the temperature measured during the Temperature Test. ** For a thickness less than that for which a value has been established, the RTI of the minimum thickness with an established value shall be used. Assembly: Connector has to be keyed to prevent any mismating that can damage the machine or hurt the user. In the same way, plugs and sockets have to be equipped to protect persons against contact with live parts. Finally the identified grounding contact shall be located so that the corresponding electrical continuity has to be completed before any other contact. 74 UTL Series | Technical Information UL94 + UL1977 Underwriter laboratories UL1977 Spacing: For a 250V max connector, distance through air or over material shall be 1.2mm whereas from 250V to 600V connector the spacing is 0.125" minimum. These distances have to be taken between uninsulated live parts as shown in the matrix below: • Applicability of spacing requirements Type Uninsulated live part - uninsulated live part of opposite polarity Uninsulated live part - uninsulated grounded metal part Uninsulated live part - exposed dead metal part 0 No No No 1A Yes Yes Yes 1B Yes Yes No 2 Yes Yes Yes 3 Yes Yes Yes 4 Yes Yes Yes An alternative way to determine voltage rating is with the Dielectric-Withstand test. If during one minute there is no arc-over or breakdown the rated voltage is given as shown below: a) 500 volts for a type 1B device b) 1000 volts plus twice rated voltage for types 1A, 2, 3 and 4 devices. Marking: A device shall be legibly marked with the manufacturer's trade name, trade mark, or other descriptive marking by which the organization responsible for the product may be identified. (Exception: If the device is too small, or where the legibility would be difficult to attain, the manufacturer’s name, trademark, or other descriptive marking may appear on the smallest unit container or carton) Technical Information The following shall be marked on the device or on the smallest unit container or carton or on a stuffer sheet in the smallest unit container or carton: a) The catalog number or an equivalent designation b) The electrical rating in both volts and amperes, if assigned c) Whether ac or dc, if restricted d) Flammability class, if identified Example : 10A 500V UL94 V-0 75 UTL Series | Technical Information IEC 61984 & IP codes explained IEC 61984 The norm is dedicated to connectors with rated voltage above 50V and up to 1000V and rated currents up to 125A per contact. Depending on your application connectors could be compliant with another standard. This has to be double checked with the customer. There are a lot of constructional requirements and performances specified in that standard. Most of them are illustrated in greater details hereafter. Provisions for grounding: The UTL connector is intended to be used on Class I,II and III systems (See IEC 61140) . Not like a typical connector, the UTL can be used to interrupt current. The “First mate Last break” contact feature is built in so any regular contact will ensure the functionality. Critically, among all of the normal assumptions we make in designing a connector, this contact has to be considered as a live part and must be protected against electric shock by double or reinforced insulation. First digit (foreign bodies protection) IP code: IP is a coding system defined by the IEC 60529 to indicate the degrees of protection provided by an enclosure. The aim of this is to give information regarding the accessibility of live parts against ingress of water and other foreign bodies. 1st digit 0 1 2 3 4 5 6 Degree of protection No protection against accidental contact. No protection against solid foreign bodies. Protection against contact with any large area by hand and against large solid foreign bodies with a diameter bigger than 50 mm. Protection against contact with the fingers. Protection against solid foreign bodies with a diameter bigger than 12 mm. Protection against tools, wires or similar objects with a diameter bigger than 2.5 mm. Protection against small solid bodies with a diameter bigger than 2.5 mm. Same as 3 however diameter is bigger than 1 mm. Full protection against contact. Protection against interior injurious dust deposits. Total protection against contact. Protection against penetration of dust. UTL offers high sealing performance IP68 / 69K… Even in dynamic situations. Code letters (international Protection) 76 Second digit (water protection) 2nd digit Degree of protection 0 No protection against water. 1 2 Drip-proof. Protection against vertical water drips. Drip-proof. Protection against water drips up to a 15° angle. 3 Spray-proof. Protection against diagonal water drips up to a 60° angle. 4 Splash-proof. Protection against splashed water from all directions. Hose-proof. Protection against water (out of a nozzle) from all directions. Protection against temporary flooding. 5 6 7 8 Protection against temporary immersions. Protection against water pressure. Pressure to be specified by supplier. In addition to the IEC 60529 we conjointly use the DIN 40050 part 9 which is dedicated to road vehicles. The main differences are: • First digit: 5 replaced by 5K, 6 by 6K. In the DIN the tested equipment is not depressurized as it is in the IEC. • Second digit: 5K and 6K has been added and are equivalent respectively to 5 and 6 but with higher pressure. 9K which represents the High pressure cleaning. 9K IEC 61984 ed.2.0 “Copyright © 2008 IEC Geneva, Switzerland.www.iec.ch" IEC 60664-1 ed.2.0 “Copyright © 2007 IEC Geneva, Switzerland.www.iec.ch” IP 6 8 High pressure hose-proof. Protection against high pressure water (out of a nozzle) from all directions. UTL Series | Technical Information IEC 61984 & IP codes explained IEC 61984 Overvoltage UTL connectors are qualified to be used on systems rated at Overvoltage category III Per the IEC 60664-1 (formely VDE 0110) each category is linked to the end application and where the device will be implemented: • Category IV (primary overcurrent protection equipment): Origin of the installation • Category III (Any fixed installation with a permanent connection) Fixed installation and equipment and for cases where the reliability and the availability is subject to special requirements • Category II (Domestic applicances): Energy consuming equipment to be supplied from the fixed installation • Category I (Protected electronic circuit): For connection to circuit in which measurements are taken to limit transient overvoltage. Pollution degree • Degree 1 (Air conditioned dry room): No pollution or only dry, non conductive pollution occurs. The pollution has no influence. • Degree 2 (Personal computer in a residential area): Only non conductive pollution occurs except that occasionally a temporary conductivity caused by condensation is to be expected. • Degree 3 (Machine tools): Conductive pollution occurs or dry non-conductive pollution occurs which becomes conductive due to condensation which is to be expected. • Degree 4 (Equipment on roofs, locomotives): Continuous conductivity occurs due to conductive dust, rain or other wet conditions. Technical Information Per the IEC 60664-1 (formerly VDE 0110) the environment affects the performance of the insulation. Particles can build a bridge between two metal parts. As a rule dust mixed with water can be conductive and more generally speaking metal dust is conductive. Finally, the standard defines 4 levels of pollution: Finally, the harsher the environment is, the longer clearance and creepage distances should be. Nonetheless, according the IEC 61984, enclosure rated at IP54 or higher can be dimensioned for a lower pollution degree. This applies to mated connectors disengaged for test and maintenance. Marking The marking should give enough details to the user to know what the main characteristics are and without going deep in technical documentation. Below examples identify the suitability of the connector: • Example 1: Marking of a connector with rated current 16A, rated voltage 400V, rated impulse voltage 6kV and pollution degree 3, 2 and 1 for use in any system, preferably unearthed or delta-earthed systems: 16A 400V 6kV 16A 400V 6kV 33 • Example 2: Marking of a connector with rated current 16A, rated insulation voltages line-to-earth 250V, line-to-line 400V, rated impulse voltage 4kV and pollution degree 3, 2 and 1 for use in earthed systems: 16A250V 250V400V 400V4kV 4kV3 3 16A 77 UTL Series | Technical Information IEC 61140 explained IEC 61140 On a daily basis, we are using many electrical appliances, some are grounded, and some are not. The levels of grounding protection are clearly defined by the International Electrotechnical Commission standard IEC 61140, a standard that has an influence on our connectors and how they should be used; our customers therefore need to pay particular attention to the three categories defined within this standard to ensure compatibility with their system. Everything explained hereafter is valid for connectors not intended to interrupt current. Class I: Devices which belong to this category have their chassis grounded via the ground wire (green/yellow in Europe, green in the US, Canada and Japan). A fault in the appliance might cause a live conductor to energize the casing. In this case, the current flows to the ground conductor and the circuit interrupter will cut off the power supply. In case of the UTL series, the envelope cannot become live since it is made in plastic. There is no special care to be taken to attach the connector shell to the ground. Class II: Products in this category have reinforced insulation, meaning that the casing does not need to be connected to ground. In this case, the possibility of electric shock has been removed. Most of the time, reinforced insulation means double insulation, i.e. the second layer will take over the first one in case the first one fails. The UTL series could be used in that condition. We recommend to contact SOURIAU for further explanation. Note: UL 1310 also defines a class II device, but in that case this is just to set the upper limit of use, like a wall charger for our cell phone. Class III: In this category, electrical appliances are fed by a low voltage source (
UTL6102G1W3S14AWG 价格&库存
很抱歉,暂时无法提供与“UTL6102G1W3S14AWG”相匹配的价格&库存,您可以联系我们找货
